Hello,
As said in the title my system seems completely broken.
I tried wayland a few days/weeks ago, not fully stable, At the same time i tried kwinft also but it completely broke the wayland session (login to black screen if i remember well) so i got back on X11 and reinstalled kwin ( all through the GUI tool)
X11 seemed to worked fine, wayland was still broken with a login loop though.
Along these few days i noticed a few times that the system doesn’t shutdown properly, just staying on with a black screen indefinitely. I had to shutdown with the reset button. Beside that it was fine.
Yesterday I executed these two commands :
cd $HOME ; wget https://raw.githubusercontent.com/gabomdq/SDL_GameControllerDB/master/gamecontrollerdb.txt ; grep Linux gamecontrollerdb.txt | grep -v '# Linux' > .controller_config ; sed -i '1s/^/export SDL_GAMECONTROLLERCONFIG="/' .controller_config ; sed -i '$s/$/&"/' .controller_config
grep -q controller_config .bashrc || echo '. "$HOME/.controller_config"' >> .bashrc ; grep -q controller_config .bash_profile || echo '. "$HOME/.controller_config"' >> .bash_profile ; grep -q controller_config .profile || echo '. "$HOME/.controller_config"' >> .profile
I closed up my session and rebooted and now i’m stuck in a login loop with both x11 and wayland, i tried to do something with the TTY but it seems broken also. I can login with it, but i can’t execute any command.
I always get “-bash: /usr/bin/ls: Liste d’arguments trop longue”, “Too many arguments” in English i guess.
It’s the same with other command: /usr/lib/pk-command not found, usr/bin/sudo, and so on. The only things that worked was “cd --help” printed the help, echo “something” printed something, but all the commands i tried were broken.
I don’t think it has anything to do with the controller variable, I don’t see how this could break my system.
Also i tried to boot with a timeshift, to get back 3days before but it didn’t change anything, i don’t know what files are changed, but apparently not the ones that causes my troubles.
I will probably reinstall anyway at this point, but i’m curious about what happened to break my system so deeply.
I searched on the web but I didn’t found anything similar. I don’t know where to start.
If someone has any leads about what i should look into, I’m not an advanced user, but I’d like to improve my knowledge
