Hi all, When i log in to my computer and try to access my browser a message appears saying i have to unlock my log in key ring as it didn’t when i logged into my computer.
I am using manjaro on a acer laptop
ian
ian
What is your desktop?
What is your web browser?
Sorry, it is linux manjaro on a acer aspire laptop. Using Chronium Browser
That’s the distribution, not the desktop.
Manjaro-kde-21.0.1-22041 0-linux 510.iso.
From what i read, Chromium should then use kwallet.
https://wiki.archlinux.org/title/KDE_Wallet#Unlock_KDE_Wallet_automatically_on_login
Thanks for your help maycne.sonahoz i will look into it.
ian
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or
or
if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
