Login issues after update
Good morning. I am new using manjaro. Today I decided to do an update with pacman -Syu and by that time i had no knowledge of the snapshot tool yet. After the reboot my login screen changed and is now the same as the image below. It is not possible to login through this interface. Through the terminal I can log in. Any idea how I can get back to using manjaro normally?
https://drive.google.com/drive/u/1/folders/1SP6LztWx4ZDvWJ0fTGfmblQfYYCdixcN
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in reading :wink: )
but image is private :sob:
I solve my problem myself. I opened my terminal with CTRL+ALT+F2 using tty and reinstaled Kde Plasma. Theres a conflitc error on pipewire package when i reinstaled, but i don´t know if this was the cause of the issue.
https://wiki.archlinux.org/title/KDE
I don´t know if this was the better sollution, but solve my issue.
