!. First I Login password bios. then login in Manajro OS. After putting os Lock on Unnecessary login screen comes up that I bypass to get to actual Manjaro login. This unnecessary login screen should be removed as it interferes with the actual Manjaro login.
That is something you set up - or you might mean system encryption
then this is also what you wanted.
whatever you mean by this
inadequate description of the issue
What did you “bypass” - and how?
The title says:
" … mulitiple login screens"
Are you sure you want to describe an issue you have
or did you want to rant / vent? ![]()
