After the last update (and after a reboot) i get logged out automatically after a 1 minute or so being logged in.
I can see errors in the logs (about logind, libseat and wlroot backend) but I don’t understand what could be the problem and how to solve it.
I’m using manjaro-sway, i’m not sure it’s related (I opened an issue there)
I tried dowgrading both manajaro-sway-settings and systemd (to 255.5-3) without any improvements.
Do you have any idea what could be the issue and how to solve it ?
Logs:
mai 31 16:43:25 amb-framework systemd[5106]: Started D-Bus User Message Bus.
mai 31 16:43:25 amb-framework dbus-broker-launch[5125]: Ready
mai 31 16:43:25 amb-framework greetd[5099]: gkr-pam: couldn't unlock the login keyring.
mai 31 16:43:25 amb-framework greetd[5151]: config: Config { file: ConfigFile { terminal: ConfigTerminal { vt: >
mai 31 16:43:26 amb-framework systemd[1694]: pcmanfm.service: Scheduled restart job, restart counter is at 6.
mai 31 16:43:26 amb-framework systemd[1694]: sway.service: Scheduled restart job, restart counter is at 1.
mai 31 16:43:26 amb-framework systemd[1694]: pcmanfm.service: Start request repeated too quickly.
mai 31 16:43:26 amb-framework systemd[1694]: pcmanfm.service: Failed with result 'exit-code'.
mai 31 16:43:26 amb-framework systemd[1694]: Failed to start Automatically mounts removable media.
mai 31 16:43:26 amb-framework systemd[1694]: Starting sway - SirCmpwn's Wayland window manager...
mai 31 16:43:26 amb-framework sway[5156]: 00:00:00.001 [ERROR] [wlr] [libseat] [libseat/libseat.c:58] Backend '>
mai 31 16:43:26 amb-framework sway[5156]: 00:00:00.001 [ERROR] [wlr] [backend/session/session.c:83] Unable to c>
mai 31 16:43:26 amb-framework sway[5156]: 00:00:00.001 [ERROR] [wlr] [backend/session/session.c:248] Failed to >
mai 31 16:43:26 amb-framework sway[5156]: 00:00:00.001 [ERROR] [wlr] [backend/backend.c:79] Failed to start a s>
mai 31 16:43:26 amb-framework sway[5156]: 00:00:00.001 [ERROR] [wlr] [backend/backend.c:359] Failed to start a >
mai 31 16:43:26 amb-framework sway[5156]: 00:00:00.001 [ERROR] [sway/server.c:137] Unable to create backend
mai 31 16:43:26 amb-framework systemd[1694]: sway.service: Main process exited, code=exited, status=1/FAILURE
mai 31 16:43:26 amb-framework systemd[1694]: sway.service: Failed with result 'exit-code'.
mai 31 16:43:26 amb-framework systemd[1694]: Failed to start sway - SirCmpwn's Wayland window manager.
mai 31 16:43:26 amb-framework systemd[1694]: waybar.service: Scheduled restart job, restart counter is at 1.
mai 31 16:43:26 amb-framework systemd[1694]: Started Highly customizable Wayland bar for Sway and Wlroots based>
mai 31 16:43:26 amb-framework waybar[5163]: cannot open display:
mai 31 16:43:26 amb-framework systemd[1694]: waybar.service: Main process exited, code=exited, status=1/FAILURE
mai 31 16:43:26 amb-framework systemd[1694]: waybar.service: Failed with result 'exit-code'.
mai 31 16:43:27 amb-framework systemd[1694]: sway.service: Scheduled restart job, restart counter is at 2.
mai 31 16:43:27 amb-framework systemd[1694]: Starting sway - SirCmpwn's Wayland window manager...
mai 31 16:43:27 amb-framework sway[5174]: 00:00:00.001 [ERROR] [wlr] [libseat] [libseat/libseat.c:58] Backend '>
mai 31 16:43:27 amb-framework sway[5174]: 00:00:00.001 [ERROR] [wlr] [backend/session/session.c:83] Unable to c>
mai 31 16:43:27 amb-framework sway[5174]: 00:00:00.001 [ERROR] [wlr] [backend/session/session.c:248] Failed to >
mai 31 16:43:27 amb-framework sway[5174]: 00:00:00.001 [ERROR] [wlr] [backend/backend.c:79] Failed to start a s>
mai 31 16:43:27 amb-framework sway[5174]: 00:00:00.001 [ERROR] [wlr] [backend/backend.c:359] Failed to start a >
mai 31 16:43:27 amb-framework sway[5174]: 00:00:00.001 [ERROR] [sway/server.c:137] Unable to create backend
mai 31 16:43:27 amb-framework systemd[1694]: sway.service: Main process exited, code=exited, status=1/FAILURE
mai 31 16:43:27 amb-framework systemd[1694]: waybar.service: Scheduled restart job, restart counter is at 2.
mai 31 16:43:27 amb-framework systemd[1694]: Started Highly customizable Wayland bar for Sway and Wlroots based>
mai 31 16:43:27 amb-framework systemd[1694]: sway.service: Failed with result 'exit-code'.
mai 31 16:43:27 amb-framework systemd[1694]: Failed to start sway - SirCmpwn's Wayland window manager.
mai 31 16:43:27 amb-framework waybar[5182]: cannot open display:
mai 31 16:43:27 amb-framework systemd[1694]: waybar.service: Main process exited, code=exited, status=1/FAILURE
mai 31 16:43:27 amb-framework systemd[1694]: waybar.service: Failed with result 'exit-code'.
mai 31 16:43:27 amb-framework greetd[5151]: gkr-pam: unable to locate daemon control file
mai 31 16:43:27 amb-framework greetd[5151]: gkr-pam: stashed password to try later in open session
mai 31 16:43:28 amb-framework greetd[5099]: pam_unix(greetd:session): session closed for user greeter
mai 31 16:43:28 amb-framework systemd[1]: session-12.scope: Deactivated successfully.
mai 31 16:43:28 amb-framework greetd[5151]: pam_unix(greetd:session): session opened for user amb(uid=1000) by >
mai 31 16:43:28 amb-framework systemd-logind[1066]: Session 12 logged out. Waiting for processes to exit.
