After the last update, I am unable to lock my screen. I get a screen that says that the lock screen is broken, and I can fix it with loginctl unlock-session 2
, which worked only the first time y used it after a reboot. But it has stopped working. I have rebooted and followed the solutions listed here Old Error Fix yet it is not working. I already replaced “qt5-virtualkeyboard-bigscreen with qt5-virtualkeyboard”
Maybe important: Before the update (I did not have this issue), but when I connected to an external monitor, the display would practically freeze (it was extremely slow). The solution was to downgrade kscreeen and libkscreen (currently 5.24.90-1). Everytime I upgrade, my external monitor is extremely slow.
Error image:
Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=995ceace-134f-4ff3-8176-1895bb048c9e rw ibt=off quiet splash
resume=UUID=62e5f3dc-afef-4548-b46e-1f7a6af1633e udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Strix G533ZW_G533ZW v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G533ZW v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G533ZW.322 date: 01/03/2023
ID-1: BAT0 charge: 83.8 Wh (100.0%) condition: 83.8/90.0 Wh (93.1%)
volts: 17.0 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown
serial: <filter> status: full
RAM: total: 15.29 GiB used: 4.63 GiB (30.3%)
Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x429
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2274 high: 3076 min/max: 400/4900:5000:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1098 2: 2900 3: 2900
4: 1321 5: 3076 6: 2900 7: 2461 8: 2900 9: 2824 10: 2900 11: 2816 12: 2900
13: 1876 14: 983 15: 564 16: 1018 17: 1351 18: 2900 19: 2900 20: 2900
bogomips: 116780
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep
smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: ASUSTeK driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1,DP-2 bus-ID: 0000:00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: ASUSTeK
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
chip-ID: 10de:24a0 class-ID: 0300
Device-3: Logitech C920 PRO HD Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-2.1:4 chip-ID: 046d:08e5
class-ID: 0102
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 5360x1440 s-dpi: 96 s-size: 1414x380mm (55.67x14.96")
s-diag: 1464mm (57.64")
Monitor-1: DP-1-0 pos: primary,right res: 3440x1440 dpi: 110
size: 797x334mm (31.38x13.15") diag: 864mm (34.02") modes: N/A
Monitor-2: eDP-1 pos: left res: 1920x1080 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 3-2.1:4 chip-ID: 046d:08e5
alternate: snd_sof_pci_intel_tgl class-ID: 0102 bus-ID: 0000:00:1f.3
chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-4: Kingston HyperX SoloCast type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2.3:7 chip-ID: 0951:170f
class-ID: 0300
Device-5: Huawei MateView GT type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-5.1:10 chip-ID: 12d1:10b6
class-ID: 0102 serial: <filter>
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
IF-ID-1: br-5a372ed13a28 state: down mac: <filter>
IF-ID-2: br-600775fcafa0 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-3: docker0 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-4: veth41993d7 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 2.75 TiB used: 40.26 GiB (1.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA1T0TFH
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P7MA001 temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:8 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 type: SSD serial: <filter> rev: P7CR402 temp: 54.9 C scheme: GPT
ID-1: / raw-size: 683.59 GiB size: 671.79 GiB (98.27%) used: 34.72 GiB (5.2%)
fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:12 label: root
uuid: 995ceace-134f-4ff3-8176-1895bb048c9e
ID-2: /boot/efi raw-size: 907 MiB size: 905.2 MiB (99.80%)
used: 320 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4 label: BOOT
uuid: A5FE-B15B
ID-3: /home raw-size: 755.48 GiB size: 742.55 GiB (98.29%)
used: 5.53 GiB (0.7%) fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:11
label: home uuid: 54e25ca2-df7a-47ec-ab28-3d3e6b8c4d98
ID-1: swap-1 type: partition size: 33.2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p2 maj-min: 259:10 label: N/A
uuid: 62e5f3dc-afef-4548-b46e-1f7a6af1633e
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: C0AE-EFFC
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 929.69 GiB fs: ntfs label: OS
uuid: AAD2B0A1D2B07365
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 850 MiB fs: ntfs label: RECOVERY
uuid: 44D45B8FD45B81DA
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 22 GiB fs: ntfs label: RESTORE
uuid: 082C59572C5940BC
ID-6: /dev/nvme0n1p7 maj-min: 259:7 size: 200 MiB fs: vfat label: MYASUS
uuid: 8259-703F
ID-7: /dev/nvme1n1p1 maj-min: 259:9 size: 390.74 GiB fs: ntfs label: N/A
uuid: 0574C4312C2B8E66
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-2:2 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 214b:7250 class-ID: 0900
Device-1: 3-2.1:4 info: Logitech C920 PRO HD Webcam type: Video,Audio
driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.1 speed: 480 Mb/s
power: 500mA chip-ID: 046d:08e5 class-ID: 0102
Device-2: 3-2.2:6 info: Razer USA BlackWidow Ultimate 2016
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0214 class-ID: 0300
Device-3: 3-2.3:7 info: Kingston HyperX SoloCast type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0951:170f class-ID: 0300
Device-4: 3-2.4:8 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Device-5: 3-3:3 info: ASUSTek N-KEY Device type: Keyboard
driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 0b05:19b6 class-ID: 0301
Hub-5: 3-5:9 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-5.1:10 info: Huawei MateView GT type: HID,Audio
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
speed: 480 Mb/s power: 250mA chip-ID: 12d1:10b6 class-ID: 0102
serial: <filter>
Device-2: 3-5.2:11 info: Silicon Labs CH549 type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 500mA
chip-ID: 10c4:92ca class-ID: 0300 serial: <filter>
Device-3: 3-10:5 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2200
Processes: 360 Uptime: 25m wakeups: 3 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 2366
pm: pacman pkgs: 1183 libs: 330 tools: pamac pm: rpm pkgs: N/A
note: see --rpm tools: dnf pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: yakuake inxi: 3.3.26
Error logs (just warnings and above):
4/17/23 3:00 PM ksplashqml file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
4/17/23 3:00 PM ksplashqml file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
4/17/23 3:00 PM ksmserver Qt: Session management error: networkIdsList argument is NULL
4/17/23 3:00 PM kwin_x11 kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
4/17/23 3:00 PM kwin_x11 kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
4/17/23 3:00 PM ksmserver QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.16'
4/17/23 3:00 PM plasmashell Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
4/17/23 3:00 PM plasmashell If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
4/17/23 3:00 PM plasmashell Checking screens: available: (QScreen(0x557fa9416740, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x557fa9416740, name="eDP-1"))
4/17/23 3:00 PM pipewire mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
4/17/23 3:00 PM pipewire mod.rt: found session bus but no portal
4/17/23 3:00 PM kded5 kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
4/17/23 3:00 PM kded5 QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
4/17/23 3:00 PM org_kde_powerdevil kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/powerdevil/action/powerdevil_powerprofileaction.so: Cannot load library /usr/lib/qt/plugins/powerdevil/action/powerdevil_powerprofileaction.so: (libKF5Screen.so.8: cannot open shared object file: No such file or directory)"
4/17/23 3:00 PM org_kde_powerdevil kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/powerdevil/action/powerdevil_dpmsaction.so: Cannot load library /usr/lib/qt/plugins/powerdevil/action/powerdevil_dpmsaction.so: (libKF5ScreenDpms.so.8: cannot open shared object file: No such file or directory)"
4/17/23 3:00 PM org_kde_powerdevil kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/powerdevil/action/powerdevil_handlebuttoneventsaction.so: Cannot load library /usr/lib/qt/plugins/powerdevil/action/powerdevil_handlebuttoneventsaction.so: (libKF5Screen.so.8: cannot open shared object file: No such file or directory)"
4/17/23 3:00 PM kded5 kscreen.kded: PowerDevil SuspendSession action not available!
4/17/23 3:00 PM org_kde_powerdevil org.kde.powerdevil: The profile "AC" tried to activate "HandleButtonEvents" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
4/17/23 3:00 PM org_kde_powerdevil org.kde.powerdevil: The profile "AC" tried to activate "DPMSControl" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
4/17/23 3:00 PM user@1000.service <WpPortalPermissionStorePlugin:0x55a10c860900> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
4/17/23 3:00 PM plasmashell Checking screens: available: (QScreen(0x7fde680038a0, name="DP-1-0"), QScreen(0x557fa9416740, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x7fde680038a0, name="DP-1-0"), QScreen(0x557fa9416740, name="eDP-1"))
4/17/23 3:00 PM kioslave5 QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
4/17/23 3:00 PM plasmashell Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
4/17/23 3:00 PM plasmashell kf.plasma.quick: QJsonValue(string, "Icons-only Task Manager")
4/17/23 3:00 PM plasmashell kf.plasma.quick: QJsonValue(array, QJsonArray(["file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:18:1: plugin cannot be loaded for module \"org.kde.plasma.private.taskmanager\": Cannot load library /usr/lib/qt/qml/org/kde/plasma/private/taskmanager/libtaskmanagerplugin.so: (libKF5Screen.so.8: cannot open shared object file: No such file or directory)"]))
4/17/23 3:00 PM plasmashell Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
4/17/23 3:00 PM plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
4/17/23 3:00 PM plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
4/17/23 3:00 PM plasmashell kf.plasma.quick: QJsonValue(string, "Notifications")
4/17/23 3:00 PM plasmashell kf.plasma.quick: QJsonValue(array, QJsonArray(["file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/main.qml:17:1: plugin cannot be loaded for module \"org.kde.notificationmanager\": Cannot load library /usr/lib/qt/qml/org/kde/notificationmanager/libnotificationmanagerplugin.so: (libKF5Screen.so.8: cannot open shared object file: No such file or directory)"]))
4/17/23 3:00 PM plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
4/17/23 3:00 PM kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 3367, resource id: 16777253, major code: 143 (DAMAGE), minor code: 3 (Subtract)
4/17/23 3:00 PM kwin_x11 kwin_core: XCB error: 3 (BadWindow), sequence: 3397, resource id: 4194358, major code: 129 (SHAPE), minor code: 6 (Input)
4/17/23 3:00 PM kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 3413, resource id: 16777351, major code: 143 (DAMAGE), minor code: 3 (Subtract)
4/17/23 3:00 PM plasmashell QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
4/17/23 3:00 PM kernel usb 3-2.1: current rate 16000 is different from the runtime rate 32000
4/17/23 3:00 PM pulseaudio stat('/etc/pulse/default.pa.d'): No such file or directory
4/17/23 3:00 PM plasmashell kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/dataengine/plasma_engine_notifications.so: Cannot load library /usr/lib/qt/plugins/plasma/dataengine/plasma_engine_notifications.so: (libKF5Screen.so.8: cannot open shared object file: No such file or directory)"
4/17/23 3:00 PM kstart5 Omitting both --window and --windowclass arguments is not recommended
4/17/23 3:00 PM user@1000.service Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
4/17/23 3:00 PM user@1000.service Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
4/17/23 3:00 PM kernel kauditd_printk_skb: 248 callbacks suppressed
4/17/23 3:00 PM kdeconnectd kdeconnect.core: Could not query capabilities from notifications server
4/17/23 3:05 PM plasmashell kf.sonnet.core: No language dictionaries for the language: "en_US"
4/17/23 3:05 PM plasmashell Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
4/17/23 3:05 PM kdesud kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Copyright (c) 1999,2000 Geert Jansen" msgid_plural: "" msgctxt: ""
4/17/23 3:05 PM kdesud kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Daemon used by kdesu" msgid_plural: "" msgctxt: ""
4/17/23 3:05 PM kdesud kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "KDE su daemon" msgid_plural: "" msgctxt: ""
4/17/23 3:05 PM kdesud kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Author" msgid_plural: "" msgctxt: ""
4/17/23 3:05 PM kdesud kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Geert Jansen" msgid_plural: "" msgctxt: ""
4/17/23 3:05 PM audit USER_AUTH pid=3986 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/3 res=success'
4/17/23 3:05 PM audit USER_ACCT pid=3986 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/3 res=success'
4/17/23 3:05 PM audit CRED_ACQ pid=3986 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/3 res=success'
4/17/23 3:05 PM audit USER_START pid=3986 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/3 res=success'
Thanks
