Today I suspended my computer and left the house for some time. When I came back it didn’t accept my password and said “Ten minutes left to unlock”.
I rebooted and tried to see if I could get in that way, but I am greeted with the same lock screen that will not accept my correct password.
I am very worried now that I will not be able to access my computer, and I have a lot of files that aren’t backed up anywhere else.
Today I completed the latest update. I used pacdiff to deal with a bunch of .pacnew files, but I really don’t understand the process very well so I suppose this could have led to the problem.
In the mean time, is there anyway to access my account?
All the similar issues I see on here suggest making changes to various files, but they all seem able to access their accounts after a reboot, whereas I am simply locked out. Please help!
Usually, this means you have entered a wrong password too many times, but if you have previously worked on pacnew files I suppose you did something wrong. What pacnew files have you tried to fix exactly and how?
I had a message about one during the installation today for mkinitcpio (I think) but when I ran pacdiff I saw I had a lot of them to deal with. I simply overwrite all of them, which I can see now is not what I am supposed to be doing.
I think I remember shadow being one of the files I changed.
I am not so great with all this stuff so it will take me a while. Is what your saying essentially that I am loading a new Manjaro and then mounting the one I am locked out of?
I am not saying you should reinstall - in fact any live linux can be used - the only thing you have to do is to mount the manjaro root partition from a live system.
Then copy the backup files back to undo the changes you made with the pacnew files.
The rough guide is
boot a live Linux ISO
open a root terminal
mount your root partition
if you are running a default EFI system the partition will most likely be /dev/sda2 or /dev/nvme0n1p2 (pure guess work)
List partitions
lsblk
Replace sdyX with the partition of your system
mount /dev/sdyX /mnt
Move into the etc folder of the mounted partition
cd /mnt/etc
compare the content of the backup files with their current equivalents
cat shadow
cat shadow-
and
cat passwd
cat passwd-
If you are confident the backups are ok
cp passwd- passwd
cp shadow- shadow
Move out of the partition and unmount the partition
