After new update 2023-06-04, Lock screen (Super + L) yields the screen to freeze for a very short moment after which the Show Application appears.
The shortcut is set up correctly:
I show here the problem (the keystrokes are shown with the help of Screenkey):
$ inxi -v7azy
Kernel: 5.10.181-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=75a0eed1-3787-4451-9020-fbb5e4209954 rw quiet apparmor=1
security=apparmor resume=UUID=1f35139c-62ba-45f9-afb4-8158f370195d
udev.log_priority=3
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: LENOVO product: 20N2S1PE00 v: ThinkPad T490
Mobo: LENOVO model: 20N2S1PE00 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: N2IET75W (1.53 )
date: 08/21/2019
ID-1: BAT0 charge: 35.8 Wh (84.6%) condition: 42.3/50.5 Wh (83.9%)
volts: 12.9 min: 11.5 model: SMP 02DL008 type: Li-poly serial: <filter>
status: charging cycles: 808
System RAM: available: 23.15 GiB used: 3.85 GiB (16.6%)
Info: model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF6
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 699 high: 700 min/max: 400/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 699 3: 700 4: 700
5: 700 6: 700 7: 700 8: 700 bogomips: 32012
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Chicony ThinkPad T490 Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b681
Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: AU Optronics 0x2036 built: 2017 res: 2560x1440
hz: 60 dpi: 210 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 2560x1440
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k5.10.181-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5
Local Storage: total: 476.94 GiB used: 408.15 GiB (85.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000L7
lanes: 4 tech: SSD serial: <filter> fw-rev: 4M2QEXF7 temp: 55.9 C
scheme: GPT
ID-1: / raw-size: 451.05 GiB size: 442.9 GiB (98.19%)
used: 408.14 GiB (92.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 75a0eed1-3787-4451-9020-fbb5e4209954
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: F798-1318
ID-1: swap-1 type: partition size: 25.59 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 1f35139c-62ba-45f9-afb4-8158f370195d
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Alcor Micro AU9540 Smartcard Reader type: smart card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 50mA chip-ID: 058f:9540 class-ID: 0b00
Device-2: 1-8:3 info: Chicony ThinkPad T490 Webcam type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b681 class-ID: 0e02 serial: <filter>
Device-3: 1-9:4 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-4: 1-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 55.0 C pch: 56.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3525
Processes: 287 Uptime: 25m wakeups: 5 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 2138 libs: 498 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
