Where is the location of the default xcursor-breeze files? Trying to use GTK3Agg backend of matplotlib on Wayland will throw an error saying Unable to load fleur from the cursor theme
On the Arch wiki there is workaround to this problem by appending the path of the folder containing the cursor files
Thank you for the answer. However, it seems that appending the cursor path does not solve the problem. I have not installed any user themes/icons/cursor and just using the default. I have appended the following line to both .bashrc and .zshrc
Unable to load tcross from the cursor theme
File "/usr/lib/python3.8/site-packages/matplotlib/backends/backend_gtk3.py", line 43, in <module>
cursors.SELECT_REGION: Gdk.Cursor.new(Gdk.CursorType.TCROSS),
TypeError: constructor returned NULL
The above exception was the direct cause of the following exception:
File "test.py", line 4, in <module>
import matplotlib.pyplot as plt
File "/usr/lib/python3.8/site-packages/matplotlib/pyplot.py", line 2336, in <module>
switch_backend(rcParams["backend"])
File "/usr/lib/python3.8/site-packages/matplotlib/pyplot.py", line 276, in switch_backend
class backend_mod(matplotlib.backend_bases._Backend):
File "/usr/lib/python3.8/site-packages/matplotlib/pyplot.py", line 277, in backend_mod
locals().update(vars(importlib.import_module(backend_name)))
File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "/usr/lib/python3.8/site-packages/matplotlib/backends/backend_gtk3agg.py", line 8, in <module>
from . import backend_agg, backend_gtk3
File "/usr/lib/python3.8/site-packages/matplotlib/backends/backend_gtk3.py", line 49, in <module>
raise ImportError(exc) from exc
ImportError: constructor returned NULL
I am not sure if this is the correct forum for this error or shall I bring it to the matplotlib or Wayland people. I am using latest releases, kernel 5.9.10, python 3.8.6, matplotlib 3.3.3.
