Local key could not be updated from a keyserver
I have already found a few threads about it but I was not able to fix the keyserver issue …
sudo pacman-key --refresh-keys
gpg: refreshing 139 keys from hkps://hkps.pool.sks-keyservers.net
gpg: keyserver refresh failed: General error
==> ERROR: A specified local key could not be updated from a keyserver.
it works only when running:
sudo pacman-key --refresh-keys -u --keyserver hkps.pool.sks-keyservers.net
shows folowing at the end
Zusammenfassung
gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
gpg: public key DB323392796CA067 is 3037 days newer than the signature
did not change anything
Zusammenfassung
sudo rm -r /etc/pacman.d/gnupg
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
sudo pacman-key --init
sudo pacman-key --populate archlinux manjaro
sudo pacman -Sc
sudo pacman -Syyu
KDE Plasma Version: 5.19.5
KDE Frameworks Version: 5.73.0
Qt Version: 5.15.0
Kernel Version: 5.8.6-1-MANJARO
OS Type: 64-bit
Processors: 8 × AMD FX™-8350 Eight-Core Processor
Memory: 15.6 GiB of RAM
Graphics Processor: GeForce GT 630/PCIe/SSE2
Is there no way to solve this problem or should I better re-install manjaro?
got it :wink:
nano /etc/pacman.d/gnupg/gpg.conf
changed from:
no-greeting
no-permission-warning
lock-never
keyserver-options timeout=10
keyserver-options import-clean
keyserver-options no-self-sigs-only
to
no-greeting
lock-never
keyserver hkp://pool.sks-keyservers.net
