So I’ve had a VPS running on a domain. The IP changed and I updated the DNS records with the registrar. On other devices/OS I reach the new server IP with the domain name but on Manjaro the old IP sticks (unless I manually add a hosts file entry). I’ve tried some stuff I found online but basically none of it applied. Restart also does not work.
here’s some info
[xxx@xbase ~]$ systemctl --user list-unit-files --state=enabled
UNIT FILE STATE VENDOR PRESET
xdg-user-dirs-update.service enabled enabled
dirmngr.socket enabled enabled
gpg-agent-browser.socket enabled enabled
gpg-agent-extra.socket enabled enabled
gpg-agent-ssh.socket enabled enabled
gpg-agent.socket enabled enabled
p11-kit-server.socket enabled enabled
pipewire.socket enabled enabled
pulseaudio.socket enabled enabled
9 unit files listed.
[xxx@xbase ~]$ cat /etc/nsswitch.conf
# Name Service Switch configuration file.
# See nsswitch.conf(5) for details.
passwd: files mymachines systemd
group: files [SUCCESS=merge] mymachines systemd
shadow: files
publickey: files
hosts: files mymachines mdns4_minimal [NOTFOUND=return] resolve [!UNAVAIL=return] dns mdns4 myhostname
networks: files
protocols: files
services: files
ethers: files
rpc: files
netgroup: files
[xxx@xbase ~]$ cat /etc/resolv.conf
# Generated by NetworkManager
search fritz.box
nameserver 192.168.178.1
nameserver fd00::3681:c4ff:fe0e:5bc6
