Loading Time from Gnome Display Manager to Desktop quite long after Mainboard Switch
Hey, I recently switched my mainboard (the same model). After switching the loading of the desktop takes quite long after having typed my password (10-15sec). I tried finding an error using journalctl, but I couldn’t find anything noteworthy at least from my experience.
inxi -zv8
  Kernel: 6.6.40-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=97edd2bb-94d6-46d3-a872-5fc965ae2865 rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 46.3.1 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASRock model: B650E Taichi Lite
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 2.03 date: 12/05/2023
  System RAM: total: 64 GiB available: 61.92 GiB used: 6.08 GiB (9.8%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 32 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
    part-no: 6400 C32 Series serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
    L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
  Speed (MHz): avg: 2432 high: 4750 min/max: 400/5759 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3146 2: 4654 3: 400
    4: 400 5: 400 6: 400 7: 400 8: 400 9: 4749 10: 4750 11: 3163 12: 3164
    13: 4748 14: 400 15: 4750 16: 3761 17: 400 18: 400 19: 400 20: 400 21: 400
    22: 400 23: 400 24: 4089 25: 4749 26: 4749 27: 3167 28: 400 29: 4748
    30: 4749 31: 4750 32: 3969 bogomips: 268906
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm
    cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vnmi
    vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xsaves
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] vendor: ASRock
    driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
    built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-1,DP-2,DP-3 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:744c
    class-ID: 0300
  Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2 bus-ID: 50:00.0
    chip-ID: 1002:164e class-ID: 0300 temp: 44.0 C
  Device-3: Microsoft Microsoft LifeCam HD-5001
    driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 3-4.1:4 chip-ID: 045e:076e class-ID: 0102
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
    compositor: gnome-shell driver: X: loaded: nvidia gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: Samsung C32HG7x serial: <filter> built: 2017
    res: 2560x1440 dpi: 93 gamma: 1.2 chroma: red: x: 0.678 y: 0.314 green:
    x: 0.267 y: 0.667 blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
    size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
    modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
    800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: DP-2 model: LG (GoldStar) Ultra HD serial: <filter> built: 2017
    res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green:
    x: 0.306 y: 0.639 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
    800x600, 720x480, 640x480
  Monitor-3: DP-3 model: Philips PHL 273V7 serial: <filter> built: 2018
    res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green:
    x: 0.271 y: 0.655 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1280x720, 1024x768, 832x624, 800x600, 640x480, 720x400
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
    navi31 LLVM 18.1.8 DRM 3.54 6.6.40-1-MANJARO) device-ID: 1002:744c
    memory: 19.53 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 24.1.3-manjaro1.1
    device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1
    type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
    driver: mesa radv v: 24.1.3-manjaro1.1 device-ID: 1002:164e
  Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30
    class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 50:00.1
    chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 50:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Device-4: Microsoft Microsoft LifeCam HD-5001
  Device-5: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
    driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 3-4.2:6 chip-ID: 1235:8202 class-ID: 0102
  Device-6: SteelSeries ApS Arctis 7
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-4.4:8 chip-ID: 1038:12ad class-ID: 0300
  Device-7: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:5
    chip-ID: 26ce:0a06 class-ID: 0300
  API: ALSA v: k6.6.40-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak]
    vendor: Rivet Networks Killer driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 49:00.0 chip-ID: 8086:2725 class-ID: 0280
  IF: wlp73s0 state: down mac: <filter>
  Device-2: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: a000 bus-ID: 4a:00.0
    chip-ID: 10ec:3000 class-ID: 0200
  IF: enp74s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:3 chip-ID: 8087:0032
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3
    lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 3.62 TiB used: 2.62 TiB (72.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup
    model: T-FORCE TM8FP7002T size: 1.82 TiB block-size: physical: 512 B
    fw-rev: EGFM15.2 temp: 37.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 960 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 40.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
    size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 480GB
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.31 TiB (72.0%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 97edd2bb-94d6-46d3-a872-5fc965ae2865
    used: 612 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 0272-20F0
  ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 1.31 TiB (72.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 97edd2bb-94d6-46d3-a872-5fc965ae2865
  ID-4: /mnt/9a81e120-ca6a-4046-b7ae-b6995fde721d raw-size: 465.76 GiB
    size: 457.38 GiB (98.20%) used: 426.93 GiB (93.3%) fs: ext4
    dev: /dev/nvme1n1p1 maj-min: 259:4 label: Daten
    uuid: 9a81e120-ca6a-4046-b7ae-b6995fde721d
  ID-5: /run/media/thomas/Daten raw-size: 447.13 GiB
    size: 447.13 GiB (100.00%) used: 213.45 GiB (47.7%) fs: btrfs dev: /dev/sdb1
    maj-min: 8:17 label: Daten uuid: bf9f763f-b123-4e64-afa5-b89812c14ccc
  ID-6: /run/media/thomas/Games raw-size: 931.51 GiB
    size: 931.51 GiB (100.00%) used: 702.74 GiB (75.4%) fs: btrfs dev: /dev/sda1
    maj-min: 8:1 label: Games uuid: 497ca50b-75ca-4c7a-ba5f-aad8aeda9f74
  ID-7: /var/cache raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-8: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
    file: /swap
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-4: 3-4:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 3-4.1:4 info: Microsoft Microsoft LifeCam HD-5001
    type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
  Device-2: 3-4.2:6 info: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
    type: audio driver: snd-usb-audio interfaces: 4 rev: 2.0
  Device-3: 3-4.3:7 info: Brother Industries DCP-J562DW
    type: printer,mass storage driver: usb-storage,usblp interfaces: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 04f9:0380 class-ID: 0806 serial: <filter>
  Device-4: 3-4.4:8 info: SteelSeries ApS Arctis 7 type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 1.1
  Device-5: 3-7:3 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Device-6: 3-8:5 info: Generic USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
  Device-7: 3-9:9 info: ROCCAT Kone Pro type: mouse,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:2c88 class-ID: 0300
  Device-8: 3-11:10 info: Ducky One 3 TKL type: HID,keyboard,mouse
    driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:8011 class-ID: 0300
    serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-6: 4-4:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 5-1:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
  Hub-9: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-10: 6-1:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
  Hub-11: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-12: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-13: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 9-1:2 info: ASRock LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
    serial: <filter>
  Hub-14: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 47.9 C mobo: N/A
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 43.0 C device: amdgpu temp: 50.0 C mem: 61.0 C
    fan: 0 watts: 33.00
  Packages: 2303 pm: pacman pkgs: 2266 libs: 511 tools: gnome-software,pamac
    pm: flatpak pkgs: 37
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: http://manjaro.grena.ge/stable/$repo/$arch
    3: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    4: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    5: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    6: https://manjaro.ynh.ovh/stable/$repo/$arch
    7: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    8: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 658
  1: cpu: 100% command: ps pid: 6538 mem: 3.50 MiB (0.0%)
  2: cpu: 9.7% command: gnome-terminal-server pid: 6450 mem: 60.0 MiB (0.0%)
  3: cpu: 6.1% command: vivaldi-bin pid: 6027 mem: 289.2 MiB (0.4%)
  4: cpu: 4.4% command: zsh pid: 6458 mem: 8.80 MiB (0.0%)
  5: cpu: 4.2% command: vivaldi-bin pid: 4458 mem: 437.2 MiB (0.6%)
  Memory top: 5 of 658
  1: mem: 845.5 MiB (1.3%) command: telegram-desktop pid: 2544 cpu: 0.0%
  2: mem: 475.3 MiB (0.7%) command: gnome-shell pid: 2163 cpu: 2.5%
  3: mem: 437.2 MiB (0.6%) command: vivaldi-bin pid: 4458 cpu: 4.2%
  4: mem: 369.3 MiB (0.5%) command: vivaldi-bin pid: 4274 cpu: 1.2%
  5: mem: 332.1 MiB (0.5%) command: vivaldi-bin pid: 6242 cpu: 3.2%
  Processes: 658 Power: uptime: 36m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.75 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.1.1 alt: 12 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.35
Using the very latest
ManjaroLinux 24.0.4 Wynsdey
Happy to provide any further information.
Hello friend! To have a better understanding of the situation, could you share the output of the following commands?
systemd-analyze
systemd-analyze blame
While this might not be related to the issue, I noticed that you’re using vivaldi-bin, presumedly from the AUR; I see no obvious need for this, as vivaldi is available via the official repositories (extra):
sudo pacman -S vivaldi
I will share the top 10 of systemd-analyze blame
16.503s plymouth-quit-wait.service
10.313s cups.service
 5.797s systemd-journald.service
 4.442s NetworkManager-wait-online.service
 2.530s systemd-rfkill.service
 2.450s udisks2.service
 2.155s upower.service
 1.085s dev-nvme0n1p2.device
  513ms mullvad-early-boot-blocking.service
  461ms systemd-udev-trigger.service
with systemd-analyze
Startup finished in 51.609s (firmware) + 9.138s (loader) + 5.661s (kernel) + 1min 31.034s (userspace) = 2min 37.443s
graphical.target reached after 24.909s in userspace.```
Is a reinstall my best/easiest option?
You could remove Plymouth, and arguably regain up to one third of that boot delay. Keep in mind though that removing Plymouth is not as simple as uninstalling it. Please see:
Scroll down to the heading of REMOVAL for the correct procedure to remove Plymouth.
Aside:- It looks like you’ve done this before although that attempt seems much more complicated than it needed to be.
Cheers.
