Loading GUI KDE plasma takes about 10 minutes after logon
About a month ago (just before I went on holiday) I noticed that after my login it would take longer to load my menus. About 2 to 3 minutes, now it is about 10 to 15 minutes.
Krunner is working, but apps like Dolphin crash, or when I click on an item in my menu. I only see my desktop background, cursor and one app that I made to start automatically. Others are really slow (I start them from Krunner). After about 10 minutes all seems to be finally working as intended. I have no idea where to start to solve this. I use the Breeze theme.
❯ inxi -zv8
  Kernel: 6.18.45-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    root=UUID=36731a5c-2049-41e3-b763-d0b4ae9b947f rw quiet
    udev.log_priority=3 ibt=off
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
    wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop X7600PC_N7600PC
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X7600PC v: 1.0 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: X7600PC.300 date: 11/08/2021
  ID-1: BAT0 charge: 43.3 Wh (73.8%) condition: 58.6/96 Wh (61%) power: 20.4 W
    volts: 11.66 min: 11.66 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    charging: status: discharging control: start: N/A end: 80% cycles: 520
  System RAM: total: 16 GiB available: 15.3 GiB used: 5 GiB (32.7%)
  Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 8 GiB
    speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M471A1G44AB0-CWE
    serial: N/A
  Device-2: Controller1-ChannelA type: DDR4 detail: synchronous size: 8 GiB
    serial: N/A
  Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xBE
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4800 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 52838
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
    driver: nvidia v: 610.57.04 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-6xx.xx+ status: current (as of 2026-07) arch: Ampere
    code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4
    speed: 16 GT/s lanes: 4 link-max: lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:25a2 class-ID: 0302
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 13d3:5458
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
    unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
    display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0xe495 built: 2021 res:
    mode: 2560x1600 hz: 120 scale: 125% (1.25) to: 2048x1280 dpi: 189 gamma: 1.2
    chroma: red: x: 0.678 y: 0.318 green: x: 0.259 y: 0.694 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 344x215mm (13.54x8.46")
    diag: 406mm (16") ratio: 16:10 modes: 2560x1600
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 26.1.7-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
    GT2) device-ID: 8086:9a49 memory: 14.94 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 4 device: 0 type: integrated-gpu name: Intel
    Iris Xe Graphics (TGL GT2) driver: mesa intel v: 26.1.7-arch1.1
    device-ID: 8086:9a49 surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 3050 Laptop GPU driver: nvidia v: 610.57.04
    device-ID: 10de:25a2 surfaces: N/A
  Device-1: Intel 500 Series Family On-Package High Definition Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k6.18.45-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: MEDIATEK MT7921 802.11ax PCIe Wireless Network Adapter [Filogic
    330] vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 2e:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:5
    chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.3
    lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 476.94 GiB used: 289.4 GiB (60.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX013N
    lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 29.9 C
    scheme: GPT
  ID-1: / raw-size: 153.33 GiB size: 150.74 GiB (98.31%)
    used: 60.87 GiB (40.4%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: OS uuid: 36731a5c-2049-41e3-b763-d0b4ae9b947f
  ID-2: /boot/efi raw-size: 488 MiB size: 487 MiB (99.80%)
    used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: BOOT
    uuid: B735-71B9
  ID-3: /home raw-size: 291.88 GiB size: 286.23 GiB (98.07%)
    used: 228.53 GiB (79.8%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:3
    label: home uuid: 3063ce74-63a2-4c3b-985a-1e1edc6b7b7f
  ID-4: /home/<filter>/Mounts/Nextcloud/KP raw-size: N/A size: 41.33 GiB
    used: 336 KiB (0.0%) fs: fuse
    remote: https:/[url removed for privacy reasons]
  ID-1: swap-1 type: partition size: 31.25 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:4 label: swap
    uuid: 94cd97fa-8333-4434-8825-c1c1f42357fd
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-6:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5458 class-ID: fe01
    serial: <filter>
  Device-2: 3-7:3 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-3: 3-8:4 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04f3:0c6e class-ID: 0000
  Device-4: 3-10:5 info: IMC Networks Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  System Temperatures: cpu: 40.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2300
  Packages: pm: pacman pkgs: 2033 libs: 500 tools: pamac pm: rpm pkgs: 0
    pm: flatpak pkgs: 0
    1: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
Processes:
  CPU top: 5 of 306
  1: cpu: 19.0% command: firefox pid: 3167 mem: 890.5 MiB (5.6%)
  2: cpu: 9.9% command: kwin_wayland pid: 932 mem: 427.2 MiB (2.7%)
  3: cpu: 8.0% command: firefox pid: 5055 mem: 363.4 MiB (2.3%)
  4: cpu: 8.0% command: firefox pid: 5254 mem: 368.2 MiB (2.3%)
  5: cpu: 2.7% command: dolphin pid: 6201 mem: 297.5 MiB (1.8%)
  Memory top: 5 of 306
  1: mem: 890.5 MiB (5.6%) command: firefox pid: 3167 cpu: 19.0%
  2: mem: 501.8 MiB (3.2%) command: plasmashell pid: 1119 cpu: 0.8%
  3: mem: 451.8 MiB (2.8%) command: systemsettings pid: 2205 cpu: 1.0%
  4: mem: 427.2 MiB (2.7%) command: kwin_wayland pid: 932 cpu: 9.9%
  5: mem: 402.3 MiB (2.5%) command: firefox pid: 3648 cpu: 0.9%
  Processes: 306 Power: uptime: 33m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.03 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 261 default: graphical tool: systemctl
  Compilers: clang: 22.1.8 gcc: 16.2.1 Shell: Zsh v: 5.9.2 default: Bash
    v: 5.3.15 running-in: konsole inxi: 3.3.41
I do have a CIFS (smb) mount using systemd for my music that resides on my NAS, but that’s on my laptop for 2 years already I think. Any changes in baloorunner that may provoke this? I will not always be at home, so if it’s not mounted, the rest should of course start as usual so I can work on my laptop.
From kdejournal
23-08-2026 19:46	sddm	Initializing...
23-08-2026 19:46	sddm	Starting...
23-08-2026 19:46	sddm	Logind interface found
23-08-2026 19:46	sddm	Adding new display...
23-08-2026 19:46	sddm	Loaded empty theme configuration
23-08-2026 19:46	sddm	Xauthority path: "/run/sddm/xauth_tvicir"
23-08-2026 19:46	sddm	Using VT 2
23-08-2026 19:46	sddm	Display server starting...
23-08-2026 19:46	sddm	Writing cookie to "/run/sddm/xauth_tvicir"
23-08-2026 19:46	sddm	Running: /usr/bin/X -dpi 128 -background none -seat seat0 vt2 -auth /run/sddm/xauth_tvicir -noreset -displayfd 16
23-08-2026 19:46	sddm	Setting default cursor
23-08-2026 19:46	sddm	Running display setup script  "/usr/share/sddm/scripts/Xsetup"
23-08-2026 19:46	sddm	Display server started.
23-08-2026 19:46	sddm	Socket server starting...
23-08-2026 19:46	sddm	Socket server started.
23-08-2026 19:46	sddm	Loading theme configuration from "/usr/share/sddm/themes/breeze/theme.conf"
23-08-2026 19:46	sddm	Greeter starting...
23-08-2026 19:46	sddm-helper	[PAM] Starting...
23-08-2026 19:46	sddm-helper	[PAM] Authenticating...
23-08-2026 19:46	sddm-helper	[PAM] returning.
23-08-2026 19:46	dbus-broker-launch	Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
23-08-2026 19:46	sddm-helper	Writing cookie to "/tmp/xauth_LhRxEE"
23-08-2026 19:46	sddm	Greeter session started successfully
23-08-2026 19:46	sddm-greeter-qt6	High-DPI autoscaling not Enabled
23-08-2026 19:46	sddm-greeter-qt6	Reading from "/usr/share/wayland-sessions/plasma.desktop"
23-08-2026 19:46	sddm-greeter-qt6	Loading theme configuration from "/usr/share/sddm/themes/breeze/theme.conf"
23-08-2026 19:46	dbus-broker-launch	Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
23-08-2026 19:46	dbus-broker-launch	Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
23-08-2026 19:46	dbus-broker-launch	Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
23-08-2026 19:46	sddm-greeter-qt6	Connected to the daemon.
23-08-2026 19:46	sddm	Message received from greeter: Connect
23-08-2026 19:46	sddm-greeter-qt6	QObject::installEventFilter(): Cannot filter events for objects in a different thread.
23-08-2026 19:46	sddm-greeter-qt6	Icon theme "Irixium" not found.
23-08-2026 19:46	sddm-greeter-qt6	Member contentWidth of the object PopupList_QMLTYPE_158 overrides a member of the base object. Consider renaming it or adding final or override specifier
23-08-2026 19:46	sddm-greeter-qt6	Adding view for "eDP-1" QRect(0,0 2560x1600)
23-08-2026 19:46	sddm-greeter-qt6	QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.34'
23-08-2026 19:46	sddm-greeter-qt6	Message received from daemon: Capabilities
23-08-2026 19:46	sddm-greeter-qt6	Message received from daemon: HostName
23-08-2026 19:47	sddm-greeter-qt6	file:///usr/share/sddm/themes/breeze/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
23-08-2026 19:47	sddm-greeter-qt6	Reading from "/usr/share/wayland-sessions/plasma.desktop"
23-08-2026 19:47	sddm	Message received from greeter: Login
23-08-2026 19:47	sddm	Reading from "/usr/share/wayland-sessions/plasma.desktop"
23-08-2026 19:47	sddm	Session "/usr/share/wayland-sessions/plasma.desktop" selected, command: "/usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland" for VT 1
23-08-2026 19:47	sddm-helper	[PAM] Starting...
23-08-2026 19:47	sddm-helper	[PAM] Authenticating...
23-08-2026 19:47	sddm-helper	[PAM] Preparing to converse...
23-08-2026 19:47	sddm-helper	[PAM] Conversation with 1 messages
23-08-2026 19:47	sddm-helper	pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
23-08-2026 19:47	sddm-helper	[PAM] returning.
23-08-2026 19:47	sddm	Authentication for user  "ninja"  successful
23-08-2026 19:47	sddm-helper	pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
23-08-2026 19:47	sddm-greeter-qt6	Message received from daemon: LoginSucceeded
23-08-2026 19:47	sddm-helper	[PAM] Closing session
23-08-2026 19:47	sddm-helper	[PAM] Ended.
23-08-2026 19:47	sddm	Auth: sddm-helper exited successfully
23-08-2026 19:47	sddm	Greeter stopped. SDDM::Auth::HELPER_SUCCESS
23-08-2026 19:47	sddm-helper	pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
23-08-2026 19:47	sddm-helper	pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
23-08-2026 19:47	sddm-helper	Jumping to VT 1
23-08-2026 19:47	sddm-helper	VT mode didn't need to be fixed
23-08-2026 19:47	sddm	Session started true
23-08-2026 19:47	dbus-broker-launch	Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
23-08-2026 19:47	dbus-broker-launch	Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
23-08-2026 19:47	dbus-broker-launch	Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
23-08-2026 19:47	kernel	nvme nvme0: using unchecked data buffer
23-08-2026 19:47	kded6	QDBusObjectPath: invalid path "/modules/wpad-detector"
23-08-2026 19:47	kded6	The kded module name "wpad-detector" is invalid!
23-08-2026 19:47	kconf_update	/usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
23-08-2026 19:47	kconf_update	/usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
23-08-2026 19:47	kaccess	X server XKB extension major= 1  minor= 0
23-08-2026 19:47	polkit-kde-authentication-agent-1	New PolkitAgentListener  0x55b6caf1c210
23-08-2026 19:47	polkit-kde-authentication-agent-1	Adding new listener  PolkitQt1::Agent::Listener(0x55b6cae23780) for  0x55b6caf1c210
23-08-2026 19:47	polkit-kde-authentication-agent-1	Listener online
23-08-2026 19:47	polkit-kde-authentication-agent-1	Authentication agent result: true
23-08-2026 19:47	kded6	PendingCall Error: "The name is not activatable"
23-08-2026 19:47	plasmashell	Member visible of the object PlasmaQuick::Dialog overrides a member of the base object. Consider renaming it or adding final or override specifier
23-08-2026 19:47	plasmashell	Member enabled of the object DeclarativeDropArea overrides a member of the base object. Consider renaming it or adding final or override specifier
23-08-2026 19:47	org_kde_powerdevil	[DDCutilDetector]: Failed to initialize callback
23-08-2026 19:47	org_kde_powerdevil	Handle button events action could not check for screen configuration
23-08-2026 19:47	/usr/lib/xdg-desktop-portal	Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
23-08-2026 19:47	kernel	warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
23-08-2026 19:47	keepassxc	kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Save All" msgid_plural: "" msgctxt: "@action:button"
23-08-2026 19:47	keepassxc	kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&Yes" msgid_plural: "" msgctxt: "@action:button"
23-08-2026 19:47	keepassxc	kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Yes to All" msgid_plural: "" msgctxt: "@action:button"
23-08-2026 19:47	keepassxc	kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&No" msgid_plural: "" msgctxt: "@action:button"
23-08-2026 19:47	keepassxc	kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "No to All" msgid_plural: "" msgctxt: "@action:button"
23-08-2026 19:47	keepassxc	kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Abort" msgid_plural: "" msgctxt: "@action:button"
23-08-2026 19:47	keepassxc	kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Retry" msgid_plural: "" msgctxt: "@action:button"
23-08-2026 19:47	keepassxc	kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Ignore" msgid_plural: "" msgctxt: "@action:button"
23-08-2026 19:47	plasmashell	Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
23-08-2026 19:47	kded6	Error changing property "_KDE_NET_WM_APPMENU_SERVICE_NAME" on window 2 error code: 3
23-08-2026 19:47	kded6	Error changing property "_KDE_NET_WM_APPMENU_OBJECT_PATH" on window 2 error code: 3
23-08-2026 19:47	keepassxc	qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
23-08-2026 19:47	plasmashell	Member enabled of the object DBusServiceModel_QMLTYPE_866 overrides a member of the base object. Consider renaming it or adding final or override specifier
23-08-2026 19:47	plasmashell	Member enabled of the object DBusSignalMonitor_QMLTYPE_897 overrides a member of the base object. Consider renaming it or adding final or override specifier
23-08-2026 19:47	plasmashell	QML Plugin org.kde.plasma.panelcolorizer loaded
23-08-2026 19:47	plasmashell	Final member StackingOrder is overridden in class QQmlDMAbstractItemModelData. The override won't be used.
23-08-2026 19:47	plasmashell	Process "awk -v OFS=, 'NR > 2 { print substr($1, 1, length($1)-1), $2, $10 }' /proc/net/dev" already running. Pid: 1431
23-08-2026 19:47	xdg-desktop-portal-kde	Namespace  "org.gnome.desktop.interface"  is not supported
23-08-2026 19:47	ksmserver	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.ksmserver'")
23-08-2026 19:47	xembedsniproxy	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.xembedsniproxy'")
23-08-2026 19:47	gmenudbusmenuproxy	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.gmenudbusmenuproxy'")
23-08-2026 19:47	polkit-kde-authentication-agent-1	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Unable to open /proc/1189/root")
23-08-2026 19:47	kactivitymanagerd	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.ActivityManager'")
23-08-2026 19:47	org_kde_powerdevil	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.org_kde_powerdevil'")
23-08-2026 19:47	kdeconnectd	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
23-08-2026 19:47	pamac-tray-plasma	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for ''")
23-08-2026 19:47	org_kde_powerdevil	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
23-08-2026 19:47	kded6	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
23-08-2026 19:47	xdg-desktop-portal-kde	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
23-08-2026 19:47	ksecretd	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
23-08-2026 19:47	kaccess	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
23-08-2026 19:47	kernel	CIFS: VFS: Error connecting to socket. Aborting operation.
23-08-2026 19:47	kernel	CIFS: VFS: cifs_mount failed w/return code = -113
23-08-2026 19:47	systemd	home-ninja-Mounts-NAS-Muziek.mount: Failed with result 'exit-code'.
23-08-2026 19:47	systemd	Failed to mount Nassie Muziekmap (/home/ninja/Mounts/Nas/Muziek).
23-08-2026 19:47	keepassxc	kf.service.services: KServiceTypeTrader: serviceType "ThumbCreator" not found
23-08-2026 19:47	systemd	home-ninja-Mounts-NAS-NAShome.mount: Failed with result 'exit-code'.
23-08-2026 19:47	systemd	Failed to mount Nassie homemap (/home/ninja/Mounts/Nas/NAShome).
23-08-2026 19:48	keepassxc	kf.service.services: KServiceTypeTrader: serviceType "ThumbCreator" not found
23-08-2026 19:48	kernel	CIFS: VFS: Error connecting to socket. Aborting operation.
23-08-2026 19:48	kernel	CIFS: VFS: cifs_mount failed w/return code = -113
23-08-2026 19:48	systemd	home-ninja-Mounts-NAS-NAShome.mount: Failed with result 'exit-code'.
23-08-2026 19:48	systemd	Failed to mount Nassie homemap (/home/ninja/Mounts/Nas/NAShome).
23-08-2026 19:48	systemd	home-ninja-Mounts-NAS-Muziek.mount: Failed with result 'exit-code'.
23-08-2026 19:48	systemd	Failed to mount Nassie Muziekmap (/home/ninja/Mounts/Nas/Muziek).
23-08-2026 19:48	kdeconnectd	No uuids found for "8C:83:94:4F:19:55"
23-08-2026 19:48	kdeconnectd	No uuids found for "48:74:12:0D:BF:C8"
23-08-2026 19:48	kdeconnectd	No uuids found for "04:F0:EE:4C:8C:E9"
23-08-2026 19:48	baloo_file_extractor	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.baloo'")
23-08-2026 19:49	kernel	CIFS: VFS: Error connecting to socket. Aborting operation.
23-08-2026 19:49	kernel	CIFS: VFS: cifs_mount failed w/return code = -113
23-08-2026 19:49	systemd	home-ninja-Mounts-NAS-NAShome.mount: Failed with result 'exit-code'.
23-08-2026 19:49	systemd	Failed to mount Nassie homemap (/home/ninja/Mounts/Nas/NAShome).
23-08-2026 19:49	krunner	Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
23-08-2026 19:49	krunner	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.krunner'")
23-08-2026 19:49	krunner	Invalid image metadata (width: 0 height: 0 rowStride: 0 )
23-08-2026 19:49	krunner	Invalid path data; path truncated.
23-08-2026 19:49	krunner	Could not create image from "/build/static/img/autoweek.png"
23-08-2026 19:49	kwin_wayland	QDBusConnection: couldn't handle call to Teardown, no slot matched
23-08-2026 19:49	kwin_wayland	Could not find slot Krunner1Adaptor::Teardown
23-08-2026 19:49	krunner	<input>:1:14107: Could not resolve property: #linearGradient4299
23-08-2026 19:49	systemd	home-ninja-Mounts-NAS-Muziek.mount: Failed with result 'exit-code'.
23-08-2026 19:49	systemd	Failed to mount Nassie Muziekmap (/home/ninja/Mounts/Nas/Muziek).
23-08-2026 19:49	krunner	Error requesting matches; calling "org.kde.runners.baloo"  : "org.freedesktop.DBus.Error.NoReply" "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
23-08-2026 19:50	kernel	CIFS: VFS: Error connecting to socket. Aborting operation.
23-08-2026 19:50	kernel	CIFS: VFS: cifs_mount failed w/return code = -113
23-08-2026 19:50	systemd	home-ninja-Mounts-NAS-NAShome.mount: Failed with result 'exit-code'.
23-08-2026 19:50	systemd	Failed to mount Nassie homemap (/home/ninja/Mounts/Nas/NAShome).
23-08-2026 19:50	krunner	Error requesting matches; calling "org.kde.runners.baloo"  : "org.freedesktop.DBus.Error.NoReply" "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
23-08-2026 19:50	krunner	QIODevice::read (QSslSocket): device not open
23-08-2026 19:50	systemd	home-ninja-Mounts-NAS-Muziek.mount: Failed with result 'exit-code'.
23-08-2026 19:50	systemd	Failed to mount Nassie Muziekmap (/home/ninja/Mounts/Nas/Muziek).
23-08-2026 19:50	systemd-coredump	Process 1834 (dolphin) of user 1000 dumped core.
Stack trace of thread 1834:
#0  0x00007f5d7571201e statx (libc.so.6 + 0x11201e)
#1  0x00007f5d785d4470 _ZN11KMountPoint18currentMountPointsE6QFlagsINS_17DetailsNeededFlagEE (libKF6KIOCore.so.6 + 0xe1470)
#2  0x00007f5d787a27e2 n/a (libKF6KIOGui.so.6 + 0x3e7e2)
#3  0x00007f5d75ff081b n/a (libQt6Core.so.6 + 0x1f081b)
#4  0x00007f5d77d8ff93 _ZN4KJob6resultEPS_NS_14QPrivateSignalE (libKF6CoreAddons.so.6 + 0x80f93)
#5  0x00007f5d77d9823c n/a (libKF6CoreAddons.so.6 + 0x8923c)
#6  0x00007f5d75ff081b n/a (libQt6Core.so.6 + 0x1f081b)
#7  0x00007f5d78615126 n/a (libKF6KIOCore.so.6 + 0x122126)
#8  0x00007f5d7860e2f3 n/a (libKF6KIOCore.so.6 + 0x11b2f3)
#9  0x00007f5d78614265 n/a (libKF6KIOCore.so.6 + 0x121265)
#10 0x00007f5d75ff081b n/a (libQt6Core.so.6 + 0x1f081b)
#11 0x00007f5d75fe7d46 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1e7d46)
#12 0x00007f5d7710411f _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x10411f)
#13 0x00007f5d75f83658 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x183658)
#14 0x00007f5d75f83a61 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x183a61)
#15 0x00007f5d7629fc98 n/a (libQt6Core.so.6 + 0x49fc98)
#16 0x00007f5d728fec76 n/a (libglib-2.0.so.0 + 0x61c76)
#17 0x00007f5d72900ed7 n/a (libglib-2.0.so.0 + 0x63ed7)
#18 0x00007f5d72901055 g_main_context_iteration (libglib-2.0.so.0 + 0x64055)
#19 0x00007f5d7629d0b2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x49d0b2)
#20 0x00007f5d75f91983 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x191983)
#21 0x00007f5d75f86eaa _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x186eaa)
#22 0x000055aee2221c63 n/a (dolphin + 0x50c63)
#23 0x00007f5d75627781 n/a (libc.so.6 + 0x27781)
#24 0x00007f5d756278b9 __libc_start_main (libc.so.6 + 0x278b9)
#25 0x000055aee2222f05 n/a (dolphin + 0x51f05)
Stack trace of thread 1835:
#0  0x00007f5d756a0952 n/a (libc.so.6 + 0xa0952)
#1  0x00007f5d75711a57 ppoll (libc.so.6 + 0x111a57)
#2  0x00007f5d72900f59 n/a (libglib-2.0.so.0 + 0x63f59)
#3  0x00007f5d72901055 g_main_context_iteration (libglib-2.0.so.0 + 0x64055)
#4  0x00007f5d7629d0b2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x49d0b2)
#5  0x00007f5d75f91983 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x191983)
#6  0x00007f5d760b9342 _ZN7QThread4execEv (libQt6Core.so.6 + 0x2b9342)
#7  0x00007f5d778a57d1 n/a (libQt6DBus.so.6 + 0x397d1)
#8  0x00007f5d761784fb n/a (libQt6Core.so.6 + 0x3784fb)
#9  0x00007f5d756980a2 n/a (libc.so.6 + 0x980a2)
#10 0x00007f5d7572080c n/a (libc.so.6 + 0x12080c)
Stack trace of thread 1838:
#1  0x00007f5d75694cd9 n/a (libc.so.6 + 0x94cd9)
#2  0x00007f5d75697762 pthread_cond_timedwait (libc.so.6 + 0x97762)
#3  0x00007f5d761713a9 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x3713a9)
#4  0x00007f5d760b6e86 n/a (libQt6Core.so.6 + 0x2b6e86)
#5  0x00007f5d761784fb n/a (libQt6Core.so.6 + 0x3784fb)
#6  0x00007f5d756980a2 n/a (libc.so.6 + 0x980a2)
#7  0x00007f5d7572080c n/a (libc.so.6 + 0x12080c)
Stack trace of thread 1839:
Stack trace of thread 1837:
#1  0x00007f5d75711365 __poll (libc.so.6 + 0x111365)
#2  0x00007f5d743556e8 n/a (libQt6WaylandClient.so.6 + 0x706e8)
#3  0x00007f5d761784fb n/a (libQt6Core.so.6 + 0x3784fb)
#4  0x00007f5d756980a2 n/a (libc.so.6 + 0x980a2)
#5  0x00007f5d7572080c n/a (libc.so.6 + 0x12080c)
Stack trace of thread 1836:
#2  0x00007f5d7569754c pthread_cond_wait (libc.so.6 + 0x9754c)
#3  0x00007f5d76171441 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x371441)
#4  0x00007f5d74355687 n/a (libQt6WaylandClient.so.6 + 0x70687)
Stack trace of thread 1842:
#7  0x00007f5d76178595 n/a (libQt6Core.so.6 + 0x378595)
#8  0x00007f5d756980a2 n/a (libc.so.6 + 0x980a2)
#9  0x00007f5d7572080c n/a (libc.so.6 + 0x12080c)
Stack trace of thread 1840:
Stack trace of thread 1875:
#4  0x00007f5d7853196d n/a (libKF6KIOCore.so.6 + 0x3e96d)
#5  0x00007f5d7857bdb2 n/a (libKF6KIOCore.so.6 + 0x88db2)
#6  0x00007f5d78619562 n/a (libKF6KIOCore.so.6 + 0x126562)
#7  0x00007f5d761784fb n/a (libQt6Core.so.6 + 0x3784fb)
Stack trace of thread 1883:
Stack trace of thread 1851:
#2  0x00007f5d756a0860 n/a (libc.so.6 + 0xa0860)
#3  0x00007f5d6400b92a _ZN13IlmThread_3_49Semaphore4waitEv (libIlmThread-3_4.so.33 + 0x492a)
#4  0x00007f5d6400ce4a n/a (libIlmThread-3_4.so.33 + 0x5e4a)
#5  0x00007f5d6400b56c n/a (libIlmThread-3_4.so.33 + 0x456c)
#6  0x00007f5d75aea859 n/a (libstdc++.so.6 + 0xea859)
#7  0x00007f5d756980a2 n/a (libc.so.6 + 0x980a2)
#8  0x00007f5d7572080c n/a (libc.so.6 + 0x12080c)
Stack trace of thread 1849:
Stack trace of thread 1853:
Stack trace of thread 1854:
Stack trace of thread 1841:
Stack trace of thread 1847:
Stack trace of thread 1848:
Stack trace of thread 1852:
23-08-2026 19:50	systemd	app-org.kde.dolphin@f975b9a4cc3d4e268066ccc3169cd4a0.service: Main process exited, code=dumped, status=6/ABRT
23-08-2026 19:50	systemd	app-org.kde.dolphin@f975b9a4cc3d4e268066ccc3169cd4a0.service: Failed with result 'core-dump'.
23-08-2026 19:50	kwin_wayland	QProcess: Destroyed while process ("/usr/lib/kwin_killer_helper") is still running.
23-08-2026 19:50	krunner	Could not create image from "/build/static/img/autoweek.png"
23-08-2026 19:50	kdeconnectd	No uuids found for "8C:83:94:4F:19:55"
23-08-2026 19:50	krunner	Invalid image metadata (width: 0 height: 0 rowStride: 0 )
23-08-2026 19:51	pamac-manager	Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
23-08-2026 19:51	krunner	Error requesting matches; calling "org.kde.runners.baloo"  : "org.freedesktop.DBus.Error.NoReply" "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
23-08-2026 19:51	kernel	CIFS: VFS: Error connecting to socket. Aborting operation.
23-08-2026 19:51	kernel	CIFS: VFS: cifs_mount failed w/return code = -113
23-08-2026 19:51	systemd	home-ninja-Mounts-NAS-NAShome.mount: Failed with result 'exit-code'.
23-08-2026 19:51	systemd	Failed to mount Nassie homemap (/home/ninja/Mounts/Nas/NAShome).
23-08-2026 19:51	systemd	home-ninja-Mounts-NAS-Muziek.mount: Failed with result 'exit-code'.
23-08-2026 19:51	systemd	Failed to mount Nassie Muziekmap (/home/ninja/Mounts/Nas/Muziek).
23-08-2026 19:51	polkit-kde-authentication-agent-1	Listener adapter polkit_qt_listener_initiate_authentication
23-08-2026 19:51	polkit-kde-authentication-agent-1	GSimpleAsyncResult: 0x55b6caf32010
23-08-2026 19:51	polkit-kde-authentication-agent-1	polkit_qt_listener_initiate_authentication callback for  0x55b6caf1c210
23-08-2026 19:51	polkit-kde-authentication-agent-1	Initiating authentication
23-08-2026 19:51	polkit-kde-authentication-agent-1	Action description has been found
23-08-2026 19:51	polkit-kde-authentication-agent-1	qrc:/qml/QuickAuthDialog.qml:57:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 70. Use 'sequences: [ <key> ]' to bind to all of them.
23-08-2026 19:51	polkit-kde-authentication-agent-1	User:  "unix-user:ninja"
23-08-2026 19:51	polkit-kde-authentication-agent-1	Trying again
23-08-2026 19:51	polkit-kde-authentication-agent-1	REQUEST
23-08-2026 19:51	polkit-kde-authentication-agent-1	Request:  "Password: "  echo:  false
23-08-2026 19:51	polkit-kde-authentication-agent-1	Dialog accepted
23-08-2026 19:51	polkit-kde-authentication-agent-1	COMPLETED
23-08-2026 19:51	polkit-kde-authentication-agent-1	Completed:  true
23-08-2026 19:51	polkit-kde-authentication-agent-1	Finishing obtaining privileges
23-08-2026 19:51	polkit-kde-authentication-agent-1	Listener adapter polkit_qt_listener_initiate_authentication_finish
23-08-2026 19:51	polkit-kde-authentication-agent-1	polkit_qt_listener_initiate_authentication_finish callback for  0x55b6caf1c210
23-08-2026 19:51	polkit-kde-authentication-agent-1	Finish obtain authorization: true
23-08-2026 19:51	polkit-kde-authentication-agent-1	Dialog cancelled
23-08-2026 19:51	user@1000.service	Source ID 11 was not found when attempting to remove it
23-08-2026 19:51	kdeconnectd	No uuids found for "8C:83:94:4F:19:55"
23-08-2026 19:52	kernel	CIFS: VFS: Error connecting to socket. Aborting operation.
23-08-2026 19:52	kernel	CIFS: VFS: cifs_mount failed w/return code = -113
23-08-2026 19:52	systemd	home-ninja-Mounts-NAS-NAShome.mount: Failed with result 'exit-code'.
23-08-2026 19:52	systemd	Failed to mount Nassie homemap (/home/ninja/Mounts/Nas/NAShome).
23-08-2026 19:52	systemd	home-ninja-Mounts-NAS-Muziek.mount: Failed with result 'exit-code'.
23-08-2026 19:52	systemd	Failed to mount Nassie Muziekmap (/home/ninja/Mounts/Nas/Muziek).
23-08-2026 19:52	kwin_wayland	Libinput: event7  - ASUE1A01:00 04F3:31D4 Touchpad: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.31.3/touchpad-jumping-cursors.html for details
23-08-2026 19:52	pamac-manager	unable to send notifications through org.freedesktop.Notifications: Tijd is verlopen
23-08-2026 19:52	krunner	Invalid image metadata (width: 0 height: 0 rowStride: 0 )
23-08-2026 19:52	systemsettings	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
23-08-2026 19:53	kernel	CIFS: VFS: Error connecting to socket. Aborting operation.
23-08-2026 19:53	kernel	CIFS: VFS: cifs_mount failed w/return code = -113
23-08-2026 19:53	systemd	home-ninja-Mounts-NAS-Muziek.mount: Failed with result 'exit-code'.
23-08-2026 19:53	systemd	Failed to mount Nassie Muziekmap (/home/ninja/Mounts/Nas/Muziek).
23-08-2026 19:53	systemd	home-ninja-Mounts-NAS-NAShome.mount: Failed with result 'exit-code'.
23-08-2026 19:53	systemd	Failed to mount Nassie homemap (/home/ninja/Mounts/Nas/NAShome).
23-08-2026 19:53	systemsettings	Invalid path data; path truncated.
23-08-2026 19:53	krunner	Error requesting matches; calling "org.kde.runners.baloo"  : "org.freedesktop.DBus.Error.NoReply" "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
Your CIFS mounts are failing, which is why it’s taking so long and causing Dolphin to crash.
kernel CIFS: VFS: cifs_mount failed with return code = -113
And so on…
Fix your mounts, and then the rest should work again.
The problem is not only Dolphin. The whole GUI is buggy, not responsive / freezing a lot, and the system’s menu bar takes up to 15 menu minutes to even show up. I can’t imagine an OS is designed to fail this horribly if one mount doesn’t work. Especially after having worked fine for 2 years already. I do take my laptop to other places, where I will not be able to mount the same things. Those errors have been in my logs forever, but never made my system so buggy I can´t even work on it. So I am trying to find out what it is that makes plasma buggy.
I noticed a whole bunch of these entries, which could be a clue, but I don’t understand them.
23-08-2026 19:47	ksmserver	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found ...."
One thing at a time – please start by restoring or disabling the mounts.
When was the last time you cleared your ~/.cache/ directory?
Try both of these and then reboot.
I cleared the cache prior to this login. The global menubar appeared right away, but not responsive and with missing icons or loading all the time. The time I logged on after that one, was identical to all the problematic ones. So no difference.
Will try to disable the mounts, but these entries in the journal are not new and never influenced the GUI.
This is the only thing that looks odd. Kwin should be below 1%. But this is only a snapshot. I would use top or htop to figure out where the compute time goes.
Not necessarily. It sits at around 6% on my AMD system:
Processes:
  CPU top: 5 of 376
  1: cpu: 14.4% command: firefox pid: 2490 mem: 796.7 MiB (2.7%)
  2: cpu: 6.1% command: kwin_wayland pid: 899 mem: 197.2 MiB (0.6%)
  3: cpu: 4.3% command: plasmashell pid: 1098 mem: 478.8 MiB (1.6%)
It might depend on factors such as wallpapers and widgets. A lot of wallpapers in a slideshow, or multiple widgets could increase the CPU & RAM usage. But I’m not really sure about that.
@womanjar0 could test if it is user or system-related by creating a new user with default settings and seeing if the issue also occurs when logging in as that user.
The OP still has to report with cifs disabled. I wonder if there is a timeout on those mounts, in the settings
Another cause could be the kactivitymanagerd database (located in ~/.local/share/kactivitymanagerd/resources/). It stores the recent file history, and in the past it has slowed down my system after logging in, especially when my system had been up for several days (which doesn’t happen now as I restart my PC every day).
So, clearing the recent file history via System Settings → Security & Privacy → Recent Files could fix the issue. Setting the history storage to a shorter time (such as 1 month) can also keep the kactivitymanagerd database at a manageable size.
An important note though: if you decide to go nuclear and delete the database manually via dolphin, then you will lose other things, such as your launcher favorites. So, deleting the database should only be considered if everything else fails. Clearing the recent file history via System Settings should be tried first.
I think OP has already cleared the cache but nothing changed.
That depends on how you mount it.
It seems like you are using mount units - and that is a great way. But mount units for network shares will fail if the network is up.
There may be other causes as well… but this is the most common cause.
But with network devices you should really create a complementary automount unit.
Then disable the mount unit and enable the automount instead.
Please see → [root tip] [How To] systemd mount unit samples
The kactivitymanagerd database which contains Plasma’s recent files has nothing to do with the ~/.cache/ directory. It is a WAL (write-ahead logging) database stored in ~/.local/share/kactivitymanagerd/resources/:
❯ ls -lAh ~/.local/share/kactivitymanagerd/resources/
total 228M
-rw-r--r-- 1 scotty scotty  44M Aug 24 06:57 database
-rw-r--r-- 1 scotty scotty  32K Aug 24 18:20 database-shm
-rw-r--r-- 1 scotty scotty 185M Aug 24 18:20 database-wal
-rw-r--r-- 1 scotty scotty 1.1K Aug 11 22:56 errors.log
drwxr-xr-x 2 scotty scotty 4.0K Aug 24 17:08 test-backup
drwxr-xr-x 2 scotty scotty 4.0K Aug 24 17:08 working-backup
I still think the system is trying unsuccessfully to connect to the CIFS mounts. During this time, the system is quite laggy, and then it tries to connect to the CIFS mount again, and the whole process starts all over. Until, at some point (after 10 minutes?), it gives up.
