Hello,
When I start my computer, I get an error failed to start service Load Apparmor Profiles. It was working fine till yesterday. When I run sudo aa-status, this is the output:
apparmor module is loaded.
11 profiles are loaded.
11 profiles are in enforce mode.
/usr/lib/lightdm/lightdm-guest-session
/usr/lib/lightdm/lightdm-guest-session//chromium
/usr/lib/snapd/snap-confine
/usr/lib/snapd/snap-confine//mount-namespace-capture-helper
/var/lib/snapd/snap/core/9804/usr/lib/snapd/snap-confine
/var/lib/snapd/snap/core/9804/usr/lib/snapd/snap-confine//mount-namespace-capture-helper
lsb_release
nvidia_modprobe
nvidia_modprobe//kmod
snap-update-ns.core
snap.core.hook.configure
0 profiles are in complain mode.
0 processes have profiles defined.
0 processes are in enforce mode.
0 processes are in complain mode.
0 processes are unconfined but have a profile defined.
if i understand correctly (im a newb) this is down to the version of firejail included in the latest stable update. There is a fix in the version that is currently in testing.
I uninstalled firejail and it worked perfectly. Thanks.
I think you might be right. I also get this error at boot with firejail installed.
The latest stable update 2020 08 28 has version 0.9.62.4-1 which has a fix.
