I have been using LMMS for a few years now and until recently I’ve never had any problems. Now, when the app is started it briefly displays the splash screen after which it crashes. If it is started via terminal it outputs the following error message:
[1] 39104 segmentation fault (core dumped) lmms
That appears a little cryptic to someone with no programming knowledge. I would be much obliged if anyone might lend their time to help me.
Inxi
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8ff3f355-0cc6-47a5-a42d-50e7f9d612a1 rw quiet
udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop Mobo: Micro-Star model: B350M PRO-VDH (MS-7A38) v: 2.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: A.C0
date: 04/24/2018
RAM: total: 15.58 GiB used: 6.62 GiB (42.5%)
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 1677 high: 2049 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2013 2: 1875
3: 1994 4: 2049 5: 1559 6: 1348 7: 1549 8: 1548 9: 1549 10: 1549 11: 1549
12: 1550 bogomips: 81614
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 525.60.11
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 1f:00.0
chip-ID: 10de:1c03 class-ID: 0300
Device-2: WaveRider USB Live camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-10:7 chip-ID: 0c46:64ab
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: N/A display-ID: :1 screens: 1
Screen-1: 0 s-res: 2944x1080 s-dpi: 96 s-size: 779x286mm (30.67x11.26")
s-diag: 830mm (32.67")
Monitor-1: DVI-D-0 pos: primary,top-left res: 1920x1080 hz: 60 dpi: 96
size: 510x290mm (20.08x11.42") diag: 587mm (23.1") modes: N/A
Monitor-2: HDMI-0 pos: bottom-r res: 1024x576 hz: 60 dpi: 144
size: 180x130mm (7.09x5.12") diag: 222mm (8.74") modes: N/A
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: bus-ID: 1-1.4:6 gen: 3 chip-ID: 0d8c:0135 class-ID: 0300 speed: 8 GT/s
lanes: 16 bus-ID: 1f:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 21:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media Q9-1 type: USB driver: hid-generic,snd-usb-audio,usbhid
Device-4: WaveRider USB Live camera type: USB
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.85 TiB used: 2.07 TiB (72.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVPW128HEGM-00000
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: CXZ7300Q temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162
type: HDD rpm: 7200 serial: <filter> rev: CC47 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1SB102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD1 rev: LW00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 73.07 GiB size: 71.37 GiB (97.68%) used: 47.81 GiB (67.0%)
fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 8ff3f355-0cc6-47a5-a42d-50e7f9d612a1
ID-2: /home raw-size: 176.53 GiB size: 172.69 GiB (97.83%)
used: 82.8 GiB (47.9%) fs: ext4 dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: 9bcccc2e-0b04-4787-8df2-eebe869b10ac
ID-3: /mnt/01D65B8863EA07D0 raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 823.44 GiB (88.4%) fs: ntfs dev: /dev/sdb5 maj-min: 8:21 label: Fun
uuid: 01D65B8863EA07D0
ID-4: /mnt/1240B20840B1F299 raw-size: 930.88 GiB size: 930.88 GiB (100.00%)
used: 556.63 GiB (59.8%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Haupt
uuid: 1240B20840B1F299
ID-5: /mnt/2E94400F764BAE09 raw-size: 674.27 GiB size: 674.27 GiB (100.00%)
used: 605.41 GiB (89.8%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: Games
uuid: 2E94400F764BAE09
ID-6: /mnt/4852B448067818F6 raw-size: 7.45 GiB size: 7.45 GiB (100.00%)
used: 3.44 GiB (46.2%) fs: ntfs dev: /dev/sdc4 maj-min: 8:36 label: Portal
uuid: 4852B448067818F6
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 119.24 GiB fs: ntfs label: SSD
uuid: 01E5FDDA27BCE01E
ID-2: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs
label: System-reserviert uuid: 60E8B001E8AFD416
ID-3: /dev/sda3 maj-min: 8:3 size: 545 MiB fs: ntfs label: N/A
uuid: C078DA9578DA8994
ID-4: /dev/sdb1 maj-min: 8:17 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-1.2:4 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: Keyboard,HID,Smart Card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 1050:0407 class-ID: 0b00
Device-2: 1-1.4:6 info: C-Media Q9-1 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0135 class-ID: 0300
Device-3: 1-3:3 info: Super Gate USB KB type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 500mA chip-ID: 05d5:624c class-ID: 0300
Device-4: 1-4:5 info: Razer USA RZ01-0321 Gaming Mouse [DeathAdder V2]
type: Mouse,Keyboard driver: razermouse,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1532:0084 class-ID: 0300
Device-5: 1-10:7 info: WaveRider USB Live camera type: Video,Audio
power: 500mA chip-ID: 0c46:64ab class-ID: 0102 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 35.5 C mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Processes: 416 Uptime: 6h 20m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1846 pm: pacman pkgs: 1785 libs: 506
tools: gnome-software,pamac,yay pm: flatpak pkgs: 58 pm: snap pkgs: 3
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
