I get an Unsupported Format error for literally every model I download for LM Studio. Also, the time stamp of the file is…
After digging around a bit, I realised that the error is related to my filesystem type (f2fs /home). Moving the models cache directory to an ext4 “fixes” the error.
I was hoping someone could shed some light on why this might be happening.
Note: the error does not interfere with the model’s function.
inxi
Kernel: 6.8.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.8-x86_64
root=UUID=48608088-12ef-424f-955a-7adf71aa34f5 rw rootflags=subvol=@ quiet
nvidia_drm.modeset=1 nvidia_drm.fbdev=1 fbcon=nodefer apparmor=1
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
BIOS: American Megatrends v: 5013 date: 03/22/2024
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701033
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2281 high: 3600 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2097 4: 3600 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 115251
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti] vendor: InnoVISION
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 4 speed: 16 GT/s lanes: 8 ports: active: none empty: DP-1,
DP-2, DP-3, HDMI-A-1 bus-ID: 05:00.0 chip-ID: 10de:2803 class-ID: 0300
Device-2: NVIDIA TU104GL [Quadro RTX 4000] driver: nvidia v: 550.67
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none off: DP-5 empty: DP-4,DP-6,Unknown-1
bus-ID: 0b:00.0 chip-ID: 10de:1eb1 class-ID: 0300
Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: DP-5 mapped: DP-3 note: disabled model: BenQ GW2283
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: nvidia device: 4 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia
x11: drv: nvidia inactive: wayland,device-2,device-3
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67 glx-v: 1.4
direct-render: yes renderer: Quadro RTX 4000/PCIe/SSE2 memory: 7.81 GiB
Device-1: NVIDIA vendor: InnoVISION driver: snd_hda_intel v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 05:00.1 chip-ID: 10de:22bd class-ID: 0403
Device-2: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:10f8
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.8.8-2-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp7s0 state: down mac: <filter>
IF-ID-1: br-2fbe7ee7da5a state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: surfshark_ipv6 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-4: surfshark_wg state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-5: veth4f70a80 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:4
chip-ID: 8087:0025 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 3.19 TiB used: 1.39 TiB (43.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: EXCERIA SSD
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFA12.9 temp: 48.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
fw-rev: EDFM20.0 temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 043 scheme: GPT
ID-1: / raw-size: 89.41 GiB size: 89.41 GiB (100.00%) used: 33.81 GiB (37.8%)
fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot raw-size: 954 MiB size: 921.8 MiB (96.63%)
used: 722.4 MiB (78.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /boot/efi raw-size: 244 MiB size: 240.2 MiB (98.46%)
used: 1 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /home raw-size: 826.03 GiB size: 826.03 GiB (100.00%)
used: 621.97 GiB (75.3%) fs: f2fs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-5: /var/log raw-size: 89.41 GiB size: 89.41 GiB (100.00%)
used: 33.81 GiB (37.8%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: partition size: 14.9 GiB used: 3.09 GiB (20.7%)
priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5
System Temperatures: cpu: 55.5 C mobo: N/A gpu: nvidia temp: 50 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 30%
Memory: total: 32 GiB available: 31.25 GiB used: 8.21 GiB (26.3%)
Processes: 547 Power: uptime: 2d 6h 2m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.43 GiB services: gsd-power,
tool: systemctl
Packages: pm: pacman pkgs: 1273 libs: 387 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Zsh
v: 5.9 running-in: code inxi: 3.3.34
