Lm_sensors and Gigabyte B450M S2H
I am trying to get lm_sensors to read my CPU temperature, however the only outputs I get are as follows
amdgpu-pci-0900
Adapter: PCI adapter
vddgfx:      950.00 mV
fan1:         785 RPM  (min =    0 RPM, max = 3200 RPM)
edge:         +38.0°C  (crit = +94.0°C, hyst = -273.1°C)
power1:       39.17 W  (cap = 175.00 W)
acpitz-acpi-0
Adapter: ACPI interface
temp1:        +16.8°C  (crit = +20.8°C)
k10temp-pci-00c3
Tdie:         +32.2°C  (high = +70.0°C)
Tctl:         +32.2°C
As you can see my CPU isn’t showing up. Arch Wiki says that some Gigabyte B450M’s use the ITE 8686E chip, I cannot find anywhere what chip my motherboard has (online or through terminal commands), however attempting to install the it87-dkms-git package returns this:
Unable to install module it87/152.2b8b4fe for kernel 5.4.105-1-MANJARO: Missing kernel headers.
If anyone knows how I can check my motherboards chip or any other ideas, help is appreciated. Thanks.
Turns out I had the wrong headers installed for the kernel I was running.
