Not sure which version started this problem.
Anything newer that 14.0.6-4 and opera browser won’t show graphics.
Anything older than 15.0.6-1 and alacritty won’t start.
I can supply more info if needed.
I assume this is known about and I also assume I just need to wait for an update?
[demo@Manjaro ~]$ inxi -Faaz
Kernel: 6.4.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw loglevel=3 audit=0
nvme_load=yes nvidia-drm.modeset=1 pcie_aspm=force
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.28 date: 07/14/2022
ID-1: BAT0 charge: 63.0 Wh (90.3%) condition: 69.8/69.8 Wh (100.0%)
volts: 12.6 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: not charging cycles: 204
Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF6
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3277 high: 4302 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 4132 2: 4302 3: 4291
4: 4295 5: 2300 6: 2300 7: 2300 8: 2300 bogomips: 36812
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
conditional, RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 3b:00.0 chip-ID: 10de:1d13
class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b67b
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 220 s-size: 443x249mm (17.44x9.80")
s-diag: 508mm (20.01")
Monitor-1: eDP-1 model: AU Optronics 0x30eb built: 2017 res: 3840x2160
hz: 60 dpi: 284 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 3840x2160
API: OpenGL v: N/A renderer: N/A direct-render: N/A
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
API: ALSA v: k6.4.3-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Local Storage: total: 931.51 GiB used: 382.11 GiB (41.0%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 169 GiB size: 166.04 GiB (98.25%) used: 60.37 GiB (36.4%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 499 MiB size: 498 MiB (99.80%)
used: 367.2 MiB (73.7%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 410.57 GiB size: 403.06 GiB (98.17%)
used: 321.38 GiB (79.7%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 50.0 C pch: 45.0 C mobo: N/A
Processes: 281 Uptime: 16m wakeups: 63063 Memory: total: 16 GiB note: est.
available: 15.26 GiB used: 3.48 GiB (22.8%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: N/A
Packages: 1817 pm: pacman pkgs: 1809 libs: 432 tools: pamac,pikaur,yay
pm: rpm pkgs: 0 pm: flatpak pkgs: 8 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.28
