I want to create Live USB of my custom and stable Manjaro as I currently have it, to restore from a support USB drive in case of any problem, I look for the suitable application or procedure.
Here is a video about it, just adapt it for KDE.
And here is the wiki to Build Manjaro ISOs with buildiso - Manjaro
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
