Hello,
I have a dual graphics notebook (Razer Blade 2019) to which I connected an external monitor via HDMI. The HDMI port is directly connected to the RTX 2080 graphics card. A while back I installed Manjaro and both monitors were working fine out of the box with the (default) video-hybrid-intel-nvidia-prime driver. Now at some point in the past few weeks (likely due to an update) the external display must have stopped working. Since I didn’t have the external display connected for at least 3 weeks or so, I can’t tell exactly when it happened. Also, to my knowIedge, I didn’t change anything graphics related since then and the display works as soon as I restart and boot into Windows… so the monitor/cable isn’t broken.
inxi -Gazy:
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Razer USA
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU104M [GeForce RTX 2080 Mobile] vendor: Razer USA
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1e90 class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 13d3:56d5 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell v: 40.3
driver: loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
nvidia-smi:
Wed Aug 18 18:37:43 2021
| NVIDIA-SMI 470.63.01 Driver Version: 470.63.01 CUDA Version: 11.4 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| N/A 46C P8 5W / N/A | 0MiB / 7982MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
xrandr --listproviders:
Providers: number : 0
I’m assuming, the problem has to do with no provider being listed and the graphics card being listed as turned off?
I’d be glad if someone could help. I’d just like things to work again since everything was working fine before.
