Little help with MS Teams
Hello all
I am am having “slight” problem with Microsoft Teams.
So my kids school was inviting me to MS teams group, where I can see some picks, get some updates of the schools projects, etc.
So I got teams from snap (seemed to be the latest version compared to flathub), made an account, and everything seems to work.
However, when I click the link from the email, the teams client “launches” but nothing happens. No groups added, no nothing (I have also experienced this with links for meetings).
Am I missing any configuration?
I am fully aware that this is not MS help forum, but maybe someone here has had similar experience and can point me in the right direction.
I am actually struggling to word this properly into my duckduck (google if duckduck doesn’t find anything) search, so bear with me.
inxi -Fazy
~ >>> inxi -Fazy
  Kernel: 5.9.3-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.9-x86_64
  root=UUID=10a7e7a7-da03-41b9-b65c-942b75a7ad97 rw rootflags=subvol=@ quiet
  udev.log_priority=3
  Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 8478 v: 70.57 serial: <filter> UEFI: Insyde v: F.22
  date: 04/21/2020
  ID-1: BAT1 charge: 33.4 Wh condition: 31.9/52.8 Wh (60%) volts: 12.8/11.6
  model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
  status: Unknown
  Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
  L2 cache: 8192 KiB
  bogomips: 36812
  Speed: 899 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 849 2: 858 3: 859
  4: 890 5: 849 6: 873 7: 856 8: 854
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
  driver: nvidia v: 455.38 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:1c8d
  Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
  Integrated Webcam
  type: USB driver: uvcvideo bus ID: 1-5:5 chip ID: 05c8:03bc
  Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting
  display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.1
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
  bus ID: 00:1f.3 chip ID: 8086:a348
  Sound Server: ALSA v: k5.9.3-1-MANJARO
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
  vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
  port: 4000 bus ID: 02:00.0 chip ID: 10ec:b822
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
  chip ID: 10ec:8168
  Local Storage: total: 1.60 TiB used: 479.27 GiB (29.3%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW256HEHP-000H1
  size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: CXB73H1Q scheme: GPT
  ID-2: /dev/sda type: USB vendor: Western Digital model: WD My Passport 0740
  size: 465.73 GiB block size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1007 scheme: GPT
  ID-3: /dev/sdb type: USB vendor: Toshiba model: External USB 3.0
  size: 931.51 GiB block size: physical: 512 B logical: 512 B serial: <filter>
  rev: 5438 scheme: MBR
  ID-1: / raw size: 237.97 GiB size: 237.97 GiB (100.00%)
  used: 70.09 GiB (29.5%) fs: btrfs dev: /dev/nvme0n1p2
  ID-2: /home raw size: 237.97 GiB size: 237.97 GiB (100.00%)
  System Temperatures: cpu: 55.0 C mobo: 29.8 C
  Processes: 319 Uptime: 4h 32m Memory: 15.53 GiB used: 5.11 GiB (32.9%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1345
  pacman: 1333 lib: 374 flatpak: 4 snap: 8 Shell: Zsh v: 5.8
  running in: konsole inxi: 3.1.08
Found a second Flatpak which I installed and that works. So of the 3 packages I have tried the one marked Microsoft Teams (com.microsoft.Teams) 1.3.00.25560 is working for me.
Just for information, there is also a “teams” AUR package available.
https://aur.archlinux.org/packages/teams/
My pacman hasn’t shown me the AUR packages for teams, only Snap and Flatpak in the “Show all” section. Forgot to check AUR section.
Thank you for the reminder.
But don’t install blindly from AUR, check the info about a package on aur.archlinux.org
Thanks man, I actually didn’t know about this page.
Hi, I m a newbie in manjaro and ı tried to download that package by using the following command : sudo pacman -U https://packages.microsoft.com/repos/ms-teams/pool/main/t/teams/teams_1.3.00.25560_amd64.deb but ı got the error: error: '/var/cache/pacman/pkg/teams_1.3.00.25560_amd64.deb': package missing required signature. Can u help me about it ? :slight_smile:
@garavel
It is not good to download anything from the web. I don’t know how to install from that package. Instead open Add/Remove software and find it there. You might need to go into settings and enable AUR.
To enable AUR open add/remove
Click the three lines to the right and select the second lowest option.
Screenshot_20201107_234214
Enable AUR
Screenshot_20201107_234239
That worked :slight_smile: Thank you!!
