None of my steam games work when i boot using the linux59
kernel, but they work with linux58
Any ideas?
Manjaro-log-helper output
Generated on 2020-11-21 13:18:1605953930
#################### inxi -Fxzc0 ########################
System: Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.20.3 Distro: Manjaro Linux
Machine: Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: X99-PRO/USB 3.1 v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 3902 date: 04/19/2018
CPU: Info: 6-Core model: Intel Core i7-5820K bits: 64 type: MT MCP arch: Haswell rev: 2
L2 cache: 15.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 79194
Speed: 1848 MHz min/max: 1200/3600 MHz Core speeds (MHz): 1: 1848 2: 1772 3: 1199
4: 1200 5: 1682 6: 1386 7: 1199 8: 1199 9: 1751 10: 1475 11: 3080 12: 1558
Graphics: Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ZOTAC driver: nvidia v: 450.80.02
bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: nvidia resolution: 2560x1080~60Hz
OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 450.80.02
direct render: Yes
Audio: Device-1: Intel C610/X99 series HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Device-2: NVIDIA GP102 HDMI Audio vendor: ZOTAC driver: snd_hda_intel v: kernel
bus ID: 01:00.1
Device-3: Elite Silicon USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-1:2
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k port: f000
bus ID: 00:19.0
IF: dmz0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom and subsidiaries BCM4352 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: wl v: kernel port: e000 bus ID: 05:00.0
IF: wlan0 state: dormant mac: <filter>
Drives: Local Storage: total: 5.60 TiB used: 279.66 GiB (4.9%)
ID-1: /dev/sda vendor: Western Digital model: WD40EZRZ-00WN9B0 size: 3.64 TiB
ID-2: /dev/sdb vendor: Western Digital model: WD20EARX-00PASB0 size: 1.82 TiB
ID-3: /dev/sdc vendor: Samsung model: HD160JJ size: 149.05 GiB
Partition: ID-1: / size: 3.64 TiB used: 279.26 GiB (7.5%) fs: btrfs dev: /dev/sda1
ID-2: /home size: 3.64 TiB used: 279.26 GiB (7.5%) fs: btrfs dev: /dev/sda1
Swap: ID-1: swap-1 type: partition size: 63.98 GiB used: 0 KiB (0.0%) dev: /dev/dm-0
ID-2: swap-2 type: zram size: 8.00 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors: System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 41 C
Info: Processes: 318 Uptime: 18m Memory: 31.27 GiB used: 2.46 GiB (7.9%) Init: systemd
Compilers: gcc: 10.2.0 Packages: 1262 Client: KDE Plasma v: 5.20.3 inxi: 3.1.08
