Linux5.19.3 --> Linux6.0-rc2-1 (Experimental) Doesn't launch Plasma DE anymore
I tried Linux 6.0.0rc2-1 (Experimental) today. Before that I was using Linux5.19.3-2
Seems like Linux6 doesn’t launch DE on boot. I am able to Ctrl+Alt+F3 and login, but Plasma is not launching on boot.
I was able to boot normally again by rebooting and holding Shift all the time after LUKS full-disk encryption password unlocked and selecting 5.19 kernel in GRUB GUI.
(don’t mind hostname)
~> sudo inxi -v7azy         ✔
[sudo] password for user:
  Kernel: 5.19.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.19-x86_64
    root=UUID=92e53ba1-2213-4b2c-a10a-76b4ce65fff4 rw rootflags=subvol=@
    mitigations=off noibrs noibpb no_stf_barrier tsx=on quiet
    cryptdevice=UUID=3a22928e-04fb-4262-b6a7-2b8911eac64b:luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
    root=/dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b apparmor=1
  Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
    base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
    serial: <filter> UEFI: American Megatrends v: 4403 date: 04/27/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  RAM: total: 125.71 GiB used: 6.09 GiB (4.8%)
  Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
    note: est.
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 32 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMN128GX4M4Z3200C16 serial: N/A
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 9 5950X socket: AM4 bits: 64 type: MT MCP arch: Zen 3
    gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
    model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2593 high: 4000 min/max: 2200/5980 boost: disabled
    base/boost: 4000/5050 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 4000 2: 4000 3: 2200 4: 2200
    5: 2200 6: 2200 7: 4000 8: 4000 9: 4000 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 4000 17: 2200 18: 2200 19: 2200 20: 2200
    21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200 28: 2200
    29: 2200 30: 2200 31: 2200 32: 4000 bogomips: 256100
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
    PBRSB-eIBRS: Not affected
  Device-1: Conexant Systems CX23887/8 PCIe Broadcast Audio and Video Decoder
    with 3D Comb vendor: Hauppauge works driver: cx23885 v: 0.0.4 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 14f1:8880 class-ID: 0400
  Device-2: Conexant Systems CX23887/8 PCIe Broadcast Audio and Video
    Decoder with 3D Comb vendor: Hauppauge works driver: cx23885 v: 0.0.4
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 14f1:8880
    class-ID: 0400
  Device-3: NVIDIA GA102 [GeForce RTX 3090] vendor: ASUSTeK driver: nvidia
    v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
    (as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.0
    chip-ID: 10de:2204 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
    compositor: kwin_x11 driver: X: loaded: nvidia unloaded: modesetting
    alternate: fbdev,nouveau,nv,vesa gpu: cx23885,cx23885,nvidia
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3000x1920 s-dpi: 80 s-size: 952x609mm (37.48x23.98")
    s-diag: 1130mm (44.49")
  Monitor-1: HDMI-0 pos: top-right res: 1080x1920 hz: 60 dpi: 94
    size: 293x521mm (11.54x20.51") diag: 598mm (23.53") modes: N/A
  Monitor-2: HDMI-1 pos: primary,bottom-l res: 1920x1080 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  OpenGL: renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2 v: 4.6.0 NVIDIA
    515.65.01 direct render: Yes
    bus-ID: 3-1:2 chip-ID: 046d:0ab7 pcie: gen: 1 class-ID: 0300
    speed: 2.5 GT/s serial: <filter> lanes: 1 bus-ID: 07:00.0
    class-ID: 0400
  Device-3: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
    bus-ID: 0e:00.1 chip-ID: 10de:1aef class-ID: 0403
  Device-4: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 10:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-5: Logitech Blue Microphones type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Sound Server-1: ALSA v: k5.19.3-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
  Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2526 class-ID: 0280
  IF: wlp9s0 state: up mac: <filter>
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 0a:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp10s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
    v: 0.8 bus-ID: 3-5:4 chip-ID: 8087:0025 class-ID: e001
  Device-1: luks-3a22928e-04fb-4262-b6a7-2b8911eac64b maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.58 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:6 size: 1.58 TiB
  Local Storage: total: 3.64 TiB used: 671.35 GiB (18.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO Plus
    2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
    temp: 55.9 C scheme: GPT
  SMART: yes health: PASSED on: 16d 6h cycles: 212 read-units: 32,174,846
    [16.4 TB] written-units: 34,888,134 [17.8 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
    model: WDS200T1X0E-00AFY0 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: 614600WD temp: 41.9 C scheme: MBR
  SMART: yes health: PASSED on: 16d 19h cycles: 85 read-units: 3,096,225
    [1.58 TB] written-units: 5,039,670 [2.58 TB]
  ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Sony model: Walkman
    size: 969.8 MiB block-size: physical: 2048 B logical: 2048 B type: N/A
    serial: <filter> rev: 1.00 scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: USB Flash
    Disk size: 3.75 GiB block-size: physical: 512 B logical: 512 B type: SSD
    serial: <filter> rev: 0.00 scheme: MBR
  ID-1: / raw-size: 1.58 TiB size: 1.58 TiB (100.00%) used: 671.35 GiB (41.5%)
    fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-3a22928e-04fb-4262-b6a7-2b8911eac64b label: N/A
    uuid: 92e53ba1-2213-4b2c-a10a-76b4ce65fff4
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 728 KiB
    (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:5
    label: NO_LABEL uuid: 36BA-AA60
  ID-3: /home raw-size: 1.58 TiB size: 1.58 TiB (100.00%) used: 671.35 GiB
    (41.5%) fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
  ID-4: /swap raw-size: 1.58 TiB size: 1.58 TiB (100.00%) used: 671.35 GiB
  ID-5: /var/cache raw-size: 1.58 TiB size: 1.58 TiB (100.00%) used: 671.35
    GiB (41.5%) fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
  ID-6: /var/log raw-size: 1.58 TiB size: 1.58 TiB (100.00%) used: 671.35
  ID-1: /dev/nvme0n1p3 maj-min: 259:7 size: 246.23 GiB fs: ntfs label: windos
    uuid: 72975FC6461C45CF
  ID-2: /dev/nvme1n1p1 maj-min: 259:1 size: 50 MiB fs: ntfs
    label: System Reserved uuid: 4052F49C52F497BC
  ID-3: /dev/nvme1n1p2 maj-min: 259:2 size: 1.82 TiB fs: ntfs label: N/A
    uuid: DCE4F6FAE4F6D5AC
  ID-4: /dev/nvme1n1p3 maj-min: 259:3 size: 509 MiB fs: ntfs label: N/A
    uuid: 169A22179A21F3C1
  ID-5: /dev/sda1 maj-min: 8:1 size: 969.6 MiB fs: vfat label: MP3-FLASH
    uuid: C6EA-C71E
  ID-6: /dev/sdb1 maj-min: 8:17 size: 3.75 GiB fs: vfat label: UBUNTU 21_0
    uuid: 4483-3A16
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 1-3:2 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 1532:005c class-ID: 0300
  Device-2: 1-4:3 info: Logitech Unifying Receiver type: Keyboard,Mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 98mA chip-ID: 046d:c534 class-ID: 0301
  Device-3: 1-5:4 info: Integrated Express Flash Drive type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 480mA
    chip-ID: 048d:1172 class-ID: 0806 serial: <filter>
  Device-4: 1-6:5 info: Frys MEC0003 type: HID driver: hid-generic,usbhid
    interfaces: 1 rev: 1.1 speed: 1.5 Mb/s power: 100mA chip-ID: 0001:0000
    class-ID: 0300
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-1:2 info: Logitech Blue Microphones type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 480 Mb/s power: 100mA chip-ID: 046d:0ab7 class-ID: 0300
    serial: <filter>
  Device-2: 3-2:3 info: Sony Device type: Mass Storage driver: usb-storage
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 054c:02c4
    class-ID: 0805 serial: <filter>
  Device-3: 3-5:4 info: Intel Wireless-AC 9260 Bluetooth Adapter
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0025 class-ID: e001
  Device-4: 3-6:5 info: ASUSTek AURA LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
    chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 49.5 C mobo: 37.0 C gpu: nvidia temp: 50 C
  Fan Speeds (RPM): fan-1: 0 fan-2: 238 fan-3: 319 fan-4: 551 fan-5: 2993
    fan-6: 0 fan-7: 247 gpu: nvidia fan: 0%
  Processes: 528 Uptime: 10m wakeups: 2 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: 1631 pacman: 1539 lib: 384 flatpak: 75 snap: 17 Shell: Zsh (sudo)
  v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.20
~> journalctl /usr/bin/plasmashell
aug. 23 20:46:55 dell-nvme-inspiron7577 plasmashell[1926]: org.kde.plasma.notifications: Trying to replace notification with id 1650 which doesn't exist, creating a new one. This is an application bug!
aug. 23 20:46:55 dell-nvme-inspiron7577 plasmashell[1926]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x560ff847b990) QQmlContext(0x560ff7f969f0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
aug. 23 20:46:55 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
aug. 23 20:46:55 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
aug. 23 20:47:37 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
aug. 23 21:26:20 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
aug. 23 21:26:31 dell-nvme-inspiron7577 plasmashell[1926]: libkcups: Renew-Subscription last error: 0 successful-ok
aug. 23 21:33:10 dell-nvme-inspiron7577 plasmashell[1926]: QXcbClipboard::setMimeData: Cannot set X11 selection owner
aug. 23 21:39:06 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
aug. 23 21:41:15 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
aug. 23 21:41:21 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
aug. 23 21:41:21 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
aug. 23 21:41:21 dell-nvme-inspiron7577 plasmashell[1926]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
aug. 23 21:41:21 dell-nvme-inspiron7577 plasmashell[1926]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
aug. 23 21:41:24 dell-nvme-inspiron7577 plasmashell[1926]: QDBusObjectPath: invalid path ""
aug. 23 21:41:37 dell-nvme-inspiron7577 plasmashell[1926]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x560ff9ebdcf0) QQmlContext(0x560ff7f969f0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
aug. 23 21:41:37 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
aug. 23 21:41:37 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
aug. 23 21:41:51 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
aug. 23 21:57:12 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
aug. 23 21:59:03 dell-nvme-inspiron7577 plasmashell[1926]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 814, resource id: 136317857, major code: 3 (GetWindowAttributes), minor code: 0
aug. 23 21:59:03 dell-nvme-inspiron7577 plasmashell[1926]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 815, resource id: 136317857, major code: 2 (ChangeWindowAttributes), minor code: 0
aug. 23 21:59:35 dell-nvme-inspiron7577 plasmashell[1926]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 951, resource id: 136317982, major code: 2 (ChangeWindowAttributes), minor code: 0
aug. 23 21:59:36 dell-nvme-inspiron7577 plasmashell[1926]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 991, resource id: 136317991, major code: 3 (GetWindowAttributes), minor code: 0
aug. 23 21:59:36 dell-nvme-inspiron7577 plasmashell[1926]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 992, resource id: 136317991, major code: 2 (ChangeWindowAttributes), minor code: 0
aug. 23 21:59:37 dell-nvme-inspiron7577 plasmashell[1926]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1032, resource id: 136318004, major code: 3 (GetWindowAttributes), minor code: 0
aug. 23 21:59:37 dell-nvme-inspiron7577 plasmashell[1926]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1033, resource id: 136318004, major code: 2 (ChangeWindowAttributes), minor code: 0
aug. 23 22:02:17 dell-nvme-inspiron7577 plasmashell[1926]: QXcbClipboard::setMimeData: Cannot set X11 selection owner
aug. 23 22:07:04 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
aug. 23 22:08:42 dell-nvme-inspiron7577 plasmashell[1926]: org.kde.plasma.notifications: Trying to replace notification with id 1701 which doesn't exist, creating a new one. This is an application bug!
aug. 23 22:08:42 dell-nvme-inspiron7577 plasmashell[1926]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x560ffc2ea810) QQmlContext(0x560ff7f969f0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
aug. 23 22:08:42 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
aug. 23 22:08:42 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
aug. 23 22:12:38 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
aug. 23 22:12:38 dell-nvme-inspiron7577 plasmashell[1926]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
aug. 23 22:12:38 dell-nvme-inspiron7577 plasmashell[1926]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
aug. 23 22:12:41 dell-nvme-inspiron7577 plasmashell[1926]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x560ffbfccde0) QQmlContext(0x560ff7f969f0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
aug. 23 22:12:41 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
aug. 23 22:12:41 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
aug. 23 22:13:04 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
aug. 23 22:24:51 dell-nvme-inspiron7577 plasmashell[1926]: libkcups: Renew-Subscription last error: 0 successful-ok
aug. 23 23:01:23 dell-nvme-inspiron7577 plasmashell[1926]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34976, resource id: 136325925, major code: 3 (GetWindowAttributes), minor code: 0
aug. 23 23:01:23 dell-nvme-inspiron7577 plasmashell[1926]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34977, resource id: 136325925, major code: 2 (ChangeWindowAttributes), minor code: 0
aug. 23 23:11:13 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:499:25: Unable to assign [undefined] to bool
aug. 23 23:11:13 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:384:21: Unable to assign [undefined] to bool
aug. 23 23:11:15 dell-nvme-inspiron7577 plasmashell[1926]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
aug. 23 23:11:43 dell-nvme-inspiron7577 plasmashell[1926]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
-- Boot e473eff225cc44cda66bc80fcc92378e --
aug. 23 23:48:53 dell-nvme-inspiron7577 plasmashell[1944]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
aug. 23 23:48:53 dell-nvme-inspiron7577 plasmashell[1944]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
aug. 23 23:48:54 dell-nvme-inspiron7577 plasmashell[1944]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
aug. 23 23:48:54 dell-nvme-inspiron7577 plasmashell[1944]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
aug. 23 23:48:54 dell-nvme-inspiron7577 plasmashell[1944]: kf.plasma.quick: Applet preload policy set to 1
aug. 23 23:48:56 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
aug. 23 23:48:56 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
aug. 23 23:48:56 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
aug. 23 23:48:56 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
aug. 23 23:48:56 dell-nvme-inspiron7577 plasmashell[1944]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
aug. 23 23:48:57 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
aug. 23 23:48:57 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
aug. 23 23:48:57 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
aug. 23 23:48:57 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
aug. 23 23:48:57 dell-nvme-inspiron7577 plasmashell[1944]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
aug. 23 23:48:59 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
aug. 23 23:48:59 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
aug. 23 23:48:59 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
aug. 23 23:48:59 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
aug. 23 23:48:59 dell-nvme-inspiron7577 plasmashell[1944]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
aug. 23 23:48:59 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
aug. 23 23:48:59 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
aug. 23 23:48:59 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: libkcups: CUPS-Get-Printers last error: 0 successful-ok
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: libkcups: Create-Printer-Subscriptions last error: 0 successful-ok
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: libkcups: Get-Jobs last error: 0 successful-ok
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5626975fe150) QQmlContext(0x562697283160) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5626977c65a0) QQmlContext(0x562697283160) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: libkcups: 5 "Brother_DCP-1510_series"
aug. 23 23:49:00 dell-nvme-inspiron7577 plasmashell[1944]: libkcups: 0
aug. 23 23:49:01 dell-nvme-inspiron7577 plasmashell[1944]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
aug. 23 23:49:01 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:50:17: Unable to assign [undefined] to int
aug. 23 23:49:03 dell-nvme-inspiron7577 plasmashell[1944]: libpng warning: iCCP: known incorrect sRGB profile
aug. 23 23:49:03 dell-nvme-inspiron7577 plasmashell[1944]: libpng warning: known incorrect sRGB profile
aug. 23 23:49:03 dell-nvme-inspiron7577 plasmashell[1944]: libpng warning: profile matches sRGB but writing iCCP instead
aug. 23 23:49:16 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
aug. 23 23:49:26 dell-nvme-inspiron7577 plasmashell[1944]: libpng warning: iCCP: known incorrect sRGB profile
aug. 23 23:49:26 dell-nvme-inspiron7577 plasmashell[1944]: libpng warning: known incorrect sRGB profile
aug. 23 23:49:26 dell-nvme-inspiron7577 plasmashell[1944]: libpng warning: profile matches sRGB but writing iCCP instead
aug. 23 23:50:04 dell-nvme-inspiron7577 plasmashell[1944]: kf.sonnet.core: No language dictionaries for the language: "en_US"
aug. 23 23:50:04 dell-nvme-inspiron7577 plasmashell[1944]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
aug. 23 23:50:07 dell-nvme-inspiron7577 plasmashell[1944]: qt.quick.styledtext: StyledText doesn't support entity "#8212"
aug. 23 23:50:07 dell-nvme-inspiron7577 plasmashell[1944]: qt.quick.styledtext: StyledText doesn't support entity "#45"
aug. 23 23:50:07 dell-nvme-inspiron7577 plasmashell[1944]: trying to show an empty dialog
aug. 23 23:50:08 dell-nvme-inspiron7577 plasmashell[1944]: kf.sonnet.core: No language dictionaries for the language: "en_US"
aug. 23 23:55:41 dell-nvme-inspiron7577 plasmashell[1944]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Can this be that Linux6 defaults to launch Wayland Plasma, while Linux5.19 defaults to X11 Plasma ?
Because before this issue I tried wayland Plasma mode before, and it was giving me blackscreens too, that’s why I fallbacked to X11 ever since.
This looks relevant.
You could also check
systemctl status display-manager.service
With Linux6.0-rc2-1 kernel:
~> systemctl status display-manager.service
● sddm.service - Simple Desktop Display Manager
     Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; preset: disabled)
     Active: active (running) since Wed 2022-08-24 00:33:51 EEST; 4min 10s ago
       Docs: man:sddm(1)
             man:sddm.conf(5)
   Main PID: 1248 (sddm)
      Tasks: 2 (limit: 154438)
     Memory: 24.4M
        CPU: 14ms
     CGroup: /system.slice/sddm.service
             └─1248 /usr/bin/sddm
aug. 24 00:33:51 dell-nvme-inspiron7577 systemd[1]: Started Simple Desktop Display Manager.
aug. 24 00:33:51 dell-nvme-inspiron7577 sddm[1248]: Initializing...
aug. 24 00:33:51 dell-nvme-inspiron7577 sddm[1248]: Starting...
aug. 24 00:33:51 dell-nvme-inspiron7577 sddm[1248]: Logind interface found
Seems normal.
There are no Nvidia modules for the 6 kernel yet, don’t understand why you already want to test it …
  1. Current lack of knowledge that I need to track nVidia module version with Linux kernel version.
  2. Wanting to test report on experimental issues early.
  3. Always trying to use the most recent non-rt kernel available through Manjaro Kernels GUI by default, unless something doesn’t work out.
I think we both can agree that, if nVidia modules for linux6 kernel are missing and there is nVidia card which is used for displays, then something somewhere should output this issue into log for the next time. Ideally as TTY text on failed DE boot. Maybe there already is this log ?
To be fair this is like that all the times, some modules are not built with the RC experimental kernels available.
You probably can install the DKMS Nvidia driver I guess?
With the following patch, it is possible to have the nvidia 515 driver compiled against kernel 6.0:
--- a/kernel/nvidia-drm/nvidia-drm-helper.c	2022-08-26 11:42:33.152047728 +0200
+++ b/kernel/nvidia-drm/nvidia-drm-helper.c	2022-08-26 11:42:51.741615701 +0200
@@ -28,7 +28,7 @@
 #include "nvidia-drm-helper.h"
+#include <drm/drm_framebuffer.h>
 #include "nvmisc.h"
 #if defined(NV_DRM_ATOMIC_MODESET_AVAILABLE)
With that patch applied, the DKMS modules for kernel 6.0 install without error, and also appear to be functioning.
I am currently writing this text running kernel 6.0.0-1-MANJARO with Nvidia driver 515.65.01.
Hello,
at first, thanks a lot to the folks who made the Linux kernel 6.0 available in Manjaro Testing.
If you want to test that kernel and have an Nvidia graphics card installed in your machine which uses the proprietary driver 515.65.01, you can do so with the help of Robert Gadson’s solution: http://rglinuxtech.com/?p=3053
In Manjaro, you need the files below, if you are using the DKMS approach to load drivers. Just create them in an empty directory.
  1. PKGBUILD
# Now working with Kernel 6.0
# based on the 340xx package #
# Maintainer: Jerry Xiao <aur@mail.jerryxiao.cc>
# Maintainer: graysky <graysky AT archlinux DOT us>
# Contributor: Giancarlo Razzolini <grazzolini@archlinux.org>
# Contributor: Eric Bélanger <eric@archlinux.org>
pkgbase=nvidia-515xx
pkgname=(nvidia-dkms)
pkgver=515.65.01
pkgrel=4
pkgdesc="NVIDIA drivers for linux, 515xx current branch"
arch=('x86_64')
url="https://www.nvidia.com/"
makedepends=("nvidia-utils" 'linux>=6.0' 'linux-headers>=6.0')
conflicts=('nvidia')
license=('custom')
options=(!strip)
_durl="http://us.download.nvidia.com/XFree86/Linux-x86"
source=("${_durl}_64/${pkgver}/NVIDIA-Linux-${CARCH}-${pkgver}-no-compat32.run"
        "kernel-6.0.patch")
sha256sums=('89e9c22b3903a2360bb18a7f1220dc52234b2cb928bb9dd6690236cf2b024695'
            '8fc3b8eea5e0a566cde2e58d6d4955b7506b50a1754cfb049d118750dca43188')
_pkg="NVIDIA-Linux-${CARCH}-${pkgver}-no-compat32"
prepare() {
    # Remove previous builds
    [ -d "$_pkg" ] && rm -rf "$_pkg"
    sh "${_pkg}.run" --extract-only
    cd "${_pkg}"
    # patches here
    # Fix compile problem with 6.0
    echo "PATCH: kernel-6.0.patch (improved)"
    patch -p1 -i "$srcdir"/kernel-6.0.patch
    cd kernel
    sed -i "s/__VERSION_STRING/${pkgver}/" dkms.conf
    sed -i 's/__JOBS/`nproc`/' dkms.conf
    sed -i 's/__DKMS_MODULES//' dkms.conf
    sed -i '$iBUILT_MODULE_NAME[0]="nvidia"\
DEST_MODULE_LOCATION[0]="/kernel/drivers/video"\
BUILT_MODULE_NAME[1]="nvidia-uvm"\
DEST_MODULE_LOCATION[1]="/kernel/drivers/video"\
BUILT_MODULE_NAME[2]="nvidia-modeset"\
DEST_MODULE_LOCATION[2]="/kernel/drivers/video"\
BUILT_MODULE_NAME[3]="nvidia-drm"\
DEST_MODULE_LOCATION[3]="/kernel/drivers/video"' dkms.conf
    # Gift for linux-rt guys
    sed -i 's/NV_EXCLUDE_BUILD_MODULES/IGNORE_PREEMPT_RT_PRESENCE=1 NV_EXCLUDE_BUILD_MODULES/' dkms.conf
    cd ..
    cp -a kernel kernel-dkms
package_nvidia-dkms() {
    pkgdesc="NVIDIA driver sources for linux, 515xx current branch"
    depends=('dkms' "nvidia-utils=$pkgver" 'libgl' 'linux>=6.0')
    optdepends=('linux-headers: Build the module for Manjaro kernel')
    provides=("nvidia-515xx=$pkgver")
    conflicts+=('nvidia-515xx')
    cd "${_pkg}"
    install -dm 755 "${pkgdir}"/usr/src
    cp -dr --no-preserve='ownership' kernel-dkms "${pkgdir}/usr/src/nvidia-${pkgver}"
    echo "blacklist nouveau" |
        install -Dm644 /dev/stdin "${pkgdir}/usr/lib/modprobe.d/${pkgname}.conf"
# vim:set ts=2 sw=2 et:
  1. kernel-6.0.patch
@@ -28,7 +28,7 @@
 #include "nvmisc.h"
  1. nvidia.install
EXTRAMODULES='extramodules-6.0-MANJARO'
post_install() {
    depmod "$(cat /usr/lib/modules/${EXTRAMODULES}/version)"
    echo 'In order to use the nvidia module, reboot the system.'
post_upgrade() {
    post_install
post_remove() {
    post_install
After that, run the usual makepkg -i command to install that package :wink:
is there any invention for nvidia that make sense using kernel 6.0 or just a game for early adaptors ?
Simply curiosity to check if it works :smiley:
And besides that, the kernels seem to become EOL faster and faster - so I just wanted to take the chance to test the 6.0 kernel before it also becomes EOL :joy:
And for why kernel 6.0? It was announced in some places that it will provide a huge performance increase: Linux 6.0 Supporting New Intel/AMD Hardware, Performance Improvements & Much More - Phoronix - so that made me even more eager to test it :slight_smile:
…then install linux60-nvidia. :wink:
The Nvidia developers are aware of that issue, too: Add missing include to fix 6.0-rc1 build by asuka-mio · Pull Request #350 · NVIDIA/open-gpu-kernel-modules · GitHub
They propose including <drm/drm_framebuffer.h> in nvidia-drm-helper.h instead of nvidia-drm-helper.c to improve its availability:
--- a/kernel/nvidia-drm/nvidia-drm-helper.h	2022-08-26 11:42:33.152047728 +0200
+++ b/kernel/nvidia-drm/nvidia-drm-helper.h	2022-08-26 11:42:51.741615701 +0200
@@ -108,6 +108,7 @@ nv_drm_prime_pages_to_sg(struct drm_device *dev,
 * OTHER DEALINGS IN THE SOFTWARE.
#include <drm/drm_crtc.h>
#if defined(drm_for_each_plane)
#define nv_drm_for_each_plane(plane, dev) \
not good with recent changes about conf include headers :
drm_framebuffer will be included in others components outside Nvidia …
this is not nvidia headers …
I am afraid that I do not understand your point.
Adding #include <drm/drm_framebuffer.h> to kernel/nvidia-drm/nvidia-drm-helper.h was proposed by the Nvidia developers themselves, and I am sure they understand what they are doing :slight_smile:
Update: As expected, the driver compiles and works flawlessly with #include <drm/drm_framebuffer.h> in kernel/nvidia-drm/nvidia-drm-helper.h as per the following patch:
@@ -108,6 +108,7 @@
As for an explanation for those who are interested what is going on:
Per https://github.com/torvalds/linux/commit/720cf96d8fecde29b72e1101f8a567a0ce99594f , #include <drm/drm_framebuffer.h> was removed from <drm/drm_crtc.h> in kernels >= 6.0 because there was no need for that include in <drm/drm_crtc.h> from kernel developer perspective.
Hence, we now have to include it separately in case it is needed (as for our Nvidia driver). Obviously, the best place to add that separate #include <drm/drm_framebuffer.h> is alongside <drm/drm_crtc.h> in kernel/nvidia-drm/nvidia-drm-helper.h.
Is it discouraged to use DKMS with kernels >= 6.0? If yes, can you provide us with some more detail?
At least, DKMS seems to be still supported by kernel 6.0-rc2 and I am able to install and run the patched Nvidia DKMS module on my machine.
You can use nvidia-dkms if it works. It didn’t with rc1 when I tested it.
I was just letting you know linux60-nvidia was available as it wasn’t before.
Unfortunately, there seems to be no page for nvidia-dkms on Manjaro Gitlab so it was not possible to submit the patch (see Linux5.19.3 --> Linux6.0-rc2-1 (Experimental) Doesn't launch Plasma DE anymore - #15 by DAC324 ) to the package maintainer. For Packages / Extra / linux60-extramodules / nvidia · GitLab , there is one so I could propose the patch there.
nvidia-dkms is part of the nvidia-utils split package. I won’t be patching it for 6.0 since it’s still an early release candidate and could cause problems with other kernels.
I understand your point. However, issues with other kernels are unlikely as that patch only would lead to the drm_framebuffer.h header being included twice for them. In kernels < 6.0, the header is included when using drm_crtc.h.
This was removed in the 6.0 kernels so it has to be included separately if needed.
I just tested with 5.15 and 5.19, and for both, the patched module compiles and installs flawlessly.
I’ve added the patch with 515.65.01-3.
