So, i changed my gpu, and it no longer has vga port, so i cant get new monitor atm, i use vga/dvi adapter, and when i tried installing manjaro(and also later tried different distros) it starts installation and goes no signal, works fine woth windows, so i took tv and hdmi cable, and installed manjaro, but when i return to my monitor it goes no signal and shows blackscreen.
Is there anything i can do about that besodes using tv or buying new monitor?
Thank you in advance for helping.
Hello,
First check these things.
- Does the monitor work as pure vga?
- What type of DVI adapter are you using? dvi-d, dvi-i?
- What is the brand of Monitor you have?
- Do you have it connected to the right port on video card
- What settings do you have in bios when it comes to video
- What system do you have? post inxi -Fazy so those helping can see your system specs.
- does the DVI adapter even work?
- Yeah, as i wrote, works in windows, i am currently using it,
- Dvi-D,
3.Acer X223W Q, - Yes i have it connected to right port,
- Wouldnt know, i dont think my motherboard has video settings.
- Windows atm, as linux doesnt work, because of this issue.
- I suppose, since i have monitor connected.
Hope i answered as u needed it.
Motherboard is h61m-p20(G3)
Solved!.
I fixed it by replacing vga to dvi, with vga to hdmi adapter.
