Hi everybody. Linux freezes tightly, REISUB does not work. Written kernel.sysrq=1. REISUB works in normal mode, but does not work when the system freezes. Thank you in advance.
why does your system freezes?
I think it’s because of swap, but I don’t know for sure
inxi --full --verbosity=7 --filter --no-host ✔ 3s
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: X555YI v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X555YI v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X555YI.702 date: 01/30/2019
ID-1: BAT0 charge: 23.9 Wh (100.0%) condition: 23.9/38.0 Wh (62.8%)
volts: 7.5 min: 7.5 model: ASUSTeK X555-50 type: Li-ion serial: N/A
status: not charging cycles: 383
RAM: total: 6.7 GiB used: 1.72 GiB (25.6%)
RAM Report:
Info: quad core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64
type: MCP smt: <unsupported> arch: Puma rev: 1 cache: L1: 256 KiB L2: 2 MiB
Speed (MHz): avg: 1080 high: 1132 min/max: 1000/2200 boost: enabled
cores: 1: 1132 2: 1117 3: 1025 4: 1049 bogomips: 17574
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1
bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
movbe msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae
pat pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge
pni popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall
wdt xsave xsaveopt
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: ASUSTeK
driver: amdgpu v: kernel ports: active: eDP-1 empty: DP-1 bus-ID: 00:01.0
chip-ID: 1002:9851 class-ID: 0300
Device-2: AMD Jet PRO [Radeon R5 M230 / R7 M260DX Radeon 520 Mobile]
vendor: ASUSTeK driver: amdgpu v: kernel pcie: speed: 2.5 GT/s lanes: 4
bus-ID: 01:00.0 chip-ID: 1002:6665 class-ID: 0380
Device-3: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-1.4:4 chip-ID: 04f2:b52b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x15c9 res: 1366x768
hz: 60 dpi: 101 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes:
max: 1366x768 min: 640x480
OpenGL: renderer: AMD KABINI (LLVM 13.0.1 DRM 3.42 5.15.41-1-MANJARO)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: no
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On
driver: rtl8723be v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 02:00.0 chip-ID: 10ec:b723 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: c000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-1.3:3 chip-ID: 0bda:b721 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 16.23 GiB (1.7%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 5J scheme: GPT
ID-1: / size: 661.13 GiB used: 16.23 GiB (2.5%) fs: ext4 dev: /dev/sda3
label: N/A uuid: df029a60-dcfd-4c97-be87-681cf65a4b37
ID-2: /boot/efi size: 511 MiB used: 4.6 MiB (0.9%) fs: vfat
dev: /dev/sda1 label: N/A uuid: 1328-15F3
ID-1: swap-1 type: partition size: 4.88 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 label: N/A uuid: fb2478a5-89e0-4e82-9353-380fc7ec4236
ID-1: /dev/sda2 size: 253.37 GiB fs: ext4 label: N/A
uuid: 7853b4fd-8ab7-4265-a5f1-f075176a9f01
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.3:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s power: 500mA
Device-2: 1-1.4:4 info: Chicony USB2.0 VGA UVC WebCam type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Advanced Micro Devices Root Hub ports: 2 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-2:2 info: [Maxxter] Optical Gaming Mouse [Xtrem]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0301
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
GPU: device: amdgpu temp: 41.0 C device: amdgpu temp: 37.0 C
Processes: 197 Uptime: 1h 44m wakeups: 3 Init: systemd v: 250 Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1086 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.16
dmesg
[ 0.000000] Linux version 5.15.41-1-MANJARO (builduser@fv-az180-185) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Wed May 18 09:20:01 UTC 2022
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=df029a60-dcfd-4c97-be87-681cf65a4b37 rw quiet udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] signal: max sigframe size: 1776
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000008b7a4fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008b7a5000-0x000000008b8c7fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008b8c8000-0x000000008bdc6fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008bdc7000-0x000000008d1a0fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000008d1a1000-0x000000008de2dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008de2e000-0x000000008de94fff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000008de95000-0x000000008e026fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008e027000-0x000000008e03dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008e03e000-0x000000008e066fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008e067000-0x000000008e4bbfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008e4bc000-0x000000008e998fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008e999000-0x000000008eff9fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008effa000-0x000000008effffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb00000-0x00000000feb00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000022effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.40 by American Megatrends
[ 0.000000] efi: ESRT=0x8de2a318 ACPI=0x8be4b000 ACPI 2.0=0x8be4b000 SMBIOS=0xf05b0
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: ASUSTeK COMPUTER INC. X555YI/X555YI, BIOS X555YI.702 01/30/2019
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2195.847 MHz processor
[ 0.001093] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001101] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001114] last_pfn = 0x22f000 max_arch_pfn = 0x400000000
[ 0.001578] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001849] total RAM covered: 2288M
[ 0.002333] Found optimal setting for mtrr clean up
[ 0.002334] gran_size: 64K chunk_size: 32M num_reg: 3 lose cover RAM: 0G
[ 0.002481] e820: update [mem 0x8f000000-0xffffffff] usable ==> reserved
[ 0.002501] last_pfn = 0x8f000 max_arch_pfn = 0x400000000
[ 0.010608] found SMP MP-table at [mem 0x000fd8f0-0x000fd8ff]
[ 0.010635] esrt: Reserving ESRT space from 0x000000008de2a318 to 0x000000008de2a350.
[ 0.010651] Using GB pages for direct mapping
[ 0.011933] Secure boot disabled
[ 0.011935] RAMDISK: [mem 0x36f3d000-0x37795fff]
[ 0.011945] ACPI: Early table checksum verification disabled
[ 0.011951] ACPI: RSDP 0x000000008BE4B000 000024 (v02 _ASUS_)
[ 0.011959] ACPI: XSDT 0x000000008BE4B098 0000AC (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.011972] ACPI: FACP 0x000000008BE58318 00010C (v05 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.011982] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20210730/tbfadt-615)
[ 0.011992] ACPI: DSDT 0x000000008BE4B1D0 00D147 (v02 _ASUS_ Notebook 01072009 INTL 20120913)
[ 0.011999] ACPI: FACS 0x000000008D19EB80 000040
[ 0.012006] ACPI: APIC 0x000000008BE58428 00007E (v03 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.012013] ACPI: FPDT 0x000000008BE584A8 000044 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.012020] ACPI: FIDT 0x000000008BE584F0 00009C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.012027] ACPI: MCFG 0x000000008BE58590 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00010013)
[ 0.012033] ACPI: HPET 0x000000008BE585D0 000038 (v01 _ASUS_ Notebook 01072009 AMI 00000005)
[ 0.012040] ACPI: WDRT 0x000000008BE58608 000047 (v01 _ASUS_ Notebook 01072009 AMI 00000005)
[ 0.012047] ACPI: ECDT 0x000000008BE58650 0000C1 (v01 _ASUS_ Notebook 01072009 AMI. 00000005)
[ 0.012053] ACPI: UEFI 0x000000008BE58718 000042 (v01 00000000 00000000)
[ 0.012060] ACPI: BGRT 0x000000008BE58760 000038 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.012067] ACPI: SSDT 0x000000008BE58798 000CB4 (v01 AMD AGESA 00000001 AMD 00000001)
[ 0.012074] ACPI: SSDT 0x000000008BE59450 0048CE (v02 AMD AGESA 00000002 MSFT 04000000)
[ 0.012081] ACPI: SSDT 0x000000008BE5DD20 0015A5 (v01 AMD CPMCMN 00000001 INTL 20120913)
[ 0.012088] ACPI: SSDT 0x000000008BE5F2C8 000F39 (v01 AMD CPMZPODD 00000001 INTL 20120913)
[ 0.012095] ACPI: SSDT 0x000000008BE60208 00155C (v01 AMD CPMDFIGP 00000001 INTL 20120913)
[ 0.012102] ACPI: SSDT 0x000000008BE61768 00082B (v01 AMD CPMDFDGP 00000001 INTL 20120913)
[ 0.012108] ACPI: MSDM 0x000000008B87CF18 000055 (v03 _ASUS_ Notebook 00000000 ASUS 00000001)
[ 0.012114] ACPI: Reserving FACP table memory at [mem 0x8be58318-0x8be58423]
[ 0.012117] ACPI: Reserving DSDT table memory at [mem 0x8be4b1d0-0x8be58316]
[ 0.012120] ACPI: Reserving FACS table memory at [mem 0x8d19eb80-0x8d19ebbf]
[ 0.012122] ACPI: Reserving APIC table memory at [mem 0x8be58428-0x8be584a5]
[ 0.012125] ACPI: Reserving FPDT table memory at [mem 0x8be584a8-0x8be584eb]
[ 0.012127] ACPI: Reserving FIDT table memory at [mem 0x8be584f0-0x8be5858b]
[ 0.012129] ACPI: Reserving MCFG table memory at [mem 0x8be58590-0x8be585cb]
[ 0.012131] ACPI: Reserving HPET table memory at [mem 0x8be585d0-0x8be58607]
[ 0.012133] ACPI: Reserving WDRT table memory at [mem 0x8be58608-0x8be5864e]
[ 0.012136] ACPI: Reserving ECDT table memory at [mem 0x8be58650-0x8be58710]
[ 0.012138] ACPI: Reserving UEFI table memory at [mem 0x8be58718-0x8be58759]
[ 0.012140] ACPI: Reserving BGRT table memory at [mem 0x8be58760-0x8be58797]
[ 0.012142] ACPI: Reserving SSDT table memory at [mem 0x8be58798-0x8be5944b]
[ 0.012145] ACPI: Reserving SSDT table memory at [mem 0x8be59450-0x8be5dd1d]
[ 0.012147] ACPI: Reserving SSDT table memory at [mem 0x8be5dd20-0x8be5f2c4]
[ 0.012149] ACPI: Reserving SSDT table memory at [mem 0x8be5f2c8-0x8be60200]
[ 0.012152] ACPI: Reserving SSDT table memory at [mem 0x8be60208-0x8be61763]
[ 0.012154] ACPI: Reserving SSDT table memory at [mem 0x8be61768-0x8be61f92]
[ 0.012156] ACPI: Reserving MSDM table memory at [mem 0x8b87cf18-0x8b87cf6c]
[ 0.012226] No NUMA configuration found
[ 0.012228] Faking a node at [mem 0x0000000000000000-0x000000022effffff]
[ 0.012235] NODE_DATA(0) allocated [mem 0x22effc000-0x22effffff]
[ 0.012286] Zone ranges:
[ 0.012288] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.012293] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.012296] Normal [mem 0x0000000100000000-0x000000022effffff]
[ 0.012299] Device empty
[ 0.012302] Movable zone start for each node
[ 0.012303] Early memory node ranges
[ 0.012304] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.012307] node 0: [mem 0x0000000000100000-0x000000008b7a4fff]
[ 0.012310] node 0: [mem 0x000000008b8c8000-0x000000008bdc6fff]
[ 0.012312] node 0: [mem 0x000000008de95000-0x000000008e026fff]
[ 0.012314] node 0: [mem 0x000000008e03e000-0x000000008e066fff]
[ 0.012316] node 0: [mem 0x000000008e4bc000-0x000000008e998fff]
[ 0.012319] node 0: [mem 0x000000008effa000-0x000000008effffff]
[ 0.012321] node 0: [mem 0x0000000100000000-0x000000022effffff]
[ 0.012325] Initmem setup node 0 [mem 0x0000000000001000-0x000000022effffff]
[ 0.012334] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.012387] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.022160] On node 0, zone DMA32: 291 pages in unavailable ranges
[ 0.022398] On node 0, zone DMA32: 8398 pages in unavailable ranges
[ 0.022409] On node 0, zone DMA32: 23 pages in unavailable ranges
[ 0.022462] On node 0, zone DMA32: 1109 pages in unavailable ranges
[ 0.022510] On node 0, zone DMA32: 1633 pages in unavailable ranges
[ 0.044102] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.044224] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.044383] ACPI: PM-Timer IO Port: 0x808
[ 0.044396] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.044410] IOAPIC[0]: apic_id 5, version 33, address 0xfec00000, GSI 0-23
[ 0.044417] IOAPIC[1]: apic_id 6, version 33, address 0xfec01000, GSI 24-55
[ 0.044422] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.044426] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.044433] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.044436] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.044452] e820: update [mem 0x8a5e1000-0x8a5f9fff] usable ==> reserved
[ 0.044473] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.044519] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.044524] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.044528] PM: hibernation: Registered nosave memory: [mem 0x8a5e1000-0x8a5f9fff]
[ 0.044532] PM: hibernation: Registered nosave memory: [mem 0x8b7a5000-0x8b8c7fff]
[ 0.044536] PM: hibernation: Registered nosave memory: [mem 0x8bdc7000-0x8d1a0fff]
[ 0.044538] PM: hibernation: Registered nosave memory: [mem 0x8d1a1000-0x8de2dfff]
[ 0.044540] PM: hibernation: Registered nosave memory: [mem 0x8de2e000-0x8de94fff]
[ 0.044543] PM: hibernation: Registered nosave memory: [mem 0x8e027000-0x8e03dfff]
[ 0.044547] PM: hibernation: Registered nosave memory: [mem 0x8e067000-0x8e4bbfff]
[ 0.044551] PM: hibernation: Registered nosave memory: [mem 0x8e999000-0x8eff9fff]
[ 0.044555] PM: hibernation: Registered nosave memory: [mem 0x8f000000-0xf7ffffff]
[ 0.044557] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.044559] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfeafffff]
[ 0.044560] PM: hibernation: Registered nosave memory: [mem 0xfeb00000-0xfeb00fff]
[ 0.044562] PM: hibernation: Registered nosave memory: [mem 0xfeb01000-0xfebfffff]
[ 0.044564] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec01fff]
[ 0.044565] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[ 0.044567] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.044569] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfecfffff]
[ 0.044570] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.044572] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[ 0.044574] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[ 0.044576] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[ 0.044577] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.044579] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfeffffff]
[ 0.044581] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.044584] [mem 0x8f000000-0xf7ffffff] available for PCI devices
[ 0.044586] Booting paravirtualized kernel on bare hardware
[ 0.044591] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.052012] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.052565] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u524288
[ 0.052590] pcpu-alloc: s212992 r8192 d28672 u524288 alloc=1*2097152
[ 0.052596] pcpu-alloc: [0] 0 1 2 3
[ 0.052648] Built 1 zonelists, mobility grouping on. Total pages: 1786740
[ 0.052651] Policy zone: Normal
[ 0.052654] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=df029a60-dcfd-4c97-be87-681cf65a4b37 rw quiet udev.log_priority=3
[ 0.052761] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
[ 0.055000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.056141] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.056738] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.135331] Memory: 6965076K/7261060K available (14344K kernel code, 2091K rwdata, 10892K rodata, 1864K init, 3844K bss, 295724K reserved, 0K cma-reserved)
[ 0.135348] random: get_random_u64 called from __kmem_cache_create+0x2a/0x500 with crng_init=0
[ 0.135610] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.135634] ftrace: allocating 44423 entries in 174 pages
[ 0.157970] ftrace: allocated 174 pages with 5 groups
[ 0.158203] rcu: Preemptible hierarchical RCU implementation.
[ 0.158205] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.158206] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.158209] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.158211] Trampoline variant of Tasks RCU enabled.
[ 0.158212] Rude variant of Tasks RCU enabled.
[ 0.158213] Tracing variant of Tasks RCU enabled.
[ 0.158214] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.158216] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.167043] NR_IRQS: 20736, nr_irqs: 1000, preallocated irqs: 16
[ 0.167583] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.167744] Console: colour dummy device 80x25
[ 0.167771] printk: console [tty0] enabled
[ 0.167813] ACPI: Core revision 20210730
[ 0.168025] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.168050] APIC: Switch to symmetric I/O mode setup
[ 0.168683] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.184715] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1fa6dfb6b3a, max_idle_ns: 440795237165 ns
[ 0.184724] Calibrating delay loop (skipped), value calculated using timer frequency.. 4393.68 BogoMIPS (lpj=7319490)
[ 0.184729] pid_max: default: 32768 minimum: 301
[ 0.188104] LSM: Security Framework initializing
[ 0.188119] landlock: Up and running.
[ 0.188120] Yama: becoming mindful.
[ 0.188201] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.188237] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.188683] BIOS may not properly restore RDRAND after suspend, hiding RDRAND via CPUID. Use rdrand=force to reenable.
[ 0.188705] LVT offset 1 assigned for vector 0xf9
[ 0.188712] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 4
[ 0.188714] Last level dTLB entries: 4KB 512, 2MB 256, 4MB 128, 1GB 0
[ 0.188724] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.188728] Spectre V2 : Mitigation: Retpolines
[ 0.188730] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.188733] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.195161] Freeing SMP alternatives memory: 36K
[ 0.307602] smpboot: CPU0: AMD A8-7410 APU with AMD Radeon R5 Graphics (family: 0x16, model: 0x30, stepping: 0x1)
[ 0.308054] Performance Events: AMD PMU driver.
[ 0.308054] ... version: 0
[ 0.308054] ... bit width: 48
[ 0.308054] ... generic registers: 4
[ 0.308054] ... value mask: 0000ffffffffffff
[ 0.308054] ... max period: 00007fffffffffff
[ 0.308054] ... fixed-purpose events: 0
[ 0.308054] ... event mask: 000000000000000f
[ 0.308054] rcu: Hierarchical SRCU implementation.
[ 0.308054] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.308054] smp: Bringing up secondary CPUs ...
[ 0.308054] x86: Booting SMP configuration:
[ 0.308054] .... node #0, CPUs: #1 #2 #3
[ 0.313985] smp: Brought up 1 node, 4 CPUs
[ 0.313985] smpboot: Max logical packages: 1
[ 0.313985] smpboot: Total of 4 processors activated (17573.72 BogoMIPS)
[ 0.315608] devtmpfs: initialized
[ 0.315608] x86/mm: Memory block size: 128MB
[ 0.315827] ACPI: PM: Registering ACPI NVS region [mem 0x8bdc7000-0x8d1a0fff] (20815872 bytes)
[ 0.315827] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.315827] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.318114] pinctrl core: initialized pinctrl subsystem
[ 0.318293] PM: RTC time: 10:21:19, date: 2022-06-04
[ 0.318578] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.319012] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.319312] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.319634] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.319685] audit: initializing netlink subsys (disabled)
[ 0.319739] audit: type=2000 audit(1654338079.149:1): state=initialized audit_enabled=0 res=1
[ 0.319739] thermal_sys: Registered thermal governor 'fair_share'
[ 0.319739] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.319739] thermal_sys: Registered thermal governor 'step_wise'
[ 0.319739] thermal_sys: Registered thermal governor 'user_space'
[ 0.319739] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.319739] cpuidle: using governor ladder
[ 0.319739] cpuidle: using governor menu
[ 0.319739] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[ 0.319739] ACPI: bus type PCI registered
[ 0.319739] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.319739] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.319739] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.319739] PCI: Using configuration type 1 for base access
[ 0.323249] Kprobes globally optimized
[ 0.323348] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[ 0.323348] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.323348] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.324984] ACPI: Added _OSI(Module Device)
[ 0.324989] ACPI: Added _OSI(Processor Device)
[ 0.324990] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.324992] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.324994] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.324996] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.324998] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.358659] ACPI: 7 ACPI AML tables successfully acquired and loaded
[ 0.361281] ACPI: EC: EC started
[ 0.361283] ACPI: EC: interrupt blocked
[ 0.362751] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.362754] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.364304] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.372057] ACPI: Interpreter enabled
[ 0.372101] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.372104] ACPI: Using IOAPIC for interrupt routing
[ 0.372181] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.372766] ACPI: Enabled 5 GPEs in block 00 to 1F
[ 0.390042] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.390056] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.390662] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.390666] acpi PNP0A08:00: _OSC: not requesting control; platform does not support [PCIeCapability]
[ 0.390669] acpi PNP0A08:00: _OSC: OS requested [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.390672] acpi PNP0A08:00: _OSC: platform willing to grant []
[ 0.390674] acpi PNP0A08:00: _OSC: platform retains control of PCIe features (AE_SUPPORT)
[ 0.390704] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.391596] PCI host bridge to bus 0000:00
[ 0.391599] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.391603] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.391606] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.391610] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.391613] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.391616] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.391619] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfed3ffff window]
[ 0.391622] pci_bus 0000:00: root bus resource [mem 0xfed45000-0xffffffff window]
[ 0.391625] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.391765] pci 0000:00:00.0: [1022:1566] type 00 class 0x060000
[ 0.392039] pci 0000:00:01.0: [1002:9851] type 00 class 0x030000
[ 0.392054] pci 0000:00:01.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.392065] pci 0000:00:01.0: reg 0x18: [mem 0xf0000000-0xf07fffff 64bit pref]
[ 0.392072] pci 0000:00:01.0: reg 0x20: [io 0xf000-0xf0ff]
[ 0.392079] pci 0000:00:01.0: reg 0x24: [mem 0xfea00000-0xfea3ffff]
[ 0.392086] pci 0000:00:01.0: reg 0x30: [mem 0xfea40000-0xfea5ffff pref]
[ 0.392094] pci 0000:00:01.0: enabling Extended Tags
[ 0.392108] pci 0000:00:01.0: BAR 0: assigned to efifb
[ 0.392114] pci 0000:00:01.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.392147] pci 0000:00:01.0: supports D1 D2
[ 0.392149] pci 0000:00:01.0: PME# supported from D1 D2 D3hot
[ 0.392340] pci 0000:00:01.1: [1002:9840] type 00 class 0x040300
[ 0.392354] pci 0000:00:01.1: reg 0x10: [mem 0xfea64000-0xfea67fff 64bit]
[ 0.392381] pci 0000:00:01.1: enabling Extended Tags
[ 0.392415] pci 0000:00:01.1: supports D1 D2
[ 0.392601] pci 0000:00:02.0: [1022:156b] type 00 class 0x060000
[ 0.392857] pci 0000:00:02.1: [1022:1439] type 01 class 0x060400
[ 0.392890] pci 0000:00:02.1: enabling Extended Tags
[ 0.392931] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[ 0.393171] pci 0000:00:02.2: [1022:1439] type 01 class 0x060400
[ 0.393203] pci 0000:00:02.2: enabling Extended Tags
[ 0.393245] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[ 0.393481] pci 0000:00:02.3: [1022:1439] type 01 class 0x060400
[ 0.393514] pci 0000:00:02.3: enabling Extended Tags
[ 0.393554] pci 0000:00:02.3: PME# supported from D0 D3hot D3cold
[ 0.393738] pci 0000:00:08.0: [1022:1537] type 00 class 0x108000
[ 0.393750] pci 0000:00:08.0: reg 0x10: [mem 0xf0800000-0xf081ffff 64bit pref]
[ 0.393757] pci 0000:00:08.0: reg 0x18: [mem 0xfe600000-0xfe6fffff]
[ 0.393763] pci 0000:00:08.0: reg 0x1c: [mem 0xfea6f000-0xfea6ffff]
[ 0.393772] pci 0000:00:08.0: reg 0x24: [mem 0xfea6a000-0xfea6bfff]
[ 0.394055] pci 0000:00:10.0: [1022:7814] type 00 class 0x0c0330
[ 0.394076] pci 0000:00:10.0: reg 0x10: [mem 0xfea68000-0xfea69fff 64bit]
[ 0.394172] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
[ 0.394417] pci 0000:00:11.0: [1022:7801] type 00 class 0x010601
[ 0.394431] pci 0000:00:11.0: reg 0x10: [io 0xf140-0xf147]
[ 0.394440] pci 0000:00:11.0: reg 0x14: [io 0xf130-0xf133]
[ 0.394449] pci 0000:00:11.0: reg 0x18: [io 0xf120-0xf127]
[ 0.394459] pci 0000:00:11.0: reg 0x1c: [io 0xf110-0xf113]
[ 0.394469] pci 0000:00:11.0: reg 0x20: [io 0xf100-0xf10f]
[ 0.394477] pci 0000:00:11.0: reg 0x24: [mem 0xfea6e000-0xfea6e3ff]
[ 0.394519] pci 0000:00:11.0: PME# supported from D3hot
[ 0.395439] pci 0000:00:12.0: [1022:7808] type 00 class 0x0c0320
[ 0.395453] pci 0000:00:12.0: reg 0x10: [mem 0xfea6d000-0xfea6d0ff]
[ 0.395518] pci 0000:00:12.0: supports D1 D2
[ 0.395521] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.395749] pci 0000:00:13.0: [1022:7808] type 00 class 0x0c0320
[ 0.395764] pci 0000:00:13.0: reg 0x10: [mem 0xfea6c000-0xfea6c0ff]
[ 0.395828] pci 0000:00:13.0: supports D1 D2
[ 0.395831] pci 0000:00:13.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.396051] pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
[ 0.396318] pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
[ 0.396336] pci 0000:00:14.2: reg 0x10: [mem 0xfea60000-0xfea63fff 64bit]
[ 0.396391] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.396609] pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
[ 0.396827] pci 0000:00:18.0: [1022:1580] type 00 class 0x060000
[ 0.397022] pci 0000:00:18.1: [1022:1581] type 00 class 0x060000
[ 0.397206] pci 0000:00:18.2: [1022:1582] type 00 class 0x060000
[ 0.397391] pci 0000:00:18.3: [1022:1583] type 00 class 0x060000
[ 0.397579] pci 0000:00:18.4: [1022:1584] type 00 class 0x060000
[ 0.397771] pci 0000:00:18.5: [1022:1585] type 00 class 0x060000
[ 0.398060] pci 0000:01:00.0: [1002:6665] type 00 class 0x038000
[ 0.398081] pci 0000:01:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.398095] pci 0000:01:00.0: reg 0x18: [mem 0xfe900000-0xfe93ffff 64bit]
[ 0.398104] pci 0000:01:00.0: reg 0x20: [io 0xe000-0xe0ff]
[ 0.398118] pci 0000:01:00.0: reg 0x30: [mem 0xfe940000-0xfe95ffff pref]
[ 0.398129] pci 0000:01:00.0: enabling Extended Tags
[ 0.398199] pci 0000:01:00.0: supports D1 D2
[ 0.398202] pci 0000:01:00.0: PME# supported from D1 D2 D3hot
[ 0.398247] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:02.1 (capable of 63.008 Gb/s with 8.0 GT/s PCIe x8 link)
[ 0.398375] pci 0000:00:02.1: PCI bridge to [bus 01]
[ 0.398382] pci 0000:00:02.1: bridge window [io 0xe000-0xefff]
[ 0.398386] pci 0000:00:02.1: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.398392] pci 0000:00:02.1: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.398464] pci 0000:02:00.0: [10ec:b723] type 00 class 0x028000
[ 0.398485] pci 0000:02:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.398509] pci 0000:02:00.0: reg 0x18: [mem 0xfe800000-0xfe803fff 64bit]
[ 0.398625] pci 0000:02:00.0: supports D1 D2
[ 0.398627] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.398768] pci 0000:00:02.2: PCI bridge to [bus 02]
[ 0.398774] pci 0000:00:02.2: bridge window [io 0xd000-0xdfff]
[ 0.398778] pci 0000:00:02.2: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.398900] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.398924] pci 0000:03:00.0: reg 0x10: [io 0xc000-0xc0ff]
[ 0.398953] pci 0000:03:00.0: reg 0x18: [mem 0xfe704000-0xfe704fff 64bit]
[ 0.398974] pci 0000:03:00.0: reg 0x20: [mem 0xfe700000-0xfe703fff 64bit]
[ 0.399093] pci 0000:03:00.0: supports D1 D2
[ 0.399096] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.399327] pci 0000:00:02.3: PCI bridge to [bus 03]
[ 0.399333] pci 0000:00:02.3: bridge window [io 0xc000-0xcfff]
[ 0.399337] pci 0000:00:02.3: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.401890] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[ 0.402033] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.402205] ACPI: PCI: Interrupt link LNKC configured for IRQ 4
[ 0.402377] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[ 0.402518] ACPI: PCI: Interrupt link LNKE configured for IRQ 10
[ 0.402638] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.402757] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.402876] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.403503] ACPI: EC: interrupt unblocked
[ 0.403505] ACPI: EC: event unblocked
[ 0.403510] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.403512] ACPI: EC: GPE=0x3
[ 0.403515] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot ECDT EC initialization complete
[ 0.403519] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.403649] iommu: Default domain type: Translated
[ 0.403652] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.403681] pci 0000:00:01.0: vgaarb: setting as boot VGA device
[ 0.403681] pci 0000:00:01.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.403681] pci 0000:00:01.0: vgaarb: bridge control possible
[ 0.403681] vgaarb: loaded
[ 0.403681] SCSI subsystem initialized
[ 0.403681] libata version 3.00 loaded.
[ 0.403681] ACPI: bus type USB registered
[ 0.403681] usbcore: registered new interface driver usbfs
[ 0.403681] usbcore: registered new interface driver hub
[ 0.403681] usbcore: registered new device driver usb
[ 0.403681] pps_core: LinuxPPS API ver. 1 registered
[ 0.403681] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.403681] PTP clock support registered
[ 0.403681] EDAC MC: Ver: 3.0.0
[ 0.404769] Registered efivars operations
[ 0.404994] NetLabel: Initializing
[ 0.404996] NetLabel: domain hash size = 128
[ 0.404997] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.405024] NetLabel: unlabeled traffic allowed by default
[ 0.405031] PCI: Using ACPI for IRQ routing
[ 0.406483] PCI: pci_cache_line_size set to 64 bytes
[ 0.406541] e820: reserve RAM buffer [mem 0x8a5e1000-0x8bffffff]
[ 0.406545] e820: reserve RAM buffer [mem 0x8b7a5000-0x8bffffff]
[ 0.406547] e820: reserve RAM buffer [mem 0x8bdc7000-0x8bffffff]
[ 0.406550] e820: reserve RAM buffer [mem 0x8e027000-0x8fffffff]
[ 0.406552] e820: reserve RAM buffer [mem 0x8e067000-0x8fffffff]
[ 0.406555] e820: reserve RAM buffer [mem 0x8e999000-0x8fffffff]
[ 0.406557] e820: reserve RAM buffer [mem 0x8f000000-0x8fffffff]
[ 0.406559] e820: reserve RAM buffer [mem 0x22f000000-0x22fffffff]
[ 0.406568] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.406568] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.409248] clocksource: Switched to clocksource tsc-early
[ 0.425751] VFS: Disk quotas dquot_6.6.0
[ 0.425788] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.425950] pnp: PnP ACPI init
[ 0.426260] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.426412] system 00:01: [mem 0x90000000-0xcfffffff] has been reserved
[ 0.427431] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.427436] system 00:05: [io 0x040b] has been reserved
[ 0.427439] system 00:05: [io 0x04d6] has been reserved
[ 0.427442] system 00:05: [io 0x0c00-0x0c01] has been reserved
[ 0.427446] system 00:05: [io 0x0c14] has been reserved
[ 0.427449] system 00:05: [io 0x0c50-0x0c51] has been reserved
[ 0.427452] system 00:05: [io 0x0c52] has been reserved
[ 0.427455] system 00:05: [io 0x0c6c] has been reserved
[ 0.427458] system 00:05: [io 0x0c6f] has been reserved
[ 0.427461] system 00:05: [io 0x0cd0-0x0cd1] has been reserved
[ 0.427464] system 00:05: [io 0x0cd2-0x0cd3] has been reserved
[ 0.427467] system 00:05: [io 0x0cd4-0x0cd5] has been reserved
[ 0.427470] system 00:05: [io 0x0cd6-0x0cd7] has been reserved
[ 0.427472] system 00:05: [io 0x0cd8-0x0cdf] has been reserved
[ 0.427475] system 00:05: [io 0x0800-0x089f] has been reserved
[ 0.427478] system 00:05: [io 0x0900-0x090f] has been reserved
[ 0.427481] system 00:05: [io 0x0910-0x091f] has been reserved
[ 0.427484] system 00:05: [io 0xfe00-0xfefe] has been reserved
[ 0.427488] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.427493] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.427497] system 00:05: [mem 0xfed80000-0xfed8ffff] has been reserved
[ 0.427502] system 00:05: [mem 0xfed61000-0xfed70fff] has been reserved
[ 0.427510] system 00:05: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.427514] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.429519] pnp: PnP ACPI: found 6 devices
[ 0.436926] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.437035] NET: Registered PF_INET protocol family
[ 0.437314] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.439209] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.439525] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.439961] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.440126] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.440325] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.440411] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.440475] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.440573] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.440585] NET: Registered PF_XDP protocol family
[ 0.440614] pci 0000:00:02.1: PCI bridge to [bus 01]
[ 0.440622] pci 0000:00:02.1: bridge window [io 0xe000-0xefff]
[ 0.440628] pci 0000:00:02.1: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.440633] pci 0000:00:02.1: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.440639] pci 0000:00:02.2: PCI bridge to [bus 02]
[ 0.440643] pci 0000:00:02.2: bridge window [io 0xd000-0xdfff]
[ 0.440648] pci 0000:00:02.2: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.440655] pci 0000:00:02.3: PCI bridge to [bus 03]
[ 0.440658] pci 0000:00:02.3: bridge window [io 0xc000-0xcfff]
[ 0.440663] pci 0000:00:02.3: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.440674] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.440678] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.440681] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.440684] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.440687] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.440690] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.440693] pci_bus 0000:00: resource 10 [mem 0xd0000000-0xfed3ffff window]
[ 0.440696] pci_bus 0000:00: resource 11 [mem 0xfed45000-0xffffffff window]
[ 0.440699] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.440702] pci_bus 0000:01: resource 1 [mem 0xfe900000-0xfe9fffff]
[ 0.440705] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.440708] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.440710] pci_bus 0000:02: resource 1 [mem 0xfe800000-0xfe8fffff]
[ 0.440714] pci_bus 0000:03: resource 0 [io 0xc000-0xcfff]
[ 0.440716] pci_bus 0000:03: resource 1 [mem 0xfe700000-0xfe7fffff]
[ 0.440944] pci 0000:00:01.1: D0 power state depends on 0000:00:01.0
[ 0.456418] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x750 took 14713 usecs
[ 0.456436] pci 0000:00:12.0: PME# does not work under D3, disabling it
[ 0.473636] pci 0000:00:13.0: quirk_usb_early_handoff+0x0/0x750 took 16783 usecs
[ 0.473654] pci 0000:00:13.0: PME# does not work under D3, disabling it
[ 0.473699] PCI: CLS 0 bytes, default 64
[ 0.473722] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.473724] software IO TLB: mapped [mem 0x0000000084b1a000-0x0000000088b1a000] (64MB)
[ 0.473796] LVT offset 0 assigned for vector 0x400
[ 0.473882] Trying to unpack rootfs image as initramfs...
[ 0.473963] perf: AMD IBS detected (0x000000ff)
[ 0.475062] Initialise system trusted keyrings
[ 0.475081] Key type blacklist registered
[ 0.475210] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ 0.477276] zbud: loaded
[ 0.496962] Key type asymmetric registered
[ 0.496971] Asymmetric key parser 'x509' registered
[ 0.497048] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.497125] io scheduler mq-deadline registered
[ 0.497128] io scheduler kyber registered
[ 0.497200] io scheduler bfq registered
[ 0.498285] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.498554] ACPI: AC: AC Adapter [AC0] (on-line)
[ 0.498641] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.498682] ACPI: button: Power Button [PWRB]
[ 0.498746] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.498772] ACPI: button: Lid Switch [LID]
[ 0.498819] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.500107] ACPI: button: Sleep Button [SLPB]
[ 0.500164] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.502827] ACPI: button: Power Button [PWRF]
[ 0.502908] ACPI: \_PR_.P000: Found 2 idle states
[ 0.503056] ACPI: \_PR_.P001: Found 2 idle states
[ 0.503182] ACPI: \_PR_.P002: Found 2 idle states
[ 0.503303] ACPI: \_PR_.P003: Found 2 idle states
[ 0.505419] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.505423] ACPI: thermal: Thermal Zone [THRM] (56 C)
[ 0.505737] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.508635] Non-volatile memory driver v1.3
[ 0.508638] Linux agpgart interface v0.103
[ 0.508640] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.509855] ahci 0000:00:11.0: version 3.0
[ 0.510148] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 0.510154] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[ 0.518620] scsi host0: ahci
[ 0.518887] scsi host1: ahci
[ 0.518951] ata1: SATA max UDMA/133 abar m1024@0xfea6e000 port 0xfea6e100 irq 30
[ 0.518957] ata2: SATA max UDMA/133 abar m1024@0xfea6e000 port 0xfea6e180 irq 30
[ 0.519089] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.519114] ehci-pci: EHCI PCI platform driver
[ 0.519331] ehci-pci 0000:00:12.0: EHCI Host Controller
[ 0.519343] ehci-pci 0000:00:12.0: new USB bus registered, assigned bus number 1
[ 0.519351] ehci-pci 0000:00:12.0: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.519360] ehci-pci 0000:00:12.0: debug port 2
[ 0.519422] ehci-pci 0000:00:12.0: irq 18, io mem 0xfea6d000
[ 0.535506] ehci-pci 0000:00:12.0: USB 2.0 started, EHCI 1.00
[ 0.535643] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.535648] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.535651] usb usb1: Product: EHCI Host Controller
[ 0.535654] usb usb1: Manufacturer: Linux 5.15.41-1-MANJARO ehci_hcd
[ 0.535657] usb usb1: SerialNumber: 0000:00:12.0
[ 0.536107] hub 1-0:1.0: USB hub found
[ 0.536123] hub 1-0:1.0: 2 ports detected
[ 0.536642] ehci-pci 0000:00:13.0: EHCI Host Controller
[ 0.536655] ehci-pci 0000:00:13.0: new USB bus registered, assigned bus number 2
[ 0.536662] ehci-pci 0000:00:13.0: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.536671] ehci-pci 0000:00:13.0: debug port 2
[ 0.536719] ehci-pci 0000:00:13.0: irq 18, io mem 0xfea6c000
[ 0.547729] ACPI: battery: Slot [BAT0] (battery present)
[ 0.552186] ehci-pci 0000:00:13.0: USB 2.0 started, EHCI 1.00
[ 0.552299] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.552305] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.552308] usb usb2: Product: EHCI Host Controller
[ 0.552311] usb usb2: Manufacturer: Linux 5.15.41-1-MANJARO ehci_hcd
[ 0.552313] usb usb2: SerialNumber: 0000:00:13.0
[ 0.552524] hub 2-0:1.0: USB hub found
[ 0.552539] hub 2-0:1.0: 2 ports detected
[ 0.552891] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.552897] ohci-pci: OHCI PCI platform driver
[ 0.552916] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.553000] usbcore: registered new interface driver usbserial_generic
[ 0.553009] usbserial: USB Serial support registered for generic
[ 0.553240] rtc_cmos 00:02: RTC can wake from S4
[ 0.553485] rtc_cmos 00:02: registered as rtc0
[ 0.553508] rtc_cmos 00:02: setting system clock to 2022-06-04T10:21:19 UTC (1654338079)
[ 0.553539] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.553693] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.553865] efifb: probing for efifb
[ 0.553888] efifb: showing boot graphics
[ 0.555053] efifb: framebuffer at 0xd0000000, using 4224k, total 4224k
[ 0.555056] efifb: mode is 1366x768x32, linelength=5632, pages=1
[ 0.555059] efifb: scrolling: redraw
[ 0.555060] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.555148] fbcon: Deferring console take-over
[ 0.555150] fb0: EFI VGA frame buffer device
[ 0.555192] hid: raw HID events driver (C) Jiri Kosina
[ 0.555328] ashmem: initialized
[ 0.555454] drop_monitor: Initializing network drop monitor service
[ 0.555568] Initializing XFRM netlink socket
[ 0.555718] NET: Registered PF_INET6 protocol family
[ 0.655693] Freeing initrd memory: 8548K
[ 0.665104] Segment Routing with IPv6
[ 0.665113] RPL Segment Routing with IPv6
[ 0.665144] In-situ OAM (IOAM) with IPv6
[ 0.665186] NET: Registered PF_PACKET protocol family
[ 0.665262] x86/pm: family 0x16 cpu detected, MSR saving is needed during suspending.
[ 0.665657] microcode: CPU0: patch_level=0x07030105
[ 0.665669] microcode: CPU1: patch_level=0x07030105
[ 0.665680] microcode: CPU2: patch_level=0x07030105
[ 0.665692] microcode: CPU3: patch_level=0x07030105
[ 0.665698] microcode: Microcode Update Driver: v2.2.
[ 0.665705] IPI shorthand broadcast: enabled
[ 0.665734] sched_clock: Marking stable (664949510, 587840)->(684002871, -18465521)
[ 0.666011] registered taskstats version 1
[ 0.666199] Loading compiled-in X.509 certificates
[ 0.672637] Loaded X.509 cert 'Build time autogenerated kernel key: 44e1c42abf17943da1f3658949e0d628601db193'
[ 0.675089] zswap: loaded using pool zstd/z3fold
[ 0.675658] Key type ._fscrypt registered
[ 0.675660] Key type .fscrypt registered
[ 0.675662] Key type fscrypt-provisioning registered
[ 0.676227] PM: Magic number: 10:182:375
[ 0.676325] acpi LNXVIDEO:01: hash matches
[ 0.676571] RAS: Correctable Errors collector initialized.
[ 0.785953] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.803543] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 0.839003] ata2: SATA link down (SStatus 0 SControl 300)
[ 0.933157] usb 1-1: New USB device found, idVendor=0438, idProduct=7900, bcdDevice= 0.18
[ 0.933167] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.933571] hub 1-1:1.0: USB hub found
[ 0.933649] hub 1-1:1.0: 4 ports detected
[ 0.950579] usb 2-1: New USB device found, idVendor=0438, idProduct=7900, bcdDevice= 0.18
[ 0.950590] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.950862] hub 2-1:1.0: USB hub found
[ 0.950945] hub 2-1:1.0: 2 ports detected
[ 0.999581] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.046664] ata1.00: ATA-8: TOSHIBA MQ01ABD100, AX0R5J, max UDMA/100
[ 1.046993] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.048788] ata1.00: configured for UDMA/100
[ 1.049091] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MQ01ABD1 5J PQ: 0 ANSI: 5
[ 1.049532] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.049536] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.049564] sd 0:0:0:0: [sda] Write Protect is off
[ 1.049569] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.049617] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.191594] sda: sda1 sda2 sda3 sda4
[ 1.218266] usb 1-1.3: new full-speed USB device number 3 using ehci-pci
[ 1.221811] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.223948] Freeing unused decrypted memory: 2036K
[ 1.224769] Freeing unused kernel image (initmem) memory: 1864K
[ 1.224781] Write protecting the kernel read-only data: 28672k
[ 1.225849] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.226434] Freeing unused kernel image (rodata/data gap) memory: 1396K
[ 1.235497] random: fast init done
[ 1.288665] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.288673] rodata_test: all tests were successful
[ 1.288683] Run /init as init process
[ 1.288686] with arguments:
[ 1.288689] /init
[ 1.288690] with environment:
[ 1.288692] HOME=/
[ 1.288693] TERM=linux
[ 1.288694] BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
[ 1.333977] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=b721, bcdDevice= 2.00
[ 1.333987] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.333990] usb 1-1.3: Product: Bluetooth Radio
[ 1.333993] usb 1-1.3: Manufacturer: Realtek
[ 1.333996] usb 1-1.3: SerialNumber: 00e04c000001
[ 1.411467] usb 1-1.4: new high-speed USB device number 4 using ehci-pci
[ 1.498088] tsc: Refined TSC clocksource calibration: 2195.881 MHz
[ 1.498103] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fa6ffc1640, max_idle_ns: 440795239502 ns
[ 1.498135] clocksource: Switched to clocksource tsc
[ 1.504663] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.504681] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 3
[ 1.504868] xhci_hcd 0000:00:10.0: hcc params 0x014040c3 hci version 0x100 quirks 0x0000000000000410
[ 1.505310] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.505317] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.505321] usb usb3: Product: xHCI Host Controller
[ 1.505324] usb usb3: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 1.505327] usb usb3: SerialNumber: 0000:00:10.0
[ 1.505580] hub 3-0:1.0: USB hub found
[ 1.505603] hub 3-0:1.0: 2 ports detected
[ 1.505872] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.505880] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 4
[ 1.505886] xhci_hcd 0000:00:10.0: Host supports USB 3.0 SuperSpeed
[ 1.514583] i8042: PNP: PS/2 Controller [PNP030b:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.516744] i8042: Detected active multiplexing controller, rev 1.1
[ 1.518621] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.518737] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.518789] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.518804] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.518809] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.518849] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.520317] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.520325] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.520329] usb usb4: Product: xHCI Host Controller
[ 1.520332] usb usb4: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 1.520336] usb usb4: SerialNumber: 0000:00:10.0
[ 1.520809] hub 4-0:1.0: USB hub found
[ 1.521527] hub 4-0:1.0: 2 ports detected
[ 1.534081] usb 1-1.4: New USB device found, idVendor=04f2, idProduct=b52b, bcdDevice=95.52
[ 1.534092] usb 1-1.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.534095] usb 1-1.4: Product: USB2.0 VGA UVC WebCam
[ 1.534099] usb 1-1.4: Manufacturer: Chicony Electronics Co.,Ltd.
[ 1.534102] usb 1-1.4: SerialNumber: 0x0001
[ 1.606006] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 1.758098] usb 3-2: new low-speed USB device number 2 using xhci_hcd
[ 1.930357] usb 3-2: New USB device found, idVendor=18f8, idProduct=0f97, bcdDevice= 1.00
[ 1.930368] usb 3-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.930371] usb 3-2: Product: USB OPTICAL MOUSE
[ 1.960997] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:10.0/usb3/3-2/3-2:1.0/0003:18F8:0F97.0001/input/input9
[ 1.961199] hid-generic 0003:18F8:0F97.0001: input,hidraw0: USB HID v1.10 Mouse [USB OPTICAL MOUSE ] on usb-0000:00:10.0-2/input0
[ 1.981255] input: USB OPTICAL MOUSE Keyboard as /devices/pci0000:00/0000:00:10.0/usb3/3-2/3-2:1.1/0003:18F8:0F97.0002/input/input10
[ 2.035158] hid-generic 0003:18F8:0F97.0002: input,hiddev96,hidraw1: USB HID v1.10 Keyboard [USB OPTICAL MOUSE ] on usb-0000:00:10.0-2/input1
[ 2.035235] usbcore: registered new interface driver usbhid
[ 2.035238] usbhid: USB HID core driver
[ 2.391252] fbcon: Taking over console
[ 2.391558] Console: switching to colour frame buffer device 170x48
[ 5.398721] random: crng init done
[ 24.079878] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 28.307218] systemd[1]: systemd 250.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 28.321774] systemd[1]: Detected architecture x86-64.
[ 28.350113] systemd[1]: Hostname set to <simon-x555yi>.
[ 30.333073] systemd[1]: Queued start job for default target Graphical Interface.
[ 30.335033] systemd[1]: Created slice Slice /system/getty.
[ 30.335611] systemd[1]: Created slice Slice /system/modprobe.
[ 30.336103] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 30.336452] systemd[1]: Created slice User and Session Slice.
[ 30.336568] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 30.336654] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 30.336923] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 30.336996] systemd[1]: Reached target Local Encrypted Volumes.
[ 30.337028] systemd[1]: Reached target Login Prompts.
[ 30.337060] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 30.337102] systemd[1]: Reached target Path Units.
[ 30.337136] systemd[1]: Reached target Remote File Systems.
[ 30.337164] systemd[1]: Reached target Slice Units.
[ 30.337213] systemd[1]: Reached target Local Verity Protected Volumes.
[ 30.337340] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 30.352095] systemd[1]: Listening on LVM2 poll daemon socket.
[ 30.354423] systemd[1]: Listening on Process Core Dump Socket.
[ 30.354675] systemd[1]: Listening on Journal Audit Socket.
[ 30.354913] systemd[1]: Listening on Journal Socket (/dev/log).
[ 30.355108] systemd[1]: Listening on Journal Socket.
[ 30.355437] systemd[1]: Listening on udev Control Socket.
[ 30.355587] systemd[1]: Listening on udev Kernel Socket.
[ 30.357202] systemd[1]: Mounting Huge Pages File System...
[ 30.358759] systemd[1]: Mounting POSIX Message Queue File System...
[ 30.360279] systemd[1]: Mounting Kernel Debug File System...
[ 30.361792] systemd[1]: Mounting Kernel Trace File System...
[ 30.363791] systemd[1]: Starting Create List of Static Device Nodes...
[ 30.365493] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 30.367419] systemd[1]: Starting Load Kernel Module configfs...
[ 30.369240] systemd[1]: Starting Load Kernel Module drm...
[ 30.371233] systemd[1]: Starting Load Kernel Module fuse...
[ 30.371470] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 30.493153] systemd[1]: Starting Load Kernel Modules...
[ 30.494745] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 30.494924] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 30.496547] systemd[1]: Starting Coldplug All udev Devices...
[ 30.499689] systemd[1]: Mounted Huge Pages File System.
[ 30.499864] systemd[1]: Mounted POSIX Message Queue File System.
[ 30.499997] systemd[1]: Mounted Kernel Debug File System.
[ 30.500127] systemd[1]: Mounted Kernel Trace File System.
[ 30.500476] systemd[1]: Finished Create List of Static Device Nodes.
[ 30.501008] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 30.501229] systemd[1]: Finished Load Kernel Module configfs.
[ 30.501647] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 30.501848] systemd[1]: Finished Load Kernel Module drm.
[ 30.503399] systemd[1]: Mounting Kernel Configuration File System...
[ 30.506499] systemd[1]: Mounted Kernel Configuration File System.
[ 30.514884] EXT4-fs (sda3): re-mounted. Opts: (null). Quota mode: none.
[ 30.516692] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 30.516979] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 30.676165] fuse: init (API version 7.34)
[ 30.820980] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 30.822655] systemd[1]: Starting Load/Save Random Seed...
[ 30.822783] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 30.824344] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 30.825347] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 30.825620] systemd[1]: Finished Load Kernel Module fuse.
[ 30.826117] systemd[1]: Finished Load Kernel Modules.
[ 30.829013] systemd[1]: Mounting FUSE Control File System...
[ 30.830830] systemd[1]: Starting Apply Kernel Variables...
[ 30.897302] systemd[1]: Mounted FUSE Control File System.
[ 30.931650] systemd[1]: Finished Coldplug All udev Devices.
[ 31.046336] systemd[1]: Finished Apply Kernel Variables.
[ 31.397680] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 31.517696] systemd[1]: Finished Load/Save Random Seed.
[ 31.517917] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 31.700379] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 31.700571] systemd[1]: Reached target Preparation for Local File Systems.
[ 31.700639] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[ 31.700674] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[ 31.703391] systemd[1]: Starting Journal Service...
[ 31.706028] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 31.880585] systemd[1]: Started Journal Service.
[ 31.880771] audit: type=1130 audit(1654338110.821:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.923944] systemd-journald[244]: Received client request to flush runtime journal.
[ 32.089547] systemd-journald[244]: File /var/log/journal/0484a992e03a41888032c25fc0707575/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 33.022134] audit: type=1130 audit(1654338111.964:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.427539] acpi_cpufreq: overriding BIOS provided _PSD data
[ 33.463120] input: Asus Wireless Radio Control as /devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input12
[ 33.760274] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 33.760895] acpi device:02: registered as cooling_device4
[ 33.761021] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input13
[ 33.761345] ACPI: video: Video Device [VGA1] (multi-head: yes rom: no post: no)
[ 33.774203] ACPI BIOS Error (bug): Could not resolve symbol [^^^PB2.VGA.AFN7], AE_NOT_FOUND (20210730/psargs-330)
[ 33.774224] ACPI Error: Aborting method \_SB.PCI0.VGA.LCDD._BCM due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[ 33.774240] ACPI: \_SB_.PCI0.VGA_.LCDD: _BCM evaluation failed
[ 33.774406] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input14
[ 33.850832] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\SBSM) (20210730/utaddress-204)
[ 33.850851] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 34.164751] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 34.164972] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 34.165228] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 34.395521] ccp 0000:00:08.0: 4 command queues available
[ 34.395887] input: PC Speaker as /devices/platform/pcspkr/input/input15
[ 34.414988] ccp 0000:00:08.0: ccp enabled
[ 34.472255] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 34.472884] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 34.483907] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 34.492299] r8169 0000:03:00.0 eth0: RTL8168gu/8111gu, 2c:4d:54:26:97:2a, XID 509, IRQ 39
[ 34.492313] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 34.599239] [drm] radeon kernel modesetting enabled.
[ 34.599282] vga_switcheroo: detected switching method \_SB_.PCI0.VGA_.ATPX handle
[ 34.600289] ATPX version 1, functions 0x00000003
[ 34.600502] radeon 0000:00:01.0: CIK support disabled by module param
[ 34.600594] radeon 0000:01:00.0: SI support disabled by module param
[ 34.648114] cryptd: max_cpu_qlen set to 1000
[ 34.725155] Bluetooth: Core ver 2.22
[ 34.725210] NET: Registered PF_BLUETOOTH protocol family
[ 34.725213] Bluetooth: HCI device and connection manager initialized
[ 34.725222] Bluetooth: HCI socket layer initialized
[ 34.725226] Bluetooth: L2CAP socket layer initialized
[ 34.725235] Bluetooth: SCO socket layer initialized
[ 34.913693] AVX version of gcm_enc/dec engaged.
[ 34.913736] AES CTR mode by8 optimization enabled
[ 34.964047] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
[ 35.024676] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input20
[ 35.045909] psmouse serio4: elantech: assuming hardware version 4 (with firmware version 0x381f00)
[ 35.061145] psmouse serio4: elantech: Synaptics capabilities query result 0x10, 0x14, 0x0e.
[ 35.077740] psmouse serio4: elantech: Elan sample query result 00, 23, 64
[ 35.121830] usbcore: registered new interface driver btusb
[ 35.123285] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 35.124264] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 35.124269] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 35.160784] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio4/input/input19
[ 35.185823] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 35.185959] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 35.185996] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 35.240019] mousedev: PS/2 mouse device common for all mice
[ 35.339625] snd_hda_codec_conexant hdaudioC1D0: CX20751/2: BIOS auto-probing.
[ 35.345068] snd_hda_codec_conexant hdaudioC1D0: autoconfig for CX20751/2: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 35.345083] snd_hda_codec_conexant hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 35.345087] snd_hda_codec_conexant hdaudioC1D0: hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
[ 35.345092] snd_hda_codec_conexant hdaudioC1D0: mono: mono_out=0x0
[ 35.345094] snd_hda_codec_conexant hdaudioC1D0: inputs:
[ 35.345097] snd_hda_codec_conexant hdaudioC1D0: Internal Mic=0x1a
[ 35.345100] snd_hda_codec_conexant hdaudioC1D0: Mic=0x19
[ 35.349106] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input21
[ 35.349222] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:14.2/sound/card1/input22
[ 35.365456] mc: Linux media interface: v0.10
[ 35.503729] videodev: Linux video capture interface: v2.00
[ 35.627197] rtl8723be 0000:02:00.0: enabling device (0000 -> 0003)
[ 35.641743] rtl8723be: Using firmware rtlwifi/rtl8723befw_36.bin
[ 35.652927] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 35.654279] rtlwifi: rtlwifi: wireless switch is on
[ 35.688656] kvm: Nested Virtualization enabled
[ 35.688663] SVM: kvm: Nested Paging enabled
[ 35.752930] MCE: In-kernel MCE decoding enabled.
[ 35.836477] asus_wmi: ASUS WMI generic driver loaded
[ 35.878206] asus_wmi: Initialization: 0x1
[ 35.878350] asus_wmi: BIOS WMI version: 7.9
[ 35.878476] asus_wmi: SFUN value: 0xa0077
[ 35.878482] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 35.878486] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[ 35.890768] usb 1-1.4: Found UVC 1.00 device USB2.0 VGA UVC WebCam (04f2:b52b)
[ 35.890860] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input23
[ 35.896606] input: USB2.0 VGA UVC WebCam: USB2.0 V as /devices/pci0000:00/0000:00:12.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input24
[ 35.896835] usbcore: registered new interface driver uvcvideo
[ 36.016119] r8169 0000:03:00.0 enp3s0: renamed from eth0
[ 36.029141] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 36.225150] [drm] amdgpu kernel modesetting enabled.
[ 36.225195] vga_switcheroo: detected switching method \_SB_.PCI0.VGA_.ATPX handle
[ 36.226275] ATPX version 1, functions 0x00000003
[ 36.251651] amdgpu: CRAT table not found
[ 36.251663] amdgpu: Virtual CRAT table created for CPU
[ 36.251688] amdgpu: Topology: Add CPU node
[ 36.251790] checking generic (d0000000 420000) vs hw (d0000000 10000000)
[ 36.251796] checking generic (d0000000 420000) vs hw (d0000000 10000000)
[ 36.251799] fb0: switching to amdgpu from EFI VGA
[ 36.251955] Console: switching to colour dummy device 80x25
[ 36.252047] amdgpu 0000:00:01.0: vgaarb: deactivate vga console
[ 36.252347] [drm] initializing kernel modesetting (MULLINS 0x1002:0x9851 0x1043:0x1B9D 0x45).
[ 36.252356] amdgpu 0000:00:01.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 36.252443] [drm] register mmio base: 0xFEA00000
[ 36.252446] [drm] register mmio size: 262144
[ 36.252453] [drm] add ip block number 0 <cik_common>
[ 36.252456] [drm] add ip block number 1 <gmc_v7_0>
[ 36.252457] [drm] add ip block number 2 <cik_ih>
[ 36.252459] [drm] add ip block number 3 <gfx_v7_0>
[ 36.252461] [drm] add ip block number 4 <cik_sdma>
[ 36.252463] [drm] add ip block number 5 <kv_dpm>
[ 36.252465] [drm] add ip block number 6 <dm>
[ 36.252467] [drm] add ip block number 7 <uvd_v4_2>
[ 36.252469] [drm] add ip block number 8 <vce_v2_0>
[ 36.252474] kfd kfd: amdgpu: MULLINS not supported in kfd
[ 36.275202] rtl8723be 0000:02:00.0 wlp2s0: renamed from wlan0
[ 36.286060] [drm] BIOS signature incorrect 0 0
[ 36.286140] amdgpu 0000:00:01.0: amdgpu: Fetched VBIOS from ROM BAR
[ 36.286147] amdgpu: ATOM BIOS: 113-C69300-101
[ 36.286227] [drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[ 36.286236] amdgpu 0000:00:01.0: amdgpu: VRAM: 1024M 0x000000F400000000 - 0x000000F43FFFFFFF (1024M used)
[ 36.286241] amdgpu 0000:00:01.0: amdgpu: GART: 1024M 0x000000FF00000000 - 0x000000FF3FFFFFFF
[ 36.286250] [drm] Detected VRAM RAM=1024M, BAR=1024M
[ 36.286252] [drm] RAM width 64bits UNKNOWN
[ 36.286356] [drm] amdgpu: 1024M of VRAM memory ready
[ 36.286360] [drm] amdgpu: 3072M of GTT memory ready.
[ 36.286375] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 36.286412] [drm] PCIE GART of 1024M enabled (table at 0x000000F400401000).
[ 36.543323] [drm] Internal thermal controller without fan control
[ 36.543334] [drm] amdgpu: dpm initialized
[ 36.591362] [drm] Found UVD firmware Version: 1.64 Family ID: 9
[ 36.614139] [drm] Found VCE firmware Version: 50.10 Binary ID: 2
[ 36.627079] [drm] Display Core initialized with v3.2.149!
[ 36.645239] snd_hda_intel 0000:00:01.1: bound 0000:00:01.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 36.670085] audit: type=1130 audit(1654338115.611:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.738081] [drm] UVD initialized successfully.
[ 36.754368] Adding 5119996k swap on /dev/sda4. Priority:-2 extents:1 across:5119996k FS
[ 36.849157] [drm] VCE initialized successfully.
[ 36.849179] amdgpu 0000:00:01.0: amdgpu: SE 1, SH per SE 1, CU per SH 2, active_cu_number 2
[ 36.850651] [drm] fb mappable at 0x907ED000
[ 36.850659] [drm] vram apper at 0x90000000
[ 36.850663] [drm] size 4325376
[ 36.850667] [drm] fb depth is 24
[ 36.850670] [drm] pitch is 5632
[ 36.850823] fbcon: amdgpudrmfb (fb0) is primary device
[ 37.595196] Console: switching to colour frame buffer device 170x48
[ 37.619955] amdgpu 0000:00:01.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 37.636792] [drm] Initialized amdgpu 3.42.0 20150101 for 0000:00:01.0 on minor 0
[ 37.637059] [drm] Display Core has been requested via kernel parameter but isn't supported by ASIC, ignoring
[ 37.637125] amdgpu 0000:01:00.0: enabling device (0000 -> 0003)
[ 37.637373] [drm] initializing kernel modesetting (HAINAN 0x1002:0x6665 0x1043:0x226D 0x83).
[ 37.637382] amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 37.637533] [drm] register mmio base: 0xFE900000
[ 37.637539] [drm] register mmio size: 262144
[ 37.637546] [drm] PCIE atomic ops is not supported
[ 37.637558] [drm] add ip block number 0 <si_common>
[ 37.637563] [drm] add ip block number 1 <gmc_v6_0>
[ 37.637567] [drm] add ip block number 2 <si_ih>
[ 37.637571] [drm] add ip block number 3 <gfx_v6_0>
[ 37.637575] [drm] add ip block number 4 <si_dma>
[ 37.637579] [drm] add ip block number 5 <si_dpm>
[ 37.637589] kfd kfd: amdgpu: HAINAN not supported in kfd
[ 37.829272] amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ATRM
[ 37.829283] amdgpu: ATOM BIOS: BR45747.001
[ 37.829310] [drm] GPU posting now...
[ 37.845669] [drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[ 37.894777] amdgpu 0000:01:00.0: amdgpu: VRAM: 2048M 0x000000F400000000 - 0x000000F47FFFFFFF (2048M used)
[ 37.894792] amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
[ 37.894815] [drm] Detected VRAM RAM=2048M, BAR=256M
[ 37.894819] [drm] RAM width 64bits DDR3
[ 37.894872] [drm] amdgpu: 2048M of VRAM memory ready
[ 37.894877] [drm] amdgpu: 3072M of GTT memory ready.
[ 37.894891] [drm] GART: num cpu pages 65536, num gpu pages 65536
[ 37.895496] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 37.971066] [drm] Internal thermal controller without fan control
[ 37.971104] [drm] amdgpu: dpm initialized
[ 38.280747] amdgpu 0000:01:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 5, active_cu_number 5
[ 38.636008] audit: type=1130 audit(1654338117.577:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-1328\x2d15F3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.867196] amdgpu 0000:01:00.0: amdgpu: Using ATPX for runtime pm
[ 38.867452] [drm] Initialized amdgpu 3.42.0 20150101 for 0000:01:00.0 on minor 1
[ 39.120901] audit: type=1130 audit(1654338118.061:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:acpi_video0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 39.187940] audit: type=1130 audit(1654338118.127:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.320642] audit: type=1130 audit(1654338119.261:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.630780] audit: type=1130 audit(1654338119.571:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.655400] audit: type=1127 audit(1654338119.597:10): pid=390 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 40.702185] audit: type=1130 audit(1654338119.644:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.747672] audit: type=1130 audit(1654338119.687:12): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.757588] audit: type=1334 audit(1654338119.697:13): prog-id=9 op=LOAD
[ 40.757866] audit: type=1334 audit(1654338119.697:14): prog-id=10 op=LOAD
[ 42.865737] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 42.865751] Bluetooth: BNEP filters: protocol multicast
[ 42.865765] Bluetooth: BNEP socket layer initialized
[ 42.905661] NET: Registered PF_ALG protocol family
[ 45.338784] kauditd_printk_skb: 12 callbacks suppressed
[ 45.338796] audit: type=1130 audit(1654338124.281:27): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.387716] audit: type=1130 audit(1654338124.327:28): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.391706] audit: type=1130 audit(1654338124.334:29): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 46.797711] audit: type=1130 audit(1654338125.737:30): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-swap comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 47.137858] audit: type=1130 audit(1654338126.077:31): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 47.191455] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 47.371492] r8169 0000:03:00.0 enp3s0: Link is Down
[ 48.901161] audit: type=1130 audit(1654338127.841:32): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 48.927528] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 49.247633] audit: type=1130 audit(1654338128.187:33): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 49.839587] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 49.839791] r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control off
[ 49.871725] NET: Registered PF_QIPCRTR protocol family
[ 49.876488] audit: type=1130 audit(1654338128.814:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 54.393770] audit: type=1334 audit(1654338133.334:35): prog-id=16 op=LOAD
[ 54.393794] audit: type=1300 audit(1654338133.334:35): arch=c000003e syscall=321 success=yes exit=28 a0=5 a1=7ffdc34d0c40 a2=90 a3=54 items=0 ppid=1 pid=408 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
[ 54.393810] audit: type=1327 audit(1654338133.334:35): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
[ 57.161082] audit: type=1131 audit(1654338136.101:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.747016] audit: type=1130 audit(1654338136.687:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 59.959441] audit: type=1100 audit(1654338138.901:38): pid=540 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 59.959544] audit: type=1101 audit(1654338138.901:39): pid=540 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 59.983376] audit: type=1103 audit(1654338138.927:40): pid=540 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 60.077369] audit: type=1130 audit(1654338139.017:41): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.185591] audit: type=1101 audit(1654338139.127:42): pid=542 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.185750] audit: type=1103 audit(1654338139.127:43): pid=542 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 60.185977] audit: type=1006 audit(1654338139.127:44): pid=542 uid=0 old-auid=4294967295 auid=966 tty=(none) old-ses=4294967295 ses=1 res=1
[ 60.186029] audit: type=1300 audit(1654338139.127:44): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffcaeacd3e0 a2=3 a3=7ffcaeacd0f5 items=0 ppid=1 pid=542 auid=966 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
[ 60.186047] audit: type=1327 audit(1654338139.127:44): proctitle="(systemd)"
[ 60.240844] audit: type=1105 audit(1654338139.184:45): pid=542 uid=0 auid=966 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 67.760098] kauditd_printk_skb: 6 callbacks suppressed
[ 67.760106] audit: type=1131 audit(1654338146.701:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 70.843777] audit: type=1130 audit(1654338149.784:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 70.892765] audit: type=1334 audit(1654338149.834:52): prog-id=18 op=LOAD
[ 70.892829] audit: type=1334 audit(1654338149.834:53): prog-id=19 op=LOAD
[ 71.572805] audit: type=1130 audit(1654338150.514:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 75.566927] audit: type=1131 audit(1654338154.507:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 75.646344] audit: type=1334 audit(1654338154.591:56): prog-id=0 op=UNLOAD
[ 75.646363] audit: type=1334 audit(1654338154.591:57): prog-id=0 op=UNLOAD
[ 75.646373] audit: type=1334 audit(1654338154.591:58): prog-id=0 op=UNLOAD
[ 176.399869] audit: type=1100 audit(1654338255.341:59): pid=590 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="simon" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 176.400619] audit: type=1101 audit(1654338255.341:60): pid=590 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="simon" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 176.401811] audit: type=1103 audit(1654338255.344:61): pid=590 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="simon" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 176.402093] audit: type=1006 audit(1654338255.344:62): pid=590 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 176.402107] audit: type=1300 audit(1654338255.344:62): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffcc4fadbc0 a2=4 a3=7ffcc4fad8d4 items=0 ppid=456 pid=590 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
[ 176.402119] audit: type=1327 audit(1654338255.344:62): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746833383633636636612D333664342D346535392D616238322D653134653339303537653561002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[ 176.444760] audit: type=1130 audit(1654338255.387:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 176.456787] audit: type=1101 audit(1654338255.397:64): pid=592 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="simon" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 176.456872] audit: type=1103 audit(1654338255.397:65): pid=592 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="simon" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 176.456961] audit: type=1006 audit(1654338255.397:66): pid=592 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 188.090436] kauditd_printk_skb: 11 callbacks suppressed
[ 188.090444] audit: type=1131 audit(1654338267.031:74): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 188.120894] audit: type=1131 audit(1654338267.061:75): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 191.853370] audit: type=1130 audit(1654338270.794:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 195.994356] Bluetooth: RFCOMM TTY layer initialized
[ 195.994381] Bluetooth: RFCOMM socket layer initialized
[ 195.994391] Bluetooth: RFCOMM ver 1.11
[ 205.046660] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 206.010747] audit: type=1111 audit(1654338284.951:77): pid=408 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics interface="enp3s0" ifindex=2 args=500 pid=858 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 206.039890] audit: type=1111 audit(1654338284.981:78): pid=408 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics interface="wlp2s0" ifindex=3 args=500 pid=858 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 206.047403] audit: type=1334 audit(1654338284.987:79): prog-id=21 op=LOAD
[ 206.047608] audit: type=1334 audit(1654338284.987:80): prog-id=22 op=LOAD
[ 206.047683] audit: type=1334 audit(1654338284.987:81): prog-id=23 op=LOAD
[ 206.157567] audit: type=1130 audit(1654338285.097:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 206.225326] audit: type=1111 audit(1654338285.167:83): pid=408 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics interface="wlp2s0" ifindex=3 args=500 pid=858 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 236.192649] audit: type=1131 audit(1654338315.134:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 236.261615] audit: type=1334 audit(1654338315.204:85): prog-id=0 op=UNLOAD
[ 236.261636] audit: type=1334 audit(1654338315.204:86): prog-id=0 op=UNLOAD
[ 236.261646] audit: type=1334 audit(1654338315.204:87): prog-id=0 op=UNLOAD
[ 518.837245] audit: type=1130 audit(1654338597.777:88): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 519.296391] r8169 0000:03:00.0 enp3s0: Link is Down
[ 519.308059] audit: type=1334 audit(1654338598.251:89): prog-id=0 op=UNLOAD
[ 519.773744] PM: suspend entry (deep)
[ 521.732539] Filesystems sync: 1.958 seconds
[ 521.866745] Freezing user space processes ... (elapsed 0.003 seconds) done.
[ 521.869915] OOM killer disabled.
[ 521.869918] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 521.871610] printk: Suspending console(s) (use no_console_suspend to debug)
[ 521.904721] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 521.941118] sd 0:0:0:0: [sda] Stopping disk
[ 522.156969] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 524.052735] ACPI: EC: interrupt blocked
[ 524.052738] amdgpu 0000:01:00.0: amdgpu: PCI CONFIG reset
[ 524.084981] ACPI: PM: Preparing to enter system sleep state S3
[ 524.411184] ACPI: EC: event blocked
[ 524.411191] ACPI: EC: EC stopped
[ 524.411192] ACPI: PM: Saving platform NVS memory
[ 524.411765] Disabling non-boot CPUs ...
[ 524.413778] smpboot: CPU 1 is now offline
[ 524.416771] smpboot: CPU 2 is now offline
[ 524.420003] smpboot: CPU 3 is now offline
[ 524.421486] ACPI: PM: Low-level resume complete
[ 524.421537] ACPI: EC: EC started
[ 524.421540] ACPI: PM: Restoring platform NVS memory
[ 524.422509] LVT offset 0 assigned for vector 0x400
[ 524.422955] Enabling non-boot CPUs ...
[ 524.423871] x86: Booting SMP configuration:
[ 524.423882] smpboot: Booting Node 0 Processor 1 APIC 0x1
[ 524.424743] microcode: CPU1: patch_level=0x07030105
[ 524.428273] ACPI: \_PR_.P001: Found 2 idle states
[ 524.429572] CPU1 is up
[ 524.430450] smpboot: Booting Node 0 Processor 2 APIC 0x2
[ 524.431397] microcode: CPU2: patch_level=0x07030105
[ 524.434609] ACPI: \_PR_.P002: Found 2 idle states
[ 524.436017] CPU2 is up
[ 524.436888] smpboot: Booting Node 0 Processor 3 APIC 0x3
[ 524.437826] microcode: CPU3: patch_level=0x07030105
[ 524.441086] ACPI: \_PR_.P003: Found 2 idle states
[ 524.442610] CPU3 is up
[ 524.444932] ACPI: PM: Waking up from system sleep state S3
[ 524.460637] ACPI: EC: interrupt unblocked
[ 524.494731] ACPI: EC: event unblocked
[ 524.495164] rtlwifi: rtlwifi: wireless switch is on
[ 524.500510] sd 0:0:0:0: [sda] Starting disk
[ 524.503281] [drm] PCIE GART of 1024M enabled (table at 0x000000F400401000).
[ 524.504155] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 524.507793] amdgpu 0000:00:01.0: amdgpu: SRBM_SOFT_RESET=0x00100040
[ 524.779857] usb 1-1.3: reset full-speed USB device number 3 using ehci-pci
[ 524.810016] ata2: SATA link down (SStatus 0 SControl 300)
[ 524.983140] usb 1-1.4: reset high-speed USB device number 4 using ehci-pci
[ 525.328581] [drm] UVD initialized successfully.
[ 525.439568] [drm] VCE initialized successfully.
[ 525.446950] OOM killer enabled.
[ 525.446954] Restarting tasks ... done.
[ 525.471368] audit: type=1130 audit(1654344036.046:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 525.765209] PM: suspend exit
[ 525.768413] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 525.769659] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 525.769672] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 525.769721] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 525.769840] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 525.769869] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 525.770700] audit: type=1130 audit(1654344036.346:91): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 525.770739] audit: type=1131 audit(1654344036.346:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 525.813185] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 525.993371] r8169 0000:03:00.0 enp3s0: Link is Down
[ 526.225589] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 527.073308] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 527.093748] ata1.00: configured for UDMA/100
[ 528.474726] r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control off
[ 528.474759] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 528.842761] audit: type=1131 audit(1654344039.416:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 530.272981] audit: type=1130 audit(1654344040.846:94): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 530.760143] audit: type=1131 audit(1654344041.336:95): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 532.385528] audit: type=1100 audit(1654344042.960:96): pid=1676 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="simon" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[ 532.963412] audit: type=1334 audit(1654344043.536:97): prog-id=24 op=LOAD
[ 532.963431] audit: type=1300 audit(1654344043.536:97): arch=c000003e syscall=321 success=yes exit=28 a0=5 a1=7ffdc34d0c40 a2=90 a3=54 items=0 ppid=1 pid=408 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
[ 532.963444] audit: type=1327 audit(1654344043.536:97): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
[ 540.278546] audit: type=1131 audit(1654344050.853:98): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 661.684933] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 846.487854] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 900.568036] audit: type=1130 audit(1654344411.143:99): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 900.568055] audit: type=1131 audit(1654344411.143:100): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 902.918489] audit: type=1100 audit(1654344413.493:101): pid=2267 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="simon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 902.919367] audit: type=1101 audit(1654344413.493:102): pid=2267 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="simon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 902.921383] audit: type=1110 audit(1654344413.496:103): pid=2267 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 902.925741] audit: type=1105 audit(1654344413.500:104): pid=2267 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 903.012731] audit: type=1106 audit(1654344413.586:105): pid=2267 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 903.012967] audit: type=1104 audit(1654344413.586:106): pid=2267 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1070.543927] audit: type=1100 audit(1654344581.120:107): pid=2445 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="simon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1070.544460] audit: type=1101 audit(1654344581.120:108): pid=2445 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="simon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1070.546610] audit: type=1110 audit(1654344581.123:109): pid=2445 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1070.550781] audit: type=1105 audit(1654344581.126:110): pid=2445 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1070.585498] audit: type=1106 audit(1654344581.160:111): pid=2445 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1070.585796] audit: type=1104 audit(1654344581.160:112): pid=2445 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1112.154887] audit: type=1101 audit(1654344622.730:113): pid=2484 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="simon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1112.157734] audit: type=1110 audit(1654344622.733:114): pid=2484 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1112.161866] audit: type=1105 audit(1654344622.736:115): pid=2484 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
provide also logs:
journalctl --boot=0 --priority=3 --no-pager
journalctl --boot=0 --priority=3 --no-pager ✔
[sudo] пароль для simon:
Journal file /var/log/journal/0484a992e03a41888032c25fc0707575/system@0005e01129a2298e-8f8c92a4911d5b7b.journal~ is truncated, ignoring file.
июн 04 19:52:08 simon-x555yi kernel: ACPI BIOS Error (bug): Could not resolve symbol [^^^PB2.VGA.AFN7], AE_NOT_FOUND (20210730/psargs-330)
июн 04 19:52:08 simon-x555yi kernel: ACPI Error: Aborting method \_SB.PCI0.VGA.LCDD._BCM due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
июн 04 19:52:08 simon-x555yi kernel: kfd kfd: amdgpu: MULLINS not supported in kfd
июн 04 19:52:08 simon-x555yi kernel: kfd kfd: amdgpu: HAINAN not supported in kfd
июн 04 19:52:33 simon-x555yi systemd[524]: Failed to start Update XDG user dir configuration.
июн 05 19:52:03 simon-x555yi systemd[1]: Failed to start pkgfile database update.
install the 5.17 kernel from system settings/kernel and reboot, and use your pc with it and see if you still got freezes…
