While running linux60
(version 6.0.19-3) suspend and hibernate work just fine.
At the same time linux61
(version 6.1.7-1), instantly wakes up from suspend and hibernate with no useful info in the logs.
Similar posts like this and this suggest to fully update the system. Didn’t work for me
Testing branch, the software is up to date, rebooting does not solve the issue
Kernel: 6.0.19-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=bbf95c74-e749-412e-b50f-fb355ed661e9 rw quiet
cryptdevice=UUID=045bb0d2-10a2-4f19-ad6b-4f3a68e0d579:luks-045bb0d2-10a2-4f19-ad6b-4f3a68e0d579
root=/dev/mapper/luks-045bb0d2-10a2-4f19-ad6b-4f3a68e0d579 splash
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: LENOVO product: 82KD v: Lenovo V15 G2 ALC
serial: <superuser required> Chassis: type: 10 v: Lenovo V15 G2 ALC
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: GLCN51WW date: 09/28/2022
ID-1: BAT0 charge: 37.7 Wh (97.4%) condition: 38.7/38.0 Wh (101.9%)
volts: 8.6 min: 7.7 model: LGC L20L2PF0 type: Li-poly serial: <filter>
status: not charging cycles: 145
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1839 high: 4342 min/max: 400/4372 boost: enabled scaling:
driver: amd-pstate governor: schedutil cores: 1: 4342 2: 4342 3: 2087 4: 1930
5: 1929 6: 1929 7: 1930 8: 1930 9: 1098 10: 1098 11: 1029 12: 1240 13: 1098
14: 1261 15: 1098 16: 1098 bogomips: 57508
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300
temp: 38.0 C
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 13d3:56ff class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.48 6.0.19-2-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.0.19-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.64 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eth0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2725
class-ID: 0280
IF-ID-1: wg0 state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
chip-ID: 8087:0032 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 1.14 TiB used: 794.25 GiB (67.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: UMIS RPJTJ256MEE1OWX size: 238.47 GiB block-size: physical: 512 B
rev: 2.1C0628 temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-60JC3T0
type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: GPT
ID-1: / raw-size: 190.72 GiB size: 187.17 GiB (98.14%)
used: 66.12 GiB (35.3%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-045bb0d2-10a2-4f19-ad6b-4f3a68e0d579
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 58 MiB (11.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 45.5 C mobo: N/A gpu: amdgpu temp: 39.0 C
Processes: 400 Uptime: 3m wakeups: 1 Memory: 13.5 GiB used: 3.05 GiB (22.6%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: 1913 pm: dpkg pkgs: 0 pm: pacman
pkgs: 1885 libs: 440 tools: gnome-software,pamac,yay pm: flatpak pkgs: 28
Shell: Zsh v: 5.9 running-in: guake inxi: 3.3.24
Output of journalctl -b 1 -g suspend
Jan 16 14:27:39 Wraith systemd-logind[889]: The system will suspend now!
Jan 16 14:27:39 Wraith ModemManager[910]: <info> [sleep-monitor-systemd] system is about to suspend
Jan 16 14:27:40 Wraith systemd[1]: Starting System Suspend...
Jan 16 14:27:40 Wraith systemd-sleep[1045483]: Entering sleep state 'suspend'...
Jan 16 14:27:40 Wraith kernel: PM: suspend entry (deep)
Jan 16 14:27:44 Wraith kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jan 16 14:27:44 Wraith kernel: PM: suspend exit
Jan 16 14:27:44 Wraith systemd[1]: systemd-suspend.service: Deactivated successfully.
Jan 16 14:27:44 Wraith systemd[1]: Finished System Suspend.
Jan 16 14:27:44 Wraith audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 16 14:27:44 Wraith audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 16 14:27:44 Wraith systemd[1]: Reached target Suspend.
Jan 16 14:27:44 Wraith systemd[1]: Stopped target Suspend.
Jan 16 14:27:44 Wraith kernel: audit: type=1130 audit(1673857664.959:1555): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 16 14:27:44 Wraith kernel: audit: type=1131 audit(1673857664.959:1556): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
