Links not openings when i am clicking with control on it
I don’t know if it’s a bug or if the developers just removed a feature I need, but for quite some time now I have stopped opening links from the console when I click control+left click on them. And i am getting error:
WARNING: Invalid HTTP request received.
As additional information, I need this feature when using Stable Diffusion software
Do you get the same error when you do it with an URL that points to something else as 127.0.0.1 (localhost) ? :thinking:
If those work, then most likely there is no webserver configured to answer that addres i guess :woman_shrugging:
  • Or you’re unable to access that location from your machine…
    You can check using other command-line utils via terminal, like wget/curl/telnet/etc
PS: Don’t post images, use text output in code blocks unless absolutely required like the popup.
Its working but when i am clicking some file is downloading and in browser opening window like this way
file:///home/alexbespik/.cache/kioexec/krun/69699_0/unnamed
PS:
I am clicking on this link
   ~  wget http://127.0.0.1:7860  127 ✘
–2023-08-07 00:41:09-- http://127.0.0.1:7860/
Connecting to 127.0.0.1:7860… connected.
HTTP request sent, awaiting response… 200 OK
Length: 1300376 (1,2M) [text/html]
Saving to: ‘index.html’
index.html 100%[========================================================================================================================================>] 1,24M --.-KB/s in 0,001s
2023-08-07 00:41:09 (1,08 GB/s) - ‘index.html’ saved [1300376/1300376]
   ~  xdg-open http://127.0.0.1:7860:heavy_check_mark:
   ~  command= “prime-run firefox-developer-edition” args= (“prime-run firefox-developer-edition”, “http://127.0.0.1:7860”)  :heavy_check_mark:
kf.kio.core: Protocol Class of url QUrl(“http://127.0.0.1:7860”) , isn’t ‘:local’, cancelling job.
Copying QUrl(“http://127.0.0.1:7860”) to QUrl(“file:///home/alexbespik/.cache/kioexec/krun/70480_0/unnamed”)
All files downloaded, will call slotRunApp shortly
No files downloaded → exiting
A KUiServerV2JobTracker instance contains 1 stalled jobs
Ok so that seems to work as expected :+1:
This part looks unfamiliar to me, but IIRC you should call firefox with just an URL as argument to open that URL, and not an array as you shown.
No idea if that command was crafted by you or some software, to react to the xdg-open command. But it doesn’t look right to me, i could be wrong :woman_shrugging:
What happens if you just execute the below in that case:
prime-run firefox-developer-edition http://127.0.0.1:7860
I didn’t modify xdg-open, I just know that it used to work that way and now it doesn’t. :sweat_smile:
Well i have no idea why xdg-open does it that way for you, because on my system (Kubuntu) that xdg-open line opens the address in my firefox without problem.
Maybe it’s a modification of Manjaro or some other software that messed up xdg-open :woman_shrugging:
Below is the contents of my xdg-open as provided by Kubuntu 23.04:
/usr/bin/xdg-open
#!/bin/sh
#   xdg-open
#   Utility script to open a URL in the registered default application.
#   Refer to the usage() function below for usage.
#   Copyright 2009-2010, Fathi Boudra <fabo@freedesktop.org>
#   Copyright 2009-2010, Rex Dieter <rdieter@fedoraproject.org>
#   Copyright 2006, Kevin Krammer <kevin.krammer@gmx.at>
#   Copyright 2006, Jeremy White <jwhite@codeweavers.com>
#   LICENSE:
#   Permission is hereby granted, free of charge, to any person obtaining a
#   copy of this software and associated documentation files (the "Software"),
#   to deal in the Software without restriction, including without limitation
#   the rights to use, copy, modify, merge, publish, distribute, sublicense,
#   and/or sell copies of the Software, and to permit persons to whom the
#   Software is furnished to do so, subject to the following conditions:
#   The above copyright notice and this permission notice shall be included
#   in all copies or substantial portions of the Software.
#   THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
#   OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
#   FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
#   THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
#   OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
#   ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
#   OTHER DEALINGS IN THE SOFTWARE.
manualpage()
cat << _MANUALPAGE
Name
xdg-open - opens a file or URL in the user's preferred application
Synopsis
xdg-open { file | URL }
xdg-open { --help | --manual | --version }
Description
xdg-open opens a file or URL in the user's preferred application. If a URL is
provided the URL will be opened in the user's preferred web browser. If a file
is provided the file will be opened in the preferred application for files of
that type. xdg-open supports file, ftp, http and https URLs.
xdg-open is for use inside a desktop session only. It is not recommended to use
xdg-open as root.
Options
--help
    Show command synopsis.
--manual
    Show this manual page.
--version
    Show the xdg-utils version information.
Exit Codes
An exit code of 0 indicates success while a non-zero exit code indicates
failure. The following failure codes can be returned:
1
    Error in command line syntax.
2
    One of the files passed on the command line did not exist.
3
    A required tool could not be found.
4
    The action failed.
See Also
xdg-mime(1), xdg-settings(1), MIME applications associations specification
Examples
xdg-open 'http://www.freedesktop.org/'
Opens the freedesktop.org website in the user's default browser.
xdg-open /tmp/foobar.png
Opens the PNG image file /tmp/foobar.png in the user's default image viewing
application.
_MANUALPAGE
usage()
cat << _USAGE
Synopsis
_USAGE
#@xdg-utils-common@
#   Common utility functions included in all XDG wrapper scripts
DEBUG()
  [ -z "${XDG_UTILS_DEBUG_LEVEL}" ] && return 0;
  [ ${XDG_UTILS_DEBUG_LEVEL} -lt $1 ] && return 0;
  shift
  echo "$@" >&2
# This handles backslashes but not quote marks.
first_word()
    read first rest
    echo "$first"
# map a binary to a .desktop file
binary_to_desktop_file()
    search="${XDG_DATA_HOME:-$HOME/.local/share}:${XDG_DATA_DIRS:-/usr/local/share:/usr/share}"
    binary="`which "$1"`"
    binary="`readlink -f "$binary"`"
    base="`basename "$binary"`"
    IFS=:
    for dir in $search; do
        unset IFS
        [ "$dir" ] || continue
        [ -d "$dir/applications" ] || [ -d "$dir/applnk" ] || continue
        for file in "$dir"/applications/*.desktop "$dir"/applications/*/*.desktop "$dir"/applnk/*.desktop "$dir"/applnk/*/*.desktop; do
            [ -r "$file" ] || continue
            # Check to make sure it's worth the processing.
            grep -q "^Exec.*$base" "$file" || continue
            # Make sure it's a visible desktop file (e.g. not "preferred-web-browser.desktop").
            grep -Eq "^(NoDisplay|Hidden)=true" "$file" && continue
            command="`grep -E "^Exec(\[[^]=]*])?=" "$file" | cut -d= -f 2- | first_word`"
            command="`which "$command"`"
            if [ x"`readlink -f "$command"`" = x"$binary" ]; then
                # Fix any double slashes that got added path composition
                echo "$file" | sed -e 's,//*,/,g'
                return
            fi
        done
    done
# map a .desktop file to a binary
desktop_file_to_binary()
    desktop="`basename "$1"`"
    IFS=:
        unset IFS
        [ "$dir" ] && [ -d "$dir/applications" ] || [ -d "$dir/applnk" ] || continue
        # Check if desktop file contains -
        if [ "${desktop#*-}" != "$desktop" ]; then
            vendor=${desktop%-*}
            app=${desktop#*-}
            if [ -r "$dir/applications/$vendor/$app" ]; then
                file_path=$dir/applications/$vendor/$app
            elif [ -r "$dir/applnk/$vendor/$app" ]; then
                file_path=$dir/applnk/$vendor/$app
            fi
        fi
        if test -z "$file_path" ; then
            for indir in "$dir"/applications/ "$dir"/applications/*/ "$dir"/applnk/ "$dir"/applnk/*/; do
                file="$indir/$desktop"
                if [ -r "$file" ]; then
                    file_path=$file
                    break
                fi
            done
        fi
        if [ -r "$file_path" ]; then
            # Remove any arguments (%F, %f, %U, %u, etc.).
            command="`grep -E "^Exec(\[[^]=]*])?=" "$file_path" | cut -d= -f 2- | first_word`"
            return
        fi
    done
# Exit script on successfully completing the desired operation
exit_success()
    if [ $# -gt 0 ]; then
        echo "$@"
        echo
    fi
    exit 0
# Exit script on malformed arguments, not enough arguments
# or missing required option.
# prints usage information
exit_failure_syntax()
        echo "xdg-open: $@" >&2
        echo "Try 'xdg-open --help' for more information." >&2
    else
        usage
        echo "Use 'man xdg-open' or 'xdg-open --manual' for additional info."
    fi
    exit 1
# Exit script on missing file specified on command line
exit_failure_file_missing()
    fi
    exit 2
# Exit script on failure to locate necessary tool applications
exit_failure_operation_impossible()
    fi
    exit 3
# Exit script on failure returned by a tool application
exit_failure_operation_failed()
    fi
    exit 4
# Exit script on insufficient permission to read a specified file
exit_failure_file_permission_read()
    fi
    exit 5
# Exit script on insufficient permission to write a specified file
exit_failure_file_permission_write()
    fi
    exit 6
check_input_file()
    if [ ! -e "$1" ]; then
        exit_failure_file_missing "file '$1' does not exist"
    fi
    if [ ! -r "$1" ]; then
        exit_failure_file_permission_read "no permission to read file '$1'"
    fi
check_vendor_prefix()
    file_label="$2"
    [ -n "$file_label" ] || file_label="filename"
    file=`basename "$1"`
    case "$file" in
       [[:alpha:]]*-*)
         return
    esac
    echo "xdg-open: $file_label '$file' does not have a proper vendor prefix" >&2
    echo 'A vendor prefix consists of alpha characters ([a-zA-Z]) and is terminated' >&2
    echo 'with a dash ("-"). An example '"$file_label"' is '"'example-$file'" >&2
    echo "Use --novendor to override or 'xdg-open --manual' for additional info." >&2
    exit 1
check_output_file()
    # if the file exists, check if it is writeable
    # if it does not exists, check if we are allowed to write on the directory
    if [ -e "$1" ]; then
        if [ ! -w "$1" ]; then
            exit_failure_file_permission_write "no permission to write to file '$1'"
        fi
    else
        DIR=`dirname "$1"`
        if [ ! -w "$DIR" ] || [ ! -x "$DIR" ]; then
            exit_failure_file_permission_write "no permission to create file '$1'"
        fi
    fi
# Checks for shared commands, e.g. --help
check_common_commands()
    while [ $# -gt 0 ] ; do
        parm="$1"
        shift
        case "$parm" in
            --help)
            usage
            exit_success
            --manual)
            manualpage
            exit_success
            --version)
            echo "xdg-open 1.1.3"
            exit_success
        esac
    done
check_common_commands "$@"
[ -z "${XDG_UTILS_DEBUG_LEVEL}" ] && unset XDG_UTILS_DEBUG_LEVEL;
if [ ${XDG_UTILS_DEBUG_LEVEL-0} -lt 1 ]; then
    # Be silent
    xdg_redirect_output=" > /dev/null 2> /dev/null"
else
    # All output to stderr
    xdg_redirect_output=" >&2"
fi
# Checks for known desktop environments
# set variable DE to the desktop environments name, lowercase
detectDE()
    # see https://bugs.freedesktop.org/show_bug.cgi?id=34164
    unset GREP_OPTIONS
    if [ -n "${XDG_CURRENT_DESKTOP}" ]; then
      case "${XDG_CURRENT_DESKTOP}" in
         # only recently added to menu-spec, pre-spec X- still in use
         Cinnamon|X-Cinnamon)
           DE=cinnamon;
         ENLIGHTENMENT)
           DE=enlightenment;
         # GNOME, GNOME-Classic:GNOME, or GNOME-Flashback:GNOME
         GNOME*)
           DE=gnome;
         KDE)
           DE=kde;
         DEEPIN|Deepin|deepin)
           DE=deepin;
         LXDE)
           DE=lxde;
         LXQt)
           DE=lxqt;
         MATE)
           DE=mate;
         XFCE)
           DE=xfce
         X-Generic)
           DE=generic
      esac
    fi
    if [ x"$DE" = x"" ]; then
      # classic fallbacks
      if [ x"$KDE_FULL_SESSION" != x"" ]; then DE=kde;
      elif [ x"$GNOME_DESKTOP_SESSION_ID" != x"" ]; then DE=gnome;
      elif [ x"$MATE_DESKTOP_SESSION_ID" != x"" ]; then DE=mate;
      elif `dbus-send --print-reply --dest=org.freedesktop.DBus /org/freedesktop/DBus org.freedesktop.DBus.GetNameOwner string:org.gnome.SessionManager > /dev/null 2>&1` ; then DE=gnome;
      elif xprop -root _DT_SAVE_MODE 2> /dev/null | grep ' = \"xfce4\"$' >/dev/null 2>&1; then DE=xfce;
      elif xprop -root 2> /dev/null | grep -i '^xfce_desktop_window' >/dev/null 2>&1; then DE=xfce
      elif echo $DESKTOP | grep -q '^Enlightenment'; then DE=enlightenment;
      elif [ x"$LXQT_SESSION_CONFIG" != x"" ]; then DE=lxqt;
      fi
    fi
      # fallback to checking $DESKTOP_SESSION
      case "$DESKTOP_SESSION" in
         gnome)
           DE=gnome;
         LXDE|Lubuntu)
           DE=lxde;
         MATE)
           DE=mate;
         xfce|xfce4|'Xfce Session')
           DE=xfce;
      esac
    fi
      # fallback to uname output for other platforms
      case "$(uname 2>/dev/null)" in
        CYGWIN*)
          DE=cygwin;
        Darwin)
          DE=darwin;
      esac
    fi
    if [ x"$DE" = x"gnome" ]; then
      # gnome-default-applications-properties is only available in GNOME 2.x
      # but not in GNOME 3.x
      which gnome-default-applications-properties > /dev/null 2>&1  || DE="gnome3"
    fi
    if [ -f "$XDG_RUNTIME_DIR/flatpak-info" ]; then
      DE="flatpak"
    fi
# kfmclient exec/openURL can give bogus exit value in KDE <= 3.5.4
# It also always returns 1 in KDE 3.4 and earlier
# Simply return 0 in such case
kfmclient_fix_exit_code()
    version=`LC_ALL=C.UTF-8 kde-config --version 2>/dev/null | grep '^KDE'`
    major=`echo $version | sed 's/KDE.*: \([0-9]\).*/\1/'`
    minor=`echo $version | sed 's/KDE.*: [0-9]*\.\([0-9]\).*/\1/'`
    release=`echo $version | sed 's/KDE.*: [0-9]*\.[0-9]*\.\([0-9]\).*/\1/'`
    test "$major" -gt 3 && return $1
    test "$minor" -gt 5 && return $1
    test "$release" -gt 4 && return $1
    return 0
# Returns true if there is a graphical display attached.
has_display()
    if [ -n "$DISPLAY" ] || [ -n "$WAYLAND_DISPLAY" ]; then
        return 0
    else
        return 1
    fi
last_word()
    read first rest
    echo "$rest"
# Get the value of a key in a desktop file's Desktop Entry group.
# Example: Use get_key foo.desktop Exec
# to get the values of the Exec= key for the Desktop Entry group.
get_key()
    local file="${1}"
    local key="${2}"
    local desktop_entry=""
    IFS_="${IFS}"
    IFS=""
    while read line
    do
        case "$line" in
            "[Desktop Entry]")
                desktop_entry="y"
            # Reset match flag for other groups
                desktop_entry=""
            "${key}="*)
                # Only match Desktop Entry group
                if [ -n "${desktop_entry}" ]
                then
                    echo "${line}" | cut -d= -f 2-
                fi
        esac
    done < "${file}"
    IFS="${IFS_}"
# Returns true if argument is a file:// URL or path
is_file_url_or_path()
    if echo "$1" | grep -q '^file://' \
            || ! echo "$1" | egrep -q '^[[:alpha:]+\.\-]+:'; then
        return 0
    else
        return 1
    fi
# If argument is a file URL, convert it to a (percent-decoded) path.
# If not, leave it as it is.
file_url_to_path()
    local file="$1"
    if echo "$file" | grep -q '^file:///'; then
        file=${file#file://}
        file=${file%%#*}
        file=$(echo "$file" | sed -r 's/\?.*$//')
        local printf=printf
        if [ -x /usr/bin/printf ]; then
            printf=/usr/bin/printf
        fi
        file=$($printf "$(echo "$file" | sed -e 's@%\([a-f0-9A-F]\{2\}\)@\\x\1@g')")
    fi
    echo "$file"
open_cygwin()
    cygstart "$1"
    if [ $? -eq 0 ]; then
        exit_success
    else
    fi
open_darwin()
    open "$1"
        exit_success
    else
    fi
open_kde()
    if [ -n "${KDE_SESSION_VERSION}" ]; then
      case "${KDE_SESSION_VERSION}" in
        4)
          kde-open "$1"
        5)
          kde-open${KDE_SESSION_VERSION} "$1"
      esac
    else
        kfmclient exec "$1"
        kfmclient_fix_exit_code $?
    fi
        exit_success
    else
    fi
open_deepin()
    if dde-open -version >/dev/null 2>&1; then
        dde-open "$1"
    else
        open_generic "$1"
    fi
        exit_success
    else
    fi
open_gnome3()
    if gio help open 2>/dev/null 1>&2; then
        gio open "$1"
    elif gvfs-open --help 2>/dev/null 1>&2; then
        gvfs-open "$1"
    else
        open_generic "$1"
    fi
        exit_success
    else
    fi
open_gnome()
        gio open "$1"
        gvfs-open "$1"
    elif gnome-open --help 2>/dev/null 1>&2; then
        gnome-open "$1"
    else
        open_generic "$1"
    fi
        exit_success
    else
    fi
open_mate()
        gio open "$1"
        gvfs-open "$1"
    elif mate-open --help 2>/dev/null 1>&2; then
        mate-open "$1"
    else
        open_generic "$1"
    fi
        exit_success
    else
    fi
open_xfce()
    if exo-open --help 2>/dev/null 1>&2; then
        exo-open "$1"
    elif gio help open 2>/dev/null 1>&2; then
        gio open "$1"
        gvfs-open "$1"
    else
        open_generic "$1"
    fi
        exit_success
    else
    fi
open_enlightenment()
    if enlightenment_open --help 2>/dev/null 1>&2; then
        enlightenment_open "$1"
    else
        open_generic "$1"
    fi
        exit_success
    else
    fi
open_flatpak()
    gdbus call --session \
        --dest org.freedesktop.portal.Desktop \
        --object-path /org/freedesktop/portal/desktop \
        --method org.freedesktop.portal.OpenURI.OpenURI \
        "" "$1" {}
        exit_success
    else
    fi
# Recursively search .desktop file
search_desktop_file()
    local default="$1"
    local dir="$2"
    local target="$3"
    local file=""
    # look for both vendor-app.desktop, vendor/app.desktop
    if [ -r "$dir/$default" ]; then
      file="$dir/$default"
    elif [ -r "$dir/`echo $default | sed -e 's|-|/|'`" ]; then
      file="$dir/`echo $default | sed -e 's|-|/|'`"
    fi
    if [ -r "$file" ] ; then
        command="$(get_key "${file}" "Exec" | first_word)"
        command_exec=`which $command 2>/dev/null`
        icon="$(get_key "${file}" "Icon")"
        # FIXME: Actually LC_MESSAGES should be used as described in
        # http://standards.freedesktop.org/desktop-entry-spec/latest/ar01s04.html
        localised_name="$(get_key "${file}" "Name")"
        set -- $(get_key "${file}" "Exec" | last_word)
        # We need to replace any occurrence of "%f", "%F" and
        # the like by the target file. We examine each
        # argument and append the modified argument to the
        # end then shift.
        local args=$#
        local replaced=0
        while [ $args -gt 0 ]; do
            case $1 in
                %[c])
                    replaced=1
                    arg="${localised_name}"
                    shift
                    set -- "$@" "$arg"
                %[fFuU])
                    replaced=1
                    arg="$target"
                    shift
                    set -- "$@" "$arg"
                %[i])
                    replaced=1
                    shift
                    set -- "$@" "--icon" "$icon"
                    arg="$1"
                    shift
                    set -- "$@" "$arg"
            esac
            args=$(( $args - 1 ))
        done
        [ $replaced -eq 1 ] || set -- "$@" "$target"
        local term_run=
        if [ "$(get_key "$file" Terminal)" = true ] && ! ( : <>/dev/tty ) 2>/dev/null; then
            if [ -z "$TERMINAL" ]; then
                term_run="x-terminal-emulator -e"
            elif echo "$TERMINAL" | grep -q -v '\s'; then
                term_run="$TERMINAL -e"
            else
                term_run="$TERMINAL"
            fi
        fi
        $term_run "$command_exec" "$@"
            exit_success
        else
        fi
    fi
    for d in "$dir/"*/; do
        [ -d "$d" ] && search_desktop_file "$default" "$d" "$target"
    done
open_generic_xdg_mime()
    filetype="$2"
    default=`xdg-mime query default "$filetype"`
    if [ -n "$default" ] ; then
        xdg_user_dir="$XDG_DATA_HOME"
        [ -n "$xdg_user_dir" ] || xdg_user_dir="$HOME/.local/share"
        xdg_system_dirs="$XDG_DATA_DIRS"
        [ -n "$xdg_system_dirs" ] || xdg_system_dirs=/usr/local/share/:/usr/share/
DEBUG 3 "$xdg_user_dir:$xdg_system_dirs"
        for x in `echo "$xdg_user_dir:$xdg_system_dirs" | sed 's/:/ /g'`; do
            search_desktop_file "$default" "$x/applications/" "$1"
        done
    fi
open_generic_xdg_file_mime()
    filetype=`xdg-mime query filetype "$1" | sed "s/;.*//"`
    open_generic_xdg_mime "$1" "$filetype"
open_generic_xdg_x_scheme_handler()
    scheme="`echo $1 | sed -n 's/\(^[[:alnum:]+\.-]*\):.*$/\1/p'`"
    if [ -n $scheme ]; then
        filetype="x-scheme-handler/$scheme"
    fi
open_envvar()
    local url="$1"
    local oldifs="$IFS"
    local browser browser_with_arg
    IFS=":"
    for browser in $BROWSER; do
        IFS="$oldifs"
        if [ -z "$browser" ]; then
            continue
        fi
        if echo "$browser" | grep -q %s; then
            # Use loop to insert URL for avoid argument injection.
            # See https://bugs.freedesktop.org/show_bug.cgi?id=103807
            shift $#
            for arg in $browser; do
                set -- "$@" "$(printf -- "$arg" "$url")"
            done
        else
            $browser "$url"
        fi
            exit_success
        fi
    done
open_generic()
    if is_file_url_or_path "$1"; then
        local file="$(file_url_to_path "$1")"
        check_input_file "$file"
        if has_display; then
            filetype=`xdg-mime query filetype "$file" | sed "s/;.*//"`
            open_generic_xdg_mime "$file" "$filetype"
        fi
        if which run-mailcap 2>/dev/null 1>&2; then
            run-mailcap --action=view "$file"
                exit_success
            fi
        fi
        if has_display && mimeopen -v 2>/dev/null 1>&2; then
            mimeopen -L -n "$file"
                exit_success
            fi
        fi
    fi
        open_generic_xdg_x_scheme_handler "$1"
    fi
    if [ -n "$BROWSER" ]; then
        open_envvar "$1"
    fi
    # if BROWSER variable is not set, check some well known browsers instead
    if [ x"$BROWSER" = x"" ]; then
        BROWSER=www-browser:links2:elinks:links:lynx:w3m
            BROWSER=x-www-browser:firefox:iceweasel:seamonkey:mozilla:epiphany:konqueror:chromium:chromium-browser:google-chrome:$BROWSER
        fi
    fi
    open_envvar "$1"
    exit_failure_operation_impossible "no method available for opening '$1'"
open_lxde()
    # pcmanfm only knows how to handle file:// urls and filepaths, it seems.
    if pcmanfm --help >/dev/null 2>&1 && is_file_url_or_path "$1"; then
        # handle relative paths
        if ! echo "$file" | grep -q ^/; then
            file="$(pwd)/$file"
        fi
        pcmanfm "$file"
    else
        open_generic "$1"
    fi
        exit_success
    else
    fi
open_lxqt()
    open_generic "$1"
[ x"$1" != x"" ] || exit_failure_syntax
url=
    parm="$1"
    shift
    case "$parm" in
        exit_failure_syntax "unexpected option '$parm'"
        if [ -n "$url" ] ; then
            exit_failure_syntax "unexpected argument '$parm'"
        fi
        url="$parm"
    esac
done
if [ -z "${url}" ] ; then
    exit_failure_syntax "file or URL argument missing"
fi
detectDE
    DE=generic
fi
DEBUG 2 "Selected DE $DE"
# sanitize BROWSER (avoid caling ourselves in particular)
case "${BROWSER}" in
    *:"xdg-open"|"xdg-open":*)
        BROWSER=$(echo $BROWSER | sed -e 's|:xdg-open||g' -e 's|xdg-open:||g')
    "xdg-open")
        BROWSER=
esac
case "$DE" in
    kde)
    open_kde "$url"
    deepin)
    open_deepin "$url"
    gnome3|cinnamon)
    open_gnome3 "$url"
    gnome)
    open_gnome "$url"
    mate)
    open_mate "$url"
    xfce)
    open_xfce "$url"
    lxde)
    open_lxde "$url"
    lxqt)
    open_lxqt "$url"
    enlightenment)
    open_enlightenment "$url"
    cygwin)
    open_cygwin "$url"
    darwin)
    open_darwin "$url"
    flatpak)
    open_flatpak "$url"
    generic)
    open_generic "$url"
    exit_failure_operation_impossible "no method available for opening '$url'"
esac
@alexbespik Can you check what the output of these commands give you?
  1. xdg-settings get default-web-browser
  2. xdg-settings get default-url-scheme-handler
The last command doesn’t show anything for me, while the first gives me firefox_firefox.desktop
Not manjaro.
Works here.
Opposite here. No default URL handler, but default-web-browser is set.
(PS - you may use, ex: xdg-settings set default-web-browser firefox.desktop)
((PPS firefox_firefox.desktop … what is that? Custom I guess?))
Now it’s working with stable Firefox
Thanks
So we have the same :rofl:
No Kubuntu uses the Firefox snap version, which has that i suppose…
Ok nice that it works with stable firefox now, but your problem is not solved yet…
Because that fact shows that the problem was in the target it was set before you changed it…
Which might be a package provided desktop file…
And looking at the command output you provided earlier it has todo with PRIME or firefox-developer-editon
Would explain it not matching anything in the repos.
(and the dumb as hell naming convention)
