Lines on screen during booting - Lenovo Ideapad 5 Pro
Hello,
I installed Manjaro yesterday and I have a flickering issue. I have a Lenovo Ideapad 5 Pro laptop and when Lenovo logo appears at start, the screen displays lines. This happens every time I boot.
I tried installing different kernel versions: 5.13, 5.14, 5.15
I have Ryzen 5 5600H with Integrated GPU
inxi -Fxza --no-host
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=e0e8edc8-23dc-45e8-b197-937ffa1f602c rw quiet splash apparmor=1
  security=apparmor udev.log_priority=3 acpi_backlight=video
  Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Laptop System: LENOVO product: 82L5 v: IdeaPad 5 Pro 16ACH6
  serial: <filter> Chassis: type: 10 v: IdeaPad 5 Pro 16ACH6
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: WIN serial: <filter> UEFI: LENOVO
  v: GSCN27WW date: 08/23/2021
  ID-1: BAT0 charge: 58.1 Wh (77.1%) condition: 75.4/75.0 Wh (100.6%)
  volts: 16.1 min: 15.4 model: Celxpert L20C4PE1 type: Li-ion
  serial: <filter> status: Discharging cycles: 9
  Info: 6-Core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
  microcode: A50000C cache: L2: 3 MiB
  bogomips: 79083
  Speed: 1397 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1397 3: 1226 4: 1197 5: 1201 6: 1516 7: 1198 8: 1197 9: 1198
  10: 1199 11: 2082 12: 1588
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
  IBRS_FW, STIBP: always-on, RSB filling
  Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
  bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
  bus-ID: 3-4:3 chip-ID: 04f2:b6be class-ID: fe01 serial: <filter>
  Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
  display-ID: 0 resolution: <missing: xdpyinfo>
  OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.19-2-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.2.3 direct render: Yes
  Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
  bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x
  bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: no
  Device-1: Realtek vendor: Lenovo driver: rtw89_pci v: N/A
  modules: rtw89pci port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8852
  class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
  bus-ID: 3-3:2 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 28.87 GiB (6.1%)
  model: MZVLB512HBJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
  rev: 3L1QEXF7 temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
  used: 28.87 GiB (6.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 20.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
  Processes: 316 Uptime: 9m wakeups: 2149 Memory: 13.51 GiB
  used: 2.54 GiB (18.8%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: pacman: 1276 lib: 405 flatpak: 0 Shell: Zsh v: 5.8
  running-in: gnome-terminal inxi: 3.3.08
