Hi there,
I used to experience this problem only in rare occasions, but it’s suddenly become bothersome as it now happens almost twice in an hour. I have a speaker connected to the line out plug from my motherboard. Without any apparent reason sound is not heard any longer. I checked in PulseAudio volume and the output is not muted. Connecting a headphone to the headphone plug works ok. If I reboot or even log out, it works fine again. I am not sure where to check. Here is the information I have managed to gather. I hope someone can help me diagnosing this. If not, I might try reinstalling Manjaro, as I have another still unsolved problem.
Thanks in advance,
Alan
inxi --admin --verbosity=7 --filter --width
Kernel: 5.10.98-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=20705b87-eec6-4fb3-8353-031c51df1cac ro quiet splash apparmor=1
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3405
date: 02/01/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus
status: Discharging
RAM: total: 15.6 GiB used: 3.39 GiB (21.7%)
RAM Report:
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2580 high: 3576
min/max: 2200/6442:6146:5994:5846:6294:4950:5698:5102:5398:5250:5550
boost: enabled scaling: driver: acpi-cpufreq governor: schedutil cores:
1: 2199 2: 2658 3: 2457 4: 2518 5: 2482 6: 2212 7: 2516 8: 3359 9: 2569
10: 2681 11: 2820 12: 2538 13: 2792 14: 2543 15: 2214 16: 2215 17: 2203
18: 2236 19: 2569 20: 3576 21: 2560 22: 2879 23: 2252 24: 2878
bogomips: 177681
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vaes
vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: Nanjing Magewell Eco Capture Dual HDMI M.2 vendor: SafeNet
driver: Eco Capture v: N/A alternate: MWEcoCapture bus-ID: 04:00.0
chip-ID: 1cd7:0051 class-ID: 0400
Device-2: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 0b:00.0
chip-ID: 10de:2182 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 5440x1080 s-dpi: 96 s-size: 1439x286mm (56.7x11.3")
s-diag: 1467mm (57.8")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: DP-2 res: 1920x1080 hz: 60
Monitor-3: DP-4 res: 1600x900 hz: 60 dpi: 92 size: 443x249mm (17.4x9.8")
diag: 508mm (20")
driver: Eco Capture alternate: MWEcoCapture bus-ID: 04:00.0
Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0b:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0d:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.10.98-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus-ID: 07:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-ac907f97584b state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:3
Local Storage: total: 465.76 GiB used: 286.71 GiB (61.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EGFM13.0 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.16 GiB (98.22%)
used: 286.71 GiB (62.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 20705b87-eec6-4fb3-8353-031c51df1cac
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 6206-C799
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-6:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-8: 7-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 7-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-9: 7-4:3 info: Microchip (formerly SMSC) USB2734 ports: 5 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2734 class-ID: 0900
Hub-10: 7-4.2:4 info: Microchip (formerly SMSC) Hub ports: 2 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2412 class-ID: 0900
Device-1: 7-4.2.1:7 info: Melfas LGD AIT Touch Controller type: HID
driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1fd2:6103 class-ID: 0300
Device-2: 7-4.5:5 info: Microchip (formerly SMSC) Hub Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 480 Mb/s
chip-ID: 0424:274c class-ID: 0300
Hub-11: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-12: 8-4:2 info: Microchip (formerly SMSC) USB5734 ports: 4 rev: 3.1
speed: 5 Gb/s chip-ID: 0424:5734 class-ID: 0900
System Temperatures: cpu: 49.1 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Processes: 449 Uptime: 12m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: 1761 apt: 0 pacman: 1749
lib: 451 flatpak: 5 snap: 7 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.12
sudo dmesg --level emerg,alert,crit,err,warn
[ 0.003552] __common_interrupt: 1.55 No irq handler for vector
[ 0.224192] #2
[ 0.003552] __common_interrupt: 2.55 No irq handler for vector
[ 0.226301] #3
[ 0.003552] __common_interrupt: 3.55 No irq handler for vector
[ 0.227513] #4
[ 0.003552] __common_interrupt: 4.55 No irq handler for vector
[ 0.230849] #5
[ 0.003552] __common_interrupt: 5.55 No irq handler for vector
[ 0.232945] #6
[ 0.003552] __common_interrupt: 6.55 No irq handler for vector
[ 0.234182] #7
[ 0.003552] __common_interrupt: 7.55 No irq handler for vector
[ 0.237515] #8
[ 0.003552] __common_interrupt: 8.55 No irq handler for vector
[ 0.239656] #9
[ 0.003552] __common_interrupt: 9.55 No irq handler for vector
[ 0.240844] #10
[ 0.003552] __common_interrupt: 10.55 No irq handler for vector
[ 0.244183] #11 #12
[ 0.247543] #13 #14 #15 #16 #17 #18 #19 #20 #21 #22 #23
[ 0.832696] usb: port power management may be unreliable
[ 1.231617] usb 3-4: config 1 has an invalid interface number: 2 but max is 1
[ 1.231618] usb 3-4: config 1 has no interface number 1
[ 1.707629] vboxdrv: loading out-of-tree module taints kernel.
[ 1.733585] VBoxNetAdp: Successfully started.
[ 1.735435] systemd-journald[395]: File /var/log/journal/4fa2ff52746547f9abd0d56e76db460f/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 1.736280] VBoxNetFlt: Successfully started.
[ 1.860946] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 1.861073] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 1.861204] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 1.861411] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 1.930916] nvidia: module license 'NVIDIA' taints kernel.
[ 1.930917] Disabling lock debugging due to kernel taint
[ 1.945950] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 2.003258] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.47.03 Mon Jan 24 22:58:54 UTC 2022
[ 2.139629] iwlwifi 0000:05:00.0: api flags index 2 larger than supported by driver
[ 2.284046] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 2.613826] thermal thermal_zone0: failed to read out thermal zone (-61)
[ 5.824626] kauditd_printk_skb: 88 callbacks suppressed
[ 7.395125] magicmouse 0005:004C:0265.0009: unknown main item tag 0x0
[ 12.865674] kauditd_printk_skb: 58 callbacks suppressed
[ 35.124464] systemd-journald[395]: File /var/log/journal/4fa2ff52746547f9abd0d56e76db460f/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 40.185023] kauditd_printk_skb: 29 callbacks suppressed
sudo journalctl -r --since=today | grep “audio” 3s
Feb 21 13:03:29 pc-laburo pulseaudio[1510]: Error opening PCM device hw:3: No such file or directory
Feb 21 13:03:28 pc-laburo pulseaudio[2126]: stat('/etc/pulse/default.pa.d'): No such file or directory
Feb 21 13:02:55 pc-laburo dbus-daemon[1030]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.34' (uid=120 pid=1510 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
Feb 21 13:02:52 pc-laburo kernel: snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
Feb 21 13:02:52 pc-laburo kernel: snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
Feb 21 13:02:52 pc-laburo kernel: snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
Feb 21 13:02:52 pc-laburo kernel: snd_hda_codec_realtek hdaudioC1D0: inputs:
Feb 21 13:02:52 pc-laburo kernel: snd_hda_codec_realtek hdaudioC1D0: dig-out=0x1e/0x0
Feb 21 13:02:52 pc-laburo kernel: snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
Feb 21 13:02:52 pc-laburo kernel: snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
Feb 21 13:02:52 pc-laburo kernel: snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Feb 21 13:02:52 pc-laburo kernel: snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
Feb 21 13:02:52 pc-laburo kernel: snd_hda_intel 0000:0b:00.1: Handle vga_switcheroo audio client
Feb 21 11:04:19 pc-laburo com.obsproject.Studio.desktop[24599]: info: adding 554 milliseconds of audio buffering, total audio buffering is now 618 milliseconds (source: Mic/Aux)
Feb 21 11:04:18 pc-laburo com.obsproject.Studio.desktop[24599]: info: pulse-input: Server name: 'pulseaudio 15.0'
Feb 21 11:03:41 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZaMultiCompX2>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamGEQ31>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamDynamicEQ>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamGrains>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamHeadX2>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamPhono>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZaMaximX2>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamVerb>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamDelay>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamComp>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamEQ2>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZaMultiComp>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamGate>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamGateX2>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamAutoSat>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamTube>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamCompX2>
Feb 21 11:03:40 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZaMultiCompX2>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamPhono>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZaMaximX2>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamVerb>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamDelay>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamComp>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamEQ2>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZaMultiComp>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamGate>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamGateX2>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamAutoSat>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamTube>
Feb 21 11:03:39 pc-laburo audacity.desktop[26142]: lilv_world_add_plugin(): warning: Duplicate plugin <urn:zamaudio:ZamCompX2>
Feb 21 11:01:59 pc-laburo kdenlive[25151]: // EFFECT 8 : audioconvert
"<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<mlt LC_NUMERIC=\"C\" version=\"7.4.0\" parent=\"producer0\" in=\"0\" out=\"104\"><producer id=\"producer0\" in=\"0\" out=\"104\"><property name=\"length\">105</property><property name=\"eof\">pause</property><property name=\"resource\">/home/acyment/Videos/2022-02-21 11-00-10.mp4</property><property name=\"seekable\">1</property><property name=\"aspect_ratio\">1</property><property name=\"audio_index\">1</property><property name=\"video_index\">0</property><property name=\"mute_on_pause\">0</property><property name=\"mlt_service\">avformat-novalidate</property><property name=\"kdenlive:clipname\"></property><property name=\"kdenlive:folderid\">-1</property><property name=\"kdenlive:id\">2</property><property name=\"kdenlive:file_size\">23898681</property><property name=\"kdenlive:file_hash\">aeb6b1be6969873cbb7a63425ddefc48</property><property name=\"kdenlive:audio_max1\">1</property></producer></mlt>\n"
Feb 21 11:01:57 pc-laburo kdenlive[25151]: // EFFECT 8 : audioconvert
Feb 21 11:01:42 pc-laburo kdenlive[25151]: plugin not available: "audiolevelgraph"
Feb 21 11:01:41 pc-laburo kdenlive[25151]: Failed to parse "audioconvert"
Feb 21 11:01:41 pc-laburo kdenlive[25151]: Invalid metadata for "audioconvert"
Feb 21 11:01:41 pc-laburo kdenlive[25151]: Failed to parse "audiochannels"
Feb 21 11:01:41 pc-laburo kdenlive[25151]: Invalid metadata for "audiochannels"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audiolevelgraph" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_swapchannels" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_reverb" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_pitch" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_pan" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_notch" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_normalize_2p" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_normalize_1p" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_noisegate" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_mute" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_mono" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_lowpass" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_limiter" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_invert" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_highpass" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_gain" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_fadeout" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_fadein" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_expander" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_eqparametric" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_eq3band" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_eq15band" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_delay" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_compressor" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_channelcopy" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_basstreble" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_bandpass" "meta.qml"
Feb 21 11:00:50 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <FilterController::loadFilterMetadata> reading filter metadata "audio_balance" "meta.qml"
Feb 21 11:00:49 pc-laburo org.shotcut.Shotcut.desktop[24955]: audio_codecs:
Feb 21 11:00:48 pc-laburo org.shotcut.Shotcut.desktop[24955]: [Debug ] <ShotcutSettings::log> audio channels 2
Feb 21 10:59:59 pc-laburo com.obsproject.Studio.desktop[24599]: info: adding 64 milliseconds of audio buffering, total audio buffering is now 64 milliseconds (source: Mic/Aux)
Feb 21 10:59:58 pc-laburo com.obsproject.Studio.desktop[24599]: info: [Loaded global audio device]: 'Mic/Aux'
Feb 21 10:59:58 pc-laburo com.obsproject.Studio.desktop[24599]: info: pulse-input: Server name: 'pulseaudio 15.0'
Feb 21 10:59:58 pc-laburo com.obsproject.Studio.desktop[24599]: info: [Loaded global audio device]: 'Desktop Audio'
Feb 21 10:59:58 pc-laburo com.obsproject.Studio.desktop[24599]: info: linux-pulseaudio.so
Feb 21 10:59:58 pc-laburo com.obsproject.Studio.desktop[24599]: info: audio settings reset:
Feb 21 10:59:11 pc-laburo pulseaudio[23050]: Error opening PCM device hw:3: No such file or directory
Feb 21 10:59:10 pc-laburo pulseaudio[23382]: stat('/etc/pulse/default.pa.d'): No such file or directory
Feb 21 10:58:59 pc-laburo systemd[2700]: pulseaudio.service: Consumed 10.089s CPU time.
Feb 21 10:58:58 pc-laburo pulseaudio[19658]: Lost I/O connection in module "module-gsettings"
Feb 21 10:58:54 pc-laburo com.obsproject.Studio.desktop[20973]: info: ┣buffer_audio: min=0 ms, median=0 ms, max=0.009 ms, 99th percentile=0.001 ms
Feb 21 10:58:54 pc-laburo com.obsproject.Studio.desktop[20973]: info: ┗receive_audio: min=0.001 ms, median=0.125 ms, max=1 ms, 99th percentile=0.821 ms, 0.0182886 calls per parent call
Feb 21 10:58:54 pc-laburo com.obsproject.Studio.desktop[20973]: info: audio_thread(Audio): min=0 ms, median=0.034 ms, max=1.1 ms, 99th percentile=0.34 ms
Feb 21 10:58:54 pc-laburo com.obsproject.Studio.desktop[20973]: info: ┃ ┣obs_init_module(linux-pulseaudio.so): 0 ms
Feb 21 10:58:28 pc-laburo com.obsproject.Studio.desktop[20973]: info: adding 149 milliseconds of audio buffering, total audio buffering is now 213 milliseconds (source: Mic/Aux)
Feb 21 10:49:31 pc-laburo com.obsproject.Studio.desktop[20973]: info: adding 64 milliseconds of audio buffering, total audio buffering is now 64 milliseconds (source: Mic/Aux)
Feb 21 10:49:30 pc-laburo com.obsproject.Studio.desktop[20973]: info: [Loaded global audio device]: 'Mic/Aux'
Feb 21 10:49:30 pc-laburo com.obsproject.Studio.desktop[20973]: info: pulse-input: Server name: 'pulseaudio 15.0'
Feb 21 10:49:30 pc-laburo com.obsproject.Studio.desktop[20973]: info: [Loaded global audio device]: 'Desktop Audio'
Feb 21 10:49:30 pc-laburo com.obsproject.Studio.desktop[20973]: info: linux-pulseaudio.so
Feb 21 10:49:30 pc-laburo com.obsproject.Studio.desktop[20973]: info: audio settings reset:
Feb 21 10:48:59 pc-laburo pulseaudio[19206]: Error opening PCM device hw:3: No such file or directory
Feb 21 10:48:57 pc-laburo pulseaudio[19658]: stat('/etc/pulse/default.pa.d'): No such file or directory
Feb 21 10:48:47 pc-laburo pulseaudio[18793]: Error opening PCM device hw:3: No such file or directory
Feb 21 10:48:46 pc-laburo pulseaudio[18793]: Lost I/O connection in module "module-gsettings"
Feb 21 10:48:41 pc-laburo com.obsproject.Studio.desktop[14934]: info: ┣buffer_audio: min=0 ms, median=0 ms, max=0.015 ms, 99th percentile=0.004 ms
Feb 21 10:48:41 pc-laburo com.obsproject.Studio.desktop[14934]: info: ┗receive_audio: min=0 ms, median=0.269 ms, max=1.268 ms, 99th percentile=0.894 ms, 0.00877434 calls per parent call
Feb 21 10:48:41 pc-laburo com.obsproject.Studio.desktop[14934]: info: audio_thread(Audio): min=0 ms, median=0.034 ms, max=17.664 ms, 99th percentile=0.332 ms
Feb 21 10:48:41 pc-laburo com.obsproject.Studio.desktop[14934]: info: ┃ ┣obs_init_module(linux-pulseaudio.so): 0.001 ms
Feb 21 10:48:31 pc-laburo pulseaudio[18793]: stat('/etc/pulse/default.pa.d'): No such file or directory
Feb 21 10:48:30 pc-laburo systemd[2700]: pulseaudio.service: Consumed 2min 20.949s CPU time.
Feb 21 10:22:07 pc-laburo com.obsproject.Studio.desktop[14934]: info: adding 533 milliseconds of audio buffering, total audio buffering is now 597 milliseconds (source: Mic/Aux)
Feb 21 10:22:06 pc-laburo com.obsproject.Studio.desktop[14934]: info: pulse-input: Server name: 'pulseaudio 15.0'
Feb 21 10:16:42 pc-laburo com.obsproject.Studio.desktop[14934]: info: adding 64 milliseconds of audio buffering, total audio buffering is now 64 milliseconds (source: Mic/Aux)
Feb 21 10:16:41 pc-laburo com.obsproject.Studio.desktop[14934]: info: [Loaded global audio device]: 'Mic/Aux'
Feb 21 10:16:41 pc-laburo com.obsproject.Studio.desktop[14934]: info: pulse-input: Server name: 'pulseaudio 15.0'
Feb 21 10:16:41 pc-laburo com.obsproject.Studio.desktop[14934]: info: [Loaded global audio device]: 'Desktop Audio'
Feb 21 10:16:41 pc-laburo com.obsproject.Studio.desktop[14934]: info: linux-pulseaudio.so
Feb 21 10:16:41 pc-laburo com.obsproject.Studio.desktop[14934]: info: audio settings reset:
Feb 21 10:16:36 pc-laburo com.obsproject.Studio.desktop[4067]: info: audio_thread(Audio): min=0 ms, median=0.039 ms, max=13.328 ms, 99th percentile=0.255 ms
Feb 21 10:16:36 pc-laburo com.obsproject.Studio.desktop[4067]: info: ┃ ┣obs_init_module(linux-pulseaudio.so): 0.001 ms
