I can use help with limited connectivity. Just reinstalled Plasma and on boot, wifi works OK for about 5 min then it is always going to limited connectivity. Please let me know if anything else is needed
Thank you in advance
inxi -Fazy
Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=21a6073b-7365-4adc-923a-3297928699b0 rw quiet apparmor=1
security=apparmor resume=UUID=8eb8cc61-9701-480a-94c3-aad044ca99e3
udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Notebook product: N24_25BU v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Notebook model: N24_25BU serial: <filter>
UEFI-[Legacy]: American Megatrends v: 1.05.14 date: 12/21/2016
ID-1: BAT0 charge: 34.7 Wh (100.0%) condition: 34.7/45.3 Wh (76.5%)
volts: 16.9 min: 15.1 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
microcode: EA cache: L2: 4 MiB
bogomips: 23209
Speed: 700 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
4: 701
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: CLEVO/KAPOK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 5986:1111 class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x175mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: f040 bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: e000 bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-5:2 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 1.21 TiB used: 225.49 GiB (18.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT275MX300SSD1
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R040 scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1050MX300SSD4
size: 978.09 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R031 scheme: GPT
ID-1: / raw-size: 247.37 GiB size: 242.43 GiB (98.00%)
used: 225.49 GiB (93.0%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 174 Uptime: 21m wakeups: 1 Memory: 31.16 GiB
used: 2.18 GiB (7.0%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1338 lib: 370 flatpak: 0 Shell: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.06
iwconfig
lo no wireless extensions.
enp3s0f1 no wireless extensions.
wlp2s0 IEEE 802.11 ESSID:"kzk7x"
Mode:Managed Frequency:5.745 GHz Access Point: 88:3D:24:A9:84:25
Bit Rate=433.3 Mb/s Tx-Power=22 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=54/70 Signal level=-56 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:26 Missed beacon:0
tun0 no wireless extensions.
rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
sudo dmesg | grep r8169
[ 2.636409] r8169 0000:03:00.1: can't disable ASPM; OS doesn't have ASPM control
[ 2.657839] libphy: r8169: probed
[ 2.657992] r8169 0000:03:00.1 eth0: RTL8411b, 80:fa:5b:43:c4:05, XID 5c8, IRQ 129
[ 2.657994] r8169 0000:03:00.1 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 2.798504] r8169 0000:03:00.1 enp3s0f1: renamed from eth0
[ 3.209677] Generic FE-GE Realtek PHY r8169-0-301:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-0-301:00, irq=IGNORE)
[ 3.412755] r8169 0000:03:00.1 enp3s0f1: Link is Down
** iw phy0 info
Wiphy phy0
wiphy index: 0
max # scan SSIDs: 20
max scan IEs length: 425 bytes
max # sched scan SSIDs: 20
max # match sets: 11
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports RSN-IBSS.
Device supports AP-side u-APSD.
Device supports T-DLS.
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP-128 (00-0f-ac:4)
* CMAC (00-0f-ac:6)
Available Antennas: TX 0x1 RX 0x1
Configured Antennas: TX 0x1 RX 0x1
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* P2P-client
* P2P-GO
* P2P-device
Band 1:
Capabilities: 0x116e
HT20/HT40
SM Power Save disabled
RX HT20 SGI
RX HT40 SGI
RX STBC 1-stream
Max AMSDU length: 3839 bytes
DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 4 usec (0x05)
HT Max RX data rate: 150 Mbps
HT TX/RX MCS rate indexes supported: 0-7
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 2412 MHz [1] (22.0 dBm)
* 2417 MHz [2] (22.0 dBm)
* 2422 MHz [3] (22.0 dBm)
* 2427 MHz [4] (22.0 dBm)
* 2432 MHz [5] (22.0 dBm)
* 2437 MHz [6] (22.0 dBm)
* 2442 MHz [7] (22.0 dBm)
* 2447 MHz [8] (22.0 dBm)
* 2452 MHz [9] (22.0 dBm)
* 2457 MHz [10] (22.0 dBm)
* 2462 MHz [11] (22.0 dBm)
* 2467 MHz [12] (22.0 dBm)
* 2472 MHz [13] (22.0 dBm)
* 2484 MHz [14] (disabled)
Band 2:
HT20/HT40
RX HT20 SGI
RX HT40 SGI
RX STBC 1-stream
DSSS/CCK HT40
VHT Capabilities (0x33807120):
Max MPDU length: 3895
Supported Channel Width: neither 160 nor 80+80
short GI (80 MHz)
SU Beamformee
RX antenna pattern consistency
TX antenna pattern consistency
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: not supported
3 streams: not supported
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
VHT RX highest supported: 0 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
VHT TX highest supported: 0 Mbps
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5180 MHz [36] (22.0 dBm)
* 5200 MHz [40] (22.0 dBm)
* 5220 MHz [44] (22.0 dBm)
* 5240 MHz [48] (22.0 dBm)
* 5260 MHz [52] (22.0 dBm) (no IR, radar detection)
* 5280 MHz [56] (22.0 dBm) (no IR, radar detection)
* 5300 MHz [60] (22.0 dBm) (no IR, radar detection)
* 5320 MHz [64] (22.0 dBm) (no IR, radar detection)
* 5500 MHz [100] (22.0 dBm) (no IR, radar detection)
* 5520 MHz [104] (22.0 dBm) (no IR, radar detection)
* 5540 MHz [108] (22.0 dBm) (no IR, radar detection)
* 5560 MHz [112] (22.0 dBm) (no IR, radar detection)
* 5580 MHz [116] (22.0 dBm) (no IR, radar detection)
* 5600 MHz [120] (22.0 dBm) (no IR, radar detection)
* 5620 MHz [124] (22.0 dBm) (no IR, radar detection)
* 5640 MHz [128] (22.0 dBm) (no IR, radar detection)
* 5660 MHz [132] (22.0 dBm) (no IR, radar detection)
* 5680 MHz [136] (22.0 dBm) (no IR, radar detection)
* 5700 MHz [140] (22.0 dBm) (no IR, radar detection)
* 5720 MHz [144] (22.0 dBm) (no IR, radar detection)
* 5745 MHz [149] (22.0 dBm)
* 5765 MHz [153] (22.0 dBm)
* 5785 MHz [157] (22.0 dBm)
* 5805 MHz [161] (22.0 dBm)
* 5825 MHz [165] (22.0 dBm)
Supported commands:
* new_interface
* set_interface
* new_key
* start_ap
* new_station
* new_mpath
* set_mesh_config
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* remain_on_channel
* set_tx_bitrate_mask
* frame
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* set_wds_peer
* tdls_mgmt
* tdls_oper
* start_sched_scan
* probe_client
* set_noack_map
* register_beacons
* start_p2p_device
* set_mcast_rate
* connect
* disconnect
* channel_switch
* set_qos_map
* add_tx_ts
* set_multicast_to_unicast
WoWLAN support:
* wake up on disconnect
* wake up on magic packet
* wake up on pattern match, up to 20 patterns of 16-128 bytes,
maximum packet offset 0 bytes
* can do GTK rekeying
* wake up on GTK rekey failure
* wake up on EAP identity request
* wake up on 4-way handshake
* wake up on rfkill release
* wake up on network detection, up to 11 match sets
software interface modes (can always be added):
* AP/VLAN
* monitor
valid interface combinations:
* #{ managed } <= 1, #{ AP, P2P-client, P2P-GO } <= 1, #{ P2P-device } <= 1,
total <= 3, #channels <= 2
HT Capability overrides:
* MCS: ff ff ff ff ff ff ff ff ff ff
* maximum A-MSDU length
* supported channel width
* short GI for 40 MHz
* max A-MPDU length exponent
* min MPDU start spacing
Device supports TX status socket option.
Device supports HT-IBSS.
Device supports SAE with AUTHENTICATE command
Device supports low priority scan.
Device supports scan flush.
Device supports per-vif TX power setting
P2P GO supports CT window setting
P2P GO supports opportunistic powersave setting
Driver supports full state transitions for AP/GO clients
Driver supports a userspace MPM
Driver/device bandwidth changes during BSS lifetime (AP/GO mode)
Device supports static SMPS
Device supports dynamic SMPS
Device supports WMM-AC admission (TSPECs)
Device supports configuring vdev MAC-addr on create.
Device supports TDLS channel switching
Device supports randomizing MAC-addr in scans.
Device supports randomizing MAC-addr in sched scans.
Device supports randomizing MAC-addr in net-detect scans.
max # scan plans: 2
max scan plan interval: 65535
max scan plan iterations: 254
Supported TX frame types:
* IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
Supported RX frame types:
* IBSS: 0x40 0xb0 0xc0 0xd0
* managed: 0x40 0xb0 0xd0
* AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* mesh point: 0xb0 0xc0 0xd0
* P2P-client: 0x40 0xd0
* P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* P2P-device: 0x40 0xd0
Supported extended features:
* [ VHT_IBSS ]: VHT-IBSS
* [ RRM ]: RRM
* [ SCAN_START_TIME ]: scan start timestamp
* [ BSS_PARENT_TSF ]: BSS last beacon/probe TSF
* [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
* [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
* [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
* [ EXT_KEY_ID ]: Extended Key ID support
* [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
* [ DEL_IBSS_STA ]: deletion of IBSS station support
* [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
* [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
journalctl -f -u avahi-daemon -u NetworkManager
ep 03 21:18:24 sky NetworkManager[335]: <info> [1630718304.8618] device (tun0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Sep 03 21:18:24 sky NetworkManager[335]: <info> [1630718304.8627] device (tun0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Sep 03 21:18:24 sky NetworkManager[335]: <info> [1630718304.8633] device (tun0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Sep 03 21:18:24 sky NetworkManager[335]: <info> [1630718304.8639] device (tun0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Sep 03 21:18:24 sky NetworkManager[335]: <info> [1630718304.8708] device (tun0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Sep 03 21:18:24 sky NetworkManager[335]: <info> [1630718304.8712] device (tun0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Sep 03 21:18:24 sky NetworkManager[335]: <info> [1630718304.8725] device (tun0): Activation: successful, device activated.
Sep 03 21:23:22 sky NetworkManager[335]: <info> [1630718602.6568] manager: NetworkManager state is now CONNECTED_SITE
Sep 03 21:26:18 sky NetworkManager[335]: <info> [1630718778.4978] audit: op="statistics" interface="wlp2s0" ifindex=3 args="2000" pid=2417 uid=1000 result="success"
Sep 03 21:26:24 sky NetworkManager[335]: <info> [1630718784.3070] audit: op="statistics" interface="wlp2s0" ifindex=3 args="0" pid=2417 uid=1000 result="success"
systemctl list-unit-files | grep NetworkManager
NetworkManager-dispatcher.service enabled disabled
NetworkManager-wait-online.service enabled disabled
NetworkManager.service enabled disabled
systemctl list-unit-files | grep dhcp
dhcpcd.service disabled disabled
dhcpcd@.service disabled disabled
lsmod | awk '$1~/^(realtek|r8169|libphy)/
r8169 102400 0
realtek 24576 1
libphy 151552 3 r8169,mdio_devres,realtek
lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.2 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #3 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC Controller/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
02:00.0 Network controller: Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak] (rev 10)
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411B PCI Express Card Reader (rev 01)
03:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
