Limited connectivity, very slow, disconnecting WFI
Hello guys,
I have a weird problem with my Wifi connectivity after a clean update. When i’m connecting with Wifi, it seems to connect very slowly, sometimes i got a limited connectivity and signal is low as well (router is next room).
But when i’m connecting into my phone to have access to internet: every thing is fine.
I check for power saving mode but it’s off, Ipv6 is off too. I’m pretty noob in linux. I don’t have any idea what’s wrong.
Result of Inxi -Fazy
> System:
>   Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
>   parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
>   root=UUID=d3f48133-fb09-453b-8000-0d8117a69e36 rw ipv6.disable=1 quiet
>   udev.log_priority=3
>   Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
>   Distro: Manjaro Linux base: Arch Linux
> Machine:
>   Type: Laptop System: Hewlett-Packard product: HP Pavilion 17 Notebook PC
>   v: 088C100000305910000620100 serial: <filter> Chassis: type: 10
>   serial: <filter>
>   Mobo: Hewlett-Packard model: 1972 v: 95.33 serial: <filter> UEFI: Insyde
>   v: F.23 date: 06/04/2014
> Battery:
>   ID-1: BAT0 charge: 32.5 Wh (100.0%) condition: 32.5/32.5 Wh (100.0%)
>   volts: 12.2 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
>   serial: N/A status: Full
> CPU:
>   Info: Dual Core model: Intel Core i5-3230M bits: 64 type: MT MCP
>   arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
>   cache: L2: 3 MiB
>   flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 20760
>   Speed: 1197 MHz min/max: 1200/3200 MHz Core speeds (MHz): 1: 1197 2: 1197
>   3: 1197 4: 1197
>   Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
>   Type: l1tf mitigation: PTE Inversion
>   Type: mds mitigation: Clear CPU buffers; SMT vulnerable
>   Type: meltdown mitigation: PTI
>   Type: spec_store_bypass
>   mitigation: Speculative Store Bypass disabled via prctl and seccomp
>   Type: spectre_v1
>   mitigation: usercopy/swapgs barriers and __user pointer sanitization
>   Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
>   IBRS_FW, STIBP: conditional, RSB filling
>   Type: srbds status: Vulnerable: No microcode
>   Type: tsx_async_abort status: Not affected
> Graphics:
>   Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
>   driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
>   Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon
>   520 Mobile]
>   vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
>   bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
>   Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
>   loaded: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
>   display-ID: :0 screens: 1
>   Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
>   s-diag: 485mm (19.1")
>   Monitor-1: LVDS1 res: 1600x900 hz: 60 dpi: 107 size: 380x210mm (15.0x8.3")
>   diag: 434mm (17.1")
>   OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
>   v: 4.2 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
> Audio:
>   Device-1: Intel 7 Series/C216 Family High Definition Audio
>   vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
>   chip-ID: 8086:1e20 class-ID: 0403
>   Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
>   Sound Server-2: JACK v: 0.125.0 running: no
>   Sound Server-3: PulseAudio v: 14.2 running: yes
>   Sound Server-4: PipeWire v: 0.3.23 running: no
> Network:
>   Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard
>   driver: rt2800pci v: 2.3.0 port: 4000 bus-ID: 07:00.0 chip-ID: 1814:3290
>   class-ID: 0280
>   IF: wlo1 state: up mac: <filter>
>   Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
>   driver: r8169 v: kernel port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8136
>   class-ID: 0200
>   IF: eno1 state: down mac: <filter>
> Bluetooth:
>   Device-1: Ralink RT3290 Bluetooth vendor: Hewlett-Packard driver: N/A
>   bus-ID: 07:00.1 chip-ID: 1814:3298 class-ID: 0d11
>   Report: This feature requires one of these tools: hciconfig/bt-adapter
> Drives:
>   Local Storage: total: 988.82 GiB used: 94.82 GiB (9.6%)
>   SMART Message: Unable to run smartctl. Root privileges required.
>   ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010A9E680
>   size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
>   rotation: 5400 rpm serial: <filter> rev: A590 scheme: GPT
>   ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra Fit
>   size: 57.3 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
>   rev: 1.00 scheme: MBR
>   SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
> Partition:
>   ID-1: / raw-size: 931.22 GiB size: 915.6 GiB (98.32%)
>   used: 94.82 GiB (10.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
>   ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
>   used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
> Swap:
>   Alert: No Swap data was found.
> Sensors:
>   System Temperatures: cpu: 56.0 C mobo: N/A gpu: radeon temp: 52.0 C
>   Fan Speeds (RPM): N/A
> Info:
>   Processes: 174 Uptime: 7h 21m wakeups: 1 Memory: 3.74 GiB
>   used: 2.14 GiB (57.2%) Init: systemd v: 247 tool: systemctl Compilers:
>   gcc: 10.2.0 Packages: pacman: 1207 lib: 403 Shell: Bash v: 5.1.0
>   running-in: konsole inxi: 3.3.03
and iwconfig:
lo no wireless extensions.
eno1 no wireless extensions.
wlo1 IEEE 802.11 ESSID:“NUMERICABLE-4E14”
Mode:Managed Frequency:2.412 GHz Access Point: C0:D9:62:C6:50:6B
Bit Rate=6.5 Mb/s Tx-Power=20 dBm
Retry short long limit:2 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=28/70 Signal level=-82 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:79 Invalid misc:107 Missed beacon:0
Hi @guiui59 ,
Welcome to the forum!
Could you please put the output of the following terminal commands here?
rfkill list all
You can unblock any devices with rfkill unblock all
sudo dmesg | grep r8169
iw phy0 info
I also suggest you on trying to disable randomization on your wifi card. But first I have to see the outputs.
A useful post for this is the following: ‘IPV6 drops at random intervals - #2 by megavolt
Hope this help, regards.
rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Sudo dmesg | grep R8169
> [   11.529119] r8169 0000:08:00.0: can't disable ASPM; OS doesn't have ASPM
> control
> [   11.531522] libphy: r8169: probed
> [   11.531886] r8169 0000:08:00.0 eth0: RTL8106e, a0:d3:c1:58:8d:a1, XID 449
> , IRQ 32
> [   11.716429] r8169 0000:08:00.0 eno1: renamed from eth0
> [   24.521078] RTL8208 Fast Ethernet r8169-800:00: attached PHY driver [RTL8
> 208 Fast Ethernet] (mii_bus:phy_addr=r8169-800:00, irq=IGNORE)
> [   24.792855] r8169 0000:08:00.0 eno1: Link is Down
 and iw phy0 info
> iw phy0 info
> Wiphy phy0
>         wiphy index: 0
>         max # scan SSIDs: 4
>         max scan IEs length: 2257 bytes
>         max # sched scan SSIDs: 0
>         max # match sets: 0
>         Retry short long limit: 2
>         Coverage class: 0 (up to 0m)
>         Device supports RSN-IBSS.
>         Supported Ciphers:
>                 * WEP40 (00-0f-ac:1)
>                 * WEP104 (00-0f-ac:5)
>                 * TKIP (00-0f-ac:2)
>                 * CCMP-128 (00-0f-ac:4)
>                 * CCMP-256 (00-0f-ac:10)
>                 * GCMP-128 (00-0f-ac:8)
>                 * GCMP-256 (00-0f-ac:9)
>                 * CMAC (00-0f-ac:6)
>                 * CMAC-256 (00-0f-ac:13)
>                 * GMAC-128 (00-0f-ac:11)
>                 * GMAC-256 (00-0f-ac:12)
>         Available Antennas: TX 0 RX 0
>         Supported interface modes:
>                  * IBSS
>                  * managed
>                  * AP
>                  * AP/VLAN
>                  * monitor
>                  * mesh point
>         Band 1:
>                 Capabilities: 0x17e
>                         HT20/HT40
>                         SM Power Save disabled
>                         RX Greenfield
>                         RX HT20 SGI
>                         RX HT40 SGI
>                         RX STBC 1-stream
>                         Max AMSDU length: 3839 bytes
>                         No DSSS/CCK HT40
>                 Maximum RX AMPDU length 32767 bytes (exponent: 0x002)
>                 Minimum RX AMPDU time spacing: 2 usec (0x04)
>                 HT TX/RX MCS rate indexes supported: 0-7, 32
>                 Bitrates (non-HT):
>                         * 1.0 Mbps
>                         * 2.0 Mbps (short preamble supported)
>                         * 5.5 Mbps (short preamble supported)
>                         * 11.0 Mbps (short preamble supported)
>                         * 6.0 Mbps
>                         * 9.0 Mbps
>                         * 12.0 Mbps
>                         * 18.0 Mbps
>                         * 24.0 Mbps
>                         * 36.0 Mbps
>                         * 48.0 Mbps
>                         * 54.0 Mbps
>                 Frequencies:
>                         * 2412 MHz [1] (20.0 dBm)
>                         * 2417 MHz [2] (20.0 dBm)
>                         * 2422 MHz [3] (20.0 dBm)
>                         * 2427 MHz [4] (20.0 dBm)
>                         * 2432 MHz [5] (20.0 dBm)
>                         * 2437 MHz [6] (20.0 dBm)
>                         * 2442 MHz [7] (20.0 dBm)
>                         * 2447 MHz [8] (20.0 dBm)
>                         * 2452 MHz [9] (20.0 dBm)
>                         * 2457 MHz [10] (20.0 dBm)
>                         * 2462 MHz [11] (20.0 dBm)
>                         * 2467 MHz [12] (20.0 dBm)
>                         * 2472 MHz [13] (20.0 dBm) (no IR)
>                         * 2484 MHz [14] (20.0 dBm) (no IR)
>         Supported commands:
>                  * new_interface
>                  * set_interface
>                  * new_key
>                  * start_ap
>                  * new_station
>                  * new_mpath
>                  * set_mesh_config
>                  * set_bss
>                  * authenticate
>                  * associate
>                  * deauthenticate
>                  * disassociate
>                  * join_ibss
>                  * join_mesh
>                  * remain_on_channel
>                  * set_tx_bitrate_mask
>                  * frame
>                  * frame_wait_cancel
>                  * set_wiphy_netns
>                  * set_channel
>                  * set_wds_peer
>                  * probe_client
>                  * set_noack_map
>                  * register_beacons
>                  * start_p2p_device
>                  * set_mcast_rate
>                  * connect
>                  * disconnect
>                  * set_qos_map
>                  * set_multicast_to_unicast
>         software interface modes (can always be added):
>                  * AP/VLAN
>                  * monitor
>         valid interface combinations:
>                  * #{ AP, mesh point } <= 8,
>                    total <= 8, #channels <= 1
>         HT Capability overrides:
>                  * MCS: ff ff ff ff ff ff ff ff ff ff
>                  * maximum A-MSDU length
>                  * supported channel width
>                  * short GI for 40 MHz
>                  * max A-MPDU length exponent
>                  * min MPDU start spacing
>         Device supports TX status socket option.
>         Device supports HT-IBSS.
>         Device supports SAE with AUTHENTICATE command
>         Device supports low priority scan.
>         Device supports scan flush.
>         Device supports AP scan.
>         Device supports per-vif TX power setting
>         Driver supports full state transitions for AP/GO clients
>         Driver supports a userspace MPM
>         Device supports configuring vdev MAC-addr on create.
>         max # scan plans: 1
>         max scan plan interval: -1
>         max scan plan iterations: 0
>         Supported TX frame types:
>                  * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
>                  * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
>                  * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
>                  * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
>                  * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
>                  * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
>                  * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
>                  * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
>         Supported RX frame types:
>                  * IBSS: 0x40 0xb0 0xc0 0xd0
>                  * managed: 0x40 0xb0 0xd0
>                  * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
>                  * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
>                  * mesh point: 0xb0 0xc0 0xd0
>                  * P2P-client: 0x40 0xd0
>                  * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
>                  * P2P-device: 0x40 0xd0
>         Supported extended features:
>                 * [ RRM ]: RRM
>                 * [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
>                 * [ CQM_RSSI_LIST ]: multiple CQM_RSSI_THOLD records
>                 * [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
>                 * [ SCAN_RANDOM_SN ]: use random sequence numbers in scans
>                 * [ SCAN_MIN_PREQ_CONTENT ]: use probe request with only rate IEs in scans
>                 * [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
>                 * [ DEL_IBSS_STA ]: deletion of IBSS station support
>                 * [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
>                 * [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
Thanks for the help!
Hi @guiui59,
I guess you have another problem and I need from you to post the output of the following terminal commands:
journalctl -f -u avahi-daemon -u NetworkManager
systemctl list-unit-files | grep NetworkManager
systemctl list-unit-files | grep dhcp
The reference for my questions are the post I suggest you to read and the following one.
[SOLVED] Wired connection dropping randomly for a few seconds / Networking, Server, and Protection / Arch Linux Forums
Regards
Ok no problem i’ll do it.
the first one : – Journal begins at Sat 2020-11-07 12:38:14 CET. –
avril 11 23:00:00 clementpc NetworkManager[465]: [1618174800.2619] device (wlo1): supplicant interface state: associating → completed
avril 11 23:00:02 clementpc NetworkManager[465]: [1618174802.4654] dhcp4 (wlo1): state changed unknown → bound, address=10.10.154.44
avril 11 23:52:04 clementpc NetworkManager[465]: [1618177924.4457] device (wlo1): supplicant interface state: completed → authenticating
avril 11 23:52:04 clementpc NetworkManager[465]: [1618177924.4458] device (wlo1): DHCPv4 lease renewal requested
avril 11 23:52:04 clementpc NetworkManager[465]: [1618177924.4608] dhcp4 (wlo1): canceled DHCP transaction
avril 11 23:52:04 clementpc NetworkManager[465]: [1618177924.4609] dhcp4 (wlo1): state changed bound → done
avril 11 23:52:04 clementpc NetworkManager[465]: [1618177924.4614] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
avril 11 23:52:04 clementpc NetworkManager[465]: [1618177924.4676] device (wlo1): supplicant interface state: authenticating → associating
avril 11 23:52:04 clementpc NetworkManager[465]: [1618177924.4715] device (wlo1): supplicant interface state: associating → completed
avril 11 23:52:06 clementpc NetworkManager[465]: [1618177926.6630] dhcp4 (wlo1): state changed unknown → bound, address=10.10.154.44
and
NetworkManager-dispatcher.service enabled disabled
NetworkManager-wait-online.service enabled disabled
NetworkManager.service enabled disabled
[clement@clementpc ~]$ systemctl list-unit-files | grep dhcp
dhcpcd.service disabled disabled
dhcpcd@.service disabled disabled
Hi @guiui59 ,
I could tell you that all the parameters look nice, the only thin I did not check is the output of the following commands:
lsmod | awk '$1~/^(realtek|r8169|libphy)/'
lspci
Regards
Hi j8a,
the first one
r8169 102400 0
realtek 24576 1
libphy 151552 3 r8169,mdio_devres,realtek
and
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4)
00:1c.2 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM76 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile]
07:00.0 Network controller: Ralink corp. RT3290 Wireless 802.11n 1T/1R PCIe
07:00.1 Bluetooth: Ralink corp. RT3290 Bluetooth
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
09:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
thank you so much
Hi @guiui59 ,
You have installed a different driver that could maybe working, but from this post @megavolt it is suggested another one because there is known problems using different drivers.
Ralink RT3290 Bluetooth adapter not found - #3 by megavolt
Please, consider to remove your installed drivers and follow the instructions of the post in order to install the ones that works best.
Regards,
