inxi -Fxz
❯ inxi -Fxz
System:    Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: KDE Plasma 5.20.5
           Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: MSI model: Z97S SLI Krait Edition (MS-7922) v: 2.0 serial: <filter>
           UEFI: American Megatrends v: 10.7 date: 02/16/2016
CPU:       Info: Quad Core model: Intel Core i5-4690K bits: 64 type: MCP arch: Haswell rev: 3
           L2 cache: 6 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28008
           Speed: 805 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 805 2: 825 3: 805 4: 808
Graphics:  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
           vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GM206 [GeForce GTX 960] vendor: ASUSTeK driver: nvidia v: 460.32.03
           bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia resolution: 1920x1080~60Hz
           OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03 direct render: Yes
Audio:     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Micro-Star MSI
           driver: snd_hda_intel v: kernel bus ID: 00:03.0
           Device-2: Intel 9 Series Family HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0
           Device-3: NVIDIA GM206 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 01:00.1
           Device-4: Logitech QuickCam Communicate STX type: USB driver: gspca_zc3xx,snd-usb-audio
           bus ID: 3-4:2
           Sound Server: ALSA v: k5.10.7-3-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
           driver: r8169 v: kernel port: d000 bus ID: 05:00.0
           IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 2.72 TiB used: 1002.99 GiB (36.0%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB temp: 33.9 C
           ID-2: /dev/sda vendor: Western Digital model: WD5000BEKT-00KA9T0 size: 465.76 GiB
           ID-3: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
           ID-4: /dev/sdc vendor: Kingston model: SA400S37240G size: 223.57 GiB
           ID-5: /dev/sdd type: USB vendor: Western Digital model: WD My Passport 0820 size: 931.48 GiB
Partition: ID-1: / size: 146.65 GiB used: 17.53 GiB (12.0%) fs: ext4 dev: /dev/nvme0n1p3
           ID-2: /boot/efi size: 5.49 GiB used: 312 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1
           ID-3: /home size: 353.35 GiB used: 16.61 GiB (4.7%) fs: ext4 dev: /dev/nvme0n1p4
Swap:      ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 53 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 27%
Info:      Processes: 211 Uptime: 26m Memory: 15.52 GiB used: 4.36 GiB (28.1%) Init: systemd Compilers:
           gcc: 10.2.0 Packages: 1403 Shell: Zsh v: 5.8 inxi: 3.2.02
I’ve spent several hours Google-ing and trying to get libvirt to start without the following error:
Error
 ❯ sudo systemctl status libvirtd.service
    ● libvirtd.service - Virtualization daemon
         Loaded: loaded (/usr/lib/systemd/system/libvirtd.service; enabled; vendor preset: disabled)
         Active: failed (Result: exit-code) since Tue 2021-01-19 19:51:21 PST; 16s ago
    TriggeredBy: ● libvirtd.socket
                 ● libvirtd-admin.socket
                 ● libvirtd-ro.socket
           Docs: man:libvirtd(8)
                 https://libvirt.org
        Process: 3405 ExecStart=/usr/bin/libvirtd $LIBVIRTD_ARGS (code=exited, status=3)
       Main PID: 3405 (code=exited, status=3)
    Jan 19 19:51:21 username systemd[1]: libvirtd.service: Scheduled restart job, restart counter is at 5.
    Jan 19 19:51:21 username systemd[1]: Stopped Virtualization daemon.
    Jan 19 19:51:21 username systemd[1]: libvirtd.service: Start request repeated too quickly.
    Jan 19 19:51:21 username systemd[1]: libvirtd.service: Failed with result 'exit-code'.
    Jan 19 19:51:21 username systemd[1]: Failed to start Virtualization daemon.
    Jan 19 19:51:27 username systemd[1]: libvirtd.service: Start request repeated too quickly.
    Jan 19 19:51:27 username systemd[1]: libvirtd.service: Failed with result 'exit-code'.
    Jan 19 19:51:27 username systemd[1]: Failed to start Virtualization daemon.
❯virsh -c qemu:///system
error: failed to connect to the hypervisor
error: Failed to connect socket to '/var/run/libvirt/libvirt-sock': Connection refused
System
❯ lsmod | grep kvm
kvm_intel             327680  0
kvm                   933888  1 kvm_intel
irqbypass              16384  1 kvm
❯ LC_ALL=C lscpu | grep Virtualization
Virtualization:                  VT-x
❯ zgrep CONFIG_KVM /proc/config.gz
CONFIG_KVM_GUEST=y
CONFIG_KVM_MMIO=y
CONFIG_KVM_ASYNC_PF=y
CONFIG_KVM_VFIO=y
CONFIG_KVM_GENERIC_DIRTYLOG_READ_PROTECT=y
CONFIG_KVM_COMPAT=y
CONFIG_KVM_XFER_TO_GUEST_WORK=y
CONFIG_KVM=m
CONFIG_KVM_INTEL=m
CONFIG_KVM_AMD=m
CONFIG_KVM_AMD_SEV=y
CONFIG_KVM_MMU_AUDIT=y
❯ emulator -accel-check
accel:
0
KVM (version 12) is installed and usable.
accel
Arch Wiki:
I’ve followed several posts on setup:
- Installing KVM/QEMU/virt-manager on Manjaro Linux(Arch Linux) | Boseji’s Lab
- https://computingforgeeks.com/complete-installation-of-kvmqemu-and-virt-manager-on-arch-linux-and-manjaro/
- How to install Virtual Machine Manager (KVM) in Manjaro and Arch Linux | FOSS Linux
Just a couple of the many troubleshooting articles I’ve tried:
Has anyone seen this one before and recall what you did to address it? Any thoughts, by chance?
Thanks!
