I recently switched from Nvidia to AMD graphic card. Removed the proprietary drivers, deleted all configs related to nvidia modules, deleted all nvidia-xorg.conf files. The issue i have is lightdm fails to load at boot everytime. If i switch to TTY, login and start lightdm manually it loads fine.
I followed all the tips suggested in this thread https://forum.manjaro.org/t/lightdm-failed-to-start-with-kernel-5-11-14/62946 but i still have the issue. I’m on kernel 5.13 BTW.
Yes.
It seems i was following the wrong solution afterall. I finally found It on Archwiki, LightDM troubleshooting section: https://wiki.archlinux.org/title/LightDM#LightDM_not_starting_and_screen_flashing
[LightDM]
logind-check-graphical=true
Thanks for you assistance anyway.
