Good morning, I’m not sure if this would be the place, but since yesterday I can’t start the computer in graphical mode!
Boot fails and also fails if I enter another tty and try to startx “connection to X server lost”.
The mhwd -li command just returns “video-linux”.
I use Ornara 21.0.7 updated with 5.11.22-2 kernel… even in my grub there’s only this one… then I’ll look for an LTS kernel to fix it!
looking at the startx log I saw two errors:
Failed to load module “fdev” (module does not exist, 0)
Failed to load module “vesa” (module does not exist, 0)
Before this post I followed the following tips:
/t/update-error-on-system-update/70244
and
/t/desktop-environment-does-not-start-on-load-i-have-to-run-startx/59074
form this forum…
And
after pacman -Q | grep mhwd
I have removed mhwd-nvidia and mhwd-nvidia-390xx because i have Radeon RX550
Well, I have package xfwm4 Can I reinstall and whole xfce4 will reinstalled?
The system found xfdesktop… It is not on my system…
Thanks!
Edit: I do sudo pacman -S xfwm4
gtk-update-icon-cache: error while loading shared libraries: libjpeg.so.8: cannot open shared file: No shuch file or directory
error: command not executed correctly
Thanks! there are 15 options, I dont get one, and pacman reinstall
14: xfconf, exo, garcon, thunar, thunar-volman, tumbler, xfce4-appfinder, xfce4-panel, xfce4-power-manager, xfce4-session, xfce4-setting, xfce4-terminal, xfdesktop and xfwm4…
and install: xfwm4-themes
Again:
