dmesg
[ 0.000000] microcode: microcode updated early to revision 0x7, date = 2018-04-23
[ 0.000000] Linux version 5.9.16-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=cabb4911-c30c-4498-801f-1af4194fa97d ro quiet cryptdevice=UUID=5403d2f4-15d4-4164-b22c-9edd31160ea5:luks-5403d2f4-15d4-4164-b22c-9edd31160ea5 root=/dev/mapper/luks-5403d2f4-15d4-4164-b22c-9edd31160ea5 apparmor=1 security=apparmor resume=/dev/mapper/luks-1cee0395-584e-47c4-a3a8-1c8c341226b3 udev.log_priority=3
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: x87 FPU will use FXSAVE
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000befcefff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000befcf000-0x00000000bf6cefff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bf6cf000-0x00000000bf7cefff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bf7cf000-0x00000000bf7fefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000bf7ff000-0x00000000bf7fffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bf800000-0x00000000bfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed13fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed19000-0x00000000fed19fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1b000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffd80000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000017bffffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000017c000000-0x000000017fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000180000000-0x00000001bbffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: Hewlett-Packard HP ProBook 4520s/1411, BIOS 68AZZ Ver. F.0F 02/18/2011
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2526.998 MHz processor
[ 0.001637] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001639] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001647] last_pfn = 0x1bc000 max_arch_pfn = 0x400000000
[ 0.001652] MTRR default type: uncachable
[ 0.001653] MTRR fixed ranges enabled:
[ 0.001654] 00000-9FFFF write-back
[ 0.001655] A0000-BFFFF uncachable
[ 0.001656] C0000-FFFFF write-protect
[ 0.001657] MTRR variable ranges enabled:
[ 0.001658] 0 base 0FFC00000 mask FFFC00000 write-protect
[ 0.001659] 1 base 000000000 mask F80000000 write-back
[ 0.001660] 2 base 080000000 mask FC0000000 write-back
[ 0.001661] 3 base 100000000 mask F80000000 write-back
[ 0.001662] 4 base 180000000 mask FC0000000 write-back
[ 0.001663] 5 base 1BC000000 mask FFC000000 uncachable
[ 0.001664] 6 disabled
[ 0.001664] 7 disabled
[ 0.002285] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.002467] last_pfn = 0xbf800 max_arch_pfn = 0x400000000
[ 0.014416] check: Scanning 1 areas for low memory corruption
[ 0.014767] RAMDISK: [mem 0x36029000-0x3700bfff]
[ 0.014778] ACPI: Early table checksum verification disabled
[ 0.014783] ACPI: RSDP 0x00000000000FDDC0 000024 (v02 HPQOEM)
[ 0.014787] ACPI: XSDT 0x00000000BF7FE120 000084 (v01 HPQOEM SLIC-MPC 0000000F 01000013)
[ 0.014795] ACPI: FACP 0x00000000BF7FC000 0000F4 (v03 HPQOEM 1411 0000000F HP 00000001)
[ 0.014802] ACPI: DSDT 0x00000000BF7D8000 01EC21 (v02 HPQOEM 1411 00000001 INTL 20060912)
[ 0.014806] ACPI: FACS 0x00000000BF77E000 000040
[ 0.014809] ACPI: FACS 0x00000000BF77E000 000040
[ 0.014812] ACPI: HPET 0x00000000BF7FB000 000038 (v01 HPQOEM 1411 00000001 HP 00000001)
[ 0.014815] ACPI: APIC 0x00000000BF7FA000 0000BC (v01 HPQOEM 1411 00000001 HP 00000001)
[ 0.014819] ACPI: MCFG 0x00000000BF7F9000 00003C (v01 HPQOEM 1411 00000001 HP 00000001)
[ 0.014823] ACPI: ASF! 0x00000000BF7F8000 0000A0 (v32 HPQOEM 1411 00000001 HP 00000001)
[ 0.014826] ACPI: SSDT 0x00000000BF7D5000 000135 (v01 HPQOEM SataAhci 00001000 INTL 20060912)
[ 0.014830] ACPI: SSDT 0x00000000BF7D4000 000314 (v01 HPQOEM PtidDevc 00001000 INTL 20060912)
[ 0.014834] ACPI: SLIC 0x00000000BF7D3000 000176 (v01 HPQOEM SLIC-MPC 00000001 HP 00000001)
[ 0.014837] ACPI: SSDT 0x00000000BF7D2000 00005F (v01 HPQOEM HPQNLP 00000001 INTL 20060912)
[ 0.014841] ACPI: SSDT 0x00000000BF7D1000 000A10 (v01 PmRef CpuPm 00003000 INTL 20060912)
[ 0.014845] ACPI: SSDT 0x00000000BF7D0000 000288 (v01 PmRef Cpu0Tst 00003000 INTL 20060912)
[ 0.014848] ACPI: SSDT 0x00000000BF7CF000 000225 (v01 PmRef ApTst 00003000 INTL 20060912)
[ 0.014859] ACPI: Local APIC address 0xfee00000
[ 0.014918] No NUMA configuration found
[ 0.014919] Faking a node at [mem 0x0000000000000000-0x00000001bbffffff]
[ 0.014923] NODE_DATA(0) allocated [mem 0x1bbffa000-0x1bbffdfff]
[ 0.014964] Zone ranges:
[ 0.014965] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.014966] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.014968] Normal [mem 0x0000000100000000-0x00000001bbffffff]
[ 0.014969] Device empty
[ 0.014970] Movable zone start for each node
[ 0.014970] Early memory node ranges
[ 0.014971] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.014972] node 0: [mem 0x0000000000100000-0x00000000befcefff]
[ 0.014973] node 0: [mem 0x00000000bf7ff000-0x00000000bf7fffff]
[ 0.014974] node 0: [mem 0x0000000100000000-0x000000017bffffff]
[ 0.014975] node 0: [mem 0x0000000180000000-0x00000001bbffffff]
[ 0.015623] Zeroed struct page in unavailable ranges: 37010 pages
[ 0.015626] Initmem setup node 0 [mem 0x0000000000001000-0x00000001bbffffff]
[ 0.015628] On node 0 totalpages: 1535854
[ 0.015629] DMA zone: 64 pages used for memmap
[ 0.015630] DMA zone: 21 pages reserved
[ 0.015631] DMA zone: 3998 pages, LIFO batch:0
[ 0.015678] DMA32 zone: 12160 pages used for memmap
[ 0.015679] DMA32 zone: 778192 pages, LIFO batch:63
[ 0.027042] Normal zone: 12032 pages used for memmap
[ 0.027045] Normal zone: 753664 pages, LIFO batch:63
[ 0.038289] ACPI: PM-Timer IO Port: 0x408
[ 0.038294] ACPI: Local APIC address 0xfee00000
[ 0.038304] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.038305] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.038305] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.038306] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.038307] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.038307] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.038308] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.038309] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.038325] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.038328] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.038330] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.038331] ACPI: IRQ0 used by override.
[ 0.038332] ACPI: IRQ9 used by override.
[ 0.038335] Using ACPI (MADT) for SMP configuration information
[ 0.038337] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.038344] smpboot: Allowing 8 CPUs, 4 hotplug CPUs
[ 0.038370] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.038371] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.038372] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.038373] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.038374] PM: hibernation: Registered nosave memory: [mem 0xbefcf000-0xbf6cefff]
[ 0.038375] PM: hibernation: Registered nosave memory: [mem 0xbf6cf000-0xbf7cefff]
[ 0.038376] PM: hibernation: Registered nosave memory: [mem 0xbf7cf000-0xbf7fefff]
[ 0.038377] PM: hibernation: Registered nosave memory: [mem 0xbf800000-0xbfffffff]
[ 0.038378] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xdfffffff]
[ 0.038379] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.038379] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfebfffff]
[ 0.038380] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.038381] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
[ 0.038381] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed13fff]
[ 0.038382] PM: hibernation: Registered nosave memory: [mem 0xfed14000-0xfed18fff]
[ 0.038383] PM: hibernation: Registered nosave memory: [mem 0xfed19000-0xfed19fff]
[ 0.038383] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed1afff]
[ 0.038384] PM: hibernation: Registered nosave memory: [mem 0xfed1b000-0xfed1ffff]
[ 0.038385] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.038385] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.038386] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffd7ffff]
[ 0.038387] PM: hibernation: Registered nosave memory: [mem 0xffd80000-0xffffffff]
[ 0.038388] PM: hibernation: Registered nosave memory: [mem 0x17c000000-0x17fffffff]
[ 0.038391] [mem 0xc0000000-0xdfffffff] available for PCI devices
[ 0.038392] Booting paravirtualized kernel on bare hardware
[ 0.038396] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.044286] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[ 0.044705] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
[ 0.044716] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
[ 0.044717] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.044746] Built 1 zonelists, mobility grouping on. Total pages: 1511577
[ 0.044747] Policy zone: Normal
[ 0.044749] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=cabb4911-c30c-4498-801f-1af4194fa97d ro quiet cryptdevice=UUID=5403d2f4-15d4-4164-b22c-9edd31160ea5:luks-5403d2f4-15d4-4164-b22c-9edd31160ea5 root=/dev/mapper/luks-5403d2f4-15d4-4164-b22c-9edd31160ea5 apparmor=1 security=apparmor resume=/dev/mapper/luks-1cee0395-584e-47c4-a3a8-1c8c341226b3 udev.log_priority=3
[ 0.046148] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.046782] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.046893] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.086671] Memory: 5915604K/6143416K available (14339K kernel code, 1529K rwdata, 4760K rodata, 1664K init, 2888K bss, 227552K reserved, 0K cma-reserved)
[ 0.086681] random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
[ 0.086848] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.086863] Kernel/User page tables isolation: enabled
[ 0.086888] ftrace: allocating 41085 entries in 161 pages
[ 0.106286] ftrace: allocated 161 pages with 3 groups
[ 0.106487] rcu: Preemptible hierarchical RCU implementation.
[ 0.106488] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.106489] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[ 0.106490] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.106491] Trampoline variant of Tasks RCU enabled.
[ 0.106491] Rude variant of Tasks RCU enabled.
[ 0.106492] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.106493] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.111237] NR_IRQS: 20736, nr_irqs: 488, preallocated irqs: 16
[ 0.111647] Console: colour dummy device 80x25
[ 0.111655] printk: console [tty0] enabled
[ 0.111678] ACPI: Core revision 20200717
[ 0.111887] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.111907] APIC: Switch to symmetric I/O mode setup
[ 0.112514] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.128573] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x246cda0ff86, max_idle_ns: 440795293526 ns
[ 0.128579] Calibrating delay loop (skipped), value calculated using timer frequency.. 5056.57 BogoMIPS (lpj=8423326)
[ 0.128582] pid_max: default: 32768 minimum: 301
[ 0.128613] LSM: Security Framework initializing
[ 0.128619] Yama: becoming mindful.
[ 0.128650] AppArmor: AppArmor initialized
[ 0.128695] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.128723] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.129082] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.129092] process: using mwait in idle threads
[ 0.129095] Last level iTLB entries: 4KB 512, 2MB 7, 4MB 7
[ 0.129096] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.129099] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.129102] Spectre V2 : Mitigation: Full generic retpoline
[ 0.129102] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.129103] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.129105] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.129106] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.129108] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.129110] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.129350] Freeing SMP alternatives memory: 32K
[ 0.237679] smpboot: CPU0: Intel(R) Core(TM) i3 CPU M 380 @ 2.53GHz (family: 0x6, model: 0x25, stepping: 0x5)
[ 0.237829] Performance Events: PEBS fmt1+, Westmere events, 16-deep LBR, Intel PMU driver.
[ 0.237837] core: CPUID marked event: 'bus cycles' unavailable
[ 0.237838] ... version: 3
[ 0.237839] ... bit width: 48
[ 0.237839] ... generic registers: 4
[ 0.237840] ... value mask: 0000ffffffffffff
[ 0.237841] ... max period: 000000007fffffff
[ 0.237841] ... fixed-purpose events: 3
[ 0.237842] ... event mask: 000000070000000f
[ 0.237901] rcu: Hierarchical SRCU implementation.
[ 0.238575] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.238575] smp: Bringing up secondary CPUs ...
[ 0.238575] x86: Booting SMP configuration:
[ 0.238575] .... node #0, CPUs: #1
[ 0.240921] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.240921] #2 #3
[ 0.247414] smp: Brought up 1 node, 4 CPUs
[ 0.247414] smpboot: Max logical packages: 2
[ 0.247414] smpboot: Total of 4 processors activated (20224.31 BogoMIPS)
[ 0.248966] devtmpfs: initialized
[ 0.248966] x86/mm: Memory block size: 128MB
[ 0.249359] PM: Registering ACPI NVS region [mem 0xbf6cf000-0xbf7cefff] (1048576 bytes)
[ 0.249359] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.249359] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.249359] pinctrl core: initialized pinctrl subsystem
[ 0.249359] PM: RTC time: 14:11:19, date: 2021-06-13
[ 0.251918] NET: Registered protocol family 16
[ 0.252207] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.252392] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.252583] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.252606] audit: initializing netlink subsys (disabled)
[ 0.252638] audit: type=2000 audit(1623593479.139:1): state=initialized audit_enabled=0 res=1
[ 0.252638] thermal_sys: Registered thermal governor 'fair_share'
[ 0.252638] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.252638] thermal_sys: Registered thermal governor 'step_wise'
[ 0.252638] thermal_sys: Registered thermal governor 'user_space'
[ 0.252638] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.252638] cpuidle: using governor ladder
[ 0.252638] cpuidle: using governor menu
[ 0.252638] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.252638] ACPI: bus type PCI registered
[ 0.252638] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.252638] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.252638] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.252638] PCI: Using configuration type 1 for base access
[ 0.252643] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.252644] mtrr: probably your BIOS does not setup all CPUs.
[ 0.252645] mtrr: corrected configuration.
[ 0.255258] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.255407] ACPI: Added _OSI(Module Device)
[ 0.255409] ACPI: Added _OSI(Processor Device)
[ 0.255410] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.255411] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.255413] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.255414] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.255415] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.272922] ACPI: 7 ACPI AML tables successfully acquired and loaded
[ 0.274294] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.285617] ACPI: Dynamic OEM Table Load:
[ 0.285624] ACPI: SSDT 0xFFFF8D6F74530800 00047D (v01 PmRef Cpu0Ist 00003000 INTL 20060912)
[ 0.286944] ACPI: Dynamic OEM Table Load:
[ 0.286950] ACPI: SSDT 0xFFFF8D6F7407F000 0008AA (v01 PmRef Cpu0Cst 00003001 INTL 20060912)
[ 0.288539] ACPI: Dynamic OEM Table Load:
[ 0.288544] ACPI: SSDT 0xFFFF8D6F746C2000 000303 (v01 PmRef ApIst 00003000 INTL 20060912)
[ 0.289635] ACPI: Dynamic OEM Table Load:
[ 0.289640] ACPI: SSDT 0xFFFF8D6F740F3800 000119 (v01 PmRef ApCst 00003000 INTL 20060912)
[ 0.291706] ACPI: EC: EC started
[ 0.291707] ACPI: EC: interrupt blocked
[ 0.736006] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.736009] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[ 0.736010] ACPI: Interpreter enabled
[ 0.736041] ACPI: (supports S0 S3 S4 S5)
[ 0.736043] ACPI: Using IOAPIC for interrupt routing
[ 0.736075] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.736477] ACPI: Enabled 9 GPEs in block 00 to 3F
[ 0.740173] ACPI: Power Resource [APPR] (off)
[ 0.743024] ACPI: Power Resource [COMP] (on)
[ 0.743429] ACPI: Power Resource [LPP] (on)
[ 0.748905] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.748912] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.750526] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[ 0.752733] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.752734] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.753698] PCI host bridge to bus 0000:00
[ 0.753701] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.753703] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.753704] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.753705] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xdfffffff window]
[ 0.753706] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfedfffff window]
[ 0.753708] pci_bus 0000:00: root bus resource [mem 0xfee01000-0xffffffff window]
[ 0.753709] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.753725] pci 0000:00:00.0: [8086:0044] type 00 class 0x060000
[ 0.753753] pci 0000:00:00.0: DMAR: BIOS has allocated no shadow GTT; disabling IOMMU for graphics
[ 0.753869] pci 0000:00:01.0: [8086:0045] type 01 class 0x060400
[ 0.753919] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.754085] pci 0000:00:16.0: [8086:3b64] type 00 class 0x078000
[ 0.754113] pci 0000:00:16.0: reg 0x10: [mem 0xd0604000-0xd060400f 64bit]
[ 0.754218] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.754360] pci 0000:00:1a.0: [8086:3b3c] type 00 class 0x0c0320
[ 0.754379] pci 0000:00:1a.0: reg 0x10: [mem 0xd0609000-0xd06093ff]
[ 0.754495] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.754643] pci 0000:00:1b.0: [8086:3b56] type 00 class 0x040300
[ 0.754668] pci 0000:00:1b.0: reg 0x10: [mem 0xd0600000-0xd0603fff 64bit]
[ 0.754796] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.754953] pci 0000:00:1c.0: [8086:3b42] type 01 class 0x060400
[ 0.755086] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.755263] pci 0000:00:1c.3: [8086:3b48] type 01 class 0x060400
[ 0.755397] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.755560] pci 0000:00:1c.5: [8086:3b4c] type 01 class 0x060400
[ 0.755750] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.755856] pci 0000:00:1d.0: [8086:3b34] type 00 class 0x0c0320
[ 0.755876] pci 0000:00:1d.0: reg 0x10: [mem 0xd0608000-0xd06083ff]
[ 0.755991] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.756140] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[ 0.756364] pci 0000:00:1f.0: [8086:3b0b] type 00 class 0x060100
[ 0.756616] pci 0000:00:1f.2: [8086:3b2f] type 00 class 0x010601
[ 0.756635] pci 0000:00:1f.2: reg 0x10: [io 0x4028-0x402f]
[ 0.756647] pci 0000:00:1f.2: reg 0x14: [io 0x4034-0x4037]
[ 0.756657] pci 0000:00:1f.2: reg 0x18: [io 0x4020-0x4027]
[ 0.756668] pci 0000:00:1f.2: reg 0x1c: [io 0x4030-0x4033]
[ 0.756678] pci 0000:00:1f.2: reg 0x20: [io 0x4000-0x401f]
[ 0.756689] pci 0000:00:1f.2: reg 0x24: [mem 0xd0607000-0xd06077ff]
[ 0.756761] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.756950] pci 0000:01:00.0: [1002:68e0] type 00 class 0x030000
[ 0.756971] pci 0000:01:00.0: reg 0x10: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.756983] pci 0000:01:00.0: reg 0x18: [mem 0xd0500000-0xd051ffff 64bit]
[ 0.756992] pci 0000:01:00.0: reg 0x20: [io 0x3000-0x30ff]
[ 0.757007] pci 0000:01:00.0: reg 0x30: [mem 0xfffe0000-0xffffffff pref]
[ 0.757014] pci 0000:01:00.0: enabling Extended Tags
[ 0.757068] pci 0000:01:00.0: supports D1 D2
[ 0.757156] pci 0000:01:00.1: [1002:aa68] type 00 class 0x040300
[ 0.757177] pci 0000:01:00.1: reg 0x10: [mem 0xd0520000-0xd0523fff 64bit]
[ 0.757219] pci 0000:01:00.1: enabling Extended Tags
[ 0.757271] pci 0000:01:00.1: supports D1 D2
[ 0.757350] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.757352] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.757354] pci 0000:00:01.0: bridge window [mem 0xd0500000-0xd05fffff]
[ 0.757357] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.757411] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.757418] pci 0000:00:1c.0: bridge window [mem 0xd0400000-0xd04fffff]
[ 0.757540] pci 0000:03:00.0: [1814:3090] type 00 class 0x028000
[ 0.757571] pci 0000:03:00.0: reg 0x10: [mem 0xd0300000-0xd030ffff]
[ 0.757999] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.758006] pci 0000:00:1c.3: bridge window [mem 0xd0300000-0xd03fffff]
[ 0.758104] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[ 0.758127] pci 0000:04:00.0: reg 0x10: [io 0x2000-0x20ff]
[ 0.758157] pci 0000:04:00.0: reg 0x18: [mem 0xd0004000-0xd0004fff 64bit pref]
[ 0.758175] pci 0000:04:00.0: reg 0x20: [mem 0xd0000000-0xd0003fff 64bit pref]
[ 0.758187] pci 0000:04:00.0: reg 0x30: [mem 0xfffe0000-0xffffffff pref]
[ 0.758291] pci 0000:04:00.0: supports D1 D2
[ 0.758292] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.758455] pci 0000:00:1c.5: PCI bridge to [bus 04]
[ 0.758459] pci 0000:00:1c.5: bridge window [io 0x2000-0x2fff]
[ 0.758464] pci 0000:00:1c.5: bridge window [mem 0xd0200000-0xd02fffff]
[ 0.758471] pci 0000:00:1c.5: bridge window [mem 0xd0000000-0xd00fffff 64bit pref]
[ 0.758495] pci_bus 0000:05: extended config space not accessible
[ 0.758556] pci 0000:00:1e.0: PCI bridge to [bus 05] (subtractive decode)
[ 0.758563] pci 0000:00:1e.0: bridge window [mem 0xd0100000-0xd01fffff]
[ 0.758570] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.758571] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.758573] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.758579] pci 0000:00:1e.0: bridge window [mem 0xc0000000-0xdfffffff window] (subtractive decode)
[ 0.758580] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfedfffff window] (subtractive decode)
[ 0.758581] pci 0000:00:1e.0: bridge window [mem 0xfee01000-0xffffffff window] (subtractive decode)
[ 0.760035] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 *10 12 14 15)
[ 0.760124] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 *5 6 7 11 12 14 15)
[ 0.760210] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 *10 12 14 15)
[ 0.760297] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.760384] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 *10 12 14 15)
[ 0.760471] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 *11 12 14 15)
[ 0.760556] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
[ 0.760642] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
[ 0.760726] ACPI: PCI Root Bridge [CPBG] (domain 0000 [bus ff])
[ 0.760731] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.760849] PCI host bridge to bus 0000:ff
[ 0.760852] pci_bus 0000:ff: root bus resource [bus ff]
[ 0.760861] pci 0000:ff:00.0: [8086:2c62] type 00 class 0x060000
[ 0.760914] pci 0000:ff:00.1: [8086:2d01] type 00 class 0x060000
[ 0.760986] pci 0000:ff:02.0: [8086:2d10] type 00 class 0x060000
[ 0.761039] pci 0000:ff:02.1: [8086:2d11] type 00 class 0x060000
[ 0.761087] pci 0000:ff:02.2: [8086:2d12] type 00 class 0x060000
[ 0.761136] pci 0000:ff:02.3: [8086:2d13] type 00 class 0x060000
[ 0.761918] ACPI: EC: interrupt unblocked
[ 0.761918] ACPI: EC: event unblocked
[ 0.761918] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.761918] ACPI: EC: GPE=0x16
[ 0.761918] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
[ 0.761918] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[ 0.761918] iommu: Default domain type: Translated
[ 0.761938] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.761938] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.761938] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.761938] vgaarb: loaded
[ 0.762161] SCSI subsystem initialized
[ 0.762181] libata version 3.00 loaded.
[ 0.762181] ACPI: bus type USB registered
[ 0.762181] usbcore: registered new interface driver usbfs
[ 0.762181] usbcore: registered new interface driver hub
[ 0.762181] usbcore: registered new device driver usb
[ 0.762181] pps_core: LinuxPPS API ver. 1 registered
[ 0.762181] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.762181] PTP clock support registered
[ 0.762181] EDAC MC: Ver: 3.0.0
[ 0.762181] NetLabel: Initializing
[ 0.762181] NetLabel: domain hash size = 128
[ 0.762181] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.762181] NetLabel: unlabeled traffic allowed by default
[ 0.762181] PCI: Using ACPI for IRQ routing
[ 0.771863] PCI: pci_cache_line_size set to 64 bytes
[ 0.771952] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[ 0.771954] e820: reserve RAM buffer [mem 0xbefcf000-0xbfffffff]
[ 0.771955] e820: reserve RAM buffer [mem 0xbf800000-0xbfffffff]
[ 0.773208] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.773215] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.775338] clocksource: Switched to clocksource tsc-early
[ 0.793148] VFS: Disk quotas dquot_6.6.0
[ 0.793174] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.793332] AppArmor: AppArmor Filesystem Enabled
[ 0.793377] pnp: PnP ACPI init
[ 0.793886] system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.793888] system 00:00: [mem 0xfed10000-0xfed13fff] has been reserved
[ 0.793890] system 00:00: [mem 0xfed1b000-0xfed1bfff] has been reserved
[ 0.793891] system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.793893] system 00:00: [mem 0xd0700000-0xd0700fff] has been reserved
[ 0.793894] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.793896] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.793897] system 00:00: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.793899] system 00:00: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.793908] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.794100] system 00:01: [io 0xfe00-0xfe0f] has been reserved
[ 0.794102] system 00:01: [io 0xfe80-0xfe8f] has been reserved
[ 0.794104] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.794109] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.794237] system 00:02: [io 0x0200-0x027f] has been reserved
[ 0.794239] system 00:02: [io 0x1000-0x100f] has been reserved
[ 0.794240] system 00:02: [io 0xffff] has been reserved
[ 0.794242] system 00:02: [io 0xffff] has been reserved
[ 0.794243] system 00:02: [io 0x0400-0x047f] has been reserved
[ 0.794245] system 00:02: [io 0x0500-0x057f] has been reserved
[ 0.794246] system 00:02: [io 0xef80-0xef9f] has been reserved
[ 0.794252] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.794282] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.794540] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.794568] pnp 00:05: Plug and Play ACPI device, IDs SYN016a SYN0100 SYN0002 PNP0f13 (active)
[ 0.795260] pnp: PnP ACPI: found 6 devices
[ 0.801449] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.801524] NET: Registered protocol family 2
[ 0.801776] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.801877] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.802132] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.802255] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.802375] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.802440] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.802485] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.802628] NET: Registered protocol family 1
[ 0.802634] NET: Registered protocol family 44
[ 0.802642] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfffe0000-0xffffffff pref]: no compatible bridge window
[ 0.802646] pci 0000:04:00.0: can't claim BAR 6 [mem 0xfffe0000-0xffffffff pref]: no compatible bridge window
[ 0.802664] pci 0000:01:00.0: BAR 6: assigned [mem 0xd0540000-0xd055ffff pref]
[ 0.802667] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.802670] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.802673] pci 0000:00:01.0: bridge window [mem 0xd0500000-0xd05fffff]
[ 0.802675] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.802679] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.802684] pci 0000:00:1c.0: bridge window [mem 0xd0400000-0xd04fffff]
[ 0.802694] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.802700] pci 0000:00:1c.3: bridge window [mem 0xd0300000-0xd03fffff]
[ 0.802711] pci 0000:04:00.0: BAR 6: assigned [mem 0xd0200000-0xd021ffff pref]
[ 0.802712] pci 0000:00:1c.5: PCI bridge to [bus 04]
[ 0.802715] pci 0000:00:1c.5: bridge window [io 0x2000-0x2fff]
[ 0.802721] pci 0000:00:1c.5: bridge window [mem 0xd0200000-0xd02fffff]
[ 0.802725] pci 0000:00:1c.5: bridge window [mem 0xd0000000-0xd00fffff 64bit pref]
[ 0.802732] pci 0000:00:1e.0: PCI bridge to [bus 05]
[ 0.802738] pci 0000:00:1e.0: bridge window [mem 0xd0100000-0xd01fffff]
[ 0.802749] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.802750] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.802752] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.802753] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xdfffffff window]
[ 0.802754] pci_bus 0000:00: resource 8 [mem 0xf0000000-0xfedfffff window]
[ 0.802755] pci_bus 0000:00: resource 9 [mem 0xfee01000-0xffffffff window]
[ 0.802757] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.802758] pci_bus 0000:01: resource 1 [mem 0xd0500000-0xd05fffff]
[ 0.802759] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.802761] pci_bus 0000:02: resource 1 [mem 0xd0400000-0xd04fffff]
[ 0.802762] pci_bus 0000:03: resource 1 [mem 0xd0300000-0xd03fffff]
[ 0.802764] pci_bus 0000:04: resource 0 [io 0x2000-0x2fff]
[ 0.802765] pci_bus 0000:04: resource 1 [mem 0xd0200000-0xd02fffff]
[ 0.802766] pci_bus 0000:04: resource 2 [mem 0xd0000000-0xd00fffff 64bit pref]
[ 0.802768] pci_bus 0000:05: resource 1 [mem 0xd0100000-0xd01fffff]
[ 0.802769] pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7 window]
[ 0.802770] pci_bus 0000:05: resource 5 [io 0x0d00-0xffff window]
[ 0.802771] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.802773] pci_bus 0000:05: resource 7 [mem 0xc0000000-0xdfffffff window]
[ 0.802774] pci_bus 0000:05: resource 8 [mem 0xf0000000-0xfedfffff window]
[ 0.802775] pci_bus 0000:05: resource 9 [mem 0xfee01000-0xffffffff window]
[ 0.804215] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.804248] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.804323] PCI: CLS 64 bytes, default 64
[ 0.804389] Trying to unpack rootfs image as initramfs...
[ 1.023530] Freeing initrd memory: 16268K
[ 1.023550] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.023551] software IO TLB: mapped [mem 0xbafcf000-0xbefcf000] (64MB)
[ 1.023821] check: Scanning for low memory corruption every 60 seconds
[ 1.024304] Initialise system trusted keyrings
[ 1.024315] Key type blacklist registered
[ 1.024404] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ 1.025882] zbud: loaded
[ 1.036941] Key type asymmetric registered
[ 1.036943] Asymmetric key parser 'x509' registered
[ 1.036954] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.037022] io scheduler mq-deadline registered
[ 1.037023] io scheduler kyber registered
[ 1.037052] io scheduler bfq registered
[ 1.037728] pcieport 0000:00:01.0: PME: Signaling with IRQ 24
[ 1.038176] pcieport 0000:00:1c.0: PME: Signaling with IRQ 25
[ 1.038621] pcieport 0000:00:1c.3: PME: Signaling with IRQ 26
[ 1.039064] pcieport 0000:00:1c.5: PME: Signaling with IRQ 27
[ 1.039097] pcieport 0000:00:1c.5: pciehp: Slot #5 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 1.039284] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.039378] vesafb: mode is 1366x768x32, linelength=5504, pages=0
[ 1.039379] vesafb: scrolling: redraw
[ 1.039380] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 1.039398] vesafb: framebuffer at 0xc0000000, mapped to 0x(____ptrval____), using 4160k, total 4160k
[ 1.039450] fbcon: Deferring console take-over
[ 1.039452] fb0: VESA VGA frame buffer device
[ 1.039467] intel_idle: MWAIT substates: 0x1120
[ 1.039469] intel_idle: v0.5.1 model 0x25
[ 1.039681] intel_idle: Local APIC timer is reliable in all C-states
[ 1.039787] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 1.039817] ACPI: Sleep Button [SLPB]
[ 1.039857] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 1.039878] ACPI: Lid Switch [LID]
[ 1.039919] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.047806] ACPI: Power Button [PWRF]
[ 1.048963] ACPI: Video Device [DGFX] (multi-head: yes rom: no post: no)
[ 1.062502] acpi device:03: registered as cooling_device0
[ 1.062606] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/LNXVIDEO:00/input/input3
[ 1.071691] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.071692] ACPI: Thermal Zone [EXTZ] (41 C)
[ 1.071800] thermal LNXTHERM:01: registered as thermal_zone1
[ 1.071801] ACPI: Thermal Zone [EX2Z] (0 C)
[ 1.071915] thermal LNXTHERM:02: registered as thermal_zone2
[ 1.071916] ACPI: Thermal Zone [PWMZ] (0 C)
[ 1.075856] thermal LNXTHERM:03: registered as thermal_zone3
[ 1.075858] ACPI: Thermal Zone [LOCZ] (33 C)
[ 1.076772] thermal LNXTHERM:04: registered as thermal_zone4
[ 1.076773] ACPI: Thermal Zone [GFXZ] (0 C)
[ 1.093734] thermal LNXTHERM:05: registered as thermal_zone5
[ 1.093736] ACPI: Thermal Zone [BATZ] (29 C)
[ 1.108442] thermal LNXTHERM:06: registered as thermal_zone6
[ 1.108443] ACPI: Thermal Zone [EGXZ] (0 C)
[ 1.108878] thermal LNXTHERM:07: registered as thermal_zone7
[ 1.108880] ACPI: Thermal Zone [CPUZ] (55 C)
[ 1.109264] thermal LNXTHERM:08: registered as thermal_zone8
[ 1.109265] ACPI: Thermal Zone [MCHZ] (45 C)
[ 1.109642] thermal LNXTHERM:09: registered as thermal_zone9
[ 1.109643] ACPI: Thermal Zone [PCHZ] (59 C)
[ 1.110025] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.111835] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.111836] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 1.112805] ahci 0000:00:1f.2: version 3.0
[ 1.113214] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[ 1.113257] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 3 Gbps 0x13 impl SATA mode
[ 1.113260] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ems sxs apst
[ 1.135683] scsi host0: ahci
[ 1.136157] scsi host1: ahci
[ 1.136424] scsi host2: ahci
[ 1.136761] scsi host3: ahci
[ 1.137321] scsi host4: ahci
[ 1.137894] scsi host5: ahci
[ 1.137990] ata1: SATA max UDMA/133 abar m2048@0xd0607000 port 0xd0607100 irq 28
[ 1.137992] ata2: SATA max UDMA/133 abar m2048@0xd0607000 port 0xd0607180 irq 28
[ 1.137993] ata3: DUMMY
[ 1.137994] ata4: DUMMY
[ 1.137996] ata5: SATA max UDMA/133 abar m2048@0xd0607000 port 0xd0607300 irq 28
[ 1.137997] ata6: DUMMY
[ 1.138083] usbcore: registered new interface driver usbserial_generic
[ 1.138088] usbserial: USB Serial support registered for generic
[ 1.138120] rtc_cmos 00:03: RTC can wake from S4
[ 1.138483] rtc_cmos 00:03: registered as rtc0
[ 1.138519] rtc_cmos 00:03: setting system clock to 2021-06-13T14:11:20 UTC (1623593480)
[ 1.138550] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.138621] intel_pstate: CPU model not supported
[ 1.138685] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.138781] ashmem: initialized
[ 1.138932] drop_monitor: Initializing network drop monitor service
[ 1.139125] NET: Registered protocol family 10
[ 1.145963] Segment Routing with IPv6
[ 1.145965] RPL Segment Routing with IPv6
[ 1.145997] NET: Registered protocol family 17
[ 1.146378] microcode: sig=0x20655, pf=0x10, revision=0x7
[ 1.146532] microcode: Microcode Update Driver: v2.2.
[ 1.146538] IPI shorthand broadcast: enabled
[ 1.146547] sched_clock: Marking stable (1146196712, 329880)->(1152035336, -5508744)
[ 1.146832] registered taskstats version 1
[ 1.146856] Loading compiled-in X.509 certificates
[ 1.152065] Loaded X.509 cert 'Build time autogenerated kernel key: 9d03c4d841bf08bdacc38e7fc2cd16df39302a02'
[ 1.153671] zswap: loaded using pool zstd/z3fold
[ 1.154370] Key type ._fscrypt registered
[ 1.154373] Key type .fscrypt registered
[ 1.154375] Key type fscrypt-provisioning registered
[ 1.154474] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.154920] PM: Magic number: 9:78:182
[ 1.155011] acpi device:41: hash matches
[ 1.155336] RAS: Correctable Errors collector initialized.
[ 1.453138] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.455725] ata1.00: unexpected _GTF length (8)
[ 1.462801] ata1.00: ATA-9: Intenso SSD SATAIII, S0424A0, max UDMA/133
[ 1.462804] ata1.00: 937703088 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.470585] ata1.00: unexpected _GTF length (8)
[ 1.477777] ata1.00: configured for UDMA/133
[ 1.478004] scsi 0:0:0:0: Direct-Access ATA Intenso SSD SATA 4A0 PQ: 0 ANSI: 5
[ 1.478377] sd 0:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 GiB)
[ 1.478395] sd 0:0:0:0: [sda] Write Protect is off
[ 1.478398] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.478427] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.479782] sda: sda1 sda2
[ 1.480720] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.793077] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.796920] ata2.00: unexpected _GTF length (8)
[ 1.796924] ata2.00: ATAPI: hp DVDRAM GT31L, mP01, max UDMA/100
[ 1.800879] ata2.00: unexpected _GTF length (8)
[ 1.800885] ata2.00: configured for UDMA/100
[ 1.803817] scsi 1:0:0:0: CD-ROM hp DVDRAM GT31L mP01 PQ: 0 ANSI: 5
[ 2.028667] tsc: Refined TSC clocksource calibration: 2526.999 MHz
[ 2.028676] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x246cdab5d1d, max_idle_ns: 440795263955 ns
[ 2.028749] clocksource: Switched to clocksource tsc
[ 2.153159] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.156197] Freeing unused decrypted memory: 2040K
[ 2.156687] Freeing unused kernel image (initmem) memory: 1664K
[ 2.156771] Write protecting the kernel read-only data: 22528k
[ 2.157680] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 2.158251] Freeing unused kernel image (rodata/data gap) memory: 1384K
[ 2.217990] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 2.217993] x86/mm: Checking user space page tables
[ 2.275658] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 2.275669] Run /init as init process
[ 2.275671] with arguments:
[ 2.275672] /init
[ 2.275673] with environment:
[ 2.275673] HOME=/
[ 2.275674] TERM=linux
[ 2.275675] BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
[ 2.275675] cryptdevice=UUID=5403d2f4-15d4-4164-b22c-9edd31160ea5:luks-5403d2f4-15d4-4164-b22c-9edd31160ea5
[ 2.385645] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 2.387458] i8042: Detected active multiplexing controller, rev 1.1
[ 2.388247] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.388326] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 2.388373] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 2.388416] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 2.388463] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 2.397628] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.399414] ehci-pci: EHCI PCI platform driver
[ 2.400045] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 2.400056] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 2.400074] ehci-pci 0000:00:1a.0: debug port 2
[ 2.404045] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 2.404075] ehci-pci 0000:00:1a.0: irq 16, io mem 0xd0609000
[ 2.415559] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 2.415665] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 2.415667] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.415669] usb usb1: Product: EHCI Host Controller
[ 2.415671] usb usb1: Manufacturer: Linux 5.9.16-1-MANJARO ehci_hcd
[ 2.415673] usb usb1: SerialNumber: 0000:00:1a.0
[ 2.415915] hub 1-0:1.0: USB hub found
[ 2.415930] hub 1-0:1.0: 2 ports detected
[ 2.417076] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 2.417085] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 2.417102] ehci-pci 0000:00:1d.0: debug port 2
[ 2.421217] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 2.421245] ehci-pci 0000:00:1d.0: irq 20, io mem 0xd0608000
[ 2.428655] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.428662] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.433561] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 2.433666] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 2.433669] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.433671] usb usb2: Product: EHCI Host Controller
[ 2.433673] usb usb2: Manufacturer: Linux 5.9.16-1-MANJARO ehci_hcd
[ 2.433675] usb usb2: SerialNumber: 0000:00:1d.0
[ 2.433982] hub 2-0:1.0: USB hub found
[ 2.434126] hub 2-0:1.0: 2 ports detected
[ 2.445094] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.464092] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 2.745266] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 2.754176] device-mapper: uevent: version 1.0.3
[ 2.754270] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[ 2.765300] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 2.766554] Key type encrypted registered
[ 2.892277] usb 1-1: New USB device found, idVendor=8087, idProduct=0020, bcdDevice= 0.00
[ 2.892280] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.892678] hub 1-1:1.0: USB hub found
[ 2.892818] hub 1-1:1.0: 6 ports detected
[ 2.912416] usb 2-1: New USB device found, idVendor=8087, idProduct=0020, bcdDevice= 0.00
[ 2.912418] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.912686] hub 2-1:1.0: USB hub found
[ 2.912805] hub 2-1:1.0: 8 ports detected
[ 3.171925] usb 1-1.5: new high-speed USB device number 3 using ehci-pci
[ 4.451790] usb 1-1.5: New USB device found, idVendor=05c8, idProduct=0403, bcdDevice= 1.06
[ 4.451792] usb 1-1.5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 4.451794] usb 1-1.5: Product: HP Webcam [2 MP Fixed]
[ 4.451796] usb 1-1.5: Manufacturer: Foxlink
[ 4.451798] usb 1-1.5: SerialNumber: 200909240102
[ 6.741751] random: cryptsetup: uninitialized urandom read (2 bytes read)
[ 6.752594] cryptd: max_cpu_qlen set to 1000
[ 7.000444] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 11.159207] random: cryptsetup: uninitialized urandom read (2 bytes read)
[ 11.211244] PM: Image not found (code -22)
[ 11.251843] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 11.311877] random: fast init done
[ 11.567142] systemd[1]: systemd 247.7-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 11.582158] systemd[1]: Detected architecture x86-64.
[ 11.617738] systemd[1]: Set hostname to <manjone-KalK>.
[ 12.253438] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 12.468626] systemd[1]: Queued start job for default target Graphical Interface.
[ 12.469351] random: systemd: uninitialized urandom read (16 bytes read)
[ 12.497752] systemd[1]: Created slice system-getty.slice.
[ 12.497907] random: systemd: uninitialized urandom read (16 bytes read)
[ 12.498865] systemd[1]: Created slice system-modprobe.slice.
[ 12.499793] systemd[1]: Created slice Cryptsetup Units Slice.
[ 12.500837] systemd[1]: Created slice User and Session Slice.
[ 12.501048] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 12.501212] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.501669] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 12.501863] systemd[1]: Reached target Login Prompts.
[ 12.502087] systemd[1]: Reached target Remote File Systems.
[ 12.502138] systemd[1]: Reached target Slices.
[ 12.502398] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 12.503167] systemd[1]: Listening on LVM2 poll daemon socket.
[ 12.506492] systemd[1]: Listening on Process Core Dump Socket.
[ 12.506943] systemd[1]: Listening on Journal Audit Socket.
[ 12.507263] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.507613] systemd[1]: Listening on Journal Socket.
[ 12.509941] systemd[1]: Listening on udev Control Socket.
[ 12.510238] systemd[1]: Listening on udev Kernel Socket.
[ 12.512502] systemd[1]: Mounting Huge Pages File System...
[ 12.514230] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.515879] systemd[1]: Mounting Kernel Debug File System...
[ 12.517490] systemd[1]: Mounting Kernel Trace File System...
[ 12.519267] systemd[1]: Starting Load AppArmor profiles...
[ 12.521212] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 12.522958] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 12.524477] systemd[1]: Starting Load Kernel Module configfs...
[ 12.526420] systemd[1]: Starting Load Kernel Module drm...
[ 12.528319] systemd[1]: Starting Load Kernel Module fuse...
[ 12.531309] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 12.533183] systemd[1]: Starting File System Check on Root Device...
[ 12.536766] systemd[1]: Starting Load Kernel Modules...
[ 12.536934] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 12.538644] systemd[1]: Starting Coldplug All udev Devices...
[ 12.544772] systemd[1]: Mounted Huge Pages File System.
[ 12.554800] systemd[1]: Mounted POSIX Message Queue File System.
[ 12.554969] systemd[1]: Mounted Kernel Debug File System.
[ 12.555129] systemd[1]: Mounted Kernel Trace File System.
[ 12.556024] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 12.556534] systemd[1]: modprobe@configfs.service: Succeeded.
[ 12.557195] systemd[1]: Finished Load Kernel Module configfs.
[ 12.559587] systemd[1]: Mounting Kernel Configuration File System...
[ 12.560284] fuse: init (API version 7.31)
[ 12.562451] Linux agpgart interface v0.103
[ 12.563588] systemd[1]: modprobe@fuse.service: Succeeded.
[ 12.564349] systemd[1]: Finished Load Kernel Module fuse.
[ 12.565638] systemd[1]: Mounted Kernel Configuration File System.
[ 12.569446] systemd[1]: Mounting FUSE Control File System...
[ 12.595665] systemd[1]: Finished Load Kernel Modules.
[ 12.596050] systemd[1]: Mounted FUSE Control File System.
[ 12.597751] systemd[1]: Starting Apply Kernel Variables...
[ 12.607193] systemd[1]: Finished File System Check on Root Device.
[ 12.609175] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.619466] systemd[1]: Finished Apply Kernel Variables.
[ 12.625210] EXT4-fs (dm-0): re-mounted. Opts: (null)
[ 12.627103] systemd[1]: Starting CLI Netfilter Manager...
[ 12.629145] systemd[1]: modprobe@drm.service: Succeeded.
[ 12.629915] systemd[1]: Finished Load Kernel Module drm.
[ 12.636317] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 12.636594] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 12.641866] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 12.643943] systemd[1]: Starting Load/Save Random Seed...
[ 12.644112] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 12.645899] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 12.676864] systemd[1]: Finished CLI Netfilter Manager.
[ 12.682911] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 12.685052] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 12.687922] systemd[1]: Starting Journal Service...
[ 12.690479] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 12.744864] systemd[1]: Finished Coldplug All udev Devices.
[ 12.781118] audit: type=1400 audit(1623593492.136:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=301 comm="apparmor_parser"
[ 12.872439] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 12.872551] audit: type=1130 audit(1623593492.230:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.876463] systemd[1]: Started Journal Service.
[ 12.876599] audit: type=1130 audit(1623593492.233:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.889587] systemd-journald[309]: Received client request to flush runtime journal.
[ 13.053099] audit: type=1400 audit(1623593492.410:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=299 comm="apparmor_parser"
[ 13.058225] audit: type=1400 audit(1623593492.413:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=299 comm="apparmor_parser"
[ 13.263688] random: crng init done
[ 13.263692] random: 5 urandom warning(s) missed due to ratelimiting
[ 13.264007] audit: type=1130 audit(1623593492.620:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.283314] audit: type=1130 audit(1623593492.640:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.377936] ACPI: AC Adapter [AC] (on-line)
[ 13.408493] hp_accel: hardware type HPB452x found
[ 13.418958] lis3lv02d: 8 bits sensor found
[ 13.457083] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 13.498700] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input9
[ 13.678564] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200717/utaddress-204)
[ 13.678573] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 13.679187] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200717/utaddress-204)
[ 13.679193] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 13.679195] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200717/utaddress-204)
[ 13.679199] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 13.679201] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200717/utaddress-204)
[ 13.679205] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 13.679206] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 13.702897] audit: type=1400 audit(1623593493.046:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=311 comm="apparmor_parser"
[ 13.725607] audit: type=1400 audit(1623593493.080:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=337 comm="apparmor_parser"
[ 13.772422] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[ 13.846602] audit: type=1130 audit(1623593493.203:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-cryptsetup@luks\x2d1cee0395\x2d584e\x2d47c4\x2da3a8\x2d1c8c341226b3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.855755] input: PC Speaker as /devices/platform/pcspkr/input/input11
[ 13.956836] snd_hda_codec_idt hdaudioC0D0: autoconfig for 92HD81B1X5: line_outs=1 (0xd/0x0/0x0/0x0/0x0) type:speaker
[ 13.956841] snd_hda_codec_idt hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 13.956844] snd_hda_codec_idt hdaudioC0D0: hp_outs=1 (0xb/0x0/0x0/0x0/0x0)
[ 13.956846] snd_hda_codec_idt hdaudioC0D0: mono: mono_out=0x0
[ 13.956848] snd_hda_codec_idt hdaudioC0D0: inputs:
[ 13.956850] snd_hda_codec_idt hdaudioC0D0: Internal Mic=0x11
[ 13.956853] snd_hda_codec_idt hdaudioC0D0: Mic=0xa
[ 13.959744] libphy: Fixed MDIO Bus: probed
[ 14.001307] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 14.001421] input: HDA Intel MID Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 14.001521] input: HDA Intel MID Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[ 14.100194] r8169 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 14.123704] libphy: r8169: probed
[ 14.124426] r8169 0000:04:00.0 eth0: RTL8168d/8111d, 64:31:50:09:5b:b2, XID 283, IRQ 32
[ 14.124429] r8169 0000:04:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 14.275294] Adding 9225416k swap on /dev/mapper/luks-1cee0395-584e-47c4-a3a8-1c8c341226b3. Priority:-2 extents:1 across:9225416k SSFS
[ 14.355570] iTCO_vendor_support: vendor-support=0
[ 14.380135] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 14.380236] iTCO_wdt: Found a HM57 TCO device (Version=2, TCOBASE=0x0460)
[ 14.392383] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 14.405395] r8169 0000:04:00.0 ens5: renamed from eth0
[ 14.445058] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 14.492426] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 14.559382] input: HP WMI hotkeys as /devices/virtual/input/input19
[ 14.762301] psmouse serio4: synaptics: queried max coordinates: x [..5686], y [..4548]
[ 14.834887] psmouse serio4: synaptics: Touchpad model: 1, fw: 7.4, id: 0x1e0b1, caps: 0xd04771/0xe40000/0x5a0400/0x0, board id: 0, fw id: 640916
[ 14.863312] kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
[ 14.878773] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input15
[ 14.888020] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 3090, rev 3213 detected
[ 14.954792] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 0005 detected
[ 14.954851] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 14.983786] rt2800pci 0000:03:00.0 wlo1: renamed from wlan0
[ 15.001399] mousedev: PS/2 mouse device common for all mice
[ 15.017887] [drm] radeon kernel modesetting enabled.
[ 15.020427] checking generic (c0000000 410000) vs hw (c0000000 10000000)
[ 15.020430] fb0: switching to radeondrmfb from VESA VGA
[ 15.020538] radeon 0000:01:00.0: vgaarb: deactivate vga console
[ 15.030960] [drm] initializing kernel modesetting (CEDAR 0x1002:0x68E0 0x103C:0x1411 0x00).
[ 15.031085] ATOM BIOS: HP
[ 15.031154] radeon 0000:01:00.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
[ 15.031157] radeon 0000:01:00.0: GTT: 1024M 0x0000000020000000 - 0x000000005FFFFFFF
[ 15.031163] [drm] Detected VRAM RAM=512M, BAR=256M
[ 15.031164] [drm] RAM width 64bits DDR
[ 15.034329] [TTM] Zone kernel: Available graphics memory: 2969648 KiB
[ 15.034332] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
[ 15.034334] [TTM] Initializing pool allocator
[ 15.034341] [TTM] Initializing DMA pool allocator
[ 15.034373] [drm] radeon: 512M of VRAM memory ready
[ 15.034375] [drm] radeon: 1024M of GTT memory ready.
[ 15.034406] [drm] Loading CEDAR Microcode
[ 15.057410] [drm] Internal thermal controller with fan control
[ 15.082952] [drm] radeon: dpm initialized
[ 15.091363] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 15.101739] [drm] PCIE GART of 1024M enabled (table at 0x000000000014C000).
[ 15.101887] radeon 0000:01:00.0: WB enabled
[ 15.101891] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000020000c00
[ 15.101893] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000020000c0c
[ 15.102317] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x000000000005c418
[ 15.127751] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
[ 15.127876] radeon 0000:01:00.0: radeon: using MSI.
[ 15.127913] [drm] radeon: irq initialized.
[ 15.151297] [drm] ring test on 0 succeeded in 1 usecs
[ 15.151308] [drm] ring test on 3 succeeded in 3 usecs
[ 15.293888] RTL8211B Gigabit Ethernet r8169-400:00: attached PHY driver [RTL8211B Gigabit Ethernet] (mii_bus:phy_addr=r8169-400:00, irq=IGNORE)
[ 15.345377] [drm] ring test on 5 succeeded in 1 usecs
[ 15.345384] [drm] UVD initialized successfully.
[ 15.345779] [drm] ib test on ring 0 succeeded in 0 usecs
[ 15.345821] [drm] ib test on ring 3 succeeded in 0 usecs
[ 15.471111] r8169 0000:04:00.0 ens5: Link is Down
[ 15.559320] loop: module loaded
[ 15.590218] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 16.005432] [drm] ib test on ring 5 succeeded
[ 16.065400] [drm] radeon atom DIG backlight initialized
[ 16.065409] [drm] Radeon Display Connectors
[ 16.065411] [drm] Connector 0:
[ 16.065412] [drm] LVDS-1
[ 16.065413] [drm] DDC: 0x6560 0x6560 0x6564 0x6564 0x6568 0x6568 0x656c 0x656c
[ 16.065414] [drm] Encoders:
[ 16.065415] [drm] LCD1: INTERNAL_UNIPHY
[ 16.065416] [drm] Connector 1:
[ 16.065417] [drm] HDMI-A-1
[ 16.065418] [drm] HPD1
[ 16.065419] [drm] DDC: 0x6430 0x6430 0x6434 0x6434 0x6438 0x6438 0x643c 0x643c
[ 16.065420] [drm] Encoders:
[ 16.065420] [drm] DFP1: INTERNAL_UNIPHY1
[ 16.065421] [drm] Connector 2:
[ 16.065421] [drm] VGA-1
[ 16.065423] [drm] DDC: 0x64d8 0x64d8 0x64dc 0x64dc 0x64e0 0x64e0 0x64e4 0x64e4
[ 16.065423] [drm] Encoders:
[ 16.065424] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 16.171375] mc: Linux media interface: v0.10
[ 16.195237] videodev: Linux video capture interface: v2.00
[ 16.356231] uvcvideo: Found UVC 1.00 device HP Webcam [2 MP Fixed] (05c8:0403)
[ 16.382517] input: HP Webcam [2 MP Fixed]: HP Webc as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input20
[ 16.382786] usbcore: registered new interface driver uvcvideo
[ 16.382789] USB Video Class driver (1.1.1)
[ 16.477556] [drm] fb mappable at 0xC034D000
[ 16.477560] [drm] vram apper at 0xC0000000
[ 16.477561] [drm] size 4325376
[ 16.477563] [drm] fb depth is 24
[ 16.477565] [drm] pitch is 5632
[ 16.477739] fbcon: radeondrmfb (fb0) is primary device
[ 16.477742] fbcon: Deferring console take-over
[ 16.477749] radeon 0000:01:00.0: [drm] fb0: radeondrmfb frame buffer device
[ 16.509227] [drm] Initialized radeon 2.50.0 20080528 for 0000:01:00.0 on minor 0
[ 18.986228] kauditd_printk_skb: 35 callbacks suppressed
[ 18.986232] audit: type=1103 audit(1623593498.343:47): pid=897 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 19.019748] audit: type=1130 audit(1623593498.376:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.048981] audit: type=1101 audit(1623593498.406:49): pid=901 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.049011] audit: type=1103 audit(1623593498.406:50): pid=901 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 19.049158] audit: type=1006 audit(1623593498.406:51): pid=901 uid=0 subj==unconfined old-auid=4294967295 auid=969 tty=(none) old-ses=4294967295 ses=1 res=1
[ 19.053548] audit: type=1105 audit(1623593498.410:52): pid=901 uid=0 auid=969 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.064048] audit: type=1334 audit(1623593498.420:53): prog-id=11 op=LOAD
[ 19.064055] audit: type=1334 audit(1623593498.420:54): prog-id=11 op=UNLOAD
[ 19.283855] audit: type=1130 audit(1623593498.640:55): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.298764] audit: type=1105 audit(1623593498.653:56): pid=897 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 26.019485] kauditd_printk_skb: 2 callbacks suppressed
[ 26.019487] audit: type=1131 audit(1623593505.376:59): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.033735] audit: type=1131 audit(1623593524.390:60): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.095447] audit: type=1334 audit(1623593524.453:61): prog-id=10 op=UNLOAD
[ 45.095454] audit: type=1334 audit(1623593524.453:62): prog-id=9 op=UNLOAD
[ 45.367737] audit: type=1100 audit(1623593524.723:63): pid=949 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="manjone" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 45.370271] audit: type=1101 audit(1623593524.726:64): pid=949 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjone" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 50.576576] audit: type=1100 audit(1623593529.933:65): pid=961 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="manjone" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 50.579356] audit: type=1101 audit(1623593529.936:66): pid=961 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjone" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 52.184867] audit: type=1130 audit(1623593531.540:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.191128] fbcon: Taking over console
[ 52.210644] Console: switching to colour frame buffer device 170x48
[ 60.003028] audit: type=1100 audit(1623593539.360:68): pid=965 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="manjone" exe="/usr/bin/login" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 60.005849] audit: type=1101 audit(1623593539.363:69): pid=965 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjone" exe="/usr/bin/login" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 60.007406] audit: type=1103 audit(1623593539.363:70): pid=965 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="manjone" exe="/usr/bin/login" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 60.007618] audit: type=1006 audit(1623593539.363:71): pid=965 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=2 res=1
[ 60.044247] audit: type=1130 audit(1623593539.400:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.055819] audit: type=1101 audit(1623593539.413:73): pid=973 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjone" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.055877] audit: type=1103 audit(1623593539.413:74): pid=973 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="manjone" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 60.055964] audit: type=1006 audit(1623593539.413:75): pid=973 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 60.057992] audit: type=1105 audit(1623593539.413:76): pid=973 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="manjone" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.066599] audit: type=1334 audit(1623593539.423:77): prog-id=12 op=LOAD
[ 72.626335] kauditd_printk_skb: 4 callbacks suppressed
[ 72.626340] audit: type=1100 audit(1623593551.983:82): pid=1008 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="manjone" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 72.628697] audit: type=1101 audit(1623593551.986:83): pid=1008 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjone" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 72.629659] audit: type=1110 audit(1623593551.986:84): pid=1008 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 72.635960] audit: type=1105 audit(1623593551.993:85): pid=1008 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 457.555528] audit: type=1106 audit(1623593936.913:86): pid=1008 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 457.555722] audit: type=1104 audit(1623593936.913:87): pid=1008 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 490.836210] audit: type=1100 audit(1623593970.193:88): pid=1015 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="manjone" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 490.839563] audit: type=1101 audit(1623593970.196:89): pid=1015 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjone" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 490.840377] audit: type=1110 audit(1623593970.196:90): pid=1015 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 490.847103] audit: type=1105 audit(1623593970.203:91): pid=1015 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 491.701853] audit: type=1106 audit(1623593971.056:92): pid=1015 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 491.702200] audit: type=1104 audit(1623593971.060:93): pid=1015 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 533.011251] audit: type=1101 audit(1623594012.366:94): pid=1020 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjone" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 533.011742] audit: type=1110 audit(1623594012.366:95): pid=1020 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
[ 533.015206] audit: type=1105 audit(1623594012.373:96): pid=1020 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjone-KalK addr=? terminal=/dev/tty2 res=success'
