Zum Status von lightdm: ist geladen und aktiv:
● lightdm.service - Light Display Manager
Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2021-10-26 12:42:08 CEST; 2h 7min ago
Docs: man:lightdm(1)
Main PID: 519 (lightdm)
Tasks: 9 (limit: 4388)
Memory: 100.1M
CPU: 1.519s
CGroup: /system.slice/lightdm.service
├─ 519 /usr/bin/lightdm
├─ 531 /usr/lib/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
├─ 868 lightdm --session-child 12 19
└─1044 lightdm --session-child 12 21
Okt 26 12:42:07 medion systemd[1]: Starting Light Display Manager...
Okt 26 12:42:08 medion systemd[1]: Started Light Display Manager.
Okt 26 12:42:22 medion lightdm[818]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=969) by (uid=0)
Okt 26 14:45:21 medion lightdm[868]: gkr-pam: unable to locate daemon control file
Okt 26 14:45:21 medion lightdm[868]: gkr-pam: stashed password to try later in open session
Okt 26 14:45:21 medion lightdm[868]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Hier das Ergebnis von dmesg:
[ 0.000000] microcode: microcode updated early to revision 0xa0b, date = 2010-09-28
[ 0.000000] Linux version 5.10.70-1-MANJARO (builduser@fv-az72-704) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Thu Sep 30 15:29:01 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=3dbb2b21-5b0b-4d7f-ad7d-44ecb7471055 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'standard' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009e7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000cff9ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cffa0000-0x00000000cffadfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000cffae000-0x00000000cffeffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000cfff0000-0x00000000dfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff700000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000011fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: MEDIONPC MS-7621/MS-7621, BIOS A7621MLN.107 09/17/2009
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2199.970 MHz processor
[ 0.001069] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001073] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001080] last_pfn = 0x120000 max_arch_pfn = 0x400000000
[ 0.001088] MTRR default type: uncachable
[ 0.001089] MTRR fixed ranges enabled:
[ 0.001091] 00000-9FFFF write-back
[ 0.001092] A0000-BFFFF uncachable
[ 0.001094] C0000-CFFFF write-protect
[ 0.001095] D0000-DFFFF uncachable
[ 0.001096] E0000-EFFFF write-through
[ 0.001098] F0000-FFFFF write-protect
[ 0.001099] MTRR variable ranges enabled:
[ 0.001101] 0 base 0E0000000 mask FE0000000 uncachable
[ 0.001103] 1 base 000000000 mask F00000000 write-back
[ 0.001104] 2 base 100000000 mask FE0000000 write-back
[ 0.001106] 3 disabled
[ 0.001107] 4 disabled
[ 0.001108] 5 disabled
[ 0.001109] 6 disabled
[ 0.001110] 7 disabled
[ 0.001647] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001869] total RAM covered: 4096M
[ 0.002542] Found optimal setting for mtrr clean up
[ 0.002544] gran_size: 64K chunk_size: 1G num_reg: 3 lose cover RAM: 0G
[ 0.002979] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.002988] last_pfn = 0xcffa0 max_arch_pfn = 0x400000000
[ 0.015766] found SMP MP-table at [mem 0x000ff780-0x000ff78f]
[ 0.021620] check: Scanning 1 areas for low memory corruption
[ 0.022091] RAMDISK: [mem 0x3674b000-0x3739cfff]
[ 0.022097] ACPI: Early table checksum verification disabled
[ 0.022103] ACPI: RSDP 0x00000000000FA990 000014 (v00 ACPIAM)
[ 0.022109] ACPI: RSDT 0x00000000CFFA0000 000048 (v01 MEDION MEDIONAG 20090917 MSFT 00000097)
[ 0.022117] ACPI: FACP 0x00000000CFFA0200 000084 (v01 091709 FACP0956 20090917 MSFT 00000097)
[ 0.022125] ACPI: DSDT 0x00000000CFFA0620 009851 (v01 1AAAA 1AAAA000 00000000 INTL 20051117)
[ 0.022131] ACPI: FACS 0x00000000CFFAE000 000040
[ 0.022135] ACPI: APIC 0x00000000CFFA0390 000080 (v01 091709 APIC0956 20090917 MSFT 00000097)
[ 0.022140] ACPI: MCFG 0x00000000CFFA0410 00003C (v01 091709 OEMMCFG 20090917 MSFT 00000097)
[ 0.022145] ACPI: SLIC 0x00000000CFFA0450 000176 (v01 MEDION MEDIONAG 20090917 MSFT 00000097)
[ 0.022150] ACPI: WDRT 0x00000000CFFA05D0 000047 (v01 091709 NV-WDRT 20090917 MSFT 00000097)
[ 0.022155] ACPI: OEMB 0x00000000CFFAE040 00007A (v01 091709 OEMB0956 20090917 MSFT 00000097)
[ 0.022160] ACPI: HPET 0x00000000CFFAA620 000038 (v01 091709 OEMHPET0 20090917 MSFT 00000097)
[ 0.022165] ACPI: NVHD 0x00000000CFFAE0C0 000284 (v01 091709 NVHDCP 20090917 MSFT 00000097)
[ 0.022171] ACPI: SSDT 0x00000000CFFAEC50 0004F0 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.022176] ACPI: Reserving FACP table memory at [mem 0xcffa0200-0xcffa0283]
[ 0.022177] ACPI: Reserving DSDT table memory at [mem 0xcffa0620-0xcffa9e70]
[ 0.022179] ACPI: Reserving FACS table memory at [mem 0xcffae000-0xcffae03f]
[ 0.022180] ACPI: Reserving APIC table memory at [mem 0xcffa0390-0xcffa040f]
[ 0.022181] ACPI: Reserving MCFG table memory at [mem 0xcffa0410-0xcffa044b]
[ 0.022183] ACPI: Reserving SLIC table memory at [mem 0xcffa0450-0xcffa05c5]
[ 0.022184] ACPI: Reserving WDRT table memory at [mem 0xcffa05d0-0xcffa0616]
[ 0.022185] ACPI: Reserving OEMB table memory at [mem 0xcffae040-0xcffae0b9]
[ 0.022187] ACPI: Reserving HPET table memory at [mem 0xcffaa620-0xcffaa657]
[ 0.022188] ACPI: Reserving NVHD table memory at [mem 0xcffae0c0-0xcffae343]
[ 0.022189] ACPI: Reserving SSDT table memory at [mem 0xcffaec50-0xcffaf13f]
[ 0.022200] ACPI: Local APIC address 0xfee00000
[ 0.022276] No NUMA configuration found
[ 0.022278] Faking a node at [mem 0x0000000000000000-0x000000011fffffff]
[ 0.022282] NODE_DATA(0) allocated [mem 0x11fff8000-0x11fffbfff]
[ 0.052592] Zone ranges:
[ 0.052595] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.052599] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.052601] Normal [mem 0x0000000100000000-0x000000011fffffff]
[ 0.052603] Device empty
[ 0.052605] Movable zone start for each node
[ 0.052606] Early memory node ranges
[ 0.052608] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.052609] node 0: [mem 0x0000000000100000-0x00000000cff9ffff]
[ 0.052611] node 0: [mem 0x0000000100000000-0x000000011fffffff]
[ 0.052615] Initmem setup node 0 [mem 0x0000000000001000-0x000000011fffffff]
[ 0.052618] On node 0 totalpages: 982845
[ 0.052620] DMA zone: 64 pages used for memmap
[ 0.052621] DMA zone: 21 pages reserved
[ 0.052622] DMA zone: 3997 pages, LIFO batch:0
[ 0.052625] DMA32 zone: 13247 pages used for memmap
[ 0.052626] DMA32 zone: 847776 pages, LIFO batch:63
[ 0.052628] Normal zone: 2048 pages used for memmap
[ 0.052629] Normal zone: 131072 pages, LIFO batch:31
[ 0.052637] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.052761] On node 0, zone DMA: 98 pages in unavailable ranges
[ 0.083247] On node 0, zone Normal: 96 pages in unavailable ranges
[ 0.083630] ACPI: PM-Timer IO Port: 0x4008
[ 0.083633] ACPI: Local APIC address 0xfee00000
[ 0.083657] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
[ 0.083660] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.083662] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.083664] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
[ 0.083666] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
[ 0.083667] ACPI: IRQ0 used by override.
[ 0.083669] ACPI: IRQ9 used by override.
[ 0.083670] ACPI: IRQ14 used by override.
[ 0.083671] ACPI: IRQ15 used by override.
[ 0.083673] Using ACPI (MADT) for SMP configuration information
[ 0.083675] ACPI: HPET id: 0x10de8201 base: 0xfed00000
[ 0.083684] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.083706] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.083709] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[ 0.083710] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.083711] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.083712] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.083714] PM: hibernation: Registered nosave memory: [mem 0xcffa0000-0xcffadfff]
[ 0.083715] PM: hibernation: Registered nosave memory: [mem 0xcffae000-0xcffeffff]
[ 0.083716] PM: hibernation: Registered nosave memory: [mem 0xcfff0000-0xdfffffff]
[ 0.083717] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xfebfffff]
[ 0.083718] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.083720] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[ 0.083721] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.083722] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff6fffff]
[ 0.083723] PM: hibernation: Registered nosave memory: [mem 0xff700000-0xffffffff]
[ 0.083726] [mem 0xe0000000-0xfebfffff] available for PCI devices
[ 0.083727] Booting paravirtualized kernel on bare hardware
[ 0.083733] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.091637] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.092875] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u524288
[ 0.092885] pcpu-alloc: s192512 r8192 d28672 u524288 alloc=1*2097152
[ 0.092888] pcpu-alloc: [0] 0 1 2 3
[ 0.092927] Built 1 zonelists, mobility grouping on. Total pages: 967465
[ 0.092929] Policy zone: Normal
[ 0.092932] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=3dbb2b21-5b0b-4d7f-ad7d-44ecb7471055 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.094955] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.095945] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.096024] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.163388] Memory: 3744972K/3931380K available (14344K kernel code, 2064K rwdata, 9164K rodata, 1708K init, 4236K bss, 186148K reserved, 0K cma-reserved)
[ 0.163403] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[ 0.163605] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.163629] Kernel/User page tables isolation: enabled
[ 0.163664] ftrace: allocating 41922 entries in 164 pages
[ 0.183722] ftrace: allocated 164 pages with 3 groups
[ 0.183983] rcu: Preemptible hierarchical RCU implementation.
[ 0.183984] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.183986] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.183987] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.183989] Trampoline variant of Tasks RCU enabled.
[ 0.183989] Rude variant of Tasks RCU enabled.
[ 0.183990] Tracing variant of Tasks RCU enabled.
[ 0.183992] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.183994] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.189292] NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
[ 0.189631] spurious 8259A interrupt: IRQ7.
[ 0.189660] Console: colour dummy device 80x25
[ 0.189679] printk: console [tty0] enabled
[ 0.189718] ACPI: Core revision 20200925
[ 0.189845] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.189864] APIC: Switch to symmetric I/O mode setup
[ 0.190321] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.206532] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1fb61685cd2, max_idle_ns: 440795226699 ns
[ 0.206539] Calibrating delay loop (skipped), value calculated using timer frequency.. 4401.27 BogoMIPS (lpj=7333233)
[ 0.206543] pid_max: default: 32768 minimum: 301
[ 0.206582] LSM: Security Framework initializing
[ 0.206591] Yama: becoming mindful.
[ 0.206631] AppArmor: AppArmor initialized
[ 0.206679] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.206707] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.207111] mce: CPU0: Thermal monitoring enabled (TM2)
[ 0.207115] process: using mwait in idle threads
[ 0.207120] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[ 0.207122] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[ 0.207128] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.207130] Spectre V2 : Mitigation: Full generic retpoline
[ 0.207131] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.207132] Speculative Store Bypass: Vulnerable
[ 0.207135] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.207367] Freeing SMP alternatives memory: 36K
[ 0.316072] smpboot: CPU0: Intel Pentium(R) Dual-Core CPU T4400 @ 2.20GHz (family: 0x6, model: 0x17, stepping: 0xa)
[ 0.316385] Performance Events: PEBS fmt0+, Core2 events, 4-deep LBR, Intel PMU driver.
[ 0.316396] ... version: 2
[ 0.316398] ... bit width: 40
[ 0.316399] ... generic registers: 2
[ 0.316400] ... value mask: 000000ffffffffff
[ 0.316401] ... max period: 000000007fffffff
[ 0.316402] ... fixed-purpose events: 3
[ 0.316403] ... event mask: 0000000700000003
[ 0.316535] rcu: Hierarchical SRCU implementation.
[ 0.316535] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.316535] smp: Bringing up secondary CPUs ...
[ 0.316535] x86: Booting SMP configuration:
[ 0.316535] .... node #0, CPUs: #1
[ 0.323307] smp: Brought up 1 node, 2 CPUs
[ 0.323307] smpboot: Max logical packages: 2
[ 0.323307] smpboot: Total of 2 processors activated (8803.54 BogoMIPS)
[ 0.324438] devtmpfs: initialized
[ 0.324438] x86/mm: Memory block size: 128MB
[ 0.326597] PM: Registering ACPI NVS region [mem 0xcffae000-0xcffeffff] (270336 bytes)
[ 0.326672] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.326703] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.326790] pinctrl core: initialized pinctrl subsystem
[ 0.326980] PM: RTC time: 12:41:49, date: 2021-10-26
[ 0.327182] NET: Registered protocol family 16
[ 0.327502] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.327714] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.327967] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.328002] audit: initializing netlink subsys (disabled)
[ 0.328052] audit: type=2000 audit(1635252109.136:1): state=initialized audit_enabled=0 res=1
[ 0.328052] thermal_sys: Registered thermal governor 'fair_share'
[ 0.328052] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.328052] thermal_sys: Registered thermal governor 'step_wise'
[ 0.328052] thermal_sys: Registered thermal governor 'user_space'
[ 0.328052] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.328052] cpuidle: using governor ladder
[ 0.328052] cpuidle: using governor menu
[ 0.328052] ACPI: bus type PCI registered
[ 0.328052] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.328052] PCI: MMCONFIG for domain 0000 [bus 00-1f] at [mem 0xfc000000-0xfdffffff] (base 0xfc000000)
[ 0.328052] PCI: not using MMCONFIG
[ 0.328052] PCI: Using configuration type 1 for base access
[ 0.331188] Kprobes globally optimized
[ 0.331199] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.331199] ACPI: Added _OSI(Module Device)
[ 0.331199] ACPI: Added _OSI(Processor Device)
[ 0.331199] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.331199] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.331199] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.331199] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.331199] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.342938] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.344892] ACPI: Dynamic OEM Table Load:
[ 0.344901] ACPI: SSDT 0xFFFF9DABC09BB600 0001FA (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.345839] ACPI: Dynamic OEM Table Load:
[ 0.345845] ACPI: SSDT 0xFFFF9DABC03ED800 000594 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.347076] ACPI: Dynamic OEM Table Load:
[ 0.347082] ACPI: SSDT 0xFFFF9DABC0811100 0000CC (v01 PmRef Cpu1Ist 00003000 INTL 20051117)
[ 0.347833] ACPI: Dynamic OEM Table Load:
[ 0.347839] ACPI: SSDT 0xFFFF9DABC09653C0 000085 (v01 PmRef Cpu1Cst 00003000 INTL 20051117)
[ 0.349234] ACPI: Interpreter enabled
[ 0.349259] ACPI: (supports S0 S3 S4 S5)
[ 0.349261] ACPI: Using IOAPIC for interrupt routing
[ 0.349313] PCI: MMCONFIG for domain 0000 [bus 00-1f] at [mem 0xfc000000-0xfdffffff] (base 0xfc000000)
[ 0.351105] PCI: MMCONFIG at [mem 0xfc000000-0xfdffffff] reserved in ACPI motherboard resources
[ 0.351120] pmd_set_huge: Cannot satisfy [mem 0xfc000000-0xfc200000] with a huge-page mapping due to MTRR override.
[ 0.351195] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.351670] ACPI: Enabled 11 GPEs in block 00 to 1F
[ 0.351678] ACPI: Enabled 1 GPEs in block 20 to 5F
[ 0.372521] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.372532] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.372918] acpi PNP0A03:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PCIeCapability LTR DPC]
[ 0.373102] acpi PNP0A03:00: _OSC: not requesting control; platform does not support [PCIeCapability]
[ 0.373105] acpi PNP0A03:00: _OSC: OS requested [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.373107] acpi PNP0A03:00: _OSC: platform willing to grant [PME AER]
[ 0.373109] acpi PNP0A03:00: _OSC failed (AE_SUPPORT); disabling ASPM
[ 0.373128] acpi PNP0A03:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-1f] only partially covers this bridge
[ 0.373641] PCI host bridge to bus 0000:00
[ 0.373645] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.373646] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.373649] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.373650] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
[ 0.373652] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfbffffff window]
[ 0.373654] pci_bus 0000:00: root bus resource [mem 0xfe000000-0xfebfffff window]
[ 0.373656] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.373680] pci 0000:00:00.0: [10de:0a82] type 00 class 0x060000
[ 0.373895] pci 0000:00:00.1: [10de:0a88] type 00 class 0x050000
[ 0.374115] pci 0000:00:03.0: [10de:0aae] type 00 class 0x060100
[ 0.374126] pci 0000:00:03.0: reg 0x10: [io 0x4f00-0x4fff]
[ 0.374296] pci 0000:00:03.1: [10de:0aa4] type 00 class 0x050000
[ 0.374483] pci 0000:00:03.2: [10de:0aa2] type 00 class 0x0c0500
[ 0.374495] pci 0000:00:03.2: reg 0x10: [io 0x4900-0x493f]
[ 0.374517] pci 0000:00:03.2: reg 0x20: [io 0x4d00-0x4d3f]
[ 0.374523] pci 0000:00:03.2: reg 0x24: [io 0x4e00-0x4e3f]
[ 0.374562] pci 0000:00:03.2: PME# supported from D3hot D3cold
[ 0.374707] pci 0000:00:03.3: [10de:0a89] type 00 class 0x050000
[ 0.374942] pci 0000:00:03.5: [10de:0aa3] type 00 class 0x0b4000
[ 0.374968] pci 0000:00:03.5: reg 0x10: [mem 0xf9e80000-0xf9efffff]
[ 0.375187] pci 0000:00:04.0: [10de:0aa5] type 00 class 0x0c0310
[ 0.375199] pci 0000:00:04.0: reg 0x10: [mem 0xf9e7f000-0xf9e7ffff]
[ 0.375253] pci 0000:00:04.0: supports D1 D2
[ 0.375255] pci 0000:00:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.375397] pci 0000:00:04.1: [10de:0aa6] type 00 class 0x0c0320
[ 0.375409] pci 0000:00:04.1: reg 0x10: [mem 0xf9e7ec00-0xf9e7ecff]
[ 0.375469] pci 0000:00:04.1: supports D1 D2
[ 0.375471] pci 0000:00:04.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.375613] pci 0000:00:06.0: [10de:0aa7] type 00 class 0x0c0310
[ 0.375625] pci 0000:00:06.0: reg 0x10: [mem 0xf9e7d000-0xf9e7dfff]
[ 0.375679] pci 0000:00:06.0: supports D1 D2
[ 0.375681] pci 0000:00:06.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.375816] pci 0000:00:06.1: [10de:0aa9] type 00 class 0x0c0320
[ 0.375827] pci 0000:00:06.1: reg 0x10: [mem 0xf9e7e800-0xf9e7e8ff]
[ 0.375888] pci 0000:00:06.1: supports D1 D2
[ 0.375889] pci 0000:00:06.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.376030] pci 0000:00:08.0: [10de:0ac0] type 00 class 0x040300
[ 0.376042] pci 0000:00:08.0: reg 0x10: [mem 0xf9e78000-0xf9e7bfff]
[ 0.376097] pci 0000:00:08.0: PME# supported from D3hot D3cold
[ 0.376227] pci 0000:00:09.0: [10de:0aab] type 01 class 0x060401
[ 0.376392] pci 0000:00:0b.0: [10de:0ab8] type 00 class 0x010601
[ 0.376402] pci 0000:00:0b.0: reg 0x10: [io 0xa080-0xa087]
[ 0.376408] pci 0000:00:0b.0: reg 0x14: [io 0xa000-0xa003]
[ 0.376414] pci 0000:00:0b.0: reg 0x18: [io 0x9c00-0x9c07]
[ 0.376420] pci 0000:00:0b.0: reg 0x1c: [io 0x9880-0x9883]
[ 0.376425] pci 0000:00:0b.0: reg 0x20: [io 0x9800-0x980f]
[ 0.376431] pci 0000:00:0b.0: reg 0x24: [mem 0xf9e76000-0xf9e77fff]
[ 0.376649] pci 0000:00:0c.0: [10de:0ac4] type 01 class 0x060400
[ 0.376753] pci 0000:00:0c.0: enabling Extended Tags
[ 0.376904] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.377112] pci 0000:00:10.0: [10de:0aa0] type 01 class 0x060400
[ 0.377158] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.377333] pci 0000:00:15.0: [10de:0ac6] type 01 class 0x060400
[ 0.377454] pci 0000:00:15.0: enabling Extended Tags
[ 0.377603] pci 0000:00:15.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.377841] pci 0000:00:16.0: [10de:0ac7] type 01 class 0x060400
[ 0.377962] pci 0000:00:16.0: enabling Extended Tags
[ 0.378111] pci 0000:00:16.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.378352] pci 0000:00:17.0: [10de:0ac7] type 01 class 0x060400
[ 0.378473] pci 0000:00:17.0: enabling Extended Tags
[ 0.378621] pci 0000:00:17.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.378859] pci 0000:00:18.0: [10de:0ac7] type 01 class 0x060400
[ 0.378963] pci 0000:00:18.0: enabling Extended Tags
[ 0.379112] pci 0000:00:18.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.379322] pci_bus 0000:01: extended config space not accessible
[ 0.379378] pci 0000:00:09.0: PCI bridge to [bus 01] (subtractive decode)
[ 0.379385] pci 0000:00:09.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.379387] pci 0000:00:09.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.379389] pci 0000:00:09.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.379391] pci 0000:00:09.0: bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
[ 0.379393] pci 0000:00:09.0: bridge window [mem 0xe0000000-0xfbffffff window] (subtractive decode)
[ 0.379394] pci 0000:00:09.0: bridge window [mem 0xfe000000-0xfebfffff window] (subtractive decode)
[ 0.379505] pci 0000:00:0c.0: PCI bridge to [bus 02]
[ 0.379554] pci_bus 0000:03: extended config space not accessible
[ 0.379597] pci 0000:03:00.0: [10de:086e] type 00 class 0x030000
[ 0.379610] pci 0000:03:00.0: reg 0x10: [mem 0xfa000000-0xfaffffff]
[ 0.379621] pci 0000:03:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.379632] pci 0000:03:00.0: reg 0x1c: [mem 0xf4000000-0xf5ffffff 64bit pref]
[ 0.379640] pci 0000:03:00.0: reg 0x24: [io 0xbc00-0xbc7f]
[ 0.379647] pci 0000:03:00.0: reg 0x30: [mem 0xf9fe0000-0xf9ffffff pref]
[ 0.379989] pci 0000:00:10.0: PCI bridge to [bus 03]
[ 0.379993] pci 0000:00:10.0: bridge window [io 0xb000-0xbfff]
[ 0.379996] pci 0000:00:10.0: bridge window [mem 0xf9f00000-0xfaffffff]
[ 0.380000] pci 0000:00:10.0: bridge window [mem 0xe0000000-0xf5ffffff 64bit pref]
[ 0.380132] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[ 0.380151] pci 0000:04:00.0: reg 0x10: [io 0xd800-0xd8ff]
[ 0.380174] pci 0000:04:00.0: reg 0x18: [mem 0xf020fff000-0xf020ffffff 64bit pref]
[ 0.380190] pci 0000:04:00.0: reg 0x20: [mem 0xfff00000c000-0xfff00000ffff 64bit pref]
[ 0.380200] pci 0000:04:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[ 0.380284] pci 0000:04:00.0: supports D1 D2
[ 0.380286] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.389906] pci 0000:00:15.0: PCI bridge to [bus 04-06]
[ 0.389920] pci 0000:00:15.0: bridge window [io 0xc000-0xdfff]
[ 0.389928] pci 0000:00:15.0: bridge window [mem 0xfb000000-0xfbffffff]
[ 0.389942] pci 0000:00:15.0: bridge window [mem 0xf6000000-0xf8ffffff 64bit pref]
[ 0.390060] pci 0000:07:00.0: [1131:7231] type 00 class 0x048000
[ 0.390087] pci 0000:07:00.0: reg 0x10: [mem 0xfe400000-0xfe7fffff 64bit]
[ 0.390105] pci 0000:07:00.0: reg 0x18: [mem 0xfe000000-0xfe3fffff 64bit]
[ 0.390212] pci 0000:07:00.0: supports D1 D2
[ 0.390214] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot
[ 0.399897] pci 0000:00:16.0: PCI bridge to [bus 07]
[ 0.399917] pci 0000:00:16.0: bridge window [mem 0xfe000000-0xfe7fffff]
[ 0.400047] pci 0000:08:00.0: [10ec:8172] type 00 class 0x028000
[ 0.400065] pci 0000:08:00.0: reg 0x10: [io 0xe800-0xe8ff]
[ 0.400076] pci 0000:08:00.0: reg 0x14: [mem 0xfebfc000-0xfebfffff]
[ 0.400190] pci 0000:08:00.0: supports D1 D2
[ 0.400192] pci 0000:08:00.0: PME# supported from D0 D1 D2 D3hot
[ 0.409898] pci 0000:00:17.0: PCI bridge to [bus 08]
[ 0.409912] pci 0000:00:17.0: bridge window [io 0xe000-0xefff]
[ 0.409920] pci 0000:00:17.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.410028] pci 0000:00:18.0: PCI bridge to [bus 09]
[ 0.411289] ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *0, disabled.
[ 0.411507] ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *0, disabled.
[ 0.411727] ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *0, disabled.
[ 0.411942] ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
[ 0.412160] ACPI: PCI Interrupt Link [LN0A] (IRQs 16 17 18 19) *0, disabled.
[ 0.412375] ACPI: PCI Interrupt Link [LN0B] (IRQs 16 17 18 19) *0, disabled.
[ 0.412595] ACPI: PCI Interrupt Link [LN0C] (IRQs 16 17 18 19) *0, disabled.
[ 0.412810] ACPI: PCI Interrupt Link [LN0D] (IRQs 16 17 18 19) *0, disabled.
[ 0.413029] ACPI: PCI Interrupt Link [LN1A] (IRQs 16 17 18 19) *0, disabled.
[ 0.413251] ACPI: PCI Interrupt Link [LN1B] (IRQs 16 17 18 19) *0, disabled.
[ 0.413471] ACPI: PCI Interrupt Link [LN1C] (IRQs 16 17 18 19) *0, disabled.
[ 0.413687] ACPI: PCI Interrupt Link [LN1D] (IRQs 16 17 18 19) *0, disabled.
[ 0.413906] ACPI: PCI Interrupt Link [LN2A] (IRQs 16 17 18 19) *0, disabled.
[ 0.414124] ACPI: PCI Interrupt Link [LN2B] (IRQs 16 17 18 19) *0, disabled.
[ 0.414343] ACPI: PCI Interrupt Link [LN2C] (IRQs 16 17 18 19) *0, disabled.
[ 0.414558] ACPI: PCI Interrupt Link [LN2D] (IRQs 16 17 18 19) *0, disabled.
[ 0.414783] ACPI: PCI Interrupt Link [LN3A] (IRQs 16 17 18 19) *15
[ 0.414999] ACPI: PCI Interrupt Link [LN3B] (IRQs 16 17 18 19) *0, disabled.
[ 0.415218] ACPI: PCI Interrupt Link [LN3C] (IRQs 16 17 18 19) *0, disabled.
[ 0.415433] ACPI: PCI Interrupt Link [LN3D] (IRQs 16 17 18 19) *0, disabled.
[ 0.415658] ACPI: PCI Interrupt Link [LN4A] (IRQs 16 17 18 19) *10
[ 0.415872] ACPI: PCI Interrupt Link [LN4B] (IRQs 16 17 18 19) *0, disabled.
[ 0.416092] ACPI: PCI Interrupt Link [LN4C] (IRQs 16 17 18 19) *0, disabled.
[ 0.416307] ACPI: PCI Interrupt Link [LN4D] (IRQs 16 17 18 19) *0, disabled.
[ 0.416541] ACPI: PCI Interrupt Link [LN5A] (IRQs 16 17 18 19) *11
[ 0.416758] ACPI: PCI Interrupt Link [LN5B] (IRQs 16 17 18 19) *0, disabled.
[ 0.416977] ACPI: PCI Interrupt Link [LN5C] (IRQs 16 17 18 19) *0, disabled.
[ 0.417199] ACPI: PCI Interrupt Link [LN5D] (IRQs 16 17 18 19) *0, disabled.
[ 0.417419] ACPI: PCI Interrupt Link [LN6A] (IRQs 16 17 18 19) *0, disabled.
[ 0.417634] ACPI: PCI Interrupt Link [LN6B] (IRQs 16 17 18 19) *0, disabled.
[ 0.417854] ACPI: PCI Interrupt Link [LN6C] (IRQs 16 17 18 19) *0, disabled.
[ 0.418070] ACPI: PCI Interrupt Link [LN6D] (IRQs 16 17 18 19) *0, disabled.
[ 0.418294] ACPI: PCI Interrupt Link [LUB0] (IRQs 20 21 22 23) *9
[ 0.418513] ACPI: PCI Interrupt Link [LUB2] (IRQs 20 21 22 23) *15
[ 0.418731] ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22 23) *0, disabled.
[ 0.418951] ACPI: PCI Interrupt Link [LAZA] (IRQs 20 21 22 23) *9
[ 0.419173] ACPI: PCI Interrupt Link [SGRU] (IRQs 20 21 22 23) *7
[ 0.419393] ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22 23) *10
[ 0.419616] ACPI: PCI Interrupt Link [LPMU] (IRQs 20 21 22 23) *11
[ 0.419834] ACPI: PCI Interrupt Link [LSA0] (IRQs 20 21 22 23) *5
[ 0.420083] ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22 23) *0, disabled.
[ 0.420303] ACPI: PCI Interrupt Link [UB11] (IRQs 20 21 22 23) *10
[ 0.420526] ACPI: PCI Interrupt Link [UB12] (IRQs 20 21 22 23) *11
[ 0.420745] ACPI: PCI Interrupt Link [LRP0] (IRQs 20 21 22 23) *10
[ 0.420964] ACPI: PCI Interrupt Link [LRP1] (IRQs 20 21 22 23) *0, disabled.
[ 0.421180] ACPI: PCI Interrupt Link [LRP2] (IRQs 20 21 22 23) *0, disabled.
[ 0.421404] ACPI: PCI Interrupt Link [LRP3] (IRQs 20 21 22 23) *11
[ 0.421622] ACPI: PCI Interrupt Link [LRP4] (IRQs 20 21 22 23) *9
[ 0.421847] ACPI: PCI Interrupt Link [LRP5] (IRQs 20 21 22 23) *15
[ 0.422067] ACPI: PCI Interrupt Link [LRP6] (IRQs 20 21 22 23) *14
[ 0.422313] iommu: Default domain type: Translated
[ 0.422340] pci 0000:03:00.0: vgaarb: setting as boot VGA device
[ 0.422340] pci 0000:03:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.422340] pci 0000:03:00.0: vgaarb: bridge control possible
[ 0.422340] vgaarb: loaded
[ 0.422340] SCSI subsystem initialized
[ 0.422340] libata version 3.00 loaded.
[ 0.422340] ACPI: bus type USB registered
[ 0.422340] usbcore: registered new interface driver usbfs
[ 0.422340] usbcore: registered new interface driver hub
[ 0.422340] usbcore: registered new device driver usb
[ 0.422340] pps_core: LinuxPPS API ver. 1 registered
[ 0.422340] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.422340] PTP clock support registered
[ 0.422340] EDAC MC: Ver: 3.0.0
[ 0.422340] NetLabel: Initializing
[ 0.422340] NetLabel: domain hash size = 128
[ 0.422340] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.422340] NetLabel: unlabeled traffic allowed by default
[ 0.422340] PCI: Using ACPI for IRQ routing
[ 0.422340] PCI: pci_cache_line_size set to 64 bytes
[ 0.422340] pci 0000:04:00.0: can't claim BAR 2 [mem 0xf020fff000-0xf020ffffff 64bit pref]: no compatible bridge window
[ 0.422340] pci 0000:04:00.0: can't claim BAR 4 [mem 0xfff00000c000-0xfff00000ffff 64bit pref]: no compatible bridge window
[ 0.422340] e820: reserve RAM buffer [mem 0x0009e800-0x0009ffff]
[ 0.422340] e820: reserve RAM buffer [mem 0xcffa0000-0xcfffffff]
[ 0.424770] hpet: 4 channels of 0 reserved for per-cpu timers
[ 0.424776] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 31, 31
[ 0.424783] hpet0: 4 comparators, 64-bit 25.000000 MHz counter
[ 0.427647] clocksource: Switched to clocksource tsc-early
[ 0.448612] VFS: Disk quotas dquot_6.6.0
[ 0.448641] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.448834] AppArmor: AppArmor Filesystem Enabled
[ 0.448880] pnp: PnP ACPI init
[ 0.449752] system 00:00: [io 0x04d0-0x04d1] has been reserved
[ 0.449756] system 00:00: [io 0x0800-0x080f] has been reserved
[ 0.449758] system 00:00: [io 0x4000-0x407f] has been reserved
[ 0.449760] system 00:00: [io 0x4080-0x40ff] has been reserved
[ 0.449762] system 00:00: [io 0x4400-0x447f] has been reserved
[ 0.449764] system 00:00: [io 0x4480-0x44ff] has been reserved
[ 0.449766] system 00:00: [io 0x4800-0x487f] has been reserved
[ 0.449767] system 00:00: [io 0x4880-0x48ff] has been reserved
[ 0.449770] system 00:00: [mem 0x000d0000-0x000d3fff window] has been reserved
[ 0.449772] system 00:00: [mem 0x000d4000-0x000d7fff window] has been reserved
[ 0.449774] system 00:00: [mem 0x000de000-0x000dffff window] has been reserved
[ 0.449776] system 00:00: [mem 0xfefe2000-0xfefe3fff] has been reserved
[ 0.449778] system 00:00: [mem 0xfefe1000-0xfefe1fff] has been reserved
[ 0.449780] system 00:00: [mem 0xfee01000-0xfeefffff] has been reserved
[ 0.449790] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.449908] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.450122] system 00:02: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.450124] system 00:02: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.450132] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.450387] system 00:03: [io 0x0a00-0x0a0f] has been reserved
[ 0.450395] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.450537] system 00:04: [mem 0xfc000000-0xfdffffff] has been reserved
[ 0.450544] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.450894] system 00:05: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.450897] system 00:05: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.450899] system 00:05: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.450902] system 00:05: [mem 0x00100000-0xdfffffff] could not be reserved
[ 0.450904] system 00:05: [mem 0xfec00000-0xffffffff] could not be reserved
[ 0.450911] system 00:05: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.452421] pnp: PnP ACPI: found 6 devices
[ 0.458893] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.458993] NET: Registered protocol family 2
[ 0.459204] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.460137] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.460254] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.460494] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.460575] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.460769] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.460836] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.460882] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.461764] NET: Registered protocol family 1
[ 0.461783] NET: Registered protocol family 44
[ 0.461878] pci 0000:00:09.0: PCI bridge to [bus 01]
[ 0.461891] pci 0000:00:0c.0: PCI bridge to [bus 02]
[ 0.461918] pci 0000:00:10.0: PCI bridge to [bus 03]
[ 0.461922] pci 0000:00:10.0: bridge window [io 0xb000-0xbfff]
[ 0.461925] pci 0000:00:10.0: bridge window [mem 0xf9f00000-0xfaffffff]
[ 0.461928] pci 0000:00:10.0: bridge window [mem 0xe0000000-0xf5ffffff 64bit pref]
[ 0.461938] pci 0000:04:00.0: BAR 6: assigned [mem 0xfb000000-0xfb01ffff pref]
[ 0.461941] pci 0000:04:00.0: BAR 4: assigned [mem 0xf6000000-0xf6003fff 64bit pref]
[ 0.461952] pci 0000:04:00.0: BAR 2: assigned [mem 0xf6004000-0xf6004fff 64bit pref]
[ 0.461962] pci 0000:00:15.0: PCI bridge to [bus 04-06]
[ 0.461967] pci 0000:00:15.0: bridge window [io 0xc000-0xdfff]
[ 0.461977] pci 0000:00:15.0: bridge window [mem 0xfb000000-0xfbffffff]
[ 0.461984] pci 0000:00:15.0: bridge window [mem 0xf6000000-0xf8ffffff 64bit pref]
[ 0.461997] pci 0000:00:16.0: PCI bridge to [bus 07]
[ 0.462007] pci 0000:00:16.0: bridge window [mem 0xfe000000-0xfe7fffff]
[ 0.462026] pci 0000:00:17.0: PCI bridge to [bus 08]
[ 0.462031] pci 0000:00:17.0: bridge window [io 0xe000-0xefff]
[ 0.462041] pci 0000:00:17.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.462060] pci 0000:00:18.0: PCI bridge to [bus 09]
[ 0.462087] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.462089] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.462091] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.462093] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.462095] pci_bus 0000:00: resource 8 [mem 0xe0000000-0xfbffffff window]
[ 0.462097] pci_bus 0000:00: resource 9 [mem 0xfe000000-0xfebfffff window]
[ 0.462099] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7 window]
[ 0.462101] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff window]
[ 0.462102] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.462104] pci_bus 0000:01: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.462106] pci_bus 0000:01: resource 8 [mem 0xe0000000-0xfbffffff window]
[ 0.462108] pci_bus 0000:01: resource 9 [mem 0xfe000000-0xfebfffff window]
[ 0.462110] pci_bus 0000:03: resource 0 [io 0xb000-0xbfff]
[ 0.462111] pci_bus 0000:03: resource 1 [mem 0xf9f00000-0xfaffffff]
[ 0.462113] pci_bus 0000:03: resource 2 [mem 0xe0000000-0xf5ffffff 64bit pref]
[ 0.462115] pci_bus 0000:04: resource 0 [io 0xc000-0xdfff]
[ 0.462117] pci_bus 0000:04: resource 1 [mem 0xfb000000-0xfbffffff]
[ 0.462118] pci_bus 0000:04: resource 2 [mem 0xf6000000-0xf8ffffff 64bit pref]
[ 0.462120] pci_bus 0000:07: resource 1 [mem 0xfe000000-0xfe7fffff]
[ 0.462122] pci_bus 0000:08: resource 0 [io 0xe000-0xefff]
[ 0.462124] pci_bus 0000:08: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 0.462740] PCI Interrupt Link [LUB0] enabled at IRQ 23
[ 0.528449] pci 0000:00:04.0: quirk_usb_early_handoff+0x0/0x720 took 64609 usecs
[ 0.528835] PCI Interrupt Link [LUB2] enabled at IRQ 22
[ 0.529323] PCI Interrupt Link [UB11] enabled at IRQ 21
[ 0.551773] pci 0000:00:06.0: quirk_usb_early_handoff+0x0/0x720 took 22285 usecs
[ 0.552159] PCI Interrupt Link [UB12] enabled at IRQ 20
[ 0.552412] pci 0000:03:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.552425] PCI: CLS 64 bytes, default 64
[ 0.552518] Trying to unpack rootfs image as initramfs...
[ 0.724277] Freeing initrd memory: 12616K
[ 0.724286] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.724289] software IO TLB: mapped [mem 0x00000000cbfa0000-0x00000000cffa0000] (64MB)
[ 0.724750] check: Scanning for low memory corruption every 60 seconds
[ 0.725245] Initialise system trusted keyrings
[ 0.725258] Key type blacklist registered
[ 0.725355] workingset: timestamp_bits=41 max_order=20 bucket_order=0
[ 0.727257] zbud: loaded
[ 0.740597] Key type asymmetric registered
[ 0.740601] Asymmetric key parser 'x509' registered
[ 0.740621] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.740671] io scheduler mq-deadline registered
[ 0.740673] io scheduler kyber registered
[ 0.740711] io scheduler bfq registered
[ 0.740783] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[ 0.741445] PCI Interrupt Link [LRP0] enabled at IRQ 23
[ 0.742099] PCI Interrupt Link [LRP3] enabled at IRQ 22
[ 0.742723] PCI Interrupt Link [LRP4] enabled at IRQ 21
[ 0.743353] PCI Interrupt Link [LRP5] enabled at IRQ 20
[ 0.743968] PCI Interrupt Link [LRP6] enabled at IRQ 23
[ 0.744256] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.744305] vesafb: mode is 1024x768x32, linelength=4096, pages=0
[ 0.744306] vesafb: scrolling: redraw
[ 0.744308] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.744331] vesafb: framebuffer at 0xf5000000, mapped to 0x(____ptrval____), using 3072k, total 3072k
[ 0.744402] fbcon: Deferring console take-over
[ 0.744404] fb0: VESA VGA frame buffer device
[ 0.744424] intel_idle: MWAIT substates: 0x2220
[ 0.744580] Monitor-Mwait will be used to enter C-1 state
[ 0.744588] Monitor-Mwait will be used to enter C-2 state
[ 0.744594] Monitor-Mwait will be used to enter C-3 state
[ 0.744601] ACPI: \_PR_.P001: Found 3 idle states
[ 0.744603] intel_idle: v0.5.1 model 0x17
[ 0.744728] intel_idle: Local APIC timer is reliable in C1
[ 0.744920] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.751321] ACPI: Power Button [PWRB]
[ 0.751383] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.751427] ACPI: Power Button [PWRF]
[ 0.751934] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.754402] Non-volatile memory driver v1.3
[ 0.754405] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.754406] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 0.755122] ahci 0000:00:0b.0: version 3.0
[ 0.755583] PCI Interrupt Link [LSA0] enabled at IRQ 22
[ 0.755619] ahci 0000:00:0b.0: controller can't do PMP, turning off CAP_PMP
[ 0.755721] ahci 0000:00:0b.0: AHCI 0001.0200 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[ 0.755724] ahci 0000:00:0b.0: flags: 64bit ncq sntf led pio slum part sxs
[ 0.756474] scsi host0: ahci
[ 0.756692] scsi host1: ahci
[ 0.756887] scsi host2: ahci
[ 0.757063] scsi host3: ahci
[ 0.757136] ata1: SATA max UDMA/133 abar m8192@0xf9e76000 port 0xf9e76100 irq 29
[ 0.757138] ata2: SATA max UDMA/133 abar m8192@0xf9e76000 port 0xf9e76180 irq 29
[ 0.757140] ata3: SATA max UDMA/133 abar m8192@0xf9e76000 port 0xf9e76200 irq 29
[ 0.757142] ata4: SATA max UDMA/133 abar m8192@0xf9e76000 port 0xf9e76280 irq 29
[ 0.757296] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.757326] ehci-pci: EHCI PCI platform driver
[ 0.757560] ehci-pci 0000:00:04.1: EHCI Host Controller
[ 0.757570] ehci-pci 0000:00:04.1: new USB bus registered, assigned bus number 1
[ 0.757581] ehci-pci 0000:00:04.1: debug port 1
[ 0.757623] ehci-pci 0000:00:04.1: cache line size of 64 is not supported
[ 0.757643] ehci-pci 0000:00:04.1: irq 22, io mem 0xf9e7ec00
[ 0.767992] ehci-pci 0000:00:04.1: USB 2.0 started, EHCI 1.00
[ 0.768063] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 0.768066] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.768068] usb usb1: Product: EHCI Host Controller
[ 0.768070] usb usb1: Manufacturer: Linux 5.10.70-1-MANJARO ehci_hcd
[ 0.768071] usb usb1: SerialNumber: 0000:00:04.1
[ 0.768245] hub 1-0:1.0: USB hub found
[ 0.768255] hub 1-0:1.0: 6 ports detected
[ 0.768659] ehci-pci 0000:00:06.1: EHCI Host Controller
[ 0.768667] ehci-pci 0000:00:06.1: new USB bus registered, assigned bus number 2
[ 0.768676] ehci-pci 0000:00:06.1: debug port 1
[ 0.768709] ehci-pci 0000:00:06.1: cache line size of 64 is not supported
[ 0.768728] ehci-pci 0000:00:06.1: irq 20, io mem 0xf9e7e800
[ 0.781312] ehci-pci 0000:00:06.1: USB 2.0 started, EHCI 1.00
[ 0.781392] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 0.781394] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.781396] usb usb2: Product: EHCI Host Controller
[ 0.781398] usb usb2: Manufacturer: Linux 5.10.70-1-MANJARO ehci_hcd
[ 0.781399] usb usb2: SerialNumber: 0000:00:06.1
[ 0.781551] hub 2-0:1.0: USB hub found
[ 0.781564] hub 2-0:1.0: 6 ports detected
[ 0.781822] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.781827] ohci-pci: OHCI PCI platform driver
[ 0.781972] ohci-pci 0000:00:04.0: OHCI PCI host controller
[ 0.781983] ohci-pci 0000:00:04.0: new USB bus registered, assigned bus number 3
[ 0.782021] ohci-pci 0000:00:04.0: irq 23, io mem 0xf9e7f000
[ 0.840001] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 0.840004] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.840006] usb usb3: Product: OHCI PCI host controller
[ 0.840008] usb usb3: Manufacturer: Linux 5.10.70-1-MANJARO ohci_hcd
[ 0.840009] usb usb3: SerialNumber: 0000:00:04.0
[ 0.840174] hub 3-0:1.0: USB hub found
[ 0.840185] hub 3-0:1.0: 6 ports detected
[ 0.840608] ohci-pci 0000:00:06.0: OHCI PCI host controller
[ 0.840616] ohci-pci 0000:00:06.0: new USB bus registered, assigned bus number 4
[ 0.840653] ohci-pci 0000:00:06.0: irq 21, io mem 0xf9e7d000
[ 0.896681] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 0.896684] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.896686] usb usb4: Product: OHCI PCI host controller
[ 0.896687] usb usb4: Manufacturer: Linux 5.10.70-1-MANJARO ohci_hcd
[ 0.896689] usb usb4: SerialNumber: 0000:00:06.0
[ 0.896830] hub 4-0:1.0: USB hub found
[ 0.896840] hub 4-0:1.0: 6 ports detected
[ 0.897077] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.897159] usbcore: registered new interface driver usbserial_generic
[ 0.897165] usbserial: USB Serial support registered for generic
[ 0.897192] i8042: PNP: No PS/2 controller found.
[ 0.897193] i8042: Probing ports directly.
[ 0.897657] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.897696] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.897887] rtc_cmos 00:01: RTC can wake from S4
[ 0.898286] rtc_cmos 00:01: registered as rtc0
[ 0.898351] rtc_cmos 00:01: setting system clock to 2021-10-26T12:41:50 UTC (1635252110)
[ 0.898373] rtc_cmos 00:01: alarms up to one year, y3k, 114 bytes nvram, hpet irqs
[ 0.898429] intel_pstate: CPU model not supported
[ 0.898461] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.898739] hid: raw HID events driver (C) Jiri Kosina
[ 0.898836] ashmem: initialized
[ 0.899007] drop_monitor: Initializing network drop monitor service
[ 0.899094] Initializing XFRM netlink socket
[ 0.899241] NET: Registered protocol family 10
[ 0.908847] Segment Routing with IPv6
[ 0.908851] RPL Segment Routing with IPv6
[ 0.908893] NET: Registered protocol family 17
[ 0.909209] microcode: sig=0x1067a, pf=0x80, revision=0xa0b
[ 0.909217] microcode: Microcode Update Driver: v2.2.
[ 0.909222] IPI shorthand broadcast: enabled
[ 0.909235] sched_clock: Marking stable (908758366, 302316)->(913450962, -4390280)
[ 0.909344] registered taskstats version 1
[ 0.909370] Loading compiled-in X.509 certificates
[ 0.915092] Loaded X.509 cert 'Build time autogenerated kernel key: 0bd158d4f9a759e7389f888b623e06b46f337649'
[ 0.916629] zswap: loaded using pool zstd/z3fold
[ 0.916973] Key type ._fscrypt registered
[ 0.916975] Key type .fscrypt registered
[ 0.916976] Key type fscrypt-provisioning registered
[ 0.917050] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.917685] PM: Magic number: 9:384:684
[ 0.917751] mem full: hash matches
[ 0.917986] RAS: Correctable Errors collector initialized.
[ 1.031163] usb 2-6: new high-speed USB device number 2 using ehci-pci
[ 1.074460] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.074481] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.074502] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.074511] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.075610] ata1.00: ATA-8: ST31000520AS, CC32, max UDMA/133
[ 1.075613] ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 32)
[ 1.076926] ata1.00: configured for UDMA/133
[ 1.077088] scsi 0:0:0:0: Direct-Access ATA ST31000520AS CC32 PQ: 0 ANSI: 5
[ 1.077351] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.077366] sd 0:0:0:0: [sda] Write Protect is off
[ 1.077369] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.077392] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.103160] ata2.00: ATAPI: HL-DT-ST DVDRAM GSA-T50N, RQ01, max UDMA/133
[ 1.107962] ata2.00: configured for UDMA/133
[ 1.160291] sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 sda8 sda9 sda10 sda11 >
[ 1.174513] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.219984] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GSA-T50N RQ01 PQ: 0 ANSI: 5
[ 1.254250] usb 3-2: new low-speed USB device number 2 using ohci-pci
[ 1.258498] Freeing unused decrypted memory: 2036K
[ 1.259573] Freeing unused kernel image (initmem) memory: 1708K
[ 1.259634] Write protecting the kernel read-only data: 26624k
[ 1.261138] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.261879] Freeing unused kernel image (rodata/data gap) memory: 1076K
[ 1.312979] usb 2-6: New USB device found, idVendor=04f2, idProduct=b1a0, bcdDevice=69.59
[ 1.312983] usb 2-6: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 1.312985] usb 2-6: Product: Chicony WebCam
[ 1.312986] usb 2-6: Manufacturer: Chicony Electronics Co., Ltd.
[ 1.320430] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.320436] rodata_test: all tests were successful
[ 1.320456] x86/mm: Checking user space page tables
[ 1.376347] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.376354] Run /init as init process
[ 1.376355] with arguments:
[ 1.376356] /init
[ 1.376357] with environment:
[ 1.376359] HOME=/
[ 1.376360] TERM=linux
[ 1.376361] BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
[ 1.490607] usb 3-2: New USB device found, idVendor=04f2, idProduct=0618, bcdDevice= 1.40
[ 1.490611] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.490613] usb 3-2: Product: USB Wireless HID Receiver
[ 1.490615] usb 3-2: Manufacturer: Chicony
[ 1.528589] random: fast init done
[ 1.536866] usbcore: registered new interface driver usbhid
[ 1.536869] usbhid: USB HID core driver
[ 1.566937] input: Chicony USB Wireless HID Receiver as /devices/pci0000:00/0000:00:04.0/usb3/3-2/3-2:1.0/0003:04F2:0618.0001/input/input4
[ 1.623466] topseed 0003:04F2:0618.0001: input,hidraw0: USB HID v1.11 Keyboard [Chicony USB Wireless HID Receiver] on usb-0000:00:04.0-2/input0
[ 1.624165] input: Chicony USB Wireless HID Receiver as /devices/pci0000:00/0000:00:04.0/usb3/3-2/3-2:1.1/0003:04F2:0618.0002/input/input5
[ 1.680038] input: Chicony USB Wireless HID Receiver as /devices/pci0000:00/0000:00:04.0/usb3/3-2/3-2:1.1/0003:04F2:0618.0002/input/input6
[ 1.680202] input: Chicony USB Wireless HID Receiver as /devices/pci0000:00/0000:00:04.0/usb3/3-2/3-2:1.1/0003:04F2:0618.0002/input/input7
[ 1.680363] topseed 0003:04F2:0618.0002: input,hiddev96,hidraw1: USB HID v1.11 Device [Chicony USB Wireless HID Receiver] on usb-0000:00:04.0-2/input1
[ 1.680759] input: Chicony USB Wireless HID Receiver as /devices/pci0000:00/0000:00:04.0/usb3/3-2/3-2:1.2/0003:04F2:0618.0003/input/input8
[ 1.680868] topseed 0003:04F2:0618.0003: input,hidraw2: USB HID v1.11 Mouse [Chicony USB Wireless HID Receiver] on usb-0000:00:04.0-2/input2
[ 1.683339] tsc: Refined TSC clocksource calibration: 2196.678 MHz
[ 1.683346] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fa9f0a7913, max_idle_ns: 440795248863 ns
[ 1.683361] clocksource: Switched to clocksource tsc
[ 1.716305] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.716311] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.873301] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.963235] usb 3-6: new full-speed USB device number 3 using ohci-pci
[ 2.192795] usb 3-6: New USB device found, idVendor=22b9, idProduct=0008, bcdDevice= 0.00
[ 2.192801] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.192805] usb 3-6: Product: eTurboTouch
[ 2.192808] usb 3-6: Manufacturer: eTurboTouch
[ 2.202456] input: eTurboTouch eTurboTouch as /devices/pci0000:00/0000:00:04.0/usb3/3-6/3-6:1.0/0003:22B9:0008.0004/input/input9
[ 2.202601] hid-generic 0003:22B9:0008.0004: input,hidraw3: USB HID v1.01 Device [eTurboTouch eTurboTouch] on usb-0000:00:04.0-6/input0
[ 3.097404] fbcon: Taking over console
[ 3.097658] Console: switching to colour frame buffer device 128x48
[ 3.285196] EXT4-fs (sda10): mounted filesystem with ordered data mode. Opts: (null)
[ 3.801553] random: crng init done
[ 4.083121] systemd[1]: RTC configured in localtime, applying delta of 120 minutes to system time.
[ 4.293606] systemd[1]: systemd 249.4-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 4.310003] systemd[1]: Detected architecture x86-64.
[ 4.331983] systemd[1]: Hostname set to <medion>.
[ 7.081814] systemd[1]: Queued start job for default target Graphical Interface.
[ 7.083630] systemd[1]: Created slice Slice /system/getty.
[ 7.084303] systemd[1]: Created slice Slice /system/modprobe.
[ 7.084953] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 7.085346] systemd[1]: Created slice User and Session Slice.
[ 7.085491] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 7.085590] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.085874] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.085975] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.086006] systemd[1]: Reached target Login Prompts.
[ 7.086063] systemd[1]: Reached target Remote File Systems.
[ 7.086087] systemd[1]: Reached target Slice Units.
[ 7.086139] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[ 7.086283] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.086471] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.088562] systemd[1]: Listening on Process Core Dump Socket.
[ 7.088874] systemd[1]: Listening on Journal Audit Socket.
[ 7.089053] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.089264] systemd[1]: Listening on Journal Socket.
[ 7.095693] systemd[1]: Listening on udev Control Socket.
[ 7.095884] systemd[1]: Listening on udev Kernel Socket.
[ 7.097611] systemd[1]: Mounting Huge Pages File System...
[ 7.099376] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.101339] systemd[1]: Mounting Kernel Debug File System...
[ 7.104064] systemd[1]: Mounting Kernel Trace File System...
[ 7.106359] systemd[1]: Starting Load AppArmor profiles...
[ 7.108652] systemd[1]: Starting Create List of Static Device Nodes...
[ 7.110829] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 7.116220] systemd[1]: Starting Load Kernel Module configfs...
[ 7.119214] systemd[1]: Starting Load Kernel Module drm...
[ 7.121538] systemd[1]: Starting Load Kernel Module fuse...
[ 7.154224] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 7.154310] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.207709] Linux agpgart interface v0.103
[ 7.252154] systemd[1]: Starting Load Kernel Modules...
[ 7.254168] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.254349] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 7.256278] systemd[1]: Starting Coldplug All udev Devices...
[ 7.259420] systemd[1]: Mounted Huge Pages File System.
[ 7.259626] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.259787] systemd[1]: Mounted Kernel Debug File System.
[ 7.260012] systemd[1]: Mounted Kernel Trace File System.
[ 7.260550] systemd[1]: Finished Create List of Static Device Nodes.
[ 7.261151] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 7.261504] systemd[1]: Finished Load Kernel Module configfs.
[ 7.263464] systemd[1]: Mounting Kernel Configuration File System...
[ 7.267206] systemd[1]: Mounted Kernel Configuration File System.
[ 7.307536] EXT4-fs (sda10): re-mounted. Opts: (null)
[ 7.309328] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 7.311016] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 7.323401] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 7.325104] systemd[1]: Starting Load/Save Random Seed...
[ 7.325277] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 7.327220] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 7.357557] fuse: init (API version 7.32)
[ 7.358862] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 7.359258] systemd[1]: Finished Load Kernel Module fuse.
[ 7.361203] systemd[1]: Mounting FUSE Control File System...
[ 7.371712] systemd[1]: Mounted FUSE Control File System.
[ 7.420706] systemd[1]: Finished Coldplug All udev Devices.
[ 7.447749] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 7.448105] systemd[1]: Finished Load Kernel Module drm.
[ 7.622963] systemd[1]: Finished Load Kernel Modules.
[ 7.624796] systemd[1]: Starting Apply Kernel Variables...
[ 7.758397] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 7.877388] systemd[1]: Finished Load/Save Random Seed.
[ 7.877660] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 7.892650] systemd[1]: Finished Apply Kernel Variables.
[ 7.920748] systemd[1]: Starting CLI Netfilter Manager...
[ 8.025908] systemd[1]: Finished CLI Netfilter Manager.
[ 8.103926] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 8.104141] systemd[1]: Reached target Preparation for Local File Systems.
[ 8.104215] systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
[ 8.104248] systemd[1]: Condition check resulted in Entropy Daemon based on the HAVEGE algorithm being skipped.
[ 8.107029] systemd[1]: Starting Journal Service...
[ 8.109712] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 8.179108] audit: type=1400 audit(1635244917.778:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=206 comm="apparmor_parser"
[ 8.283643] systemd[1]: Started Journal Service.
[ 8.286594] audit: type=1130 audit(1635244917.884:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8.366968] systemd-journald[213]: Received client request to flush runtime journal.
[ 8.398900] audit: type=1400 audit(1635244917.998:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=215 comm="apparmor_parser"
[ 8.400524] audit: type=1400 audit(1635244917.998:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=215 comm="apparmor_parser"
[ 8.495251] audit: type=1400 audit(1635244918.094:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=205 comm="apparmor_parser"
[ 8.497213] audit: type=1400 audit(1635244918.098:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=205 comm="apparmor_parser"
[ 8.622249] audit: type=1400 audit(1635244918.218:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=217 comm="apparmor_parser"
[ 8.880732] audit: type=1400 audit(1635244918.478:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=218 comm="apparmor_parser"
[ 9.316408] audit: type=1400 audit(1635244918.911:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=219 comm="apparmor_parser"
[ 9.317929] audit: type=1400 audit(1635244918.914:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=219 comm="apparmor_parser"
[ 10.479491] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 10.500938] ACPI Warning: SystemIO range 0x0000000000004D00-0x0000000000004D3F conflicts with OpRegion 0x0000000000004D00-0x0000000000004D3F (\_SB.PCI0.SM00) (20200925/utaddress-204)
[ 10.500949] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 10.501036] i2c i2c-0: nForce2 SMBus adapter at 0x4e00
[ 10.531123] [Firmware Bug]: ACPI(IGPU) defines _DOD but not _DOS
[ 10.531397] ACPI: Video Device [IGPU] (multi-head: yes rom: no post: no)
[ 10.531839] acpi device:1e: registered as cooling_device2
[ 10.531897] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:1d/LNXVIDEO:00/input/input10
[ 10.564244] nv_tco: NV TCO WatchDog Timer Driver v0.01
[ 10.564391] nv_tco: Watchdog reboot not detected
[ 10.564483] nv_tco: initialized (0x4440). heartbeat=30 sec (nowayout=0)
[ 10.795615] input: PC Speaker as /devices/platform/pcspkr/input/input11
[ 10.999380] intel_powerclamp: No package C-state available
[ 11.033788] intel_powerclamp: No package C-state available
[ 11.114217] r8169 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 11.114676] PCI Interrupt Link [LN3A] enabled at IRQ 19
[ 11.118286] libphy: r8169: probed
[ 11.118921] r8169 0000:04:00.0 eth0: RTL8168d/8111d, 40:61:86:2a:2f:8d, XID 281, IRQ 30
[ 11.118925] r8169 0000:04:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 11.315615] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 11.321396] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 11.336959] input: MSI WMI hotkeys as /devices/virtual/input/input13
[ 11.380686] PCI Interrupt Link [LAZA] enabled at IRQ 21
[ 11.380701] snd_hda_intel 0000:00:08.0: Disabling MSI
[ 11.494699] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC889A: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 11.494704] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 11.494707] snd_hda_codec_realtek hdaudioC0D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 11.494709] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 11.494710] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 11.494712] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 11.494714] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x19
[ 11.494717] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 11.494718] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 11.516597] input: HDA NVidia Mic as /devices/pci0000:00/0000:00:08.0/sound/card0/input14
[ 11.516688] input: HDA NVidia Line as /devices/pci0000:00/0000:00:08.0/sound/card0/input15
[ 11.516764] input: HDA NVidia Line Out as /devices/pci0000:00/0000:00:08.0/sound/card0/input16
[ 11.821972] PCI Interrupt Link [LN5A] enabled at IRQ 18
[ 11.833755] rtl8192se: FW Power Save off (module option)
[ 11.833847] rtl8192se: Driver for Realtek RTL8192SE/RTL8191SE
Loading firmware rtlwifi/rtl8192sefw.bin
[ 11.844626] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 11.904237] r8169 0000:04:00.0 enp4s0: renamed from eth0
[ 12.018218] MXM: GUID detected in BIOS
[ 12.018826] ACPI Warning: \_SB.PCI0.IXVE.IGPU._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
[ 12.018912] ACPI: \_SB_.PCI0.IXVE.IGPU: failed to evaluate _DSM
[ 12.019333] PCI Interrupt Link [SGRU] enabled at IRQ 20
[ 12.019503] checking generic (f5000000 300000) vs hw (fa000000 1000000)
[ 12.019505] checking generic (f5000000 300000) vs hw (e0000000 10000000)
[ 12.019507] checking generic (f5000000 300000) vs hw (f4000000 2000000)
[ 12.019509] fb0: switching to nouveaufb from VESA VGA
[ 12.019666] Console: switching to colour dummy device 80x25
[ 12.019746] nouveau 0000:03:00.0: vgaarb: deactivate vga console
[ 12.019936] nouveau 0000:03:00.0: NVIDIA MCP79/MCP7A (0ac700b1)
[ 12.034764] nouveau 0000:03:00.0: bios: version 62.79.6c.00.00
[ 12.055517] nouveau 0000:03:00.0: fb: 256 MiB stolen system memory
[ 12.098384] rtl8192se 0000:08:00.0 wlp8s0: renamed from wlan0
[ 12.134123] [TTM] Zone kernel: Available graphics memory: 1882370 KiB
[ 12.134126] [TTM] Initializing pool allocator
[ 12.134133] [TTM] Initializing DMA pool allocator
[ 12.134158] nouveau 0000:03:00.0: DRM: VRAM: 256 MiB
[ 12.134160] nouveau 0000:03:00.0: DRM: GART: 1048576 MiB
[ 12.134165] nouveau 0000:03:00.0: DRM: TMDS table version 2.0
[ 12.134167] nouveau 0000:03:00.0: DRM: DCB version 4.0
[ 12.134170] nouveau 0000:03:00.0: DRM: DCB outp 00: 02011300 0000001e
[ 12.134172] nouveau 0000:03:00.0: DRM: DCB outp 01: 010003f3 00010035
[ 12.134174] nouveau 0000:03:00.0: DRM: DCB conn 00: 00000040
[ 12.134176] nouveau 0000:03:00.0: DRM: DCB conn 01: 00000100
[ 12.134177] nouveau 0000:03:00.0: DRM: DCB conn 02: 00001261
[ 12.134184] nouveau 0000:03:00.0: DRM: BIOS FP mode: 1920x1080 (142500kHz pixel clock)
[ 12.136533] nouveau 0000:03:00.0: DRM: MM: using M2MF for buffer copies
[ 12.148537] nouveau 0000:03:00.0: DRM: allocated 1920x1080 fb: 0x50000, bo 000000000d6c08f0
[ 12.148678] fbcon: nouveaudrmfb (fb0) is primary device
[ 13.478839] Console: switching to colour frame buffer device 240x67
[ 13.480993] nouveau 0000:03:00.0: [drm] fb0: nouveaudrmfb frame buffer device
[ 13.490327] [drm] Initialized nouveau 1.3.1 20120801 for 0000:03:00.0 on minor 0
[ 13.559640] kauditd_printk_skb: 4 callbacks suppressed
[ 13.559642] audit: type=1130 audit(1635244923.158:16): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:nv_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.613977] audit: type=1130 audit(1635244923.214:17): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:acpi_video0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.703049] Adding 5119996k swap on /dev/sda5. Priority:-2 extents:1 across:5119996k FS
[ 14.893061] audit: type=1130 audit(1635244924.491:18): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-8a6448b6\x2d3650\x2d4a51\x2db4e8\x2de7c89fda0746 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.293279] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 15.703735] audit: type=1130 audit(1635244925.304:19): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.760562] EXT4-fs (sda8): mounted filesystem with ordered data mode. Opts: (null)
[ 15.902751] mousedev: PS/2 mouse device common for all mice
[ 15.990629] mc: Linux media interface: v0.10
[ 16.030191] audit: type=1130 audit(1635244925.628:20): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.037541] videodev: Linux video capture interface: v2.00
[ 16.041814] audit: type=1334 audit(1635244925.641:21): prog-id=9 op=LOAD
[ 16.133690] audit: type=1127 audit(1635244925.734:22): pid=477 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 16.152262] audit: type=1130 audit(1635244925.751:23): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.245619] uvcvideo: Found UVC 1.00 device Chicony WebCam (04f2:b1a0)
[ 16.248213] uvcvideo: Failed to query (GET_INFO) UVC control 2 on unit 1: -32 (exp. 1).
[ 16.249285] uvcvideo: Failed to query (GET_INFO) UVC control 4 on unit 1: -32 (exp. 1).
[ 16.256669] input: Chicony WebCam: Chicony WebCam as /devices/pci0000:00/0000:00:06.1/usb2/2-6/2-6:1.0/input/input17
[ 16.256998] usbcore: registered new interface driver uvcvideo
[ 16.257000] USB Video Class driver (1.1.1)
[ 16.315801] audit: type=1130 audit(1635244925.914:24): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.336994] audit: type=1130 audit(1635244925.938:25): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.698217] kauditd_printk_skb: 21 callbacks suppressed
[ 18.698220] audit: type=1130 audit(1635244928.298:47): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.971251] audit: type=1130 audit(1635244928.571:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.583161] audit: type=1130 audit(1635244930.181:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.717724] RTL8211B Gigabit Ethernet r8169-0-400:00: attached PHY driver [RTL8211B Gigabit Ethernet] (mii_bus:phy_addr=r8169-0-400:00, irq=IGNORE)
[ 20.855440] audit: type=1130 audit(1635244930.454:50): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.905339] r8169 0000:04:00.0 enp4s0: Link is Down
[ 21.083276] audit: type=1130 audit(1635244930.681:51): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.097812] audit: type=1130 audit(1635244930.698:52): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.783886] loop: module loaded
[ 22.012923] audit: type=1130 audit(1635244931.611:53): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.078482] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 22.698787] audit: type=1130 audit(1635244932.298:54): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.020123] audit: type=1130 audit(1635244932.618:55): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.651256] NET: Registered protocol family 42
[ 23.655301] audit: type=1130 audit(1635244933.254:56): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.203272] audit: type=1130 audit(1635244936.801:57): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.861325] audit: type=1131 audit(1635244937.461:58): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.015610] audit: type=1131 audit(1635244940.614:59): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.565340] audit: type=1130 audit(1635244942.164:60): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.565429] audit: type=1131 audit(1635244942.164:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.041081] audit: type=1103 audit(1635244942.641:62): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 33.094695] audit: type=1130 audit(1635244942.694:63): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.210667] audit: type=1101 audit(1635244942.811:64): pid=822 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.210678] audit: type=1103 audit(1635244942.811:65): pid=822 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 33.210683] audit: type=1006 audit(1635244942.811:66): pid=822 uid=0 subj==unconfined old-auid=4294967295 auid=969 tty=(none) old-ses=4294967295 ses=1 res=1
[ 33.236487] audit: type=1105 audit(1635244942.834:67): pid=822 uid=0 auid=969 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.258263] audit: type=1334 audit(1635244942.858:68): prog-id=17 op=LOAD
[ 33.258270] audit: type=1334 audit(1635244942.858:69): prog-id=17 op=UNLOAD
[ 40.383629] wlp8s0: authenticate with cc:ce:1e:d2:6b:aa
[ 40.393925] wlp8s0: send auth to cc:ce:1e:d2:6b:aa (try 1/3)
[ 40.423793] wlp8s0: authenticated
[ 40.426580] wlp8s0: associate with cc:ce:1e:d2:6b:aa (try 1/3)
[ 40.436875] wlp8s0: RX AssocResp from cc:ce:1e:d2:6b:aa (capab=0x1431 status=0 aid=3)
[ 40.438497] rtl8192se: switch case 0x5e not processed
[ 40.438518] wlp8s0: associated
[ 40.480393] wlp8s0: Limiting TX power to 20 (20 - 0) dBm as advertised by cc:ce:1e:d2:6b:aa
[ 40.527754] IPv6: ADDRCONF(NETDEV_CHANGE): wlp8s0: link becomes ready
[ 40.675861] kauditd_printk_skb: 2 callbacks suppressed
[ 40.675864] audit: type=1130 audit(1635244950.274:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.681575] audit: type=1130 audit(1635244950.281:73): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 41.558318] audit: type=1130 audit(1635244951.158:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.704453] audit: type=1130 audit(1635244952.304:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 48.787816] audit: type=1131 audit(1635252158.330:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 48.836632] audit: type=1334 audit(1635252158.380:77): prog-id=16 op=UNLOAD
[ 48.836640] audit: type=1334 audit(1635252158.380:78): prog-id=15 op=UNLOAD
[ 48.836645] audit: type=1334 audit(1635252158.380:79): prog-id=14 op=UNLOAD
[ 51.010186] audit: type=1131 audit(1635252160.554:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 67.573064] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 67.582492] ata2.00: configured for UDMA/133
[ 115.383219] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 115.391592] ata2.00: configured for UDMA/133
[ 129.883213] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 129.895062] ata2.00: configured for UDMA/133
[ 164.186931] ata2.00: limiting speed to UDMA/100:PIO4
[ 164.926557] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 164.934974] ata2.00: configured for UDMA/100
[ 184.123221] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 184.131660] ata2.00: configured for UDMA/100
[ 185.523222] ata2.00: limiting speed to UDMA/33:PIO4
[ 186.263199] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 186.272035] ata2.00: configured for UDMA/33
[ 189.741904] ata2.00: limiting speed to PIO4
[ 190.479867] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 190.488680] ata2.00: configured for PIO4
[ 200.414048] ata2.00: limiting speed to PIO3
[ 201.123206] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 201.132003] ata2.00: configured for PIO3
[ 201.794984] audit: type=1100 audit(1635252321.919:81): pid=868 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="andrej" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 201.800300] audit: type=1101 audit(1635252321.926:82): pid=868 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="andrej" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 206.112654] audit: type=1130 audit(1635252326.236:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 207.179700] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 207.188744] ata2.00: configured for PIO3
[ 216.493192] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 216.501987] ata2.00: configured for PIO3
[ 220.122389] audit: type=1100 audit(1635252342.736:84): pid=1045 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="andrej" exe="/usr/bin/login" hostname=medion addr=? terminal=/dev/tty3 res=success'
[ 220.126273] audit: type=1101 audit(1635252342.739:85): pid=1045 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="andrej" exe="/usr/bin/login" hostname=medion addr=? terminal=/dev/tty3 res=success'
[ 220.163460] audit: type=1103 audit(1635252342.779:86): pid=1045 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="andrej" exe="/usr/bin/login" hostname=medion addr=? terminal=/dev/tty3 res=success'
[ 220.163650] audit: type=1006 audit(1635252342.779:87): pid=1045 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty3 old-ses=4294967295 ses=2 res=1
[ 220.209265] audit: type=1130 audit(1635252342.822:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 220.224200] audit: type=1101 audit(1635252342.836:89): pid=1047 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="andrej" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 220.224208] audit: type=1103 audit(1635252342.839:90): pid=1047 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="andrej" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 220.224212] audit: type=1006 audit(1635252342.839:91): pid=1047 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 220.226532] audit: type=1105 audit(1635252342.839:92): pid=1047 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="andrej" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 220.256352] audit: type=1334 audit(1635252342.869:93): prog-id=18 op=LOAD
[ 229.040512] kauditd_printk_skb: 4 callbacks suppressed
[ 229.040516] audit: type=1100 audit(1635252351.656:98): pid=1066 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="andrej" exe="/usr/bin/sudo" hostname=medion addr=? terminal=/dev/tty3 res=success'
[ 229.044813] audit: type=1101 audit(1635252351.659:99): pid=1066 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="andrej" exe="/usr/bin/sudo" hostname=medion addr=? terminal=/dev/tty3 res=success'
[ 229.044823] audit: type=1110 audit(1635252351.659:100): pid=1066 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=medion addr=? terminal=/dev/tty3 res=success'
[ 229.046109] audit: type=1105 audit(1635252351.659:101): pid=1066 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=medion addr=? terminal=/dev/tty3 res=success'
[ 240.019865] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 240.028635] ata2.00: configured for PIO3
[ 241.368171] ata2.00: limiting speed to PIO0
[ 242.096535] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 242.105356] ata2.00: configured for PIO0
[ 244.229869] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 244.238627] ata2.00: configured for PIO0
