Libwebkit error on installation Zekr programme
I am a newbie in manjaro. I installed Manjaro Cinnamon. I like it so much. However, I get a libwebkit error while installing the Zekr program related to Quran studies. It needs to install libwebkit. I searched on the internet but could not find how to install it. Can you help me?
Thank you.
Output
$ sudo pamac install zekr
Warning: zekr is only available from AUR
Preparing…
Cloning zekr build files…
Running as unit: run-u154.service
Finished with result: success
Main processes terminated with: code=exited/status=0
Service runtime: 396ms
Running as unit: run-u155.service
Service runtime: 10ms
Checking zekr dependencies…
Error: Failed to prepare transaction:
could not satisfy dependencies:
  • unable to satisfy dependency ‘libwebkit’ required by zekr
    Resolving dependencies…
    Warning: cannot resolve “libwebkit”, a dependency of “zekr”
Edit build files : [e]
Apply transaction ? [e/y/N] y
Transaction cancelled.
Looking at the PKGBUILD for that program it looks like that this program is just downloaded and unpacked - there is no building from source going on.
But the PKGBUILD was last updated almost 5 years ago.
Much has changed since then.
It could be that the needed dependency is in
extra/webkit2gtk
which is in the normal repositories.
I tried:
You edit the PKGBUILD and remove this dependency and try installing.
This worked - but then when the program starts, java throws an error.
Probably an older or otherwise specific version is needed.
Don’t know.
Thanks Nachlese.
I don’t know how do that you said.
Well, then as the latest comment says, the website is down and you should probably find an alternative.
You need to install webkitgtk2 (which provide libwebkit) from the AUR since pamac isn’t able to deal with that
