I get this sometimes when I try to login into a VM.
So the VM starts fine, but after type in the password i get this error and virt-manager has no response.
How can I fix this?
I tried already to change the keepalive timeout to 5, 15 sec.
It does not help and revert the change.
you’re added yourself to this groups ?
libvirt-qemu libvirt kvm
and the libvirtd-service is started/enabled ?
I followed the manjaro wiki as I installed it:
It did not tell me to add the groups you mention expect libvirt.
i know but i came up with the 2 other one’s while i also had various trouble with the last 2-3 updates in the past. by digging the internet i found this 2 ones by time. you can try them otherwise you can delete them from groups. trial and error… fingers crossed that it helps.
Yep, thanks it works better now.
I updated the wiki as well.
Had this issue still:
uncommented this in libvirtd.conf
keepalive_interval = 5
keepalive_count = 5
