Hi, I’m trying to understand how to assign a passed through device (vfio) to a predefined address (domain:bus:slot:function).
I’m running manjaro latest stable version with updated libvirt (7.1.0-3) and qemu (6.0.0-2), running a mac os vm q35+ovmf.
As far as I know, for vfio in libvirt we have to specify the source address of the device in the host and a target address for the guest.
So, for example:
<hostdev mode='subsystem' type='pci' managed='yes'>
<driver name='vfio'/>
<source>
<address domain='0x0000' bus='0x00' slot='0x1b' function='0x0'/>
</source>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/>
</hostdev>
This will passthrough the device in the host at 0000:00:1b.0 (in the host, domain, bus, slot, function) to 0000:00:02.0 (in the guest, domain, bus, slot, function).
In my xml I have the following devices passed through:
<hostdev mode='subsystem' type='pci' managed='yes'> // GPU VIDEO [GeForce GTX TITAN Black] [10de:100c]
<source>
<address domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
</source>
<address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0' multifunction='on'/>
</hostdev>
<hostdev mode='subsystem' type='pci' managed='yes'> // GPU AUDIO [10de:0e1a]
<source>
<address domain='0x0000' bus='0x04' slot='0x00' function='0x1'/>
</source>
<address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x1'/>
</hostdev>
<hostdev mode='subsystem' type='pci' managed='yes'> // MB AUDIO C600/X79 High Definition Audio Controller [8086:1d20]
<source>
</source>
</hostdev>
<hostdev mode='subsystem' type='pci' managed='yes'> // SATA Marvell 88SE9230 Controller [1b4b:9230]
<source>
<address domain='0x0000' bus='0x0a' slot='0x00' function='0x0'/>
</source>
<address type='pci' domain='0x0000' bus='0x00' slot='0x00' function='0x0' multifunction='on'/>
</hostdev>
<hostdev mode='subsystem' type='pci' managed='yes'> // USB 3.0 Fresco Logic FL1100 Controller [1b73:1100]
<source>
<address domain='0x0000' bus='0x84' slot='0x00' function='0x0'/>
</source>
<address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
</hostdev>
<hostdev mode='subsystem' type='pci' managed='yes'> // FIREWIRE VIA VT6315 Controller [1106:3403]
<source>
<address domain='0x0000' bus='0x0b' slot='0x00' function='0x0'/>
</source>
<address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
</hostdev>
Ok, everything shows up in the vm, everything works.
Now, one can stop here, but since I like to understand, I did an lspci -nn in the guest, and this is what is showing:
00:00.0 Host bridge [0600]: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller [8086:29c0] (subsys 1af4:1100)
00:01.0 PCI bridge [0604]: Red Hat, Inc. (null) [1b36:000c]
00:01.1 PCI bridge [0604]: Red Hat, Inc. (null) [1b36:000c]
00:01.2 PCI bridge [0604]: Red Hat, Inc. (null) [1b36:000c]
00:01.3 PCI bridge [0604]: Red Hat, Inc. (null) [1b36:000c]
00:01.4 PCI bridge [0604]: Red Hat, Inc. (null) [1b36:000c]
01:00.0 PCI bridge [0604]: Red Hat, Inc. (null) [1b36:000e]
00:01.5 PCI bridge [0604]: Red Hat, Inc. (null) [1b36:000c]
03:00.0 Communication controller [0780]: Red Hat, Inc (null) [1af4:1043] (rev 01) (subsys 1af4:1100)
00:02.0 Audio device [0403]: Intel Corporation C600/X79 series chipset High Definition Audio Controller [8086:1d20] (rev 06) (subsys 1043:84d8)
00:02.3 PCI bridge [0604]: Red Hat, Inc. (null) [1b36:000c]
04:00.0 FireWire (IEEE 1394) [0c00]: VIA Technologies, Inc. VT6315 Series Firewire Controller [1106:3403] (rev 01) (subsys 1106:3403)
05:00.0 SATA controller [0106]: Marvell Technology Group Ltd. 88SE9230 PCIe SATA 6Gb/s Controller [1b4b:9230] (rev 10) (subsys 1b4b:9230)
00:07.0 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 [8086:2934] (rev 03) (subsys 1af4:1100)
00:07.7 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 [8086:293a] (rev 03) (subsys 1af4:1100)
00:1f.0 ISA bridge [0601]: Intel Corporation 82801IB (ICH9) LPC Interface Controller [8086:2918] (rev 02) (subsys 1af4:1100)
06:00.0 VGA compatible controller [0300]: NVIDIA Corporation (null) [10de:100c] (rev a1) (subsys 10de:0010)
00:1f.2 SATA controller [0106]: Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode] [8086:2922] (rev 02) (subsys 1af4:1100)
06:00.1 Audio device [0403]: NVIDIA Corporation GK110 HDMI Audio [10de:0e1a] (rev a1) (subsys 10de:1066)
02:01.0 Ethernet controller [0200]: Red Hat, Inc Virtio network device [1af4:1000] (subsys 1af4:0001)
00:1f.3 SMBus [0c05]: Intel Corporation 82801I (ICH9 Family) SMBus Controller [8086:2930] (rev 02) (subsys 1af4:1100)
02:08.0 Ethernet controller [0200]: Red Hat, Inc Virtio network device [1af4:1000] (subsys 1af4:0001)
08:00.0 USB controller [0c03]: Fresco Logic (null) [1b73:1100] (rev 10) (subsys 1b73:1100)
It doesn’t correspond to what I assigned…
GPU (video) should be at 0000:03:00.0, instead it’s at 0000:06:00.0
GPU (audio) should be at 0000:03:00.1, instead it’s at 0000:06:00.1
Fresco USB should be at 0000:04:00.0 instead it’s at 0000:08:00.0
Firewire should be at 0000:05:00.0 instead it’s at 0000:04:00.0
I have also two network bridges which are at the wrong addresses.
Mainboard audio is correct, it’s specified in the xml at 0000:00:02.0 and shows at 0000:00:02.0
Also the other bridges and virtual usb controller are correct.
I know marvell sata it’s wrong in the xml since 0000:00:00.0 is reserved and hardcoded in qemu, maybe libvirt automatically reassigns it at 000:05:00.0
So, I modified the xml to assign the assigned addresses that showed in the guest (for every vfio devices, for example I assigned for marvell SATA domain=‘0x0000’ bus=‘0x05’ slot=‘0x00’ function=‘0x0’ multifunction=‘on’), but with the result that the lspci command returns (again) not correct addresses.
Anyone is able to explain?
