Thank you I now enabled it. I’m getting tearing with all FF settings but “Use recommended performance settings”. So that’s ok I think. However Video Engine Utilization: 0%
Now that I added the kernel module to be loaded, SMPlayer (with your settings above) and VLC (default settings) do not get >0%. However before the restart it did work on these settings.
For me it’s complicating things though now …
Edit, it’s working on VLC most of the time and in SMPlayer with the setting Performance > nvdec-copy as well, just not for 4k videos in both apps, but still all tear-free.
I see that you didn’t set necessary environmental variables system wide. Did you put them in firefox.desktop file? Post “Exec=” sting from firefox.desktop.
I knew what you were referring to. That bug was in mesa driver which provides VA-API.
libva-nvidia-driver doesn’t really provide VA-API, it’s a wrapper around NVDEC, pretending to be VA-API. So fixes of mesa bugs have nothing to do with our driver.
Ok I do not seem to get it working in Firefox. Thank for the help with SMPlayer and most likely VLC (that auto-configured correctly).
I concluded also that my small GPU can’t help/handle 4K videos so CPU’s gotta do that job.
Here is me summarizing myself of what I did:
set what @Mirdarthos set in about:config but also later tried without it, kept his settings for now
did what is prbb. not needed because it’s in the libva-nvidia-driver is in the repos but these are building dependencies: sudo pacman -S meson gst-plugins-bad ffnvcodec-headers
installed libva-nvidia-driver (with Pacman which uninstalled the default libva-vdpau-driver) However, lib32libva-vdpau-driver is still installed!
rebooted
set a required kernel parameter so my grub file looks like:
first set global environment variables which didn’t work, then later only applied them in the /usr/share/applications/firefox.desktop file (which for some reason is not ~/.local/share/applications, must I link or copy it there to work?) which I kept like that:
Does HW acceleration work for videos having lower resolution than 4K?
Can you navigate to about:support page, scroll down and take a screenshot of Codec Support Information?
Thanks this may provide useful info, after a logout/in, screen-tearing seems to be gone.
I had set the media.av1.enabled setting in about:config to false and use enhanced-h264ify addon to block Vp8 and Av1 now. However, still 0% in nvidia-settings :).
The first two tries, Ff crashed when I tried to resize the window (before trying to navigate to Yt respectively playing a video). I had wanted to debug that and I think the Dark Reader addon is the culprit, anyway these logs then got overwritten:
I played 1 4K video, afterwards an HD vid, also skipped a bit forward, both for a bit more than 15-20 seconds in total. Looks like my 2 GB VRAM memory is the issue?
The crash only happens when I resize the newly opened browser with last sessions’ tabs to smaller. Initially the size is around 3K. Then it logs as follows:
LIBVA_DRIVER_NAME=nvidia NVD_BACKEND=direct NVD_LOG=1 MOZ_DISABLE_RDD_SANDBOX=1 firefox 2>&1 | tee nvdec.log
[Parent 3174666, Main Thread] WARNING: Theme directory 64/devices of theme Gruvbox has no size field
: 'glib warning', file /usr/src/debug/firefox/firefox-125.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:3174666): Gtk-WARNING **: 18:35:35.342: Theme directory 64/devices of theme Gruvbox has no size field
[GFX1-]: GFX: RenderThread detected a device reset in PostUpdate
[Parent 3174666, Main Thread] WARNING: The program 'firefox' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadValue (integer parameter out of range for operation)'.
(Details: serial 1979 error_code 2 request_code 156 (NV-GLX) minor_code 24)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the GDK_SYNCHRONIZE environment
variable to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.): 'glib warning', file /usr/src/debug/firefox/firefox-125.0.1/toolkit/xre/nsSigHandlers.cpp:187
(firefox:3174666): Gdk-WARNING **: 18:35:44.945: The program 'firefox' received an X Window System error.
Exiting due to channel error.
I mean, do I have to uncomment both? The last one is at the bottom and lists default-release, default, dev-edition-default to me (create, delete, rename them).
