Libtorrent 2.x on Manjaro?
If i should try qbittorrent with newer libtorrent 2.x what to do? I check “pamac search -a libtorrent|grep 2”
libtorrent-rasterbar-git                2.0.4.r297.gf0864b383-1       AUR
libtorrent-rasterbar-2_0-git            r16804.g05560ba12-1           AUR
    library (git branch RC_2_0)
libtorrent-rasterbar-1_2-git            r16804.gbf5d475a6-1           AUR
    library (git branch RC_1_2)
libtorrent-rasterbar-1_1-git            1.1.14.r4.g760f94862-1        AUR
libtorrent-git                          0.13.7.r1.g7b29b6bd-1         AUR
libtorrent-rasterbar        [Installed] 1:1.2.15-1                    extra
libtorrent                  [Installed] 0.13.8-2                      community
not knowing if -rasterbar is something different that qbt will not use, i do:
pamac build libtorrent-git
To build (1):
To remove (1):
  libtorrent      0.13.8-2               (Conflicts With: libtorrent-git)  community
when it asks, i type “e” to edit and see "url=“GitHub - rakshasa/libtorrent: libTorrent BitTorrent library”. In that repository i do not see which version is inside. But when i visit different repository GitHub - arvidn/libtorrent: an efficient feature complete C++ bittorrent implementation it shows by default 2.0RC
so if i build from arvidn repository (i do not understand much building commands at libtorrent ) it will somehow make this libtorrent 2.x system-wide default or which commands i need to do? I can then install normal libtorrent from repo once i am finished testing 2.x i guess and that will make it default?
  • libtorrent and libtorrent-rasterbar are different.
  • qbittorrent currently uses libtorrent-rasterbar.
$ LANG=C pacman -Qi qbittorrent | grep Depends
Depends On      : libtorrent-rasterbar  qt5-base  qt5-svg  hicolor-icon-theme
You would have to built qbittorrent 4.4.0 with libtorrent-rasterbar 2.0.5 + a newer commit that fixes building with boost 1.78.0.
FYI, libtorrent-rasterbar 1:2.0.5-1 and qbittorrent 4.4.0-2 just landed in Arch Testing.
i already have qbt 4.4.0beta3. Now i do:
pamac build libtorrent-rasterbar-2_0-git
==> WARNING: Package contains reference to $srcdir
usr/lib/python3.10/site-packages/libtorrent.cpython-310-x86_64-linux-gnu.so
usr/lib/libtorrent-rasterbar.so.2.0.5
Finished making: libtorrent-rasterbar-2_0-git r17537.g8e6e3c2d0-1
/usr/local/bin/qbittorrent
error while loading shared libraries: libtorrent-rasterbar.so.10: cannot open shared object file: No such file or directory
cd /usr/local/bin/;ldd qbittorrent|grep found
libtorrent-rasterbar.so.10 => not found
locate libtorrent-rasterbar.so.10
/usr/lib/libtorrent-rasterbar.so.10
sudo ln -s /usr/lib/libtorrent-rasterbar.so.10 /usr/local/lib/libtorrent-rasterbar.so.10
not helped, how to make qbt working with latest (2.x) libtorrent-rasterbar please?
You need to rebuild qbittorrent every time you rebuild libtorrent-rasterbar. You’ll also need to rebuild them both when there’s a new boost release.
Somehow qbt failed to build when there was rasterbar 2.0.x or 2.0.5:
building rasterbar .x and .5
building qbt cloned from git repo: fail
What are proper commands you are doing?
Use the Arch PKGBUILDs.
Thanks,
Anyone knows which, where, how?
That’s something for you to learn yourself. The Arch Wiki is a great resource.
Teach a man to fish… you know the rest. :wink:
:fishing_pole_and_fish:
If you have questions along the way, you’re welcome to ask.
qbittorrent 4.4.0-2 built with libtorrent-rasterbar 1:2.0.5-1 are now in the unstable branch, FYI.
