Hey,
I’m facing updgrade issues for librewolf 125.0.2-1 :
Type:Arch - AUR Name: librewolf-bin Version:124.0.1-1 New version: 125.0.2-1
==> Validating source files with sha256sums…
source … NOT FOUND
default192x192.png … Passed
librewolf.desktop … Passed
==> ERROR: One or more files did not pass the validity check!
rm -rf /tmp/bauh@xxx/arch/build_1714047651
Upgrade des Pakets “librewolf-bin” fehlgeschlagen validity check!
That’s an AUR package, not a Manjaro package. You could contact the maintainers at their GitLab page, or you could build the librewolf package from sources instead…
similar issue:
0:10.82 ERROR: Package dependency requirement ‘nss >= 3.99’ could not be satisfied.
0:10.83 ERROR: Package ‘nss’ has version ‘3.98’, required version is ‘>= 3.99’
*** Fix above errors and then restart with “./mach build”
==> FEHLER: Ein Fehler geschah in build().
Breche ab…
Why Librewolf wont install, Librewolf has updated their dependancy for nss to 3.99, Manjaro stable is currently on 3.98. It looks like 3.99 is currently in testing for Manjaro and should be in the next update.
Librewolf certianly wont downgrade for us, no need to bother them, just wait for the next Manjaro update, maybe switch to Firefox temporarily so your not stuck with an out of date browser.
Also just know AUR packages are not officially supported by Manjaro, while they do work updates from AUR are pushed out faster than Manjaro feature updates so things can get out of date temporarily like in this situation.
Hi, enable Flatpack and install from there, solution. True, in wayland there are no window decorations sometimes(maybe only for me), but everything is fine
Failing AUR updates on manjaro-stable of librewolf and librewolf-bin might be two different issues:
Makepkg does not allow to update librewolf-bin because of issues with verification of signature.
makepkg -sic
==> Erstelle Paket: librewolf-bin 125.0.2-1 (So 28 Apr 2024 11:31:29 CEST)
==> Prüfe Laufzeit-Abhängigkeiten…
==> Prüfe Buildtime-Abhängigkeiten…
==> Empfange Quellen…
→ Klone das source git Repo…
Klone in Bare-Repository ‘/home/jomo/librewolf-bin/source’ …
remote: Enumerating objects: 3630, done.
remote: Counting objects: 100% (456/456), done.
remote: Compressing objects: 100% (359/359), done.
remote: Total 3630 (delta 284), reused 85 (delta 85), pack-reused 3174 (from 1)
Empfange Objekte: 100% (3630/3630), 3.66 MiB | 7.03 MiB/s, fertig.
Löse Unterschiede auf: 100% (2109/2109), fertig.
→ default192x192.png gefunden
→ librewolf.desktop gefunden
→ Lade librewolf-125.0.2-1-linux-x86_64-package.tar.bz2 herunter…
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 92.4M 100 92.4M 0 0 6487k 0 0:00:14 0:00:14 --:–:-- 7133k
→ Lade librewolf-125.0.2-1-linux-x86_64-package.tar.bz2.sig herunter…
100 566 100 566 0 0 1629 0 --:–:-- --:–:-- --:–:-- 1631
==> Überprüfe source Dateien mit sha256sums…
source … NICHT GEFUNDEN
default192x192.png … Erfolg
librewolf.desktop … Erfolg
==> FEHLER: Eine oder mehrere Dateien überstanden nicht die Gültigkeits-Prüfung!lockquote
And that might have to do with /etc/makepkg.conf and so the installed version of pacman.
This has recently be discussed in the unstable monthy update announcement strings.
Could someone of unstable or testing confirm the succesful update of AUR/librewolf-bin please?
