My settings in Dropbox are that anyone who has the link can access and download. At least that’s what I read there.
Peter
Peter
Once again:
“AAA—Dropbox - Claris Wks files - Simplify your life”
In spite of the camouflage the forum page sees that it is a link …
My text is transformed.
and that is correct
still - when one wants to access the dropbox link you provided,
they are presented with a choice to register via Google or Apple
and
also
at the bottom
the download link without registratiion
You took the easy route - used something you knew.
That’s o.k.
But the people on the other side might not think the same way … ![]()
the opportunity to just download the thing without any of the above.
… try accessing your own links from the outside - from within a plain Manjaro live session or fresh install … see what happens
I see,
but I’m not sure if I understand.
You mean it’s a safety issue? People would hesitate to download?
But how can it possibly be made safer? The folders and files will be exactly the same, whichever way they are downloaded.
And I don’t see any options in Dropbox to change the way of access, apart from entering the email addresses of specific people.
Peter
The ~ is there by default when I open Terminal.
Peter
No. Not really.
But in the minds of people: really ![]()
yes, definitely, some would
you can’t - you could try by using any of the many anonymous file sharing services out there
If I was you - I would not bother.
You did what needed to be done. Provide access to files that can be used to replicate your issue.
I was just telling you how some or even many people might react …
to Dropbox links that are presenting themselves in the way that they do …
I myself have not downloaded any of the files because I know that I have never in my life encountered files with such extensions
and could therefore not be of help even if I now saw them - I’m totally oblivious of anything in OSX and it’s software.
That path doesn’t exist.
The command should be one of these:
nano ~/.config/mimeapps.list # absolute path
nano .config/mimeapps.list # relative path
and it worked - but just in case, here are two other way to post the same:
https://www.dropbox.com/scl/fo/fp22etaxace18rxrzjn9m/h?rlkey=12540343zaqcua2o9m0u67wej&dl=0---BBB
Just so you know:
That’s only part of the prompt, not the command. Your prompt has a ~, mine doesn’t:
╭─mirdarthos@Mirdarthos-PC
╰─➤ echo $SHELL
/usr/bin/zsh
And, anyway, ~ is just an alias for your home directory:
╰─➤ echo ~
/home/mirdarthos
╰─➤ echo $HOME
/home/mirdarthos
So, I don’t know if I can be any help further, because on my PC everything seems to open just fine. I will, however, note what I’ve found:
(This is just an example.)
I downloaded 5 AppleWorks 6.0 other documents.zip to a test folder. I extracted it there, too:
$ ls -l
.rw-r--r-- mirdarthos mirdarthos 82 KB Mon Feb 12 14:59:11 2024 '5 AppleWorks 6.0 other documents.zip'
.rw-r--r-- mirdarthos mirdarthos 29 KB Sun Feb 11 17:31:42 2024 'Kreuzschaltung [v6.0].cwk'
.rw-r--r-- mirdarthos mirdarthos 52 KB Sun Feb 11 17:31:42 2024 'Kreuzschaltung [v6.0].odt'
Upon extracting, I notices the 2 files:
.odt estension; and.cwk extension.The .odt one seems to be a standard Open Document Text file, that Libreoffice opens with a smile.
The .cwk one has no association, but I could open it with Libreoffice just fine. The page/paper did look a bit weird though, but I didn’t look any deeper.
The above leads me to the conclusion that Apple uses and thus will support .odt files.
So you could use that.
But either way, I doubt I can be of assistance any further.
Hi,
and thank you very much indeed. I will have to work my way through these instructions step by step, since I am not familiar with the command line yet.
So you could open these files. Could you please let me know:
Peter
$ libreoffice --version
LibreOffice 7.6.4.1 60(Build:1)
(The latest one inn the repository.)
Kernel: 6.1.71-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa rw quiet
udev.log_priority=3 modprobe.blacklist=iTCO_wdt
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: cairo-dock
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z370 HD3 v: N/A serial: N/A
Mobo: Gigabyte model: Z370 HD3-CF serial: N/A UEFI: American Megatrends
v: F14 date: 11/13/2021
Fully updated:
$ cat /etc/lsb-release
DISTRIB_ID="ManjaroLinux"
DISTRIB_RELEASE="23.1.3"
DISTRIB_CODENAME="Vulcan"
DISTRIB_DESCRIPTION="Manjaro Linux"
I recently received the update to LibreOffice 24.2 (it’s available in Manjaro’s unstable branch), and while I didn’t have any documents in the formats you’re having trouble with, I decided to download a document in the .pages format, and this version of LibreOffice opened it.
I have 7.5.9.2, and I am told “Everything is up to date”.
How can I lay my hand on 7.6?
Thanks for your valuable help,
Peter
Thank you for the information. But: version 24? I have version 7 (7.5.9.2).
And: sorry, but I am quite new to Linux, and I don’t know what the “unstable branch” is and how to get there. I can imagine, but I think with my limited knowledge I should stick to the standard version.
Anyway, I value and appreciate any information.
Peter
LO 24 is due to the new versioning system that libreoffice is using. If you want to try 7.6.4 you need to install libreoffice-fresh
pamac install libroffice-fresh
24.2 is still in unstable branch and will come along in due time to stable and testing branches.
“Starting with the next release, LibreOffice will
adopt a year.month-based versioning system
and the upcoming iteration will bear the version number 24.2.”
I haven’t looked into the reason for the big version number change, but it is what it is, https://www.libreoffice.org
You can find info regarding branches here, but I don’t recommend that you as a new user switch: Switching Branches - Manjaro
Thank you.
Concerning version 7.6.4 of LibreOffice: „fresh“ probably means that it is sort of a new and unstable (?) version?
Can I install it alongside my current version 7.5.9.2 without risk for testing, and switch between the two?
Peter
As far as I know, the “fresh” version is the newer version that gats new features and Libreoffice still rarely gets updates. From LibreOffice - ArchWiki
- libreoffice-still is the stable maintenance branch with relatively rare updates, for conservative users.
- libreoffice-fresh is the feature branch, with new program enhancements for early adopters or power users.
Can they be used together? I don’t know man, you’ll have to test. But, in my opinion, just switch to fresh…
They likely use the same configuration file so side-by-side installation might be tricky.I always have used libreoffice-fresh. I don’t use the software frequently. I am running 24.2 here with no issues that I have noticed.
