It takes about 30 seconds for LibreOffice to load after the last updates. Even when open, opening a new document causes the same wait.
This thread says to disable hardware acceleration but it didn’t work for me.
Thank you for the link! ![]()
I got the list of packages that have Python3.10 in them…
pacman -Qoq /usr/lib/python3.10/
ceph-libs
dr14_tmeter
python-pep517
python-progress
python-sip4
But when I tried the build command this happened:
`pamac build $(pacman -Qoq /usr/lib/python3.10)
Error: target not found: python-pep517
So I started building the first item in the list, ceph-libs. The name didn’t ring a bell at first, but then when the build process put a bunch of confusing text on the screen and heated up the cpu, I remembered it. This package got stuck trying to build about 6 months ago(?) taking forever and never finishing, probably shortening my cpu life. Eventually I had to just quit it. Looking up online there were other people with weird issues with it. So I’ve just removed ceph-libs for now, after reading this reddit thread. What is ceph-libs...? - r/ManjaroLinux
Is ceph-libs actually needed in Manajro? - #8 by tracyanne
Hopefully nothing depended on that (I learned about the pactree command about a minute after uninstalling
Now I need to find out about python-pep517. (Maybe learning about pactree will enlighten?).
no, you would want to click the arrow that says: Many applications (firefox, thunderbird, etc) slow to start on desktops other than Gnome
python issue is not related. (but can be fixed by removing python-pep517 and running the command again. At least for me, pacman will refuse if it is needed)
That was easy ![]()
Thanks!!
