Try uninstalling libreoffice-fresh, and installing libreoffice-still, and test whether it happens in that. If it doesn’t, then LibreOffice itself may be the culprit. Wait for the next fresh release, and try again.
Login to a new profile and see if the issue persists.
If it doesn’t launch, then we still don’t know the cause, but if it does launch (without issue), then at least that narrows it down to being an issue with your main profile.
Ya, it seems I have also a Create new user problem, after trying to Login with a new user I get pushed back to the login screen.
Same by trying to create new user in the Terminal sudo useradd -mG <newuser>
switch to that user in the Terminal works.
login-log
pam_unix(sudo:session): session closed for user root
Dez 01 17:19:53 $USER systemd[1]: user-969.slice: Consumed 1.935s CPU time.
Dez 01 17:19:53 $USER systemd[1]: Removed slice User Slice of UID 969.
Dez 01 17:19:52 $USER systemd[1]: Stopped User Runtime Directory /run/user/969.
Dez 01 17:19:52 $USER systemd[1]: user-runtime-dir@969.service: Deactivated successfully.
Dez 01 17:19:52 $USER systemd[1]: run-user-969.mount: Deactivated successfully.
Dez 01 17:19:52 $USER systemd[1]: Stopping User Runtime Directory /run/user/969...
Dez 01 17:19:52 $USER systemd[1]: Stopped User Manager for UID 969.
Also, I just realized opening an existing .pptx file works fine, but open a new instant freeze and have to be killed.
Well, versioning aside, LibreOffice is also available as a Flatpak, or from the AUR, or from LibreOffice themselves, as well as the official Manjaro repositories. Issues are more likely when LO is installed as a Flatpak or from the AUR.
Some users will use Pamac-Manager (GUI), and be seemingly oblivious to the package source, as if Pamac-Manager is configured to allow AUR and Flatpak, those packages may be installed, with an amount of ambiguity.
Thanks for clarify,
the official version was 7.6.3.2 and in the AUR is not really an -fresh option.
I don’t checked snap are flatpak, so no, non-off does.
This whole post is more about saying there is an issue, if anyone else has that same issues and already finds a solution to share.
Otherwise, it’s not really importend
… Why sudo pacman -Scc And not just sudo pacman -Sc?
It seems to me all doing the same:
❯ LANG=C sudo pacman -Sc
Packages to keep:
All locally installed packages
Cache directory: /var/cache/pacman/pkg/
:: Do you want to remove all other packages from cache? [Y/n] ^C
Interrupt signal received
❯ LANG=C sudo pacman -Scc
:: Do you want to remove ALL files from cache? [y/N] ^C
❯ LANG=C sudo pacman -Scccc
here is also htop while --impress is starting: Paste.c htop
