The suite is just refusing to theme at all, got that ugly white theme that just hurts my eyes. I’m on XFCE, already tried swapping the gtk3 package for the gtk3-classic-xfce package and that didn’t resolve it so now I’m out of ideas to try. Anyone have 1 or 2?
Edit 1: By the way I did try setting the theme from “System” to “Dark”, in both cases it just ignored it and went with “Light”
Edit 2: Going to bed, delay your re-check of the thread by at least 7-8 hours.
I have an issue with Libreoffice and the icon theme. It’s been that way for awhile. I go into Tools - Options - LibreOffice - View and change the Icon Theme to what I want. In my case Breeze (dark) I’m using Plasma 6 but maybe it applies to XFCE.
Replacing system components with unsupported aur packages usually only creates new problems.
Following that logic i suggest you check what else you have installed that is outdated, aur, unsupported etc.
The defaults definitely work fine. (System theme - matcha dark something, Office theme - system)
libreoffice (the main program) → tools → options (ALT+F12) → view (on the left) → appearance mode can be selected between “system”, “light” and “dark”
choose dark
also a theme can be selected below
definitely works for me - it does change instantly upon selecting “apply”
What also works is setting a dark theme for the whole desktop (matcha dark sea instead of matcha sea …)
What looks even worse with the dark theme then is the very white writing area in writer …
one idea:
create a new (test) user account and see whether the issue is the same there
It’s BECAUSE the defaults didn’t work that I tried the AUR package, btw I’ve already reverted back the default package since the AUR one didn’t work out.
As I’ve already said, I’ve already tried that hence this thread.
I have had Adwaita-dark set ever since I installed manjaro, it was literally the 1st thing I set.
Not sure adwaita based theme is the optimal choice for xfce. Have you tried the default matcha-dark-sea?
And have you really checked for orphaned or aur packages?
What do orphans matter? If they’re there then at worst they’re just taking up memory. I do apparently have gtk4 installed too but even the ~/.config/gtk-4.0/settings.ini file shows that it’s set to dark theme (possibly a result of the Adwaita-dark theme I chose specifically to deal with edge cases that target gnome only).
LibreOffice is built using Qt and from their build instructions it appears to be based on qt5.
Xfce is based on GTK3 toolkit and the interaction between the toolkits has been difficult for as long as I can remember.
I recall back in my early linux time (late 90’s) how a Qt based distribution had severe theming issues when it came to GTK applications and the interaction still suffers - it has become better - the xdg-desktop-portal tries to unify this interaction - as does Kvantum.
You have a few places inside LibreOffice where you can adjust the look-and-feel.
Menu → Tools → Options → LibreOffice
→ View → Icon Theme (labelled Theme - I use the Breeze Icon set)
→ Personalization (I use default)
→ Application Colors (I think this is what you refer to as explored - I use System Theme)
→ Advanced → Enable experimental features (User Interface)
Save and restart LibreOffice - then you have some extras in
→ Menu → View → User Interface
only just noticed you edited your msg, don’t get notifications for that. Anyways you could check more easily by just using paman to search installed packages for libreoffice. This is one of those situations where a GUI really helps a tone.
