Hello,
Due to some compatibility issues with Microsoft Office, I needed to have both offices installed in my machine. But sometimes I was using them alternately for new documents and besides I was thinking that open sheet *.ods should be an standard document and I was expecting both offices to work in the same way, I was wrong, formatting things (font, color, tabs, etc) I do in one office, I lost if I opened it the other, it strange that it’s not even needed to save the document, just opening it is enough to mess with formatting. Due to this reason I can not stay with both anymore, in this sense, I’m planning to stay with Libreoffice only but the way it render fonts is very poor.
Take a look at the attached image, from the same document opened with Libreoffice and Onlyoffice side by side, using the same font.
Is there any away to improve Libreoffice font rendering to align with Onlyoffice quality?
check whether you have anti-aliasing enabled;
Hi all, I noticed a while back that Writer text didn’t look very smooth but I chalked it up to it just being different software than other word processors. However, today I had occasion to copy and paste the text into Wordpad and noticed quite a...
Hello koshikas,
My system is basically all default from installation, I barely customize it, as you can see in the attached image the anti-aliasing is flag on in the LibreOffice Options View. Plasma Settings for Font also show anti-aliasing flag on.
My LibreOffice is version 7.4.3.2
Below my system information in case it’s needed.
Kernel: 6.0.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.0-x86_64
root=UUID=69678a39-1940-48ee-8d02-88e765985137 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=b136d668-4460-4cf7-9211-93b9a5283ab3 udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_wayland vt: 2
Type: Desktop Mobo: N/A model: X99 serial: <superuser required>
UEFI: American Megatrends v: 5.11 date: 07/30/2021
RAM: total: 15.53 GiB used: 3.2 GiB (20.6%)
Info: model: Intel Xeon E5-2640 v3 bits: 64 type: MT MCP arch: Haswell
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3F (63) stepping: 2 microcode: 0x49
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 20 MiB
desc: 1x20 MiB
Speed (MHz): avg: 1285 high: 2577 min/max: 1200/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1196 2: 1200 3: 1200
4: 1200 5: 1197 6: 1200 7: 1200 8: 1200 9: 1200 10: 1197 11: 1200 12: 1200
13: 1200 14: 1204 15: 2577 16: 1200 bogomips: 83024
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cqm cqm_llc cqm_occup_llc
cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_ppin
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep smx
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, DVI-D-1,
HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 34.0 C
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 14.0.6 DRM 3.48 6.0.11-1-MANJARO) direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound API: ALSA v: k6.0.11-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 2.73 TiB used: 1.77 TiB (65.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Western Digital
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 234100WD temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
rev: 233010WD temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20PURZ-85GU6Y0
type: HDD rpm: 5400 serial: <filter> rev: 0A80 scheme: MBR
ID-1: / raw-size: 448.38 GiB size: 448.38 GiB (100.00%)
used: 216.03 GiB (48.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
label: LINUX uuid: 69678a39-1940-48ee-8d02-88e765985137
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
label: NO_LABEL uuid: CDC5-157E
ID-3: /home raw-size: 448.38 GiB size: 448.38 GiB (100.00%)
ID-4: /home/<filter>/GAMES raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 66.54 GiB (14.5%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:2
label: GAMES uuid: 9467047a-a0d0-46ff-859d-67a1bfff2456
ID-5: /home/<filter>/HDD-2TB raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.5 TiB (83.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: 2TB-EXT4
uuid: b9d4d0f9-d1ce-425d-8fe4-e2f830005289
ID-6: /var/cache raw-size: 448.38 GiB size: 448.38 GiB (100.00%)
ID-7: /var/log raw-size: 448.38 GiB size: 448.38 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5 label: swap
uuid: b136d668-4460-4cf7-9211-93b9a5283ab3
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-7:2 info: [Maxxter] USB GAMING MOUSE type: Mouse,Keyboard
power: 100mA chip-ID: 18f8:0fc0 class-ID: 0301
Device-2: 3-8:3 info: SINO WEALTH Gaming KB type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
chip-ID: 258a:002a class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 31.0 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 193
Processes: 395 Uptime: 1m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1765
pm: pacman pkgs: 1713 libs: 437 tools: pamac pm: flatpak pkgs: 52 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
In addition, for test purpose, I logged in with X11 to compare with Wayland and it show much better results, i’d say equivalent to Onlyoffice.
Looks like the issue is related to LibreOffice and Wayland.
winnie
December 12, 2022, 11:31pm
#5
I was just about to finish typing a reply to see if this is an issue exclusive to Wayland.
winnie
December 12, 2022, 11:34pm
#6
Which version of LibreOffice is this?
They might have fixed it in the 7.4.x series.
You’ll have to install libreoffice-fresh
and remove libreoffice-still
if it’s not already the case with your system.
It’s the the LibreOffice default version from flatpak
winnie
December 12, 2022, 11:41pm
#8
Why the Flatpak? Why not from the official repository?
The package is libreoffice-fresh
I’m slowly moving to flatpaks once I see it is as the future, who create the software manage it. While the devs from distros could concentrate more in other areas, kind of reduced redundancies. Don’t know.
I’m going try the version from repo and reply.
winnie
December 12, 2022, 11:47pm
#10
Make sure you launch the correct LibreOffice if you have both the Flatpak and package-base versions installed.
To avoid opening with wrong version I removed flatpak, it’s easy to install anyway.
The repository version is the same as you can see in the image, but fonts are rendering properly now.
Maybe, it takes more time for flatpak to mature.
Thank you for the suggestions.
Lets wait they fix the issue. I’d prefer to stay with all software as flatpak whenever possible.
system
Closed
December 16, 2022, 12:51am
#14
