For Manjaro installation here there is the desire for LibreOffice package not to upgrade to higher release versions withing coming 24 months - package release freeze-up. Currently it is 7.4 and it needs to keep be at this version.
I guess it won’t suffice to make a lock on Manjaro computer side only. I think it can work only if in mentioned time perspective Manjaro repositories provide that version among all coming Manjaro updates and upgrades. Alternatively Manjaro computer administrator will need to conduct package backport every time such is necessary - which in this particular case is problematic due to lack of free resources.
Can freeze-up pointed out work?
Which steps are to be completed in order to implement it?
How to perform version lock on repository client side?
I understand you intention, but a freeze on specific version is not supported on a rolling release model, since applications often depend on other libraries, which can have breaking changes on upgrade, thus the application can not run anymore.
You can do what @Mirdarthos suggests, also the pamac-manager supports it in the GUI:
Why flatpak? Because it delivers its own libraries and don’t rely on system libraries. That way, you would have the exact version directly delivered from the LibreOffice developers in that case.
Several other apps are in use for long time as (Canonical) snaps, eg. web browser of few different brands. These have problem to access removable media mounted under /mnt or /media. Hence I hesitate to use more sandboxed apps as far as critical mission is background, the fear to run onto numerous problems while using sandboxed app as there are very little till no free resources for troubleshooting.
EDIT
Furthermore, LO Writer needs to have working connection to one 3rd party app. Troubles can arise here as well - will need clarification if incorporation that 3rd-party app to flatpak-app is already implemented and well-working. In worst case to be incorporated by own power and resources (problematic), accepting the risk of further problems in future.
Manjaro is a rolling release. Even the libreoffice-still might get updated to the next version when the old version is moved to the still branch. You can see that in the history of package updates: Commits · main · Arch Linux / Packaging / Packages / libreoffice-still · GitLab A dot-7 normally marks the last version of a series of LibreOffice. So the next update to still branch most likely will be 7.5.5. Then there are rebuilds due to libs updates like python, icu or poppler.
Best bet here is to decouple LibreOffice from the OS and use some like flatpaks.
Another option would be to contact our commercial support and ask for a quotation to see what can be done on your special case.
No idea about snaps, but flatpak has nice GUI to manage this: Flatseal
Under “Filesystem” you can simply add the path /media and /mnt. The app will have access to directory recursively.
Understand, but also doable. Anyway… did you know that there are appimages? Maybe that could fit your needs, since these AppImages are not sandboxed and will never update itself:
LibreOffice normally ends with a dot-7 release. A new LibreOffice-Still starts with a dot-5 release. Collabora Office22.05 is based on 7.3.7 release and has 2 years LTS support you have to pay to Collabora. This may include security fixes and updates. However Arch/Manjaro might not be supported as they aim for a non rolling release like Ubuntu LTS and others.
Sure you can freeze the final dot-7 release of any LibreOffice version by using appimages, snaps or flatpaks. However the software will be not updated, not maintained and might gain security issues over the years.
Hence the still branch of LibreOffice gets constantly updated in a slow paced rolling release model.
Is the task to maintain a coherent business network?
Create your own repo service either public interface or hosted internally on company network.
This can be done using two methods - both will house on or more s.
In either case you will need to create and implement a strategy to handle the security issues which may arise from your chosen system(s) configuration.
Another possible pitfall to consider is the possible overlap between system packages and possible dependency packages required for those apps you want to freeze.
No matter how you choose to implement - you will need a reference system image which you can use to create a system which can be used as reference for future updates and thus you can know beforehand which issues will arise when you roll out the update on the local mirror.
The simple method
Copy the relevant package files to own curated repo containing the packages you want to freeze
Insert your custom repo above distribution repo in pacman.conf
The advanced method
This method can keep all computers in the network sync with your own curated repo.
Sync the entire Manjaro stable repo from an rsync capable mirror
Implement an exclude list for the rsync command excluding the packages you want to freeze
Install a pacman-mirrors enterprise package on all systems to ensure coherent mirror pool
Sync your mirror with regular intervals to keep up with security patches
