Issue in LibreOffice - Calc Application: - When the Calc Application has Standard Tool Bar set (View > User Interface > Standard Tool Bar), i.e., with 2 ICON rows also with the symbol “>>” for extension at the end of each row.
In the 2nd Row - When I press the symbol “>>” , I get the pop up as usual but when I press the Borders Icons - nothing happens and this is my issue.
All the icons that come on the new pop up does not work except the “Conditional” Icon.
Note:
- I have selected a section of rows before hand (i.e., before click on >> and click on the Borders Icon ) for the LibreOffice to draw borders
- First row with Tool Bar extension icon “>>” does not have any issue.
- LibreOffice is installed from Manjaro Repo
$ sudo pacman -Ss libreoffice
extra/libcdr 0.1.7-7 [installed]
CorelDraw file format importer library for LibreOffice
extra/libreoffice-fresh 7.6.4-2 [installed]
LibreOffice branch which contains new features and program enhancements
Tested in Other Linux Distributions :
I have installed the same LibreOffice version from the Repos in Other distributions with XFCE and Gnome as DE and I don’t have any issues.
Software Version:
Version: 7.6.4.1 (X86_64) / LibreOffice Community
Build ID: 60(Build:1)
CPU threads: 4; OS: Linux 6.6; UI render: default; VCL: gtk3
Locale: en-US (en_US.UTF-8); UI: en-US
7.6.4-2
Calc: threaded
Workaround:
Click on the right side Properties panel and click on Cell Appearance, then cell borders can be modified as desired.
Any suggestions to fix this issue would be great.
Did any one come across the same/similar issue ?
Thanks
