As a result of the latest update, LibreOffice 7.4.1.2 is not opening. Any workaround or upcoming fix?
Hi @snowdust,
I use it, and have just opened it with no problems whatsoever:
Have you tried opening it from the terminal to see if there are any errors?
libreoffice --writer
Or:
libreoffice --calc
Or:
libreoffice --base
Or:
libreoffice --draw
Or:
libreoffice --impress
Or:
libreoffice --math
Do you mean not opening or you’re not able to see the window? Because there is a bug where the window doesn’t always show and I (others have talked about it here on the forum too) need to right click on the icon in the tray and select maximize.
Tried opening from the terminal, unfortunately it’s a no-go.
Please provide the output.
Thanks. Your suggestion worked.
Glad it worked, but I’m only repeating what I learned in another thread, but I don’t remember who suggested the workaround.
